This is a pre-release version of the X server from The X.Org Foundation.
It is not supported in any way.
Bugs may be filed in the bugzilla at bugs.freedesktop.org/.
Select the « xorg » product for bugs you find in this release.
Before reporting bugs in pre-release versions please check the
latest version in the X.Org Foundation git repository.
See wiki.x.org/wiki/GitPage for git access instructions.
X.Org X Server 1.4.0.90
Release Date: 5 September 2007
X Protocol Version 11, Revision 0
Build Operating System: Linux Debian (xorg-server 2:1.4.1~git20080507-1)
Current Operating System: Linux George 2.6.24.4 #11 SMP Sat May 3 11:11:46 CEST 2008 x86_64
Build Date: 09 May 2008 08:43:18PM
Before reporting problems, check [wiki.x.org](http://wiki.x.org)
Module Loader present
Markers: (–) probed, () from config file, (==) default setting,
(==) Log file: « /var/log/Xorg.0.log », Time: Sun May 18 10:42:12 2008
(==) Using config file: « /etc/X11/xorg.conf »
(==) ServerLayout « Default Layout »
() |–>Screen « Default Screen » (0)
() | |–>Monitor « Generic Monitor »
() | |–>Device « Generic Video Card »
() |–>Input Device « Generic Keyboard »
() |–>Input Device « Configured Mouse »
(==) Automatically adding devices
(==) Automatically enabling devices
(WW) The directory « /usr/share/fonts/X11/cyrillic » does not exist.
Entry deleted from font path.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType
(==) RgbPath set to « /etc/X11/rgb »
(==) ModulePath set to « /usr/lib/xorg/modules »
(**) Extension « Composite » is enabled
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Loader magic: 0x7b3660
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 2.0
X.Org XInput driver : 2.0
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: « pcidata »
(II) Loading /usr/lib/xorg/modules//libpcidata.so
(II) Module pcidata: vendor=« X.Org Foundation »
compiled for 1.4.0.90, module version = 1.0.0
ABI class: X.Org Video Driver, version 2.0
(++) using VT number 7
(WW) xf86OpenConsole: setpgid failed: Operation not permitted
(WW) xf86OpenConsole: setsid failed: Operation not permitted
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 10de,005e card 1043,815a rev a3 class 05,80,00 hdr 00
(II) PCI: 00:01:0: chip 10de,0050 card 1043,815a rev a3 class 06,01,00 hdr 80
(II) PCI: 00:01:1: chip 10de,0052 card 1043,815a rev a2 class 0c,05,00 hdr 80
(II) PCI: 00:02:0: chip 10de,005a card 1043,815a rev a2 class 0c,03,10 hdr 80
(II) PCI: 00:02:1: chip 10de,005b card 1043,815a rev a3 class 0c,03,20 hdr 80
(II) PCI: 00:04:0: chip 10de,0059 card 1043,812a rev a2 class 04,01,00 hdr 00
(II) PCI: 00:06:0: chip 10de,0053 card 1043,815a rev f2 class 01,01,8a hdr 00
(II) PCI: 00:09:0: chip 10de,005c card 0000,0000 rev a2 class 06,04,01 hdr 01
(II) PCI: 00:0a:0: chip 10de,0057 card 1043,8141 rev a3 class 06,80,00 hdr 00
(II) PCI: 00:0b:0: chip 10de,005d card 0000,0000 rev a3 class 06,04,00 hdr 01
(II) PCI: 00:0c:0: chip 10de,005d card 0000,0000 rev a3 class 06,04,00 hdr 01
(II) PCI: 00:0d:0: chip 10de,005d card 0000,0000 rev a3 class 06,04,00 hdr 01
(II) PCI: 00:0e:0: chip 10de,005d card 0000,0000 rev a3 class 06,04,00 hdr 01
(II) PCI: 00:18:0: chip 1022,1100 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:1: chip 1022,1101 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:2: chip 1022,1102 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:3: chip 1022,1103 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 01:00:0: chip 10de,0161 card 107d,2054 rev a1 class 03,00,00 hdr 00
(II) PCI: 05:0a:0: chip 1095,3114 card 1043,8167 rev 02 class 01,04,00 hdr 00
(II) PCI: 05:0b:0: chip 104c,8023 card 1043,808b rev 00 class 0c,00,10 hdr 00
(II) PCI: 05:0c:0: chip 11ab,4320 card 1043,811a rev 13 class 02,00,00 hdr 00
(II) PCI: End of PCI scan
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:1:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 5: bridge is at (0:9:0), (0,5,5), BCTRL: 0x0202 (VGA_EN is cleared)
(II) Bus 5 I/O range:
[0] -1 0 0x0000b000 - 0x0000cfff (0x2000) IX[B]
(II) Bus 5 non-prefetchable memory range:
[0] -1 0 0xd3000000 - 0xd4ffffff (0x2000000) MX[B]
(II) PCI-to-PCI bridge:
(II) Bus 4: bridge is at (0:11:0), (0,4,4), BCTRL: 0x0002 (VGA_EN is cleared)
(II) Bus 3: bridge is at (0:12:0), (0,3,3), BCTRL: 0x0002 (VGA_EN is cleared)
(II) Bus 2: bridge is at (0:13:0), (0,2,2), BCTRL: 0x0002 (VGA_EN is cleared)
(II) Bus 1: bridge is at (0:14:0), (0,1,1), BCTRL: 0x000a (VGA_EN is set)
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xd0000000 - 0xd2ffffff (0x3000000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xc0000000 - 0xcfffffff (0x10000000) MX[B]
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:24:0), (0,0,5), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x100000000) MX[B]
(II) Bus 0 prefetchable memory range:
(–) PCI:*(1:0:0) nVidia Corporation NV44 [GeForce 6200 TurboCache™] rev 161, Mem @ 0xd0000000/24, 0xc0000000/28, 0xd1000000/24
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
[0] -1 0 0xd4004000 - 0xd4007fff (0x4000) MX[B]
[1] -1 0 0xd4000000 - 0xd4003fff (0x4000) MX[B]
[2] -1 0 0xd4009000 - 0xd40097ff (0x800) MX[B]
[3] -1 0 0xd4008000 - 0xd40083ff (0x400) MX[B]
[4] -1 0 0xd5000000 - 0xd5000fff (0x1000) MX[B]
[5] -1 0 0xd5001000 - 0xd5001fff (0x1000) MX[B]
[6] -1 0 0xfeb00000 - 0xfeb000ff (0x100) MX[B]
[7] -1 0 0xd5002000 - 0xd5002fff (0x1000) MX[B]
[8] -1 0 0xd1000000 - 0xd1ffffff (0x1000000) MXB
[9] -1 0 0xc0000000 - 0xcfffffff (0x10000000) MXB
[10] -1 0 0xd0000000 - 0xd0ffffff (0x1000000) MXB
[11] -1 0 0x0000c400 - 0x0000c4ff (0x100) IX[B]
[12] -1 0 0x0000c000 - 0x0000c00f (0x10) IX[B]
[13] -1 0 0x0000bc00 - 0x0000bc03 (0x4) IX[B]
[14] -1 0 0x0000b800 - 0x0000b807 (0x8) IX[B]
[15] -1 0 0x0000b400 - 0x0000b403 (0x4) IX[B]
[16] -1 0 0x0000b000 - 0x0000b007 (0x8) IX[B]
[17] -1 0 0x0000d000 - 0x0000d007 (0x8) IX[B]
[18] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[19] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[20] -1 0 0x0000d400 - 0x0000d4ff (0x100) IX[B]
[21] -1 0 0x00004c40 - 0x00004c7f (0x40) IX[B]
[22] -1 0 0x00004c00 - 0x00004c3f (0x40) IX[B]
[23] -1 0 0x0000dc00 - 0x0000dc1f (0x20) IX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xd4004000 - 0xd4007fff (0x4000) MX[B]
[5] -1 0 0xd4000000 - 0xd4003fff (0x4000) MX[B]
[6] -1 0 0xd4009000 - 0xd40097ff (0x800) MX[B]
[7] -1 0 0xd4008000 - 0xd40083ff (0x400) MX[B]
[8] -1 0 0xd5000000 - 0xd5000fff (0x1000) MX[B]
[9] -1 0 0xd5001000 - 0xd5001fff (0x1000) MX[B]
[10] -1 0 0xfeb00000 - 0xfeb000ff (0x100) MX[B]
[11] -1 0 0xd5002000 - 0xd5002fff (0x1000) MX[B]
[12] -1 0 0xd1000000 - 0xd1ffffff (0x1000000) MXB
[13] -1 0 0xc0000000 - 0xcfffffff (0x10000000) MXB
[14] -1 0 0xd0000000 - 0xd0ffffff (0x1000000) MXB
[15] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[16] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[17] -1 0 0x0000c400 - 0x0000c4ff (0x100) IX[B]
[18] -1 0 0x0000c000 - 0x0000c00f (0x10) IX[B]
[19] -1 0 0x0000bc00 - 0x0000bc03 (0x4) IX[B]
[20] -1 0 0x0000b800 - 0x0000b807 (0x8) IX[B]
[21] -1 0 0x0000b400 - 0x0000b403 (0x4) IX[B]
[22] -1 0 0x0000b000 - 0x0000b007 (0x8) IX[B]
[23] -1 0 0x0000d000 - 0x0000d007 (0x8) IX[B]
[24] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[25] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[26] -1 0 0x0000d400 - 0x0000d4ff (0x100) IX[B]
[27] -1 0 0x00004c40 - 0x00004c7f (0x40) IX[B]
[28] -1 0 0x00004c00 - 0x00004c3f (0x40) IX[B]
[29] -1 0 0x0000dc00 - 0x0000dc1f (0x20) IX[B]
(II) « extmod » will be loaded by default.
(II) « dbe » will be loaded by default.
(II) « glx » will be loaded. This was enabled by default and also specified in the config file.
(II) « freetype » will be loaded by default.
(II) « record » will be loaded by default.
(II) « dri » will be loaded by default.
(II) LoadModule: « glx »
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor=« NVIDIA Corporation »
compiled for 4.0.2, module version = 1.0.0
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 0.1
(II) NVIDIA GLX Module 169.12 Thu Feb 14 18:34:02 PST 2008
(II) Loading extension GLX
(II) LoadModule: « extmod »
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Module extmod: vendor=« X.Org Foundation »
ABI class: X.Org Server Extension, version 0.3
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: « dbe »
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) Module dbe: vendor=« X.Org Foundation »
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: « freetype »
(II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
(II) Module freetype: vendor=« X.Org Foundation & the After X-TT Project »
compiled for 1.4.0.90, module version = 2.1.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.5
(II) Loading font FreeType
(II) LoadModule: « record »
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
(II) Module record: vendor=« X.Org Foundation »
compiled for 1.4.0.90, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: « dri »
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) Module dri: vendor=« X.Org Foundation »
(II) Loading extension XFree86-DRI
(II) LoadModule: « nv »
(II) Loading /usr/lib/xorg/modules/drivers//nv_drv.so
(II) Module nv: vendor=« X.Org Foundation »
compiled for 1.4.0.90, module version = 2.1.9
Module class: X.Org Video Driver
(II) LoadModule: « kbd »
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
(II) Module kbd: vendor=« X.Org Foundation »
compiled for 1.4.0, module version = 1.2.2
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 2.0
(II) LoadModule: « mouse »
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
(II) Module mouse: vendor=« X.Org Foundation »
compiled for 1.4.0, module version = 1.2.3
(II) NV: driver for NVIDIA chipsets: RIVA 128, RIVA TNT, RIVA TNT2,
Unknown TNT2, Vanta, RIVA TNT2 Ultra, RIVA TNT2 Model 64,
Aladdin TNT2, GeForce 256, GeForce DDR, Quadro, GeForce2 MX/MX 400,
GeForce2 MX 100/200, GeForce2 Go, Quadro2 MXR/EX/Go,
GeForce2 Integrated GPU, GeForce2 GTS, GeForce2 Ti, GeForce2 Ultra,
Quadro2 Pro, GeForce4 MX 460, GeForce4 MX 440, GeForce4 MX 420,
GeForce4 MX 440-SE, GeForce4 440 Go, GeForce4 420 Go,
GeForce4 420 Go 32M, GeForce4 460 Go, Quadro4 550 XGL,
GeForce4 440 Go 64M, Quadro NVS, Quadro4 500 GoGL,
GeForce4 410 Go 16M, GeForce4 MX 440 with AGP8X,
GeForce4 MX 440SE with AGP8X, GeForce4 MX 420 with AGP8X,
GeForce4 MX 4000, GeForce4 448 Go, GeForce4 488 Go, Quadro4 580 XGL,
Quadro4 NVS 280 SD, Quadro4 380 XGL, Quadro NVS 50 PCI,
GeForce4 448 Go, GeForce4 MX Integrated GPU, GeForce3,
GeForce3 Ti 200, GeForce3 Ti 500, Quadro DCC, GeForce4 Ti 4600,
GeForce4 Ti 4400, GeForce4 Ti 4200, Quadro4 900 XGL, Quadro4 750 XGL,
Quadro4 700 XGL, GeForce4 Ti 4800, GeForce4 Ti 4200 with AGP8X,
GeForce4 Ti 4800 SE, GeForce4 4200 Go, Quadro4 700 GoGL,
Quadro4 980 XGL, Quadro4 780 XGL, GeForce FX 5800 Ultra,
GeForce FX 5800, Quadro FX 2000, Quadro FX 1000,
GeForce FX 5600 Ultra, GeForce FX 5600, GeForce FX 5600XT,
GeForce FX Go5600, GeForce FX Go5650, Quadro FX Go700,
GeForce FX 5200, GeForce FX 5200 Ultra, GeForce FX 5200,
GeForce FX 5200LE, GeForce FX Go5200, GeForce FX Go5250,
GeForce FX 5500, GeForce FX 5100, GeForce FX Go5200 32M/64M,
Quadro NVS 55/280 PCI, Quadro FX 500/600 PCI,
GeForce FX Go53xx Series, GeForce FX Go5100, GeForce FX 5900 Ultra,
GeForce FX 5900, GeForce FX 5900XT, GeForce FX 5950 Ultra,
GeForce FX 5900ZT, Quadro FX 3000, Quadro FX 700,
GeForce FX 5700 Ultra, GeForce FX 5700, GeForce FX 5700LE,
GeForce FX 5700VE, GeForce FX Go5700, GeForce FX Go5700,
Quadro FX Go1000, Quadro FX 1100, GeForce 6800 Ultra, GeForce 6800,
GeForce 6800 LE, GeForce 6800 XE, GeForce 6800 XT, GeForce 6800 GT,
GeForce 6800 GT, GeForce 6800 GS, GeForce 6800 XT, Quadro FX 4000,
GeForce 6800 GS, GeForce 6800, GeForce 6800 LE, GeForce 6800 XT,
GeForce Go 6800, GeForce Go 6800 Ultra, Quadro FX Go1400,
Quadro FX 3450/4000 SDI, Quadro FX 1400, GeForce 6600 GT,
GeForce 6600, GeForce 6600 LE, GeForce 6600 VE, GeForce Go 6600,
GeForce 6610 XL, GeForce Go 6600 TE/6200 TE, GeForce 6700 XL,
GeForce Go 6600, GeForce Go 6600 GT, Quadro FX 550, Quadro FX 550,
Quadro FX 540, GeForce 6200, GeForce 6500,
GeForce 6200 TurboCache™, GeForce 6200SE TurboCache™,
GeForce 6200 LE, GeForce Go 6200, Quadro NVS 285, GeForce Go 6400,
GeForce Go 6200, GeForce Go 6400, GeForce 6250, GeForce 6800,
GeForce 6800 LE, GeForce 6800 GT, GeForce 6800 XT, GeForce 6200,
GeForce 6200 A-LE, GeForce 7800 GTX, GeForce 7800 GTX,
GeForce 7800 GT, GeForce 7800 GS, GeForce 7800 SLI, GeForce Go 7800,
GeForce Go 7800 GTX, Quadro FX 4500, GeForce 7300 LE,
GeForce 7300 SE, GeForce Go 7200, GeForce Go 7300, GeForce Go 7400,
GeForce Go 7400 GS, Quadro NVS 110M, Quadro NVS 120M, Quadro FX 350M,
GeForce 7500 LE, Quadro FX 350, GeForce 7300 GS, GeForce 7600 GT,
GeForce 7600 GS, GeForce 7300 GT, GeForce 7600 LE, GeForce 7300 GT,
GeForce Go 7700, GeForce Go 7600, GeForce Go 7600 GT,
Quadro NVS 300M, GeForce Go 7900 SE, Quadro FX 550M, Quadro FX 560,
GeForce 7900 GTX, GeForce 7900 GT, GeForce 7900 GS,
GeForce Go 7900 GS, GeForce Go 7900 GTX, Quadro FX 2500M,
Quadro FX 1500M, Quadro FX 5500, Quadro FX 3500, Quadro FX 1500,
Quadro FX 4500 X2, GeForce 6150, GeForce 6150 LE, GeForce 6100,
GeForce Go 6150, GeForce Go 6100, GeForce 8800 GTX, GeForce 8800 GTS,
GeForce 8800 Ultra, Quadro FX 5600, Quadro FX 4600, GeForce 8600 GTS,
GeForce 8600 GT, GeForce 8600 GT, GeForce 8400 GS, GeForce 9500M GS,
GeForce 8600M GT, GeForce 8700M GT, Quadro FX 370, Quadro NVS 320M,
Quadro FX 570M, Quadro FX 1600M, Quadro FX 570, Quadro FX 1700,
GeForce 8400 SE, GeForce 8500 GT, GeForce 8400 GS, GeForce 8300 GS,
GeForce 8400 GS, GeForce 8600M GS, GeForce 8400M GT,
GeForce 8400M GS, GeForce 8400M G, Quadro NVS 140M, Quadro NVS 130M,
Quadro NVS 135M, Quadro FX 360M, Quadro NVS 290,
GeForce 8800 GTS 512, GeForce 8800 GT, GeForce 9800 GX2,
GeForce 8800 GS, GeForce 8800M GTS, GeForce 8800M GTX,
GeForce 8800 GS, GeForce 9600 GSO, GeForce 8800 GT, GeForce 9800 GTX,
Quadro FX 3700, Quadro FX 3600M, GeForce 9600 GT, GeForce 9600 GS,
GeForce 8400 GS
(II) Primary Device is: PCI 01:00:0
(–) Assigning device section with no busID to primary device
(–) Chipset GeForce 6200 TurboCache™ found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[15] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[16] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[17] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[18] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[19] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[20] -1 0 0x0000c400 - 0x0000c4ff (0x100) IX[B]
[21] -1 0 0x0000c000 - 0x0000c00f (0x10) IX[B]
[22] -1 0 0x0000bc00 - 0x0000bc03 (0x4) IX[B]
[23] -1 0 0x0000b800 - 0x0000b807 (0x8) IX[B]
[24] -1 0 0x0000b400 - 0x0000b403 (0x4) IX[B]
[25] -1 0 0x0000b000 - 0x0000b007 (0x8) IX[B]
[26] -1 0 0x0000d000 - 0x0000d007 (0x8) IX[B]
[27] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[28] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[29] -1 0 0x0000d400 - 0x0000d4ff (0x100) IX[B]
[30] -1 0 0x00004c40 - 0x00004c7f (0x40) IX[B]
[31] -1 0 0x00004c00 - 0x00004c3f (0x40) IX[B]
[32] -1 0 0x0000dc00 - 0x0000dc1f (0x20) IX[B]
[33] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[34] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) Loading sub module « int10 »
(II) LoadModule: « int10 »
(II) Loading /usr/lib/xorg/modules//libint10.so
(II) Module int10: vendor=« X.Org Foundation »
(II) NV(0): Initializing int10
(II) NV(0): Primary V_BIOS segment is: 0xc000
(–) NV(0): Chipset: « GeForce 6200 TurboCache™ »
() NV(0): Depth 24, (–) framebuffer bpp 32
(==) NV(0): RGB weight 888
(==) NV(0): Default visual is TrueColor
(II) Loading sub module « vgahw »
(II) LoadModule: « vgahw »
(II) Loading /usr/lib/xorg/modules//libvgahw.so
(II) Module vgahw: vendor=« X.Org Foundation »
compiled for 1.4.0.90, module version = 0.1.0
(==) NV(0): Using HW cursor
(–) NV(0): Linear framebuffer at 0xC0000000
(–) NV(0): MMIO registers at 0xD0000000
(II) Loading sub module « i2c »
(II) LoadModule: « i2c »(II) Module « i2c » already built-in
(II) Loading sub module « ddc »
(II) LoadModule: « ddc »(II) Module « ddc » already built-in
(II) NV(0): I2C bus « DDC » initialized.
(II) NV(0): Probing for analog device on output A…
(–) NV(0): …found one
(II) NV(0): Probing for analog device on output B…
(II) NV(0): Probing for EDID on I2C bus A…
(II) NV(0): I2C device « DDC:ddc2 » registered at address 0xA0.
(–) NV(0): DDC detected a CRT:
(II) NV(0): Manufacturer: PHL Model: 853 Serial#: 16843009
(II) NV(0): Year: 2007 Week: 44
(II) NV(0): EDID Version: 1.3
(II) NV(0): Analog Display Input, Input Voltage Level: 0.700/0.300 V
(II) NV(0): Sync: Separate
(II) NV(0): Max H-Image Size [cm]: horiz.: 47 vert.: 30
(II) NV(0): Gamma: 2.20
(II) NV(0): DPMS capabilities: Off; RGB/Color Display
(II) NV(0): Default color space is primary color space
(II) NV(0): First detailed timing is preferred mode
(II) NV(0): redX: 0.639 redY: 0.333 greenX: 0.289 greenY: 0.597
(II) NV(0): blueX: 0.153 blueY: 0.082 whiteX: 0.313 whiteY: 0.329
(II) NV(0): Supported VESA Video Modes:
(II) NV(0): 720x400@70Hz
(II) NV(0): 640x480@60Hz
(II) NV(0): 640x480@67Hz
(II) NV(0): 640x480@72Hz
(II) NV(0): 640x480@75Hz
(II) NV(0): 800x600@56Hz
(II) NV(0): 800x600@60Hz
(II) NV(0): 800x600@72Hz
(II) NV(0): 800x600@75Hz
(II) NV(0): 832x624@75Hz
(II) NV(0): 1024x768@60Hz
(II) NV(0): 1024x768@70Hz
(II) NV(0): 1024x768@75Hz
(II) NV(0): 1280x1024@75Hz
(II) NV(0): Manufacturer’s mask: 0
(II) NV(0): Supported Future Video Modes:
(II) NV(0): #0: hsize: 1680 vsize 1050 refresh: 60 vid: 179
(II) NV(0): #1: hsize: 1600 vsize 1200 refresh: 60 vid: 16553
(II) NV(0): #2: hsize: 1440 vsize 900 refresh: 75 vid: 3989
(II) NV(0): #3: hsize: 1440 vsize 900 refresh: 60 vid: 149
(II) NV(0): #4: hsize: 1280 vsize 720 refresh: 60 vid: 49281
(II) NV(0): #5: hsize: 1280 vsize 960 refresh: 60 vid: 16513
(II) NV(0): #6: hsize: 1152 vsize 864 refresh: 75 vid: 20337
(II) NV(0): #7: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
(II) NV(0): Supported additional Video Mode:
(II) NV(0): clock: 146.2 MHz Image Size: 474 x 296 mm
(II) NV(0): h_active: 1680 h_sync: 1784 h_sync_end 1960 h_blank_end 2240 h_border: 0
(II) NV(0): v_active: 1050 v_sync: 1053 v_sync_end 1059 v_blanking: 1089 v_border: 0
(II) NV(0): Serial No: CJ20744200757
(II) NV(0): Monitor name: Philips 220VW
(II) NV(0): Ranges: V min: 56 V max: 76 Hz, H min: 30 H max: 93 kHz, PixClock max 170 MHz
(II) NV(0): EDID (in hex):
(II) NV(0): 00ffffffffffff00410c530801010101
(II) NV(0): 2c110103082f1e782e9345a3554a9827
(II) NV(0): 155054bfef00b300a940950f950081c0
(II) NV(0): 8140714f818021399030621a274068b0
(II) NV(0): 3600da281100001c000000ff00434a32
(II) NV(0): 30373434323030373537000000fc0050
(II) NV(0): 68696c697073203232305657000000fd
(II) NV(0): 00384c1e5d11700a20323230575300ef
(II) NV(0): Probing for EDID on I2C bus B…
(II) NV(0): I2C device « DDC:ddc2 » removed.
(II) NV(0): … none found
(–) NV(0): CRTC 0 appears to have a CRT attached
(II) NV(0): Using CRT on CRTC 0
(II) NV(0): EDID vendor « PHL », prod id 2131
(II) NV(0): Using hsync ranges from config file
(II) NV(0): Using vrefresh ranges from config file
(II) NV(0): Printing DDC gathered Modelines:
(II) NV(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz)
(II) NV(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
(II) NV(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
(II) NV(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
(II) NV(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 491 520 -hsync -vsync (37.9 kHz)
(II) NV(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz)
(II) NV(0): Modeline "640x480"x0.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
(II) NV(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
(II) NV(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz)
(II) NV(0): Modeline "1024x768"x0.0 78.80 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.1 kHz)
(II) NV(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
(II) NV(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
(II) NV(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
(II) NV(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
(II) NV(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
(II) NV(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz)
(II) NV(0): Modeline "1600x1200"x59.9 161.00 1600 1712 1880 2160 1200 1203 1207 1245 -hsync +vsync (74.5 kHz)
(II) NV(0): Modeline "1440x900"x75.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz)
(II) NV(0): Modeline "1440x900"x59.9 106.50 1440 1528 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz)
(II) NV(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz)
(II) NV(0): Modeline "1280x960"x59.9 101.25 1280 1360 1488 1696 960 963 967 996 -hsync +vsync (59.7 kHz)
(II) NV(0): Modeline "1152x864"x74.8 104.00 1152 1224 1344 1536 864 867 871 905 -hsync +vsync (67.7 kHz)
(II) NV(0): Modeline "1280x1024"x59.9 109.00 1280 1368 1496 1712 1024 1027 1034 1063 -hsync +vsync (63.7 kHz)
(–) NV(0): VideoRAM: 65536 kBytes
(==) NV(0): Using gamma correction (1.0, 1.0, 1.0)
(II) NV(0): Generic Monitor: Using hsync range of 30.00-93.00 kHz
(II) NV(0): Generic Monitor: Using vrefresh range of 56.00-76.00 Hz
(II) NV(0): Generic Monitor: Using maximum pixel clock of 170.00 MHz
(II) NV(0): Clock range: 12.00 to 400.00 MHz
(II) NV(0): Not using default mode « 640x350 » (vrefresh out of range)
(II) NV(0): Not using default mode « 320x175 » (vrefresh out of range)
(II) NV(0): Not using default mode « 640x400 » (vrefresh out of range)
(II) NV(0): Not using default mode « 320x200 » (vrefresh out of range)
(II) NV(0): Not using default mode « 720x400 » (vrefresh out of range)
(II) NV(0): Not using default mode « 360x200 » (vrefresh out of range)
(II) NV(0): Not using default mode « 640x480 » (vrefresh out of range)
(II) NV(0): Not using default mode « 320x240 » (vrefresh out of range)
(II) NV(0): Not using default mode « 800x600 » (vrefresh out of range)
(II) NV(0): Not using default mode « 400x300 » (vrefresh out of range)
(II) NV(0): Not using default mode « 1024x768 » (vrefresh out of range)
(II) NV(0): Not using default mode « 512x384 » (vrefresh out of range)
(II) NV(0): Not using default mode « 1280x960 » (vrefresh out of range)
(II) NV(0): Not using default mode « 1280x1024 » (vrefresh out of range)
(II) NV(0): Not using default mode « 640x512 » (vrefresh out of range)
(II) NV(0): Not using default mode « 1600x1200 » (mode clock too high)
(II) NV(0): Not using default mode « 1600x1200 » (hsync out of range)
(II) NV(0): Not using default mode « 800x600 » (hsync out of range)
(II) NV(0): Not using default mode « 1792x1344 » (mode clock too high)
(II) NV(0): Not using default mode « 1792x1344 » (hsync out of range)
(II) NV(0): Not using default mode « 896x672 » (hsync out of range)
(II) NV(0): Not using default mode « 1856x1392 » (mode clock too high)
(II) NV(0): Not using default mode « 1856x1392 » (hsync out of range)
(II) NV(0): Not using default mode « 928x696 » (hsync out of range)
(II) NV(0): Not using default mode « 1920x1440 » (mode clock too high)
(II) NV(0): Not using default mode « 1920x1440 » (hsync out of range)
(II) NV(0): Not using default mode « 960x720 » (hsync out of range)
(II) NV(0): Not using default mode « 1152x768 » (vrefresh out of range)
(II) NV(0): Not using default mode « 576x384 » (vrefresh out of range)
(II) NV(0): Not using default mode « 1152x864 » (vrefresh out of range)
(II) NV(0): Not using default mode « 576x432 » (vrefresh out of range)
(II) NV(0): Not using default mode « 1400x1050 » (vrefresh out of range)
(II) NV(0): Not using default mode « 700x525 » (vrefresh out of range)
(II) NV(0): Not using default mode « 1920x1200 » (mode clock too high)
(II) NV(0): Not using default mode « 2048x1536 » (hsync out of range)
(II) NV(0): Not using default mode « 1024x768 » (hsync out of range)
(II) NV(0): Not using driver mode « 1600x1200 » (height too large for virtual size)
(II) NV(0): Not using default mode « 1600x1200 » (height too large for virtual size)
(–) NV(0): Virtual size is 1680x1050 (pitch 1680)
() NV(0): *Driver mode « 1680x1050 »: 146.2 MHz, 65.3 kHz, 60.0 Hz
() NV(0): Driver mode « 1680x1050 »: 146.2 MHz, 65.3 kHz, 60.0 Hz
() NV(0): Default mode « 1680x1050 »: 147.1 MHz, 65.2 kHz, 60.0 Hz
(II) NV(0): Modeline "1680x1050"x60.0 147.14 1680 1784 1968 2256 1050 1051 1054 1087 (65.2 kHz)
() NV(0): Default mode « 1400x1050 »: 155.8 MHz, 81.5 kHz, 74.8 Hz
(II) NV(0): Modeline "1400x1050"x74.8 155.80 1400 1464 1784 1912 1050 1052 1064 1090 +hsync +vsync (81.5 kHz)
() NV(0): Default mode « 1400x1050 »: 151.0 MHz, 77.0 kHz, 70.0 Hz
(II) NV(0): Modeline "1400x1050"x70.0 151.00 1400 1464 1656 1960 1050 1051 1054 1100 +hsync +vsync (77.0 kHz)
() NV(0): Default mode « 1400x1050 »: 122.0 MHz, 64.9 kHz, 60.0 Hz
(II) NV(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz)
() NV(0): Driver mode « 1280x1024 »: 135.0 MHz, 80.0 kHz, 75.0 Hz
(II) NV(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz)
() NV(0): Driver mode « 1280x1024 »: 109.0 MHz, 63.7 kHz, 59.9 Hz
() NV(0): Default mode « 1280x1024 »: 135.0 MHz, 80.0 kHz, 75.0 Hz
() NV(0): Default mode « 1280x1024 »: 108.0 MHz, 64.0 kHz, 60.0 Hz
(II) NV(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
() NV(0): Driver mode « 1440x900 »: 136.8 MHz, 70.6 kHz, 75.0 Hz
() NV(0): Driver mode « 1440x900 »: 106.5 MHz, 55.9 kHz, 59.9 Hz
() NV(0): Default mode « 1440x900 »: 108.8 MHz, 56.9 kHz, 60.2 Hz
(II) NV(0): Modeline "1440x900"x60.2 108.84 1440 1472 1880 1912 900 918 927 946 +hsync +vsync (56.9 kHz)
() NV(0): Driver mode « 1280x960 »: 101.2 MHz, 59.7 kHz, 59.9 Hz
() NV(0): Default mode « 1280x960 »: 108.0 MHz, 60.0 kHz, 60.0 Hz
(II) NV(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz)
() NV(0): Default mode « 1280x800 »: 83.5 MHz, 49.7 kHz, 60.0 Hz
(II) NV(0): Modeline "1280x800"x60.0 83.46 1280 1344 1480 1680 800 801 804 828 (49.7 kHz)
() NV(0): Driver mode « 1152x864 »: 104.0 MHz, 67.7 kHz, 74.8 Hz
() NV(0): Default mode « 1152x864 »: 108.0 MHz, 67.5 kHz, 75.0 Hz
(II) NV(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz)
() NV(0): Default mode « 1280x768 »: 80.1 MHz, 47.7 kHz, 60.0 Hz
(II) NV(0): Modeline "1280x768"x60.0 80.14 1280 1344 1480 1680 768 769 772 795 (47.7 kHz)
() NV(0): Driver mode « 1280x720 »: 74.5 MHz, 44.8 kHz, 59.9 Hz
() NV(0): Driver mode « 1024x768 »: 78.8 MHz, 60.1 kHz, 75.1 Hz
(II) NV(0): Modeline "1024x768"x75.1 78.80 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.1 kHz)
() NV(0): Driver mode « 1024x768 »: 75.0 MHz, 56.5 kHz, 70.1 Hz
(II) NV(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
() NV(0): Driver mode « 1024x768 »: 65.0 MHz, 48.4 kHz, 60.0 Hz
(II) NV(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
() NV(0): Default mode « 1024x768 »: 78.8 MHz, 60.0 kHz, 75.0 Hz
(II) NV(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
() NV(0): Default mode « 1024x768 »: 75.0 MHz, 56.5 kHz, 70.1 Hz
() NV(0): Default mode « 1024x768 »: 65.0 MHz, 48.4 kHz, 60.0 Hz
() NV(0): Default mode « 960x720 »: 117.0 MHz, 90.0 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "960x720"x60.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz)
() NV(0): Default mode « 928x696 »: 109.2 MHz, 86.4 kHz, 60.1 Hz (D)
(II) NV(0): Modeline "928x696"x60.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz)
() NV(0): Default mode « 896x672 »: 102.4 MHz, 83.7 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "896x672"x60.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz)
() NV(0): Default mode « 960x600 »: 115.0 MHz, 91.0 kHz, 72.8 Hz (D)
(II) NV(0): Modeline "960x600"x72.8 115.00 960 968 1048 1264 600 600 602 625 doublescan -hsync -vsync (91.0 kHz)
() NV(0): Default mode « 960x600 »: 96.6 MHz, 74.5 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "960x600"x60.0 96.58 960 1024 1128 1296 600 600 602 621 doublescan (74.5 kHz)
() NV(0): Driver mode « 832x624 »: 57.3 MHz, 49.7 kHz, 74.6 Hz
(II) NV(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
() NV(0): Default mode « 832x624 »: 57.3 MHz, 49.7 kHz, 74.6 Hz
() NV(0): Driver mode « 800x600 »: 49.5 MHz, 46.9 kHz, 75.0 Hz
(II) NV(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
() NV(0): Driver mode « 800x600 »: 50.0 MHz, 48.1 kHz, 72.2 Hz
(II) NV(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
() NV(0): Driver mode « 800x600 »: 40.0 MHz, 37.9 kHz, 60.3 Hz
(II) NV(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
() NV(0): Driver mode « 800x600 »: 36.0 MHz, 35.2 kHz, 56.2 Hz
(II) NV(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
() NV(0): Default mode « 800x600 »: 49.5 MHz, 46.9 kHz, 75.0 Hz
() NV(0): Default mode « 800x600 »: 101.2 MHz, 93.8 kHz, 75.0 Hz (D)
(II) NV(0): Modeline "800x600"x75.0 101.25 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (93.8 kHz)
() NV(0): Default mode « 800x600 »: 50.0 MHz, 48.1 kHz, 72.2 Hz
() NV(0): Default mode « 800x600 »: 94.5 MHz, 87.5 kHz, 70.0 Hz (D)
(II) NV(0): Modeline "800x600"x70.0 94.50 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (87.5 kHz)
() NV(0): Default mode « 800x600 »: 87.8 MHz, 81.2 kHz, 65.0 Hz (D)
(II) NV(0): Modeline "800x600"x65.0 87.75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (81.2 kHz)
() NV(0): Default mode « 800x600 »: 40.0 MHz, 37.9 kHz, 60.3 Hz
() NV(0): Default mode « 800x600 »: 81.0 MHz, 75.0 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "800x600"x60.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz)
() NV(0): Default mode « 800x600 »: 36.0 MHz, 35.2 kHz, 56.2 Hz
() NV(0): Default mode « 840x525 »: 73.6 MHz, 65.2 kHz, 60.1 Hz (D)
(II) NV(0): Modeline "840x525"x60.1 73.57 840 892 984 1128 525 525 527 543 doublescan (65.2 kHz)
() NV(0): Default mode « 700x525 »: 77.9 MHz, 81.5 kHz, 74.8 Hz (D)
(II) NV(0): Modeline "700x525"x74.8 77.90 700 732 892 956 525 526 532 545 doublescan +hsync +vsync (81.5 kHz)
() NV(0): Default mode « 700x525 »: 75.5 MHz, 77.0 kHz, 70.0 Hz (D)
(II) NV(0): Modeline "700x525"x70.0 75.50 700 732 828 980 525 525 527 550 doublescan +hsync +vsync (77.0 kHz)
() NV(0): Default mode « 700x525 »: 61.0 MHz, 64.9 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "700x525"x60.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz)
() NV(0): Default mode « 640x512 »: 67.5 MHz, 80.0 kHz, 75.0 Hz (D)
(II) NV(0): Modeline "640x512"x75.0 67.50 640 648 720 844 512 512 514 533 doublescan +hsync +vsync (80.0 kHz)
() NV(0): Default mode « 640x512 »: 54.0 MHz, 64.0 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "640x512"x60.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz)
() NV(0): Default mode « 720x450 »: 54.4 MHz, 56.9 kHz, 60.2 Hz (D)
(II) NV(0): Modeline "720x450"x60.2 54.42 720 736 940 956 450 459 463 473 doublescan +hsync +vsync (56.9 kHz)
() NV(0): Driver mode « 640x480 »: 31.5 MHz, 37.5 kHz, 75.0 Hz
(II) NV(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
() NV(0): Driver mode « 640x480 »: 31.5 MHz, 37.9 kHz, 72.8 Hz
(II) NV(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 491 520 -hsync -vsync (37.9 kHz)
() NV(0): Driver mode « 640x480 »: 30.2 MHz, 35.0 kHz, 66.7 Hz
(II) NV(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz)
() NV(0): Driver mode « 640x480 »: 25.2 MHz, 31.5 kHz, 60.0 Hz
(II) NV(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
() NV(0): Default mode « 640x480 »: 31.5 MHz, 37.5 kHz, 75.0 Hz
() NV(0): Default mode « 640x480 »: 31.5 MHz, 37.9 kHz, 72.8 Hz
(II) NV(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
() NV(0): Default mode « 640x480 »: 54.0 MHz, 60.0 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "640x480"x60.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz)
() NV(0): Default mode « 640x480 »: 25.2 MHz, 31.5 kHz, 59.9 Hz
(II) NV(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
() NV(0): Driver mode « 720x400 »: 28.3 MHz, 31.5 kHz, 70.1 Hz
(II) NV(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
() NV(0): Default mode « 640x400 »: 41.7 MHz, 49.7 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "640x400"x60.0 41.73 640 672 740 840 400 400 402 414 doublescan (49.7 kHz)
() NV(0): Default mode « 576x432 »: 54.0 MHz, 67.5 kHz, 75.0 Hz (D)
(II) NV(0): Modeline "576x432"x75.0 54.00 576 608 672 800 432 432 434 450 doublescan +hsync +vsync (67.5 kHz)
() NV(0): Default mode « 640x384 »: 40.1 MHz, 47.7 kHz, 60.1 Hz (D)
(II) NV(0): Modeline "640x384"x60.1 40.07 640 672 740 840 384 384 386 397 doublescan (47.7 kHz)
() NV(0): Default mode « 512x384 »: 39.4 MHz, 60.0 kHz, 75.0 Hz (D)
(II) NV(0): Modeline "512x384"x75.0 39.38 512 520 568 656 384 384 386 400 doublescan +hsync +vsync (60.0 kHz)
() NV(0): Default mode « 512x384 »: 37.5 MHz, 56.5 kHz, 70.1 Hz (D)
(II) NV(0): Modeline "512x384"x70.1 37.50 512 524 592 664 384 385 388 403 doublescan -hsync -vsync (56.5 kHz)
() NV(0): Default mode « 512x384 »: 32.5 MHz, 48.4 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "512x384"x60.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz)
() NV(0): Default mode « 416x312 »: 28.6 MHz, 49.7 kHz, 74.7 Hz (D)
(II) NV(0): Modeline "416x312"x74.7 28.64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync (49.7 kHz)
() NV(0): Default mode « 400x300 »: 24.8 MHz, 46.9 kHz, 75.1 Hz (D)
(II) NV(0): Modeline "400x300"x75.1 24.75 400 408 448 528 300 300 302 312 doublescan +hsync +vsync (46.9 kHz)
() NV(0): Default mode « 400x300 »: 25.0 MHz, 48.1 kHz, 72.2 Hz (D)
(II) NV(0): Modeline "400x300"x72.2 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync (48.1 kHz)
() NV(0): Default mode « 400x300 »: 20.0 MHz, 37.9 kHz, 60.3 Hz (D)
(II) NV(0): Modeline "400x300"x60.3 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz)
() NV(0): Default mode « 400x300 »: 18.0 MHz, 35.2 kHz, 56.3 Hz (D)
(II) NV(0): Modeline "400x300"x56.3 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz)
() NV(0): Default mode « 320x240 »: 15.8 MHz, 37.5 kHz, 75.0 Hz (D)
(II) NV(0): Modeline "320x240"x75.0 15.75 320 328 360 420 240 240 242 250 doublescan -hsync -vsync (37.5 kHz)
() NV(0): Default mode « 320x240 »: 15.8 MHz, 37.9 kHz, 72.8 Hz (D)
(II) NV(0): Modeline "320x240"x72.8 15.75 320 332 352 416 240 244 246 260 doublescan -hsync -vsync (37.9 kHz)
() NV(0): Default mode « 320x240 »: 12.6 MHz, 31.5 kHz, 60.1 Hz (D)
(II) NV(0): Modeline "320x240"x60.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz)
() NV(0): Display dimensions: (470, 300) mm
() NV(0): DPI set to (90, 88)
(II) Loading sub module « fb »
(II) LoadModule: « fb »
(II) Loading /usr/lib/xorg/modules//libfb.so
(II) Module fb: vendor=« X.Org Foundation »
ABI class: X.Org ANSI C Emulation, version 0.3
(II) Loading sub module « xaa »
(II) LoadModule: « xaa »
(II) Loading /usr/lib/xorg/modules//libxaa.so
(II) Module xaa: vendor=« X.Org Foundation »
compiled for 1.4.0.90, module version = 1.2.0
(II) Loading sub module « ramdac »
(II) LoadModule: « ramdac »(II) Module « ramdac » already built-in
(–) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don’t.
(II) resource ranges after preInit:
[0] 0 0 0xd1000000 - 0xd1ffffff (0x1000000) MX[B]
[1] 0 0 0xc0000000 - 0xcfffffff (0x10000000) MX[B]
[2] 0 0 0xd0000000 - 0xd0ffffff (0x1000000) MX[B]
[3] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[4] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[5] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[6] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[7] -1 0 0xd4004000 - 0xd4007fff (0x4000) MX[B]
[8] -1 0 0xd4000000 - 0xd4003fff (0x4000) MX[B]
[9] -1 0 0xd4009000 - 0xd40097ff (0x800) MX[B]
[10] -1 0 0xd4008000 - 0xd40083ff (0x400) MX[B]
[11] -1 0 0xd5000000 - 0xd5000fff (0x1000) MX[B]
[12] -1 0 0xd5001000 - 0xd5001fff (0x1000) MX[B]
[13] -1 0 0xfeb00000 - 0xfeb000ff (0x100) MX[B]
[14] -1 0 0xd5002000 - 0xd5002fff (0x1000) MX[B]
[15] -1 0 0xd1000000 - 0xd1ffffff (0x1000000) MXB
[16] -1 0 0xc0000000 - 0xcfffffff (0x10000000) MXB
[17] -1 0 0xd0000000 - 0xd0ffffff (0x1000000) MXB
[18] 0 0 0x000a0000 - 0x000affff (0x10000) MSB
[19] 0 0 0x000b0000 - 0x000b7fff (0x8000) MSB
[20] 0 0 0x000b8000 - 0x000bffff (0x8000) MSB
[21] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[22] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[23] -1 0 0x0000c400 - 0x0000c4ff (0x100) IX[B]
[24] -1 0 0x0000c000 - 0x0000c00f (0x10) IX[B]
[25] -1 0 0x0000bc00 - 0x0000bc03 (0x4) IX[B]
[26] -1 0 0x0000b800 - 0x0000b807 (0x8) IX[B]
[27] -1 0 0x0000b400 - 0x0000b403 (0x4) IX[B]
[28] -1 0 0x0000b000 - 0x0000b007 (0x8) IX[B]
[29] -1 0 0x0000d000 - 0x0000d007 (0x8) IX[B]
[30] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[31] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[32] -1 0 0x0000d400 - 0x0000d4ff (0x100) IX[B]
[33] -1 0 0x00004c40 - 0x00004c7f (0x40) IX[B]
[34] -1 0 0x00004c00 - 0x00004c3f (0x40) IX[B]
[35] -1 0 0x0000dc00 - 0x0000dc1f (0x20) IX[B]
[36] 0 0 0x000003b0 - 0x000003bb (0xc) ISB
[37] 0 0 0x000003c0 - 0x000003df (0x20) ISB
(==) NV(0): Write-combining range (0xc0000000,0x4000000)
(II) NV(0): Using XFree86 Acceleration Architecture (XAA)
Screen to screen bit blits
Solid filled rectangles
8x8 mono pattern filled rectangles
Indirect CPU to Screen color expansion
Solid Lines
Scanline Image Writes
Offscreen Pixmaps
Setting up tile and stipple cache:
32 128x128 slots
32 256x256 slots
16 512x512 slots
(==) NV(0): Backing store disabled
(==) NV(0): Silken mouse enabled
() Option « dpms »
() NV(0): DPMS enabled
(WW) NV(0): Option « nologo » is not used
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension XAccessControlExtension
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
(EE) Failed to initialize GLX extension (Compatible NVIDIA X driver not found)
() Option « CoreKeyboard »
() Generic Keyboard: always reports core events
() Option « Protocol » « standard »
() Generic Keyboard: Protocol: standard
() Option « AutoRepeat » « 500 30 »
() Option « XkbRules » « xorg »
() Generic Keyboard: XkbRules: « xorg »
() Option « XkbModel » « pc105 »
() Generic Keyboard: XkbModel: « pc105 »
() Option « XkbLayout » « fr »
() Generic Keyboard: XkbLayout: « fr »
() Option « CustomKeycodes » « off »
() Generic Keyboard: CustomKeycodes disabled
() Option « Protocol » « ImPS/2 »
() Configured Mouse: Device: « /dev/input/mice »
() Configured Mouse: Protocol: « ImPS/2 »
() Option « CorePointer »
() Configured Mouse: always reports core events
() Option « Device » « /dev/input/mice »
() Option « Emulate3Buttons » « true »
() Configured Mouse: Emulate3Buttons, Emulate3Timeout: 50
() Configured Mouse: ZAxisMapping: buttons 4 and 5
() Configured Mouse: Buttons: 9
() Configured Mouse: Sensitivity: 1
(II) evaluating device (Configured Mouse)
(II) XINPUT: Adding extended input device « Configured Mouse » (type: MOUSE)
(II) evaluating device (Generic Keyboard)
(II) XINPUT: Adding extended input device « Generic Keyboard » (type: KEYBOARD)
(II) Configured Mouse: ps2EnableDataReporting: succeeded
