Il me faudrait le module, firmware?, pour mon wipen, en un paquet, que je puisse télécharger via un portable, transférer ensuite sur clé usb, afin de pouvoir activé, ma connexion sur une tour.
Je ne sais ce que je dois prendre exactement.
Je vous colle quelques infos:
00:00.0 RAM memory: nVidia Corporation MCP67 Memory Controller (rev a2)
00:01.0 ISA bridge: nVidia Corporation MCP67 ISA Bridge (rev a2)
00:01.1 SMBus: nVidia Corporation MCP67 SMBus (rev a2)
00:01.2 RAM memory: nVidia Corporation MCP67 Memory Controller (rev a2)
00:02.0 USB Controller: nVidia Corporation MCP67 OHCI USB 1.1 Controller (rev a2)
00:02.1 USB Controller: nVidia Corporation MCP67 EHCI USB 2.0 Controller (rev a2)
00:04.0 USB Controller: nVidia Corporation MCP67 OHCI USB 1.1 Controller (rev a2)
00:04.1 USB Controller: nVidia Corporation MCP67 EHCI USB 2.0 Controller (rev a2)
00:06.0 IDE interface: nVidia Corporation MCP67 IDE Controller (rev a1)
00:07.0 Audio device: nVidia Corporation MCP67 High Definition Audio (rev a1)
00:08.0 PCI bridge: nVidia Corporation MCP67 PCI Bridge (rev a2)
00:09.0 IDE interface: nVidia Corporation MCP67 AHCI Controller (rev a2)
00:0a.0 Ethernet controller: nVidia Corporation MCP67 Ethernet (rev a2)
00:12.0 VGA compatible controller: nVidia Corporation GeForce 7025 (rev a2)
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
01:06.0 Multimedia controller: Philips Semiconductors SAA7131/SAA7133/SAA7135 Video Broadcast Decoder (rev d1)
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 1044:8008 Chu Yuen Enterprise Co., Ltd GN-WB01GS
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 003: ID 058f:9360 Alcor Micro Corp. 8-in-1 Media Card Reader
Bus 002 Device 002: ID 1bcf:0007 Sunplus Innovation Technology Inc.
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Merci de votre soutien.
