[Résolu]wx2.8-headers
J’ai eu un petit souci lors de l’installation du paquet wx2.8-headers, voici ce qu’un apt-get upgrade me donne :
/home/bask# apt-get upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0B of additional disk space will be used.
Do you want to continue [Y/n]? y
Setting up wx2.8-headers (2.8.10.1-0) ...
Traceback (most recent call last):
  File "/usr/bin/pycentral", line 1891, in <module>
    main()
  File "/usr/bin/pycentral", line 1885, in main
    rv = action.run(global_options)
  File "/usr/bin/pycentral", line 1243, in run
    pkg.read_version_info()
  File "/usr/bin/pycentral", line 707, in read_version_info
    raise PyCentralError, "package has no field Python-Version"
__main__.PyCentralError: package has no field Python-Version
dpkg: error processing wx2.8-headers (--configure):
 subprocess post-installation script returned error exit status 1
Errors were encountered while processing:
 wx2.8-headers
Si vous avez des idées sur comment régler ce problème… :unamused: merci d’avance :wink:
bask.
Bon il semblerait que j’ai trouvé :slightly_smiling: .
Il suffit de modifer le fichier /var/lib/dpkg/status et d’ajouter ces 2 lignes à la fin de la section wx2.8-headers :
Python-Runtime: python2.5 Python-Version: 2.5
Voila j’espère que ca aidera :mrgreen:
