voici j’ai remis m’ont systeme a 0 pour info
donc voici ce qui sort du dmesg
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.26-1-amd64 (Debian 2.6.26-13) (waldi@debian.org) (gcc version 4.1.3 20080704 (prerelease) (Debian 4.1.2-24)) #1 SMP Sat Jan 10 17:57:00 UTC 2009
[ 0.000000] Command line: root=/dev/sda4 ro quiet
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009cc00 (usable)
[ 0.000000] BIOS-e820: 000000000009cc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000007fff0000 (usable)
[ 0.000000] BIOS-e820: 000000007fff0000 - 000000007fff3000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000007fff3000 - 0000000080000000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
[ 0.000000] Entering add_active_range(0, 0, 156) 0 entries of 3200 used
[ 0.000000] Entering add_active_range(0, 256, 524272) 1 entries of 3200 used
[ 0.000000] max_pfn_mapped = 1048576
[ 0.000000] init_memory_mapping
[ 0.000000] DMI 2.3 present.
[ 0.000000] ACPI: RSDP 000F7C80, 0014 (r0 Nvidia)
[ 0.000000] ACPI: RSDT 7FFF3040, 0034 (r1 Nvidia AWRDACPI 42302E31 AWRD 0)
[ 0.000000] ACPI: FACP 7FFF30C0, 0074 (r1 Nvidia AWRDACPI 42302E31 AWRD 0)
[ 0.000000] ACPI: DSDT 7FFF3180, 6677 (r1 NVIDIA AWRDACPI 1000 MSFT 100000E)
[ 0.000000] ACPI: FACS 7FFF0000, 0040
[ 0.000000] ACPI: SRAT 7FFF9900, 00A0 (r1 AMD HAMMER 1 AMD 1)
[ 0.000000] ACPI: MCFG 7FFF9A00, 003C (r1 Nvidia AWRDACPI 42302E31 AWRD 0)
[ 0.000000] ACPI: APIC 7FFF9840, 007C (r1 Nvidia AWRDACPI 42302E31 AWRD 0)
[ 0.000000] SRAT: PXM 0 -> APIC 0 -> Node 0
[ 0.000000] SRAT: PXM 0 -> APIC 1 -> Node 0
[ 0.000000] SRAT: Node 0 PXM 0 0-a0000
[ 0.000000] SRAT: Node 0 PXM 0 100000-80000000
[ 0.000000] NUMA: Allocated memnodemap from c000 - d080
[ 0.000000] NUMA: Using 20 for the hash shift.
[ 0.000000] Bootmem setup node 0 0000000000000000-000000007fff0000
[ 0.000000] NODE_DATA [000000000000d080 - 000000000001207f]
[ 0.000000] bootmap [0000000000013000 - 0000000000022fff] pages 10
[ 0.000000] early res: 0 [0-fff] BIOS data page
[ 0.000000] early res: 1 [6000-7fff] TRAMPOLINE
[ 0.000000] early res: 2 [200000-675397] TEXT DATA BSS
[ 0.000000] early res: 3 [37990000-37fef562] RAMDISK
[ 0.000000] early res: 4 [9cc00-fffff] BIOS reserved
[ 0.000000] early res: 5 [8000-bfff] PGTABLE
[ 0.000000] early res: 6 [c000-d07f] MEMNODEMAP
[ 0.000000] [ffffe20000000000-ffffe20001bfffff] PMD -> [ffff810001200000-ffff810002dfffff] on node 0
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0 -> 4096
[ 0.000000] DMA32 4096 -> 1048576
[ 0.000000] Normal 1048576 -> 1048576
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[2] active PFN ranges
[ 0.000000] 0: 0 -> 156
[ 0.000000] 0: 256 -> 524272
[ 0.000000] On node 0 totalpages: 524172
[ 0.000000] DMA zone: 56 pages used for memmap
[ 0.000000] DMA zone: 1250 pages reserved
[ 0.000000] DMA zone: 2690 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 7112 pages used for memmap
[ 0.000000] DMA32 zone: 513064 pages, LIFO batch:31
[ 0.000000] Normal zone: 0 pages used for memmap
[ 0.000000] Movable zone: 0 pages used for memmap
[ 0.000000] Nvidia board detected. Ignoring ACPI timer override.
[ 0.000000] If you got timer trouble try acpi_use_timer_override
[ 0.000000] ACPI: PM-Timer IO Port: 0x4008
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 0, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: BIOS IRQ0 pin2 override ignored.
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 14 high edge)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 15 high edge)
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] ACPI: IRQ14 used by override.
[ 0.000000] ACPI: IRQ15 used by override.
[ 0.000000] Setting APIC routing to flat
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] PM: Registered nosave memory: 000000000009c000 - 000000000009d000
[ 0.000000] PM: Registered nosave memory: 000000000009d000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 88000000 (gap: 80000000:60000000)
[ 0.000000] SMP: Allowing 2 CPUs, 0 hotplug CPUs
[ 0.000000] PERCPU: Allocating 37168 bytes of per cpu data
[ 0.000000] NR_CPUS: 32, nr_cpu_ids: 2
[ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 515754
[ 0.000000] Policy zone: DMA32
[ 0.000000] Kernel command line: root=/dev/sda4 ro quiet
[ 0.000000] Initializing CPU#0
[ 0.000000] PID hash table entries: 4096 (order: 12, 32768 bytes)
[ 0.000000] TSC calibrated against PM_TIMER
[ 0.000000] Marking TSC unstable due to TSCs unsynchronized
[ 0.000000] time.c: Detected 2010.304 MHz processor.
[ 0.004000] spurious 8259A interrupt: IRQ7.
[ 0.004000] Console: colour VGA+ 80x25
[ 0.004000] console [tty0] enabled
[ 0.004000] Checking aperture...
[ 0.004000] Node 0: aperture @ 8840000000 size 32 MB
[ 0.004000] Aperture beyond 4GB. Ignoring.
[ 0.004000] No AGP bridge found
[ 0.004000] Memory: 2056636k/2097088k available (2226k kernel code, 40052k reserved, 1082k data, 392k init)
[ 0.004000] CPA: page pool initialized 1 of 1 pages preallocated
[ 0.084118] Calibrating delay using timer specific routine.. 4023.43 BogoMIPS (lpj=8046867)
[ 0.084175] Security Framework initialized
[ 0.084180] SELinux: Disabled at boot.
[ 0.084184] Capability LSM initialized
[ 0.084410] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.085737] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.086387] Mount-cache hash table entries: 256
[ 0.086563] Initializing cgroup subsys ns
[ 0.086567] Initializing cgroup subsys cpuacct
[ 0.086570] Initializing cgroup subsys devices
[ 0.086591] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
[ 0.086594] CPU: L2 Cache: 512K (64 bytes/line)
[ 0.086596] CPU 0/0 -> Node 0
[ 0.086609] CPU: Physical Processor ID: 0
[ 0.086610] CPU: Processor Core ID: 0
[ 0.087355] ACPI: Core revision 20080321
[ 0.142269] CPU0: AMD Athlon(tm) 64 X2 Dual Core Processor 3800+ stepping 01
[ 0.142273] Using local APIC timer interrupts.
[ 0.148009] APIC timer calibration result 12564416
[ 0.148009] Detected 12.564 MHz APIC timer.
[ 0.148009] Booting processor 1/1 ip 6000
[ 0.156009] Initializing CPU#1
[ 0.156009] Calibrating delay using timer specific routine.. 4020.63 BogoMIPS (lpj=8041268)
[ 0.156009] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
[ 0.156009] CPU: L2 Cache: 512K (64 bytes/line)
[ 0.156009] CPU 1/1 -> Node 0
[ 0.156009] CPU: Physical Processor ID: 0
[ 0.156009] CPU: Processor Core ID: 1
[ 0.235954] CPU1: AMD Athlon(tm) 64 X2 Dual Core Processor 3800+ stepping 01
[ 0.235965] Brought up 2 CPUs
[ 0.235968] Total of 2 processors activated (8044.06 BogoMIPS).
[ 0.236014] CPU0 attaching sched-domain:
[ 0.236014] domain 0: span 0-1
[ 0.236014] groups: 0 1
[ 0.236014] domain 1: span 0-1
[ 0.236014] groups: 0-1
[ 0.236014] CPU1 attaching sched-domain:
[ 0.236014] groups: 1 0
[ 0.236014] net_namespace: 1224 bytes
[ 0.236014] Booting paravirtualized kernel on bare hardware
[ 0.236014] NET: Registered protocol family 16
[ 0.236014] node 0 link 0: io port [1000, fffff]
[ 0.236014] TOM: 0000000080000000 aka 2048M
[ 0.236014] node 0 link 0: mmio [e0000000, efffffff]
[ 0.236014] node 0 link 0: mmio [feb00000, fec0ffff]
[ 0.236014] node 0 link 0: mmio [a0000, bffff]
[ 0.236014] node 0 link 0: mmio [80000000, fed3ffff]
[ 0.236014] bus: [00,ff] on node 0 link 0
[ 0.236014] bus: 00 index 0 io port: [0, ffff]
[ 0.236014] bus: 00 index 1 mmio: [80000000, fcffffffff]
[ 0.236014] bus: 00 index 2 mmio: [feb00000, fec0ffff]
[ 0.236014] bus: 00 index 3 mmio: [a0000, bffff]
[ 0.236014] ACPI: bus type pci registered
[ 0.236014] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255
[ 0.236014] PCI: MCFG area at e0000000 reserved in E820
[ 0.251552] PCI: Using MMCONFIG at e0000000 - efffffff
[ 0.251555] PCI: Using configuration type 1 for base access
[ 0.252015] ACPI: EC: Look up EC in DSDT
[ 0.265077] ACPI: Interpreter enabled
[ 0.265080] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.265098] ACPI: Using IOAPIC for interrupt routing
[ 0.275178] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.275178] PCI: Transparent bridge - 0000:00:09.0
[ 0.275918] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.276355] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB0._PRT]
[ 0.355754] ACPI: PCI Interrupt Link [LNK1] (IRQs *3 4 5 7 9 10 11 12 14 15)
[ 0.355754] ACPI: PCI Interrupt Link [LNK2] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[ 0.355754] ACPI: PCI Interrupt Link [LNK3] (IRQs 3 4 *5 7 9 10 11 12 14 15)
[ 0.355754] ACPI: PCI Interrupt Link [LNK4] (IRQs *3 4 5 7 9 10 11 12 14 15)
[ 0.355754] ACPI: PCI Interrupt Link [LNK5] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.355754] ACPI: PCI Interrupt Link [LUBA] (IRQs *3 4 5 7 9 10 11 12 14 15)
[ 0.355754] ACPI: PCI Interrupt Link [LUBB] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.355754] ACPI: PCI Interrupt Link [LMAC] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[ 0.355754] ACPI: PCI Interrupt Link [LACI] (IRQs *3 4 5 7 9 10 11 12 14 15)
[ 0.355754] ACPI: PCI Interrupt Link [LMCI] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.355754] ACPI: PCI Interrupt Link [LSMB] (IRQs 3 4 *5 7 9 10 11 12 14 15)
[ 0.355754] ACPI: PCI Interrupt Link [LUB2] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[ 0.357544] ACPI: PCI Interrupt Link [LIDE] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.357740] ACPI: PCI Interrupt Link [LSID] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[ 0.357938] ACPI: PCI Interrupt Link [LFID] (IRQs 3 4 *5 7 9 10 11 12 14 15)
[ 0.358132] ACPI: PCI Interrupt Link [LPCA] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.358343] ACPI: PCI Interrupt Link [APC1] (IRQs 16) *0
[ 0.358548] ACPI: PCI Interrupt Link [APC2] (IRQs 17) *0
[ 0.358752] ACPI: PCI Interrupt Link [APC3] (IRQs 18) *0
[ 0.358956] ACPI: PCI Interrupt Link [APC4] (IRQs 19) *0
[ 0.359086] ACPI: PCI Interrupt Link [APC5] (IRQs *16), disabled.
[ 0.359300] ACPI: PCI Interrupt Link [APCF] (IRQs 20 21 22 23) *0
[ 0.359513] ACPI: PCI Interrupt Link [APCG] (IRQs 20 21 22 23) *0, disabled.
[ 0.359727] ACPI: PCI Interrupt Link [APCH] (IRQs 20 21 22 23) *0
[ 0.359940] ACPI: PCI Interrupt Link [APCJ] (IRQs 20 21 22 23) *0
[ 0.360151] ACPI: PCI Interrupt Link [APCK] (IRQs 20 21 22 23) *0, disabled.
[ 0.360365] ACPI: PCI Interrupt Link [APCS] (IRQs 20 21 22 23) *0
[ 0.360577] ACPI: PCI Interrupt Link [APCL] (IRQs 20 21 22 23) *0
[ 0.360790] ACPI: PCI Interrupt Link [APCZ] (IRQs 20 21 22 23) *0, disabled.
[ 0.361015] ACPI: PCI Interrupt Link [APSI] (IRQs 20 21 22 23) *0
[ 0.361239] ACPI: PCI Interrupt Link [APSJ] (IRQs 20 21 22 23) *0
[ 0.361465] ACPI: PCI Interrupt Link [APCP] (IRQs 20 21 22 23) *0, disabled.
[ 0.361883] Linux Plug and Play Support v0.97 (c) Adam Belay
[ 0.362033] pnp: PnP ACPI init
[ 0.362042] ACPI: bus type pnp registered
[ 0.362134] pnp 00:00: parse allocated resources
[ 0.362235] pnp 00:00: add io 0xcf8-0xcff flags 0x1
[ 0.362412] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.362427] pnp 00:01: parse allocated resources
[ 0.362515] pnp 00:01: add io 0x4000-0x407f flags 0x1
[ 0.362517] pnp 00:01: add io 0x4080-0x40ff flags 0x1
[ 0.362520] pnp 00:01: add io 0x4400-0x447f flags 0x1
[ 0.362522] pnp 00:01: add io 0x4480-0x44ff flags 0x1
[ 0.362525] pnp 00:01: add io 0x4800-0x487f flags 0x1
[ 0.362527] pnp 00:01: add io 0x4880-0x48ff flags 0x1
[ 0.362530] pnp 00:01: add mem 0xa0000000-0x9fffffff flags 0x10000001
[ 0.362534] pnp 00:01: PNP0c02: calling quirk_system_pci_resources+0x0/0x15c
[ 0.362721] pnp 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.364480] pnp 00:02: parse allocated resources
[ 0.364488] pnp 00:02: add io 0x10-0x1f flags 0x1
[ 0.364490] pnp 00:02: add io 0x22-0x3f flags 0x1
[ 0.364492] pnp 00:02: add io 0x44-0x5f flags 0x1
[ 0.364494] pnp 00:02: add io 0x62-0x63 flags 0x1
[ 0.364497] pnp 00:02: add io 0x65-0x6f flags 0x1
[ 0.364499] pnp 00:02: add io 0x74-0x7f flags 0x1
[ 0.364501] pnp 00:02: add io 0x91-0x93 flags 0x1
[ 0.364503] pnp 00:02: add io 0xa2-0xbf flags 0x1
[ 0.364506] pnp 00:02: add io 0xe0-0xef flags 0x1
[ 0.364509] pnp 00:02: add io 0x4d0-0x4d1 flags 0x1
[ 0.364511] pnp 00:02: add io 0x800-0x87f flags 0x1
[ 0.364513] pnp 00:02: add io 0x290-0x297 flags 0x1
[ 0.364516] pnp 00:02: PNP0c02: calling quirk_system_pci_resources+0x0/0x15c
[ 0.364705] pnp 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.364721] pnp 00:03: parse allocated resources
[ 0.364728] pnp 00:03: add dma 4 flags 0x4
[ 0.364730] pnp 00:03: add io 0x0-0xf flags 0x1
[ 0.364732] pnp 00:03: add io 0x80-0x90 flags 0x1
[ 0.364734] pnp 00:03: add io 0x94-0x9f flags 0x1
[ 0.364736] pnp 00:03: add io 0xc0-0xdf flags 0x1
[ 0.364903] pnp 00:03: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.364919] pnp 00:04: parse allocated resources
[ 0.364924] pnp 00:04: add io 0x70-0x73 flags 0x1
[ 0.364933] pnp 00:04: add irq 8 flags 0x1
[ 0.365100] pnp 00:04: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.365114] pnp 00:05: parse allocated resources
[ 0.365119] pnp 00:05: add io 0x61-0x61 flags 0x1
[ 0.365287] pnp 00:05: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.365301] pnp 00:06: parse allocated resources
[ 0.365306] pnp 00:06: add io 0xf0-0xff flags 0x1
[ 0.365312] pnp 00:06: add irq 13 flags 0x1
[ 0.365357] pnp 00:06: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.365357] pnp 00:07: parse allocated resources
[ 0.365357] pnp 00:07: add io 0x3f0-0x3f5 flags 0x1
[ 0.365357] pnp 00:07: add io 0x3f7-0x3f7 flags 0x1
[ 0.365357] pnp 00:07: add irq 6 flags 0x1
[ 0.365357] pnp 00:07: add dma 2 flags 0x0
[ 0.365357] pnp 00:07: parse resource options
[ 0.365357] pnp 00:07: new independent option
[ 0.365357] pnp 00:07: new dependent option (priority 0x1)
[ 0.365357] pnp 00:07: io min 0x3f0 max 0x3f0 align 1 size 6 flags 0x1
[ 0.365357] pnp 00:07: io min 0x3f7 max 0x3f7 align 1 size 1 flags 0x1
[ 0.365357] pnp 00:07: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000040 flags 0x1
[ 0.365357] pnp 00:07: dma bitmask 0x4 flags 0x0
[ 0.365357] pnp 00:07: end dependent options
[ 0.365357] pnp 00:07: Plug and Play ACPI device, IDs PNP0700 (active)
[ 0.365357] pnp 00:08: parse allocated resources
[ 0.365667] pnp 00:08: add io 0x3f8-0x3ff flags 0x1
[ 0.365672] pnp 00:08: add irq 4 flags 0x1
[ 0.365674] pnp 00:08: parse resource options
[ 0.365676] pnp 00:08: new independent option
[ 0.365683] pnp 00:08: new dependent option (priority 0x1)
[ 0.365686] pnp 00:08: io min 0x3f8 max 0x3f8 align 1 size 8 flags 0x1
[ 0.365691] pnp 00:08: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00001eb8 flags 0x1
[ 0.365694] pnp 00:08: new dependent option (priority 0x1)
[ 0.365697] pnp 00:08: io min 0x2f8 max 0x2f8 align 1 size 8 flags 0x1
[ 0.365701] pnp 00:08: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00001eb8 flags 0x1
[ 0.365704] pnp 00:08: new dependent option (priority 0x1)
[ 0.365707] pnp 00:08: io min 0x3e8 max 0x3e8 align 1 size 8 flags 0x1
[ 0.365711] pnp 00:08: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00001eb8 flags 0x1
[ 0.365714] pnp 00:08: new dependent option (priority 0x1)
[ 0.365717] pnp 00:08: io min 0x2e8 max 0x2e8 align 1 size 8 flags 0x1
[ 0.365721] pnp 00:08: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00001eb8 flags 0x1
[ 0.365724] pnp 00:08: end dependent options
[ 0.369357] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.369357] pnp 00:09: parse allocated resources
[ 0.369357] pnp 00:09: add io 0x378-0x37f flags 0x1
[ 0.369357] pnp 00:09: add io 0x778-0x77b flags 0x1
[ 0.369357] pnp 00:09: add irq 7 flags 0x1
[ 0.369357] pnp 00:09: add dma 3 flags 0x0
[ 0.369357] pnp 00:09: parse resource options
[ 0.369357] pnp 00:09: new independent option
[ 0.369357] pnp 00:09: new dependent option (priority 0x1)
[ 0.369357] pnp 00:09: io min 0x378 max 0x378 align 0 size 8 flags 0x1
[ 0.369357] pnp 00:09: io min 0x778 max 0x778 align 0 size 4 flags 0x1
[ 0.369357] pnp 00:09: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00001eb8 flags 0x1
[ 0.369357] pnp 00:09: dma bitmask 0xb flags 0x0
[ 0.369357] pnp 00:09: io min 0x278 max 0x278 align 0 size 8 flags 0x1
[ 0.369357] pnp 00:09: io min 0x678 max 0x678 align 0 size 4 flags 0x1
[ 0.369357] pnp 00:09: io min 0x3bc max 0x3bc align 0 size 4 flags 0x1
[ 0.369357] pnp 00:09: io min 0x7bc max 0x7bc align 0 size 4 flags 0x1
[ 0.369357] pnp 00:09: end dependent options
[ 0.369357] pnp 00:09: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.369357] pnp 00:0a: parse allocated resources
[ 0.369357] pnp 00:0a: add irq 12 flags 0x1
[ 0.369357] pnp 00:0a: Plug and Play ACPI device, IDs PNP0f13 (active)
[ 0.369357] pnp 00:0b: parse allocated resources
[ 0.369357] pnp 00:0b: add io 0x60-0x60 flags 0x1
[ 0.369357] pnp 00:0b: add io 0x64-0x64 flags 0x1
[ 0.369357] pnp 00:0b: add irq 1 flags 0x1
[ 0.369357] pnp 00:0b: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.369357] pnp 00:0c: parse allocated resources
[ 0.369357] pnp 00:0c: add io 0x330-0x331 flags 0x1
[ 0.369357] pnp 00:0c: add irq 10 flags 0x1
[ 0.369357] pnp 00:0c: parse resource options
[ 0.369357] pnp 00:0c: new independent option
[ 0.369357] pnp 00:0c: new dependent option (priority 0x1)
[ 0.369357] pnp 00:0c: io min 0x330 max 0x330 align 1 size 2 flags 0x1
[ 0.369357] pnp 00:0c: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00001eb8 flags 0x1
[ 0.369357] pnp 00:0c: io min 0x300 max 0x300 align 1 size 2 flags 0x1
[ 0.369357] pnp 00:0c: end dependent options
[ 0.369357] pnp 00:0c: Plug and Play ACPI device, IDs PNPb006 (active)
[ 0.369357] pnp 00:0d: parse allocated resources
[ 0.369357] pnp 00:0d: add io 0x201-0x201 flags 0x1
[ 0.369357] pnp 00:0d: parse resource options
[ 0.369357] pnp 00:0d: new independent option
[ 0.369357] pnp 00:0d: new dependent option (priority 0x1)
[ 0.369357] pnp 00:0d: io min 0x201 max 0x201 align 1 size 1 flags 0x1
[ 0.369357] pnp 00:0d: io min 0x209 max 0x209 align 1 size 1 flags 0x1
[ 0.369357] pnp 00:0d: end dependent options
[ 0.369357] pnp 00:0d: Plug and Play ACPI device, IDs PNPb02f (active)
[ 0.369357] pnp 00:0e: parse allocated resources
[ 0.369357] pnp 00:0e: add mem 0xe0000000-0xefffffff flags 0x1
[ 0.369357] pnp 00:0e: PNP0c02: calling quirk_system_pci_resources+0x0/0x15c
[ 0.369357] pnp 00:0e: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.369357] pnp 00:0f: parse allocated resources
[ 0.369357] pnp 00:0f: add mem 0xdac00-0xdbfff flags 0x1
[ 0.369357] pnp 00:0f: add mem 0xf0000-0xf7fff flags 0x1
[ 0.369357] pnp 00:0f: add mem 0xf8000-0xfbfff flags 0x1
[ 0.369357] pnp 00:0f: add mem 0xfc000-0xfffff flags 0x1
[ 0.369357] pnp 00:0f: add mem 0x7fff0000-0x7fffffff flags 0x1
[ 0.369357] pnp 00:0f: add mem 0xffff0000-0xffffffff flags 0x1
[ 0.369357] pnp 00:0f: add mem 0x0-0x9ffff flags 0x1
[ 0.369357] pnp 00:0f: add mem 0x100000-0x7ffeffff flags 0x1
[ 0.369357] pnp 00:0f: add mem 0xfec00000-0xfec00fff flags 0x1
[ 0.369357] pnp 00:0f: add mem 0xfee00000-0xfeefffff flags 0x1
[ 0.369357] pnp 00:0f: add mem 0xfefff000-0xfeffffff flags 0x1
[ 0.369357] pnp 00:0f: add mem 0xfff80000-0xfff80fff flags 0x1
[ 0.369357] pnp 00:0f: add mem 0xfff90000-0xfffbffff flags 0x1
[ 0.369357] pnp 00:0f: add mem 0xfffed000-0xfffeffff flags 0x1
[ 0.369357] pnp 00:0f: PNP0c01: calling quirk_system_pci_resources+0x0/0x15c
[ 0.369357] pnp 00:0f: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.369357] pnp: PnP ACPI: found 16 devices
[ 0.369357] ACPI: ACPI bus type pnp unregistered
[ 0.369357] usbcore: registered new interface driver usbfs
[ 0.369357] usbcore: registered new interface driver hub
[ 0.369357] usbcore: registered new device driver usb
[ 0.373357] PCI: Using ACPI for IRQ routing
[ 0.405359] ACPI: RTC can wake from S4
[ 0.417202] pnp: the driver 'system' has been registered
[ 0.417214] system 00:01: ioport range 0x4000-0x407f has been reserved
[ 0.417217] system 00:01: ioport range 0x4080-0x40ff has been reserved
[ 0.417220] system 00:01: ioport range 0x4400-0x447f has been reserved
[ 0.417223] system 00:01: ioport range 0x4480-0x44ff has been reserved
[ 0.417226] system 00:01: ioport range 0x4800-0x487f has been reserved
[ 0.417229] system 00:01: ioport range 0x4880-0x48ff has been reserved
[ 0.417233] system 00:01: driver attached
[ 0.417239] system 00:02: ioport range 0x4d0-0x4d1 has been reserved
[ 0.417242] system 00:02: ioport range 0x800-0x87f has been reserved
[ 0.417245] system 00:02: ioport range 0x290-0x297 has been reserved
[ 0.417249] system 00:02: driver attached
[ 0.417262] system 00:0e: iomem range 0xe0000000-0xefffffff could not be reserved
[ 0.417265] system 00:0e: driver attached
[ 0.417272] system 00:0f: iomem range 0xdac00-0xdbfff has been reserved
[ 0.417275] system 00:0f: iomem range 0xf0000-0xf7fff could not be reserved
[ 0.417278] system 00:0f: iomem range 0xf8000-0xfbfff could not be reserved
[ 0.417281] system 00:0f: iomem range 0xfc000-0xfffff could not be reserved
[ 0.417284] system 00:0f: iomem range 0x7fff0000-0x7fffffff could not be reserved
[ 0.417287] system 00:0f: iomem range 0xffff0000-0xffffffff could not be reserved
[ 0.417290] system 00:0f: iomem range 0x0-0x9ffff could not be reserved
[ 0.417293] system 00:0f: iomem range 0x100000-0x7ffeffff could not be reserved
[ 0.417296] system 00:0f: iomem range 0xfec00000-0xfec00fff could not be reserved
[ 0.417299] system 00:0f: iomem range 0xfee00000-0xfeefffff could not be reserved
[ 0.417302] system 00:0f: iomem range 0xfefff000-0xfeffffff could not be reserved
[ 0.417305] system 00:0f: iomem range 0xfff80000-0xfff80fff could not be reserved
[ 0.417308] system 00:0f: iomem range 0xfff90000-0xfffbffff could not be reserved
[ 0.417311] system 00:0f: iomem range 0xfffed000-0xfffeffff could not be reserved
[ 0.417313] system 00:0f: driver attached
[ 0.417360] PCI: Bridge: 0000:00:09.0
[ 0.417360] IO window: 8000-9fff
[ 0.417360] MEM window: 0xd3000000-0xd4ffffff
[ 0.417360] PREFETCH window: 0x0000000088000000-0x00000000880fffff
[ 0.417360] PCI: Bridge: 0000:00:0b.0
[ 0.417360] IO window: disabled.
[ 0.417360] MEM window: disabled.
[ 0.417360] PREFETCH window: disabled.
[ 0.417360] PCI: Bridge: 0000:00:0c.0
[ 0.417360] PCI: Bridge: 0000:00:0d.0
[ 0.417360] PCI: Bridge: 0000:00:0e.0
[ 0.417360] IO window: a000-afff
[ 0.417360] MEM window: 0xd0000000-0xd2ffffff
[ 0.417360] PREFETCH window: 0x00000000c0000000-0x00000000cfffffff
[ 0.417360] PCI: Setting latency timer of device 0000:00:09.0 to 64
[ 0.417360] PCI: Setting latency timer of device 0000:00:0b.0 to 64
[ 0.417360] PCI: Setting latency timer of device 0000:00:0c.0 to 64
[ 0.417360] PCI: Setting latency timer of device 0000:00:0d.0 to 64
[ 0.417360] PCI: Setting latency timer of device 0000:00:0e.0 to 64
[ 0.417360] NET: Registered protocol family 2
[ 0.420605] Switched to high resolution mode on CPU 0
[ 0.424343] Switched to high resolution mode on CPU 1
[ 0.453294] IP route cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.457154] TCP established hash table entries: 262144 (order: 10, 4194304 bytes)
[ 0.457154] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.457784] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.457788] TCP reno registered
[ 0.469695] NET: Registered protocol family 1
[ 0.469808] checking if image is initramfs... it is
[ 0.955748] Freeing initrd memory: 6525k freed
[ 0.962278] audit: initializing netlink socket (disabled)
[ 0.962278] type=2000 audit(1236898124.948:1): initialized
[ 0.962278] Total HugeTLB memory allocated, 0
[ 0.962278] VFS: Disk quotas dquot_6.5.1
[ 0.962278] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.962278] msgmni has been set to 4029
[ 0.962278] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.962278] io scheduler noop registered
[ 0.962278] io scheduler anticipatory registered
[ 0.962278] io scheduler deadline registered
[ 0.962278] io scheduler cfq registered (default)
[ 0.962278] pci 0000:00:00.0: Enabling HT MSI Mapping
[ 0.975584] pci 0000:00:0b.0: Enabling HT MSI Mapping
[ 0.975591] pci 0000:00:0b.0: Found enabled HT MSI Mapping
[ 0.975595] pci 0000:00:0b.0: Linking AER extended capability
[ 0.975604] pci 0000:00:0c.0: Enabling HT MSI Mapping
[ 0.975610] pci 0000:00:0c.0: Found enabled HT MSI Mapping
[ 0.975613] pci 0000:00:0c.0: Linking AER extended capability
[ 0.975621] pci 0000:00:0d.0: Enabling HT MSI Mapping
[ 0.975628] pci 0000:00:0d.0: Found enabled HT MSI Mapping
[ 0.975630] pci 0000:00:0d.0: Linking AER extended capability
[ 0.975639] pci 0000:00:0e.0: Enabling HT MSI Mapping
[ 0.975645] pci 0000:00:0e.0: Found enabled HT MSI Mapping
[ 0.975647] pci 0000:00:0e.0: Linking AER extended capability
[ 0.975668] pci 0000:01:00.0: Boot video device
[ 0.977785] PCI: Setting latency timer of device 0000:00:0b.0 to 64
[ 0.977803] assign_interrupt_mode Found MSI capability
[ 0.977822] Allocate Port Service[0000:00:0b.0:pcie00]
[ 0.978278] Allocate Port Service[0000:00:0b.0:pcie03]
[ 0.978278] PCI: Setting latency timer of device 0000:00:0c.0 to 64
[ 0.978278] assign_interrupt_mode Found MSI capability
[ 0.978278] Allocate Port Service[0000:00:0c.0:pcie00]
[ 0.978278] Allocate Port Service[0000:00:0c.0:pcie03]
[ 0.978278] PCI: Setting latency timer of device 0000:00:0d.0 to 64
[ 0.978278] Allocate Port Service[0000:00:0d.0:pcie00]
[ 0.978278] Allocate Port Service[0000:00:0d.0:pcie03]
[ 0.978278] PCI: Setting latency timer of device 0000:00:0e.0 to 64
[ 0.978278] Allocate Port Service[0000:00:0e.0:pcie00]
[ 0.978278] Allocate Port Service[0000:00:0e.0:pcie03]
[ 0.982280] Linux agpgart interface v0.103
[ 0.982280] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
[ 0.982280] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.982280] pnp: the driver 'serial' has been registered
[ 0.982280] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.982280] serial 00:08: driver attached
[ 0.982294] brd: module loaded
[ 0.982294] input: Macintosh mouse button emulation as /class/input/input0
[ 0.982294] pnp: the driver 'i8042 kbd' has been registered
[ 0.982294] i8042 kbd 00:0b: driver attached
[ 0.982294] pnp: the driver 'i8042 aux' has been registered
[ 0.982294] i8042 aux 00:0a: driver attached
[ 0.982294] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.984596] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.984602] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.002278] mice: PS/2 mouse device common for all mice
[ 1.002278] pnp: the driver 'rtc_cmos' has been registered
[ 1.002278] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 1.002278] rtc0: alarms up to one year, y3k
[ 1.002278] rtc_cmos 00:04: driver attached
[ 1.002278] cpuidle: using governor ladder
[ 1.002278] cpuidle: using governor menu
[ 1.002278] No iBFT detected.
[ 1.002278] TCP cubic registered
[ 1.002278] NET: Registered protocol family 17
[ 1.002278] registered taskstats version 1
[ 1.002278] rtc_cmos 00:04: setting system clock to 2009-03-12 22:48:45 UTC (1236898125)
[ 1.002278] Freeing unused kernel memory: 392k freed
[ 1.021377] input: AT Translated Set 2 keyboard as /class/input/input1
[ 1.097476] ACPI: PNP0C0B:00 is registered as cooling_device0
[ 1.097476] ACPI: Fan [FAN] (on)
[ 1.101044] ACPI: ACPI0007:00 is registered as cooling_device1
[ 1.101044] ACPI: ACPI0007:01 is registered as cooling_device2
[ 1.105042] ACPI: LNXTHERM:01 is registered as thermal_zone0
[ 1.105042] ACPI: Thermal Zone [THRM] (40 C)
[ 1.480778] ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.481039] ACPI: PCI Interrupt Link [APCF] enabled at IRQ 23
[ 1.481039] ACPI: PCI Interrupt 0000:00:02.0[A] -> Link [APCF] -> GSI 23 (level, low) -> IRQ 23
[ 1.481039] PCI: Setting latency timer of device 0000:00:02.0 to 64
[ 1.481039] ohci_hcd 0000:00:02.0: OHCI Host Controller
[ 1.481039] ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 1
[ 1.481039] ohci_hcd 0000:00:02.0: irq 23, io mem 0xd5004000
[ 1.505313] No dock devices found.
[ 1.515701] SCSI subsystem initialized
[ 1.539005] usb usb1: configuration #1 chosen from 1 choice
[ 1.539005] hub 1-0:1.0: USB hub found
[ 1.539005] hub 1-0:1.0: 10 ports detected
[ 1.539005] libata version 3.00 loaded.
[ 1.640201] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.640205] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.640208] usb usb1: Product: OHCI Host Controller
[ 1.640210] usb usb1: Manufacturer: Linux 2.6.26-1-amd64 ohci_hcd
[ 1.640212] usb usb1: SerialNumber: 0000:00:02.0
[ 1.643014] ACPI: PCI Interrupt Link [APCL] enabled at IRQ 22
[ 1.643014] ACPI: PCI Interrupt 0000:00:02.1[B] -> Link [APCL] -> GSI 22 (level, low) -> IRQ 22
[ 1.643014] PCI: Setting latency timer of device 0000:00:02.1 to 64
[ 1.643014] ehci_hcd 0000:00:02.1: EHCI Host Controller
[ 1.643014] ehci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 2
[ 1.643014] ehci_hcd 0000:00:02.1: debug port 1
[ 1.643014] PCI: cache line size of 64 is not supported by device 0000:00:02.1
[ 1.643014] ehci_hcd 0000:00:02.1: irq 22, io mem 0xfeb00000
[ 1.651247] ehci_hcd 0000:00:02.1: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 1.651340] usb usb2: configuration #1 chosen from 1 choice
[ 1.651374] hub 2-0:1.0: USB hub found
[ 1.651383] hub 2-0:1.0: 10 ports detected
[ 1.665038] Floppy drive(s): fd0 is 1.44M
[ 1.686822] FDC 0 is a post-1991 82077
[ 1.755223] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.755227] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.755230] usb usb2: Product: EHCI Host Controller
[ 1.755232] usb usb2: Manufacturer: Linux 2.6.26-1-amd64 ehci_hcd
[ 1.755234] usb usb2: SerialNumber: 0000:00:02.1
[ 1.755444] sata_nv 0000:00:07.0: version 3.5
[ 1.755881] ACPI: PCI Interrupt Link [APSI] enabled at IRQ 21
[ 1.755889] ACPI: PCI Interrupt 0000:00:07.0[A] -> Link [APSI] -> GSI 21 (level, low) -> IRQ 21
[ 1.755937] PCI: Setting latency timer of device 0000:00:07.0 to 64
[ 1.759077] scsi0 : sata_nv
[ 1.759077] scsi1 : sata_nv
[ 1.759077] ata1: SATA max UDMA/133 cmd 0x9f0 ctl 0xbf0 bmdma 0xd800 irq 21
[ 1.759077] ata2: SATA max UDMA/133 cmd 0x970 ctl 0xb70 bmdma 0xd808 irq 21
[ 2.275651] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.333071] ata1.00: ATA-7: ST3160811AS, 3.AAE, max UDMA/133
[ 2.333071] ata1.00: 312581808 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 2.395614] ata1.00: configured for UDMA/133
[ 2.446227] usb 2-4: new high speed USB device using ehci_hcd and address 3
[ 2.586543] usb 2-4: configuration #1 chosen from 1 choice
[ 2.586741] usb 2-4: New USB device found, idVendor=0930, idProduct=6540
[ 2.586743] usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.586746] usb 2-4: Product: USB Flash Memory
[ 2.586748] usb 2-4: SerialNumber: 0A80B27073123883
[ 2.875633] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.888621] usb 1-1: new full speed USB device using ohci_hcd and address 2
[ 2.900807] ata2.00: ATA-8: SAMSUNG HD501LJ, CR100-12, max UDMA7
[ 2.900810] ata2.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 2.909801] ata2.00: configured for UDMA/133
[ 2.909801] isa bounce pool size: 16 pages
[ 2.909801] scsi 0:0:0:0: Direct-Access ATA ST3160811AS 3.AA PQ: 0 ANSI: 5
[ 2.909801] scsi 1:0:0:0: Direct-Access ATA SAMSUNG HD501LJ CR10 PQ: 0 ANSI: 5
[ 2.909801] ACPI: PCI Interrupt Link [APSJ] enabled at IRQ 20
[ 2.909801] ACPI: PCI Interrupt 0000:00:08.0[A] -> Link [APSJ] -> GSI 20 (level, low) -> IRQ 20
[ 2.909801] PCI: Setting latency timer of device 0000:00:08.0 to 64
[ 2.909801] scsi2 : sata_nv
[ 2.909801] scsi3 : sata_nv
[ 2.909801] ata3: SATA max UDMA/133 cmd 0x9e0 ctl 0xbe0 bmdma 0xc400 irq 20
[ 2.909801] ata4: SATA max UDMA/133 cmd 0x960 ctl 0xb60 bmdma 0xc408 irq 20
[ 3.111216] usb 1-1: configuration #1 chosen from 1 choice
[ 3.119424] usb 1-1: New USB device found, idVendor=045e, idProduct=070f
[ 3.119427] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.119430] usb 1-1: Product: Microsoft LifeChat LX-3000
[ 3.403229] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 3.446219] ata3.00: ATA-7: ST3160812AS, 3.AAH, max UDMA/133
[ 3.446219] ata3.00: 312581808 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 3.506218] ata3.00: configured for UDMA/133
[ 3.986231] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 4.034769] ata4.00: ATA-7: ST3160812AS, 3.AAH, max UDMA/133
[ 4.034769] ata4.00: 312581808 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 4.105865] ata4.00: configured for UDMA/133
[ 4.105865] scsi 2:0:0:0: Direct-Access ATA ST3160812AS 3.AA PQ: 0 ANSI: 5
[ 4.105865] scsi 3:0:0:0: Direct-Access ATA ST3160812AS 3.AA PQ: 0 ANSI: 5
[ 4.105865] forcedeth: Reverse Engineered nForce ethernet driver. Version 0.61.
[ 4.105865] ACPI: PCI Interrupt Link [APCH] enabled at IRQ 23
[ 4.105865] ACPI: PCI Interrupt 0000:00:0a.0[A] -> Link [APCH] -> GSI 23 (level, low) -> IRQ 23
[ 4.105865] PCI: Setting latency timer of device 0000:00:0a.0 to 64
[ 4.626305] forcedeth 0000:00:0a.0: ifname eth0, PHY OUI 0x5043 @ 9, addr 00:15:f2:da:13:b4
[ 4.626309] forcedeth 0000:00:0a.0: highdma csum timirq gbit lnktim desc-v3
[ 4.633653] sata_sil 0000:05:0a.0: version 2.3
[ 4.633863] ACPI: PCI Interrupt Link [APC4] enabled at IRQ 19
[ 4.633863] ACPI: PCI Interrupt 0000:05:0a.0[A] -> Link [APC4] -> GSI 19 (level, low) -> IRQ 19
[ 4.633863] sata_sil 0000:05:0a.0: Applying R_ERR on DMA activate FIS errata fix
[ 4.714856] scsi4 : sata_sil
[ 4.714856] Uniform Multi-Platform E-IDE driver
[ 4.714856] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
[ 4.715424] scsi5 : sata_sil
[ 4.715424] NFORCE-CK804: 0000:00:06.0 (rev f2) UDMA133 controller
[ 4.715424] NFORCE-CK804: IDE controller (0x10de:0x0053 rev 0xf2) at PCI slot 0000:00:06.0
[ 4.715424] NFORCE-CK804: not 100% native mode: will probe irqs later
[ 4.715424] ide0: BM-DMA at 0xf000-0xf007
[ 4.715424] ide1: BM-DMA at 0xf008-0xf00f
[ 4.715424] Probing IDE interface ide0...
[ 4.724281] scsi6 : sata_sil
[ 4.724342] scsi7 : sata_sil
[ 4.724372] ata5: SATA max UDMA/100 mmio m1024@0xd4010000 tf 0xd4010080 irq 19
[ 4.724375] ata6: SATA max UDMA/100 mmio m1024@0xd4010000 tf 0xd40100c0 irq 19
[ 4.724379] ata7: SATA max UDMA/100 mmio m1024@0xd4010000 tf 0xd4010280 irq 19
[ 4.724382] ata8: SATA max UDMA/100 mmio m1024@0xd4010000 tf 0xd40102c0 irq 19
[ 4.747365] Driver 'sd' needs updating - please use bus_type methods
[ 4.747365] sd 0:0:0:0: [sda] 312581808 512-byte hardware sectors (160042 MB)
[ 4.747365] sd 0:0:0:0: [sda] Write Protect is off
[ 4.747365] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 4.747365] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 4.747365] sda: sda1 sda2 sda3 < sda5 > sda4
[ 4.798991] sd 0:0:0:0: [sda] Attached SCSI disk
[ 4.800037] sd 1:0:0:0: [sdb] 976773168 512-byte hardware sectors (500108 MB)
[ 4.800037] sd 1:0:0:0: [sdb] Write Protect is off
[ 4.800037] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 4.800037] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 4.800037] sdb:<6>Initializing USB Mass Storage driver...
[ 4.811033] scsi8 : SCSI emulation for USB Mass Storage devices
[ 4.811033] usbcore: registered new interface driver usb-storage
[ 4.811033] USB Mass Storage support registered.
[ 4.811033] usb-storage: device found at 3
[ 4.811033] usb-storage: waiting for device to settle before scanning
[ 4.826427] sdb1
[ 4.826567] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 4.826672] sd 2:0:0:0: [sdc] 312581808 512-byte hardware sectors (160042 MB)
[ 4.826697] sd 2:0:0:0: [sdc] Write Protect is off
[ 4.826699] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[ 4.826740] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 4.826812] sd 2:0:0:0: [sdc] 312581808 512-byte hardware sectors (160042 MB)
[ 4.826834] sd 2:0:0:0: [sdc] Write Protect is off
[ 4.826837] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[ 4.826877] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 4.826880] sdc: unknown partition table
[ 4.843086] sd 2:0:0:0: [sdc] Attached SCSI disk
[ 4.843086] sd 3:0:0:0: [sdd] 312581808 512-byte hardware sectors (160042 MB)
[ 4.843086] sd 3:0:0:0: [sdd] Write Protect is off
[ 4.843086] sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[ 4.843086] sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 4.843086] sdd:<6>usbcore: registered new interface driver hiddev
[ 4.860258] sdd1 sdd2 sdd3 <<6>input: Microsoft LifeChat LX-3000 as /class/input/input2
[ 4.883921] > sdd4
[ 4.883967] sdd: p4 exceeds device capacity
[ 4.884088] sd 3:0:0:0: [sdd] Attached SCSI disk
[ 4.894245] input,hidraw0: USB HID v1.00 Device [Microsoft LifeChat LX-3000 ] on usb-0000:00:02.0-1
[ 4.894269] usbcore: registered new interface driver usbhid
[ 4.894273] usbhid: v2.6:USB HID core driver
[ 4.983910] attempt to access beyond end of device
[ 4.983910] sdd: rw=0, want=389110367, limit=312581808
[ 4.983910] Buffer I/O error on device sdd4, logical block 0
[ 4.983910] sdd: rw=0, want=389110369, limit=312581808
[ 4.983910] Buffer I/O error on device sdd4, logical block 1
[ 4.983910] sdd: rw=0, want=389110371, limit=312581808
[ 4.983910] Buffer I/O error on device sdd4, logical block 2
[ 4.983910] sdd: rw=0, want=389110373, limit=312581808
[ 4.983910] Buffer I/O error on device sdd4, logical block 3
[ 4.983910] sdd: rw=0, want=389110375, limit=312581808
[ 4.983910] Buffer I/O error on device sdd4, logical block 4
[ 4.983910] sdd: rw=0, want=389110377, limit=312581808
[ 4.983910] Buffer I/O error on device sdd4, logical block 5
[ 4.983910] sdd: rw=0, want=389110379, limit=312581808
[ 4.983910] Buffer I/O error on device sdd4, logical block 6
[ 4.983910] sdd: rw=0, want=389110381, limit=312581808
[ 4.983910] Buffer I/O error on device sdd4, logical block 7
[ 4.983910] sdd: rw=0, want=389110383, limit=312581808
[ 4.983910] Buffer I/O error on device sdd4, logical block 8
[ 4.983910] sdd: rw=0, want=389110385, limit=312581808
[ 4.983910] sdd: rw=0, want=389110387, limit=312581808
[ 4.983910] sdd: rw=0, want=389110389, limit=312581808
[ 4.983910] sdd: rw=0, want=389110391, limit=312581808
[ 4.983910] sdd: rw=0, want=389110393, limit=312581808
[ 4.983910] sdd: rw=0, want=389110395, limit=312581808
[ 4.983910] sdd: rw=0, want=389110397, limit=312581808
[ 5.050687] ata5: SATA link down (SStatus 0 SControl 310)
[ 5.301924] Probing IDE interface ide1...
[ 5.381390] ata6: SATA link down (SStatus 0 SControl 310)
[ 5.701151] ata7: SATA link down (SStatus 0 SControl 310)
[ 6.020909] ata8: SATA link down (SStatus 0 SControl 310)
[ 6.360909] ACPI: PCI Interrupt Link [APC1] enabled at IRQ 16
[ 6.360909] ACPI: PCI Interrupt 0000:05:0b.0[A] -> Link [APC1] -> GSI 16 (level, low) -> IRQ 16
[ 6.380987] hdc: PIONEER DVD-RW DVR-111D, ATAPI CD/DVD-ROM drive
[ 6.416902] ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[16] MMIO=[d4011000-d40117ff] Max Packet=[2048] IR/IT contexts=[4/8]
[ 6.416902] ACPI: PCI Interrupt Link [APC2] enabled at IRQ 17
[ 6.416902] ACPI: PCI Interrupt 0000:05:0c.0[A] -> Link [APC2] -> GSI 17 (level, low) -> IRQ 17
[ 6.416902] skge 1.13 addr 0xd400c000 irq 17 chip Yukon-Lite rev 9
[ 6.416902] skge eth1: addr 00:15:f2:da:18:be
[ 7.052623] hdc: host max PIO5 wanted PIO255(auto-tune) selected PIO4
[ 7.052723] hdc: UDMA/66 mode selected
[ 7.052970] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
[ 7.053018] ide1 at 0x170-0x177,0x376 on irq 15
[ 7.617556] hdc: ATAPI 40X DVD-ROM DVD-R CD-R/RW drive, 2000kB Cache
[ 7.617556] Uniform CD-ROM driver Revision: 3.20
[ 7.746481] PM: Starting manual resume from disk
[ 7.754418] ReiserFS: sda4: found reiserfs format "3.6" with standard journal
[ 7.754429] ReiserFS: sda4: using ordered data mode
[ 7.761557] ReiserFS: sda4: journal params: device sda4, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
[ 7.761557] ReiserFS: sda4: checking transaction log (sda4)
[ 7.792398] ReiserFS: sda4: Using r5 hash to sort names
[ 8.290473] ieee1394: Host added: ID:BUS[0-00:1023] GUID[0011d80000966d2e]
[ 9.272837] udevd version 125 started
[ 9.761909] attempt to access beyond end of device
[ 9.761916] sdd: rw=0, want=389110367, limit=312581808
[ 9.761919] __ratelimit: 11 messages suppressed
[ 9.761922] Buffer I/O error on device sdd4, logical block 0
[ 9.761968] attempt to access beyond end of device
[ 9.761970] sdd: rw=0, want=389110369, limit=312581808
[ 9.761973] attempt to access beyond end of device
[ 9.761975] sdd: rw=0, want=389110371, limit=312581808
[ 9.761978] attempt to access beyond end of device
[ 9.761980] sdd: rw=0, want=389110373, limit=312581808
[ 9.761985] attempt to access beyond end of device
[ 9.761987] sdd: rw=0, want=389110375, limit=312581808
[ 9.761989] attempt to access beyond end of device
[ 9.761992] sdd: rw=0, want=389110377, limit=312581808
[ 9.761994] attempt to access beyond end of device
[ 9.761997] sdd: rw=0, want=389110379, limit=312581808
[ 9.761999] attempt to access beyond end of device
[ 9.762001] sdd: rw=0, want=389110381, limit=312581808
[ 9.762006] attempt to access beyond end of device
[ 9.762008] sdd: rw=0, want=389110383, limit=312581808
[ 9.762011] attempt to access beyond end of device
[ 9.762013] sdd: rw=0, want=389110385, limit=312581808
[ 9.762016] attempt to access beyond end of device
[ 9.762018] sdd: rw=0, want=389110387, limit=312581808
[ 9.762021] attempt to access beyond end of device
[ 9.762023] sdd: rw=0, want=389110389, limit=312581808
[ 9.762027] attempt to access beyond end of device
[ 9.762029] sdd: rw=0, want=389110391, limit=312581808
[ 9.762032] attempt to access beyond end of device
[ 9.762034] sdd: rw=0, want=389110393, limit=312581808
[ 9.762036] attempt to access beyond end of device
[ 9.762039] sdd: rw=0, want=389110395, limit=312581808
[ 9.762041] attempt to access beyond end of device
[ 9.762044] sdd: rw=0, want=389110397, limit=312581808
[ 9.762047] attempt to access beyond end of device
[ 9.762049] sdd: rw=0, want=389110367, limit=312581808
[ 9.762052] attempt to access beyond end of device
[ 9.762054] sdd: rw=0, want=389110369, limit=312581808
[ 9.762057] attempt to access beyond end of device
[ 9.762059] sdd: rw=0, want=389110371, limit=312581808
[ 9.762062] attempt to access beyond end of device
[ 9.762064] sdd: rw=0, want=389110373, limit=312581808
[ 10.190371] i2c-adapter i2c-0: nForce2 SMBus adapter at 0x4c00
[ 10.190371] i2c-adapter i2c-1: nForce2 SMBus adapter at 0x4c40
[ 10.310478] input: Power Button (FF) as /class/input/input3
[ 10.362596] ACPI: Power Button (FF) [PWRF]
[ 10.362674] input: Power Button (CM) as /class/input/input4
[ 10.426884] ACPI: Power Button (CM) [PWRB]
[ 10.821040] ACPI: PCI Interrupt Link [APCJ] enabled at IRQ 22
[ 10.821040] ACPI: PCI Interrupt 0000:00:04.0[A] -> Link [APCJ] -> GSI 22 (level, low) -> IRQ 22
[ 10.821040] PCI: Setting latency timer of device 0000:00:04.0 to 64
[ 10.856984] usb-storage: device scan complete
[ 10.862348] scsi 8:0:0:0: Direct-Access USB Flash Memory 6.50 PQ: 0 ANSI: 0 CCS
[ 10.874788] sd 8:0:0:0: [sde] 3903487 512-byte hardware sectors (1999 MB)
[ 10.874788] sd 8:0:0:0: [sde] Write Protect is off
[ 10.874788] sd 8:0:0:0: [sde] Mode Sense: 45 00 00 08
[ 10.874788] sd 8:0:0:0: [sde] Assuming drive cache: write through
[ 10.884510] sd 8:0:0:0: [sde] 3903487 512-byte hardware sectors (1999 MB)
[ 10.888510] sd 8:0:0:0: [sde] Write Protect is off
[ 10.888510] sd 8:0:0:0: [sde] Mode Sense: 45 00 00 08
[ 10.888510] sd 8:0:0:0: [sde] Assuming drive cache: write through
[ 10.888510] sde: sde1
[ 10.896510] sd 8:0:0:0: [sde] Attached SCSI removable disk
[ 11.030647] usbcore: registered new interface driver snd-usb-audio
[ 11.042217] input: PC Speaker as /class/input/input5
[ 11.148395] intel8x0_measure_ac97_clock: measured 54661 usecs
[ 11.148399] intel8x0: clocking to 46853
[ 11.222428] ACPI: PCI Interrupt 0000:05:07.0[A] -> Link [APC2] -> GSI 17 (level, low) -> IRQ 17
[ 11.228614] phy0: Selected rate control algorithm 'pid'
[ 11.279126] pnp: the driver 'parport_pc' has been registered
[ 11.279128] parport_pc 00:09: reported by Plug and Play ACPI
[ 11.279128] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 11.380151] parport_pc 00:09: driver attached
[ 11.407424] pnp: the driver 'ns558' has been registered
[ 11.407424] ns558 00:0d: driver attached
[ 11.431413] gameport: NS558 PnP Gameport is pnp00:0d/gameport0, io 0x201, speed 898kHz
[ 11.587737] Registered led device: rt61pci-phy0:radio
[ 11.587737] Registered led device: rt61pci-phy0:assoc
[ 12.178148] input: ImPS/2 Logitech Wheel Mouse as /class/input/input6
[ 12.219910] pnp: the driver 'mpu401' has been registered
[ 12.220040] mpu401 00:0c: driver attached
[ 13.150309] Adding 1959888k swap on /dev/sda5. Priority:-1 extents:1 across:1959888k
[ 23.831808] loop: module loaded
[ 27.379312] powernow-k8: Found 1 AMD Athlon(tm) 64 X2 Dual Core Processor 3800+ processors (2 cpu cores) (version 2.20.00)
[ 27.379312] powernow-k8: ACPI Processor support is required for SMP systems but is absent. Please load the ACPI Processor module before starting this driver.
[ 28.221497] NET: Registered protocol family 10
[ 28.221497] lo: Disabled Privacy Extensions
[ 28.408552] lp0: using parport0 (interrupt-driven).
[ 28.452703] ppdev: user-space parallel port driver
[ 32.925915] attempt to access beyond end of device
[ 32.925915] sdd: rw=0, want=389110367, limit=312581808
[ 32.925915] __ratelimit: 19 messages suppressed
[ 32.925915] Buffer I/O error on device sdd4, logical block 0
[ 32.925915] sdd: rw=0, want=389110369, limit=312581808
[ 32.925915] Buffer I/O error on device sdd4, logical block 1
[ 32.925915] sdd: rw=0, want=389110371, limit=312581808
[ 32.925915] Buffer I/O error on device sdd4, logical block 2
[ 32.925915] sdd: rw=0, want=389110373, limit=312581808
[ 32.925915] Buffer I/O error on device sdd4, logical block 3
[ 32.925915] sdd: rw=0, want=389110375, limit=312581808
[ 32.925915] sdd: rw=0, want=389110377, limit=312581808
[ 32.925915] sdd: rw=0, want=389110379, limit=312581808
[ 32.925915] sdd: rw=0, want=389110381, limit=312581808
[ 32.925915] sdd: rw=0, want=389110383, limit=312581808
[ 32.925915] sdd: rw=0, want=389110385, limit=312581808
[ 32.925915] sdd: rw=0, want=389110387, limit=312581808
[ 32.925915] sdd: rw=0, want=389110389, limit=312581808
[ 32.925915] sdd: rw=0, want=389110391, limit=312581808
[ 32.925915] sdd: rw=0, want=389110393, limit=312581808
[ 32.925915] sdd: rw=0, want=389110395, limit=312581808
[ 32.925915] sdd: rw=0, want=389110397, limit=312581808
[ 33.297821] firmware: requesting rt2561.bin
[ 33.325940] phy0 -> rt2x00lib_request_firmware: Error - Failed to request Firmware.
[ 35.650873] skge eth1: enabling interface
[ 35.654768] ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 35.666829] eth0: no link during initialization.
[ 35.666829] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 36.090444] firmware: requesting rt2561.bin
[ 36.094194] phy0 -> rt2x00lib_request_firmware: Error - Failed to request Firmware.
[ 57.032875] firmware: requesting rt2561.bin
[ 57.037623] phy0 -> rt2x00lib_request_firmware: Error - Failed to request Firmware.
[ 66.664229] FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 74.595829] firmware: requesting rt2561.bin
[ 74.608286] phy0 -> rt2x00lib_request_firmware: Error - Failed to request Firmware.
[ 78.450884] firmware: requesting rt2561.bin
[ 78.490869] phy0 -> rt2x00lib_request_firmware: Error - Failed to request Firmware.
[ 92.965797] firmware: requesting rt2561.bin
[ 92.973556] phy0 -> rt2x00lib_request_firmware: Error - Failed to request Firmware.
[ 102.070089] firmware: requesting rt2561.bin
[ 102.073772] phy0 -> rt2x00lib_request_firmware: Error - Failed to request Firmware.
[ 115.791661] firmware: requesting rt2561.bin
[ 115.799082] phy0 -> rt2x00lib_request_firmware: Error - Failed to request Firmware.
