Arf… J’aurais peut-être dû effectivement commencer par là :
[code]*****@Sviatopolk:~$ cat .wm*/wmiirc
#!/bin/sh -f
Configure wmii
Configuration Variables
MODKEY=Mod4
UP=Up
DOWN=Down
LEFT=Left
RIGHT=Right
Colors tuples: " "
WMII_NORMCOLORS=’#808080 #000000 #808080’
WMII_FOCUSCOLORS=’#00ff00 #000000 #00ff00’
WMII_BACKGROUND=’#333333’
WMII_FONT=‘fixed’
set – $(echo $WMII_NORMCOLORS $WMII_FOCUSCOLORS)
WMII_MENU="dmenu -b -fn ‘$WMII_FONT’ -nf ‘$1’ -nb ‘$2’ -sf ‘$4’ -sb ‘$5’"
WMII_9MENU="wmii9menu -font ‘$WMII_FONT’ -nf ‘$1’ -nb ‘$2’ -sf ‘$4’ -sb ‘$5’ -br ‘$6’"
WMII_TERM=“urxvt -transparent -sh 20 -bg black -cr green -fg green +sb -sl 500”
Column Rules
wmiir write /colrules <<!
/.*/ -> 58+42
Tagging Rules
wmiir write /tagrules <<!
/XMMS./ -> ~
/MPlayer./ -> ~
/trayer./ -> network
/nm-applet./ -> network
/Téléchargements./ -> download
/./ -> sel
/.*/ -> 1
Status Bar Info
status() {
echo -n $(acpi -b | grep -Eo ‘[0-9]+%’) ‘|’ $(date +"%d/%m/%y - %H:%M:%S")
Event processing
Processed later by `wmiiloop’ and evaled.
Duplicate the eval line and replace ‘eval’ with ‘echo’ for details.
eventstuff() {
cat <<’!’
# Events
Event Start
case “$1” in
wmiirc)
exit;
esac
Event Key
fn=$(echo “$@” | sed ‘s/[^a-zA-Z_0-9]//g’)
Key$fn "$@"
Event CreateTag
echo “$WMII_NORMCOLORS” “$@” | wmiir create "/lbar/$@"
Event DestroyTag
wmiir remove "/lbar/$@"
Event FocusTag
wmiir xwrite “/lbar/$@” “$WMII_FOCUSCOLORS” "$@"
Event UnfocusTag
wmiir xwrite “/lbar/$@” “$WMII_NORMCOLORS” "$@"
Event UrgentTag
shift
wmiir xwrite “/lbar/$@” "*$@"
Event NotUrgentTag
shift
wmiir xwrite “/lbar/$@” "$@"
Event LeftBarClick
shift
wmiir xwrite /ctl view “$@”
# Actions
Action quit
wmiir xwrite /ctl quit
Action exec
wmiir xwrite /ctl exec “$@“
Action rehash
proglist $PATH >$progsfile
Action status
set +xv
if wmiir remove /rbar/status 2>/dev/null; then
sleep 2
fi
echo “$WMII_NORMCOLORS” | wmiir create /rbar/status
while status | wmiir write /rbar/status; do
sleep 1
done
Event ClientMouseDown
client=$1; button=$2
case “$button” in
3)
do=$(eval $WMII_9MENU -initial “${menulast:-SomeRandomName}” Nop Delete Fullscreen)
case “$do” in
Delete)
wmiir xwrite /client/$client/ctl kill;;
Fullscreen)
wmiir xwrite /client/$client/ctl Fullscreen on;;
esac
menulast=${do:-”$menulast”}
esac
# Key Bindings
Key $MODKEY-Control-t
case $(wmiir read /keys | wc -l | tr -d ’ \t\n’) in
0|1)
echo -n $Keys | tr ’ ’ ‘\012’ | wmiir write /keys
wmiir xwrite /ctl grabmod $MODKEY;;
wmiir xwrite /keys $MODKEY-Control-t
wmiir xwrite /ctl grabmod Mod3;;
esac
Key $MODKEY-space
wmiir xwrite /tag/sel/ctl select toggle
Key $MODKEY-Shift-Escape
/sbin/shutdown -h now &
Key $MODKEY-d
wmiir xwrite /tag/sel/ctl colmode sel default
Key $MODKEY-s
wmiir xwrite /tag/sel/ctl colmode sel stack
Key $MODKEY-m
wmiir xwrite /tag/sel/ctl colmode sel max
Key $MODKEY-a
Action $(actionlist | eval $WMII_MENU) &
Key $MODKEY-p
sh -c “$(eval $WMII_MENU <$progsfile)” &
Key $MODKEY-t
wmiir xwrite /ctl “view $(tagsmenu)” &
Key $MODKEY-Return
eval $WMII_TERM &
Key $MODKEY-Shift-space
wmiir xwrite /tag/sel/ctl send sel toggle
Key $MODKEY-f
wmiir xwrite /client/sel/ctl Fullscreen toggle
Key $MODKEY-Shift-c
wmiir xwrite /client/sel/ctl kill
Key $MODKEY-Shift-t
wmiir xwrite “/client/$(wmiir read /client/sel/ctl)/tags” “$(tagsmenu)” &
Key $MODKEY-$LEFT
wmiir xwrite /tag/sel/ctl select left
Key $MODKEY-$RIGHT
wmiir xwrite /tag/sel/ctl select right
Key $MODKEY-$DOWN
wmiir xwrite /tag/sel/ctl select down
Key $MODKEY-$UP
wmiir xwrite /tag/sel/ctl select up
Key $MODKEY-Shift-$LEFT
wmiir xwrite /tag/sel/ctl send sel left
Key $MODKEY-Shift-$RIGHT
wmiir xwrite /tag/sel/ctl send sel right
Key $MODKEY-Shift-$DOWN
wmiir xwrite /tag/sel/ctl send sel down
Key $MODKEY-Shift-$UP
wmiir xwrite /tag/sel/ctl send sel up
for i in 0 1 2 3 4 5 6 7 8 9; do
cat <<!
Key $MODKEY-$i
wmiir xwrite /ctl view "$i"
Key $MODKEY-Shift-$i
wmiir xwrite /client/sel/tags “$i”
done
WM Configuration
wmiir write /ctl << EOF
font $WMII_FONT
focuscolors $WMII_FOCUSCOLORS
normcolors $WMII_NORMCOLORS
grabmod $MODKEY
border 1
EOF
export WMII_MENU WMII_9MENU WMII_FONT WMII_TERM
export WMII_FOCUSCOLORS WMII_SELCOLORS WMII_NORMCOLORS
Feed events to `wmiiloop’ for processing
eval “$(eventstuff | sed ‘s/^[ ]//’ | { . wmiiloop; })”
echo “$Keys” | tr ’ ’ ‘\n’ | wmiir write /keys
Functions
Action() {
action=$1; shift
if [ -n “$action” ]; then
Action_$action “$@”
|| conf_which $action "$@"
fi
proglist() {
paths=$(echo “$@” | sed ‘y/
ls -lL $paths 2>/dev/null
| awk ‘$1 ~ /^[^d].*x/ && NF > 2 { print $NF }’
| sort | uniq
Misc
progsfile="$WMII_NS_DIR/.proglist"
Action status &
proglist $PATH >$progsfile &
xsetroot -solid “$WMII_BACKGROUND” &
Setup Tag Bar
seltag="$(wmiir read /tag/sel/ctl 2>/dev/null)"
wmiir ls /lbar |
while read bar; do
wmiir remove "/lbar/$bar"
done
wmiir ls /tag | sed -e ‘s|/||; /^sel$/d’ |
while read tag; do
if [ “X$tag” = “X$seltag” ]; then
echo “$WMII_FOCUSCOLORS” “$tag” | wmiir create "/lbar/$tag"
else
echo “$WMII_NORMCOLORS” “$tag” | wmiir create "/lbar/$tag"
fi
done
More functions
tagsmenu() {
wmiir ls /tag | sed ‘s|/||; /^sel$/d’ | eval $WMII_MENU
actionlist() {
{ proglist $WMII_CONFPATH
echo -n $Actions | tr ’ ’ ‘\012’
} | sort | uniq
conf_which() {
which=$(which which)
prog=$(PATH="$WMII_CONFPATH" $which $1); shift
[ -n “$prog” ] && $prog “$@”
touchpad
synclient TapButton1=1 &
fond d’ecran
feh --bg-scale /home/****/iamacrocodile.jpg &
internet
#[ “ps aux | grep trayer | grep -v grep” = “” ] && trayer &
#[ “ps aux | grep nm-applet | grep -v grep” = “” ] && nm-applet &
shutdown : mod+shift+esc
chmod u+s /sbin/shutdown
Stop any running instances of wmiirc
echo Start wmiirc | wmiir write /event || exit 1
wmiir read /event |
while read event; do
set – $event
event=$1; shift
Event_$event $@
done 2>/dev/null
*****@Sviatopolk:~$ [/code]
