Voici un petit moment que j’ai mon pc et je n’ai toujours pas réussir à installer le wifi. Dans le nouveau paquet 2624 ma carte devait être intégré, mais toujours pas. Alors je voudrais enfin réussir à l’installer.
Pour comprendre voici quelques résultats :
uname -a :
Linux pc-nelson 2.6.24-1-686 #1 SMP Mon Jan 28 01:33:13 UTC 2008 i686 GNU/Linux
iwconfig :
lo no wireless extensions.
eth1 no wireless extensions.
ifconfig :
eth1 Link encap:Ethernet HWaddr 00:1b:fc:93:69:48
inet adr:192.168.0.11 Bcast:192.168.0.255 Masque:255.255.255.0
adr inet6: fe80::21b:fcff:fe93:6948/64 Scope:Lien
RX packets:45963 errors:0 dropped:0 overruns:0 frame:0
TX packets:25648 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:67091897 (63.9 MiB) TX bytes:1960408 (1.8 MiB)
Interruption:218 Adresse de base:0x4000
lo Link encap:Boucle locale
adr inet6: ::1/128 Scope:Hôte
RX packets:8 errors:0 dropped:0 overruns:0 frame:0
TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:560 (560.0 B) TX bytes:560 (560.0 B)
# dmesg /var/log/messages :
Initializing cgroup subsys cpuset
Linux version 2.6.24-1-686 (Debian 2.6.24-2) (waldi@debian.org) (gcc version 4.1.3 20080114 (prerelease) (Debian 4.1.2-19)) #1 SMP Thu Jan 31 20:35:50 UTC 2008
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000e3000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000007f7a0000 (usable)
BIOS-e820: 000000007f7a0000 - 000000007f7ae000 (ACPI data)
BIOS-e820: 000000007f7ae000 - 000000007f7f0000 (ACPI NVS)
BIOS-e820: 000000007f7f0000 - 000000007f800000 (reserved)
BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
1143MB HIGHMEM available.
896MB LOWMEM available.
found SMP MP-table at 000ff780
Entering add_active_range(0, 0, 522144) 0 entries of 256 used
Zone PFN ranges:
DMA 0 -> 4096
Normal 4096 -> 229376
HighMem 229376 -> 522144
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
0: 0 -> 522144
On node 0 totalpages: 522144
DMA zone: 32 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 4064 pages, LIFO batch:0
Normal zone: 1760 pages used for memmap
Normal zone: 223520 pages, LIFO batch:31
HighMem zone: 2287 pages used for memmap
HighMem zone: 290481 pages, LIFO batch:31
Movable zone: 0 pages used for memmap
DMI 2.4 present.
ACPI: RSDP 000F7FD0, 0024 (r2 ACPIAM)
ACPI: XSDT 7F7A0100, 007C (r1 _ASUS_ Notebook 7000731 MSFT 97)
ACPI: FACP 7F7A0290, 00F4 (r3 A_M_I_ OEMFACP 7000731 MSFT 97)
ACPI: DSDT 7F7A0640, CCA6 (r1 A8S00 A8S00001 1 INTL 20051117)
ACPI: FACS 7F7AE000, 0040
ACPI: APIC 7F7A0390, 005C (r1 A_M_I_ OEMAPIC 7000731 MSFT 97)
ACPI: MCFG 7F7A03F0, 003C (r1 A_M_I_ OEMMCFG 7000731 MSFT 97)
ACPI: SLIC 7F7A0430, 0176 (r1 _ASUS_ Notebook 7000731 MSFT 97)
ACPI: BOOT 7F7A05B0, 0028 (r1 A_M_I_ OEMBOOT 7000731 MSFT 97)
ACPI: ECDT 7F7A05E0, 0054 (r1 A_M_I_ OEMECDT 7000731 MSFT 97)
ACPI: OEMB 7F7AE040, 0060 (r1 A_M_I_ AMI_OEM 7000731 MSFT 97)
ACPI: HPET 7F7AD2F0, 0038 (r1 A_M_I_ OEMHPET 7000731 MSFT 97)
ACPI: GSCI 7F7AE0A0, 2024 (r1 A_M_I_ GMCHSCI 7000731 MSFT 97)
ACPI: ATKG 7F7B02D0, 8024 (r1 A_M_I_ OEMATKG 5000702 MSFT 97)
ACPI: SSDT 7F7B8CB0, 04E6 (r1 PmRef CpuPm 3000 INTL 20051117)
ACPI: PM-Timer IO Port: 0x808
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Processor #0 6:15 APIC version 20
ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
Processor #1 6:15 APIC version 20
ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Enabling APIC mode: Flat. Using 1 I/O APICs
ACPI: HPET id: 0x8086a201 base: 0xfed00000
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at 80000000 (gap: 7f800000:7f600000)
swsusp: Registered nosave memory region: 000000000009f000 - 00000000000a0000
swsusp: Registered nosave memory region: 00000000000a0000 - 00000000000e3000
swsusp: Registered nosave memory region: 00000000000e3000 - 0000000000100000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 518065
Kernel command line: root=/dev/sda8 ro
mapped APIC to ffffb000 (fee00000)
mapped IOAPIC to ffffa000 (fec00000)
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Initializing CPU#0
PID hash table entries: 4096 (order: 12, 16384 bytes)
Detected 1795.610 MHz processor.
Console: colour VGA+ 80x25
console [tty0] enabled
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 2061296k/2088576k available (1785k kernel code, 26024k reserved, 715k data, 248k init, 1171072k highmem)
virtual kernel memory layout:
fixmap : 0xfff4c000 - 0xfffff000 ( 716 kB)
pkmap : 0xff800000 - 0xffc00000 (4096 kB)
vmalloc : 0xf8800000 - 0xff7fe000 ( 111 MB)
lowmem : 0xc0000000 - 0xf8000000 ( 896 MB)
.init : 0xc0377000 - 0xc03b5000 ( 248 kB)
.data : 0xc02be755 - 0xc0371384 ( 715 kB)
.text : 0xc0100000 - 0xc02be755 (1785 kB)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
hpet clockevent registered
Calibrating delay using timer specific routine.. 3595.23 BogoMIPS (lpj=7190473)
Security Framework initialized
SELinux: Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 512
Initializing cgroup subsys ns
Initializing cgroup subsys cpuacct
CPU: After generic identify, caps: bfebfbff 20100000 00000000 00000000 0000e3bd 00000000 00000001 00000001
monitor/mwait feature present.
using mwait in idle threads.
CPU: L1 I cache: 32K, L1 D cache: 32K
CPU: L2 cache: 2048K
CPU: Physical Processor ID: 0
CPU: Processor Core ID: 0
CPU: After all inits, caps: bfebfbff 20100000 00000000 00003940 0000e3bd 00000000 00000001 00000001
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
Compat vDSO mapped to ffffe000.
Checking 'hlt' instruction... OK.
SMP alternatives: switching to UP code
ACPI: Core revision 20070126
CPU0: Intel(R) Core(TM)2 Duo CPU T7100 @ 1.80GHz stepping 0d
SMP alternatives: switching to SMP code
Booting processor 1/1 eip 3000
Initializing CPU#1
Calibrating delay using timer specific routine.. 3590.93 BogoMIPS (lpj=7181866)
CPU: Processor Core ID: 1
Intel machine check reporting enabled on CPU#1.
CPU1: Intel(R) Core(TM)2 Duo CPU T7100 @ 1.80GHz stepping 0d
Total of 2 processors activated (7186.16 BogoMIPS).
ENABLING IO-APIC IRQs
..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
APIC calibration not consistent with PM Timer: 115ms instead of 100ms
APIC delta adjusted to PM-Timer: 1246873 (1446354)
checking TSC synchronization [CPU#0 -> CPU#1]: passed.
Brought up 2 CPUs
net_namespace: 64 bytes
Booting paravirtualized kernel on bare hardware
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: BIOS Bug: MCFG area at e0000000 is not E820-reserved
PCI: Not using MMCONFIG.
PCI: PCI BIOS revision 3.00 entry at 0xf0031, last bus=7
PCI: Using configuration type 1
Setting up standard PCI resources
ACPI: EC: EC description table is found, configuring boot EC
ACPI: EC: non-query interrupt received, switching to interrupt mode
ACPI: Interpreter enabled
ACPI: (supports S0 S1 S3 S4 S5)
ACPI: Using IOAPIC for interrupt routing
Error attaching device data
ACPI: EC: GPE = 0x1c, I/O: command/status = 0x66, data = 0x62
ACPI: EC: driver started in poll mode
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI quirk: region 0800-087f claimed by ICH6 ACPI/GPIO/TCO
PCI quirk: region 0500-053f claimed by ICH6 GPIO
PCI: Transparent bridge - 0000:00:1e.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P2._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P3._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P4._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P5._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P6._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P9._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *10 11 12)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 10 12)
ACPI: PCI Interrupt Link [LNKC] (IRQs *6)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 *7 10 12)
ACPI: PCI Interrupt Link [LNKE] (IRQs *6)
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 *4 5 6 7 10 12)
ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 *10 12)
ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 *5 6 7 10 12)
ACPI Warning (tbutils-0217): Incorrect checksum in table [ATKG] - CF, should be 59 [20070126]
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
ACPI: bus type pnp registered
pnp: PnP ACPI: found 14 devices
ACPI: ACPI bus type pnp unregistered
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
NET: Registered protocol family 8
NET: Registered protocol family 20
hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
hpet0: 3 64-bit timers, 14318180 Hz
ACPI: RTC can wake from S4
Time: tsc clocksource has been installed.
system 00:01: iomem range 0xfed14000-0xfed19fff has been reserved
system 00:08: ioport range 0x480-0x48f has been reserved
system 00:09: ioport range 0x4d0-0x4d1 has been reserved
system 00:09: ioport range 0x800-0x87f has been reserved
system 00:09: ioport range 0x400-0x41f has been reserved
system 00:09: ioport range 0x500-0x53f has been reserved
system 00:09: iomem range 0xfed1c000-0xfed1ffff has been reserved
system 00:09: iomem range 0xfed20000-0xfed3ffff has been reserved
system 00:09: iomem range 0xfed45000-0xfed89fff has been reserved
system 00:09: iomem range 0xffb00000-0xffbfffff could not be reserved
system 00:09: iomem range 0xfff00000-0xffffffff could not be reserved
system 00:0b: ioport range 0x250-0x253 has been reserved
system 00:0b: ioport range 0x256-0x25f has been reserved
system 00:0b: iomem range 0xfec00000-0xfec00fff has been reserved
system 00:0b: iomem range 0xfee00000-0xfee00fff could not be reserved
system 00:0c: iomem range 0xe0000000-0xefffffff has been reserved
system 00:0d: iomem range 0x0-0x9ffff could not be reserved
system 00:0d: iomem range 0xc0000-0xcffff could not be reserved
system 00:0d: iomem range 0xe0000-0xfffff could not be reserved
system 00:0d: iomem range 0x100000-0x7f7fffff could not be reserved
system 00:0d: iomem range 0x0-0x0 could not be reserved
PCI: Bridge: 0000:00:1c.0
IO window: disabled.
MEM window: disabled.
PREFETCH window: disabled.
PCI: Bridge: 0000:00:1c.1
MEM window: fdc00000-fdcfffff
PCI: Bridge: 0000:00:1c.2
IO window: b000-bfff
MEM window: fdd00000-fddfffff
PCI: Bridge: 0000:00:1c.3
PCI: Bridge: 0000:00:1c.4
IO window: c000-cfff
MEM window: fde00000-fe5fffff
PREFETCH window: bdf00000-bfefffff
PCI: Bridge: 0000:00:1e.0
MEM window: fe600000-fe6fffff
ACPI: PCI Interrupt 0000:00:1c.0[A] -> GSI 16 (level, low) -> IRQ 16
PCI: Setting latency timer of device 0000:00:1c.0 to 64
ACPI: PCI Interrupt 0000:00:1c.1[B] -> GSI 17 (level, low) -> IRQ 17
PCI: Setting latency timer of device 0000:00:1c.1 to 64
ACPI: PCI Interrupt 0000:00:1c.2[C] -> GSI 18 (level, low) -> IRQ 18
PCI: Setting latency timer of device 0000:00:1c.2 to 64
ACPI: PCI Interrupt 0000:00:1c.3[D] -> GSI 19 (level, low) -> IRQ 19
PCI: Setting latency timer of device 0000:00:1c.3 to 64
ACPI: PCI Interrupt 0000:00:1c.4[A] -> GSI 16 (level, low) -> IRQ 16
PCI: Setting latency timer of device 0000:00:1c.4 to 64
PCI: Setting latency timer of device 0000:00:1e.0 to 64
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
checking if image is initramfs...<7>Switched to high resolution mode on CPU 1
Switched to high resolution mode on CPU 0
it is
Freeing initrd memory: 5714k freed
Simple Boot Flag at 0x52 set to 0x1
audit: initializing netlink socket (disabled)
audit(1201952281.932:1): initialized
highmem bounce pool size: 64 pages
Total HugeTLB memory allocated, 0
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
Boot video device is 0000:00:02.0
assign_interrupt_mode Found MSI capability
Allocate Port Service[0000:00:1c.0:pcie00]
Allocate Port Service[0000:00:1c.0:pcie02]
Allocate Port Service[0000:00:1c.1:pcie00]
Allocate Port Service[0000:00:1c.1:pcie02]
Allocate Port Service[0000:00:1c.2:pcie00]
Allocate Port Service[0000:00:1c.2:pcie02]
Allocate Port Service[0000:00:1c.3:pcie00]
Allocate Port Service[0000:00:1c.3:pcie02]
Allocate Port Service[0000:00:1c.4:pcie00]
Allocate Port Service[0000:00:1c.4:pcie02]
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
hpet_resources: 0xfed00000 is busy
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
i8042.c: Detected active multiplexing controller, rev 1.1.
serio: i8042 KBD port at 0x60,0x64 irq 1
serio: i8042 AUX0 port at 0x60,0x64 irq 12
serio: i8042 AUX1 port at 0x60,0x64 irq 12
serio: i8042 AUX2 port at 0x60,0x64 irq 12
serio: i8042 AUX3 port at 0x60,0x64 irq 12
mice: PS/2 mouse device common for all mice
cpuidle: using governor ladder
cpuidle: using governor menu
TCP bic registered
NET: Registered protocol family 17
Using IPI No-Shortcut mode
registered taskstats version 1
Freeing unused kernel memory: 248k freed
input: AT Translated Set 2 keyboard as /class/input/input0
ACPI: SSDT 7F7B83D0, 0244 (r1 PmRef Cpu0Ist 3000 INTL 20051117)
ACPI: SSDT 7F7B86B0, 05F1 (r1 PmRef Cpu0Cst 3001 INTL 20051117)
Monitor-Mwait will be used to enter C-1 state
Monitor-Mwait will be used to enter C-2 state
ACPI: CPU0 (power states: C1[C1] C2[C2])
ACPI: Processor [P001] (supports 8 throttling states)
ACPI: SSDT 7F7B8300, 00C8 (r1 PmRef Cpu1Ist 3000 INTL 20051117)
ACPI: SSDT 7F7B8620, 0085 (r1 PmRef Cpu1Cst 3000 INTL 20051117)
Marking TSC unstable due to: TSC halts in idle.
Time: hpet clocksource has been installed.
ACPI: CPU1 (power states: C1[C1] C2[C2])
ACPI: Processor [P002] (supports 8 throttling states)
ACPI: Thermal Zone [THRM] (40 C)
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
USB Universal Host Controller Interface driver v3.0
ACPI: PCI Interrupt 0000:00:1a.0[A] -> GSI 16 (level, low) -> IRQ 16
PCI: Setting latency timer of device 0000:00:1a.0 to 64
uhci_hcd 0000:00:1a.0: UHCI Host Controller
uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000dc00
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:1a.1[B] -> GSI 21 (level, low) -> IRQ 20
PCI: Setting latency timer of device 0000:00:1a.1 to 64
uhci_hcd 0000:00:1a.1: UHCI Host Controller
uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:1a.1: irq 20, io base 0x0000d880
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
SCSI subsystem initialized
libata version 3.00 loaded.
r8169 Gigabit Ethernet driver 2.2LK-NAPI loaded
ACPI: PCI Interrupt 0000:03:00.0[A] -> GSI 18 (level, low) -> IRQ 18
PCI: Setting latency timer of device 0000:03:00.0 to 64
eth0: RTL8168b/8111b at 0xf886e000, 00:1b:fc:93:69:48, XID 38000000 IRQ 218
ACPI: PCI Interrupt 0000:07:03.0[A] -> GSI 21 (level, low) -> IRQ 20
udev: renamed network interface eth0 to eth1
firewire_ohci: Added fw-ohci device 0000:07:03.0, OHCI version 1.0
ACPI: PCI Interrupt 0000:00:1a.7[C] -> GSI 18 (level, low) -> IRQ 18
PCI: Setting latency timer of device 0000:00:1a.7 to 64
ehci_hcd 0000:00:1a.7: EHCI Host Controller
ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 3
ehci_hcd 0000:00:1a.7: debug port 1
PCI: cache line size of 32 is not supported by device 0000:00:1a.7
ehci_hcd 0000:00:1a.7: irq 18, io mem 0xfeaff400
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
usb 1-1: new full speed USB device using uhci_hcd and address 2
ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 4 ports detected
ACPI: PCI Interrupt 0000:00:1d.7[A] -> GSI 23 (level, low) -> IRQ 21
PCI: Setting latency timer of device 0000:00:1d.7 to 64
ehci_hcd 0000:00:1d.7: EHCI Host Controller
ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 4
ehci_hcd 0000:00:1d.7: debug port 1
PCI: cache line size of 32 is not supported by device 0000:00:1d.7
ehci_hcd 0000:00:1d.7: irq 21, io mem 0xfeaff000
ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 6 ports detected
ACPI: PCI Interrupt 0000:00:1d.0[A] -> GSI 23 (level, low) -> IRQ 21
PCI: Setting latency timer of device 0000:00:1d.0 to 64
uhci_hcd 0000:00:1d.0: UHCI Host Controller
uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 5
uhci_hcd 0000:00:1d.0: irq 21, io base 0x0000d800
usb usb5: configuration #1 chosen from 1 choice
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:1d.1[B] -> GSI 19 (level, low) -> IRQ 19
PCI: Setting latency timer of device 0000:00:1d.1 to 64
uhci_hcd 0000:00:1d.1: UHCI Host Controller
uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 6
uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000d480
usb usb6: configuration #1 chosen from 1 choice
hub 6-0:1.0: USB hub found
hub 6-0:1.0: 2 ports detected
usb 3-1: new high speed USB device using ehci_hcd and address 2
firewire_core: created new fw device fw0 (0 config rom retries, S400)
ACPI: PCI Interrupt 0000:00:1d.2[C] -> GSI 18 (level, low) -> IRQ 18
PCI: Setting latency timer of device 0000:00:1d.2 to 64
uhci_hcd 0000:00:1d.2: UHCI Host Controller
uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 7
uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000d400
usb usb7: configuration #1 chosen from 1 choice
hub 7-0:1.0: USB hub found
hub 7-0:1.0: 2 ports detected
usb 3-1: configuration #1 chosen from 1 choice
ata_piix 0000:00:1f.2: version 2.12
ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
ACPI: PCI Interrupt 0000:00:1f.2[B] -> GSI 20 (level, low) -> IRQ 22
PCI: Setting latency timer of device 0000:00:1f.2 to 64
scsi0 : ata_piix
scsi1 : ata_piix
ata1: SATA max UDMA/133 cmd 0xe880 ctl 0xe800 bmdma 0xe080 irq 22
ata2: SATA max UDMA/133 cmd 0xe480 ctl 0xe400 bmdma 0xe088 irq 22
ata1.00: ATA-7: ST9120822AS, 3.ALC, max UDMA/133
ata1.00: 234441648 sectors, multi 16: LBA48 NCQ (depth 0/32)
ata1.00: configured for UDMA/133
scsi 0:0:0:0: Direct-Access ATA ST9120822AS 3.AL PQ: 0 ANSI: 5
ICH8M: IDE controller (0x8086:0x2850 rev 0x03) at PCI slot 0000:00:1f.1
ACPI: PCI Interrupt 0000:00:1f.1[A] -> GSI 18 (level, low) -> IRQ 18
ICH8M: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0xffa0-0xffa7, BIOS settings: hda:DMA, hdb:pio
ICH8M: IDE port disabled
Probing IDE interface ide0...
usb 6-1: new full speed USB device using uhci_hcd and address 2
usb 6-1: configuration #1 chosen from 1 choice
usb 7-2: new low speed USB device using uhci_hcd and address 2
usb 7-2: configuration #1 chosen from 1 choice
usbcore: registered new interface driver hiddev
input: Logitech USB Optical Mouse as /class/input/input1
input,hidraw0: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:00:1d.2-2
usbcore: registered new interface driver usbhid
drivers/hid/usbhid/hid-core.c: v2.6:USB HID core driver
hda: HL-DT-ST DVDRAM GSA-T20N, ATAPI CD/DVD-ROM drive
hda: host max PIO4 wanted PIO255(auto-tune) selected PIO4
hda: UDMA/33 mode selected
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Driver 'sd' needs updating - please use bus_type methods
sd 0:0:0:0: [sda] 234441648 512-byte hardware sectors (120034 MB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sda:<6>hda: ATAPI 24X DVD-ROM DVD-R-RAM CD-R/RW drive, 2048kB Cache
Uniform CD-ROM driver Revision: 3.20
sda1 sda2 < sda5 sda6 sda7 sda8 >
sd 0:0:0:0: [sda] Attached SCSI disk
Attempting manual resume
swsusp: Marking nosave pages: 000000000009f000 - 0000000000100000
swsusp: Basic memory bitmaps created
swsusp: Basic memory bitmaps freed
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
Linux agpgart interface v0.102
Asus Laptop ACPI Extras version 0.30
unsupported model A8E, trying default values
send /proc/acpi/dsdt to the developers
input: Power Button (FF) as /class/input/input2
agpgart: Detected an Intel 965GM Chipset.
agpgart: Detected 7676K stolen memory.
agpgart: AGP aperture is 256M @ 0xd0000000
ACPI: Power Button (FF) [PWRF]
input: Sleep Button (CM) as /class/input/input3
ACPI: Sleep Button (CM) [SLPB]
input: Lid Switch as /class/input/input4
ACPI: Lid Switch [LID]
ACPI: AC Adapter [AC0] (on-line)
ACPI: Battery Slot [BAT0] (battery present)
input: Video Bus as /class/input/input5
ACPI: Video Device [VGA] (multi-head: yes rom: no post: no)
input: Video Bus as /class/input/input6
iTCO_wdt: Intel TCO WatchDog Timer Driver v1.02 (26-Jul-2007)
iTCO_wdt: Found a ICH8M TCO device (Version=2, TCOBASE=0x0860)
iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
Bluetooth: Core ver 2.11
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
input: PC Speaker as /class/input/input7
Real Time Clock Driver v1.12ac
Bluetooth: HCI USB driver ver 2.9
usbcore: registered new interface driver hci_usb
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci: SDHCI controller found at 0000:07:03.1 [1180:0822] (rev 22)
ACPI: PCI Interrupt 0000:07:03.1[B] -> GSI 20 (level, low) -> IRQ 22
sdhci:slot0: Will use DMA mode even though HW doesn't fully claim to support it.
mmc0: SDHCI at 0xfe6ff400 irq 22 DMA
iwl4965: Intel(R) Wireless WiFi Link 4965AGN driver for Linux, 1.1.17ks
iwl4965: Copyright(c) 2003-2007 Intel Corporation
ACPI: PCI Interrupt 0000:02:00.0[A] -> GSI 17 (level, low) -> IRQ 17
PCI: Setting latency timer of device 0000:02:00.0 to 64
iwl4965: Detected Intel Wireless WiFi Link 4965AGN
iwl4965: iwlwifi-4965-1.ucode firmware file req failed: Reason -2
iwl4965: Could not read microcode: -2
ACPI: PCI interrupt for device 0000:02:00.0 disabled
iwl4965: probe of 0000:02:00.0 failed with error -2
ACPI: PCI Interrupt 0000:00:1b.0[A] -> GSI 22 (level, low) -> IRQ 23
PCI: Setting latency timer of device 0000:00:1b.0 to 64
Synaptics Touchpad, model: 1, fw: 6.2, id: 0x81a0b1, caps: 0xa04713/0x200000
input: SynPS/2 Synaptics TouchPad as /class/input/input8
Adding 1951824k swap on /dev/sda6. Priority:-1 extents:1 across:1951824k
EXT3 FS on sda8, internal journal
loop: module loaded
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.12.0-ioctl (2007-10-02) initialised: dm-devel@redhat.com
EXT3 FS on sda7, internal journal
r8169: eth1: link up
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
lp: driver loaded but no devices found
ppdev: user-space parallel port driver
Bluetooth: L2CAP ver 2.9
Bluetooth: L2CAP socket layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM ver 1.8
[drm] Initialized drm 1.1.0 20060810
ACPI: PCI Interrupt 0000:00:02.0[A] -> GSI 16 (level, low) -> IRQ 16
[drm] Initialized i915 1.6.0 20060119 on minor 0
eth1: no IPv6 routers present
# dmesg /var/log/syslog :
Zone PFN ranges:
DMA 0 -> 4096
0: 0 -> 522144
DMI 2.4 present.
Initializing CPU#0
Initializing CPU#1
Brought up 2 CPUs
pnp: PnP ACPI init
TCP reno registered
it is
TCP bic registered
scsi0 : ata_piix
scsi1 : ata_piix
loop: module loaded
Je peux aussi fournir un dmesg. Je ne l’ai pas mi directement il est assez long.
Besoin d’autre chose ?
Je voulais installer : firmware-iwlwifi, mais le paquet n’est pas disponible, alors que sur d’autres machines de même version il est disponible.
