Resolution nvidia noyau 3.2.0-3-686-pae
Bonjour, j’utilise une crunchbang (à la base) mais maintenant basée sur les dépôts de sid. Depuis que j’ai fait une mise à jour du noyau (3.2.0-2 vers 3.2.0-3), je ne peux plus changer de résolution d’écran (que ce soit avec grandr, nvidia-settings ou dans les settings d’un jeu full screen) : c’est 1920x1080 obligatoire (pas d’autres résolutions dans les menus).
Par exemple :$ xrandr -s 1024x768 Size 1024x768 not found in available modes
QQues infos complémentaires :
lowje@byiiana:~$ uname -r 3.2.0-3-686-pae
lowje@byiiana:~$ xrandr Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 16384 x 16384 VGA-0 disconnected (normal left inverted right x axis y axis) LVDS-0 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 193mm 1920x1080 60.0*+ HDMI-0 disconnected (normal left inverted right x axis y axis) lowje@byiiana:~$
[code]lowje@byiiana:~$ cat /var/log/Xorg.0.log
[ 7.821]
X.Org X Server 1.12.1.902 (1.12.2 RC 2)
Release Date: 2012-05-19
[ 7.821] X Protocol Version 11, Revision 0
[ 7.821] Build Operating System: Linux 2.6.32-5-686-bigmem i686 Debian
[ 7.821] Current Operating System: Linux byiiana 3.2.0-3-686-pae #1 SMP Thu Jun 28 08:56:46 UTC 2012 i686
[ 7.821] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-3-686-pae root=UUID=b8ea81df-42c7-403c-a4e1-72d168bfefa1 ro quiet
[ 7.821] Build Date: 20 May 2012 10:23:38AM
[ 7.821] xorg-server 2:1.12.1.902-1 (Cyril Brulebois kibi@debian.org)
[ 7.821] Current version of pixman: 0.26.0
[ 7.821] Before reporting problems, check http://wiki.x.org
[ 7.821] Markers: (–) probed, () from config file, (==) default setting,
[ 7.822] (==) Log file: “/var/log/Xorg.0.log”, Time: Wed Jul 4 17:35:06 2012
[ 7.823] (==) Using config file: “/etc/X11/xorg.conf”
[ 7.823] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 7.824] (==) ServerLayout “Layout0”
[ 7.824] (
) |–>Screen “Screen0” (0)
[ 7.824] () | |–>Monitor “Monitor0”
[ 7.825] (
) | |–>Device “Device0”
[ 7.825] () |–>Input Device “Keyboard0”
[ 7.825] (
) |–>Input Device “Mouse0”
[ 7.825] (==) Automatically adding devices
[ 7.825] (==) Automatically enabling devices
[ 7.827] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 7.827] Entry deleted from font path.
[ 7.829] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,
built-ins
[ 7.829] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 7.829] (WW) Hotplugging is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
[ 7.829] (WW) Disabling Keyboard0
[ 7.829] (WW) Disabling Mouse0
[ 7.829] (II) Loader magic: 0xb771e5a0
[ 7.829] (II) Module ABI versions:
[ 7.829] X.Org ANSI C Emulation: 0.4
[ 7.829] X.Org Video Driver: 12.0
[ 7.829] X.Org XInput driver : 16.0
[ 7.829] X.Org Server Extension : 6.0
[ 7.830] (–) PCI:*(0:1:0:0) 10de:0df4:14c0:0059 rev 161, Mem @ 0xc2000000/16777216, 0xb0000000/268435456, 0xc0000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x???/524288
[ 7.830] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 7.830] (II) LoadModule: “extmod”
[ 7.833] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[ 7.834] (II) Module extmod: vendor=“X.Org Foundation”
[ 7.834] compiled for 1.12.1.902, module version = 1.0.0
[ 7.834] Module class: X.Org Server Extension
[ 7.834] ABI class: X.Org Server Extension, version 6.0
[ 7.834] (II) Loading extension SELinux
[ 7.834] (II) Loading extension MIT-SCREEN-SAVER
[ 7.834] (II) Loading extension XFree86-VidModeExtension
[ 7.834] (II) Loading extension XFree86-DGA
[ 7.834] (II) Loading extension DPMS
[ 7.834] (II) Loading extension XVideo
[ 7.834] (II) Loading extension XVideo-MotionCompensation
[ 7.834] (II) Loading extension X-Resource
[ 7.834] (II) LoadModule: “dbe”
[ 7.835] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[ 7.835] (II) Module dbe: vendor=“X.Org Foundation”
[ 7.835] compiled for 1.12.1.902, module version = 1.0.0
[ 7.835] Module class: X.Org Server Extension
[ 7.835] ABI class: X.Org Server Extension, version 6.0
[ 7.835] (II) Loading extension DOUBLE-BUFFER
[ 7.835] (II) LoadModule: “glx”
[ 7.836] (II) Loading /usr/lib/xorg/modules/linux/libglx.so
[ 7.926] (II) Module glx: vendor=“NVIDIA Corporation”
[ 7.926] compiled for 4.0.2, module version = 1.0.0
[ 7.926] Module class: X.Org Server Extension
[ 7.926] (II) NVIDIA GLX Module 302.17 Tue Jun 12 18:58:55 PDT 2012
[ 7.926] (II) Loading extension GLX
[ 7.926] (II) LoadModule: “record”
[ 7.927] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[ 7.927] (II) Module record: vendor=“X.Org Foundation”
[ 7.927] compiled for 1.12.1.902, module version = 1.13.0
[ 7.927] Module class: X.Org Server Extension
[ 7.927] ABI class: X.Org Server Extension, version 6.0
[ 7.927] (II) Loading extension RECORD
[ 7.927] (II) LoadModule: “dri”
[ 7.928] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[ 7.929] (II) Module dri: vendor=“X.Org Foundation”
[ 7.929] compiled for 1.12.1.902, module version = 1.0.0
[ 7.929] ABI class: X.Org Server Extension, version 6.0
[ 7.929] (II) Loading extension XFree86-DRI
[ 7.929] (II) LoadModule: “dri2”
[ 7.929] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 7.929] (II) Module dri2: vendor=“X.Org Foundation”
[ 7.929] compiled for 1.12.1.902, module version = 1.2.0
[ 7.929] (II) Loading extension DRI2
[ 7.929] (II) LoadModule: “nvidia”
[ 7.930] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 7.935] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 7.935] compiled for 4.0.2, module version = 1.0.0
[ 7.935] Module class: X.Org Video Driver
[ 7.937] (II) NVIDIA dlloader X Driver 302.17 Tue Jun 12 18:39:24 PDT 2012
[ 7.937] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 7.937] (++) using VT number 7
[ 7.955] (II) Loading sub module “fb”
[ 7.955] (II) LoadModule: “fb”
[ 7.955] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 7.956] (II) Module fb: vendor=“X.Org Foundation”
[ 7.956] compiled for 1.12.1.902, module version = 1.0.0
[ 7.956] ABI class: X.Org ANSI C Emulation, version 0.4
[ 7.956] (II) Loading sub module “wfb”
[ 7.956] (II) LoadModule: “wfb”
[ 7.956] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 7.957] (II) Module wfb: vendor=“X.Org Foundation”
[ 7.957] compiled for 1.12.1.902, module version = 1.0.0
[ 7.957] ABI class: X.Org ANSI C Emulation, version 0.4
[ 7.957] (II) Loading sub module “ramdac”
[ 7.957] (II) LoadModule: “ramdac”
[ 7.958] (II) Module “ramdac” already built-in
[ 7.960] () NVIDIA(0): Depth 24, (–) framebuffer bpp 32
[ 7.960] (==) NVIDIA(0): RGB weight 888
[ 7.960] (==) NVIDIA(0): Default visual is TrueColor
[ 7.960] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 7.960] (
) NVIDIA(0): Option “DPI” “96 x 96”
[ 7.960] () NVIDIA(0): Option “OnDemandVBlankInterrupts” “1”
[ 7.960] (
) NVIDIA(0): Enabling 2D acceleration
[ 9.012] (II) NVIDIA(0): NVIDIA GPU GeForce GT 540M (GF108) at PCI:1:0:0 (GPU-0)
[ 9.012] (–) NVIDIA(0): Memory: 2097152 kBytes
[ 9.012] (–) NVIDIA(0): VideoBIOS: 70.08.3c.00.18
[ 9.012] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 9.012] (–) NVIDIA(0): Interlaced video modes are supported on this GPU
[ 9.018] (–) NVIDIA(0): Valid display device(s) on GeForce GT 540M at PCI:1:0:0
[ 9.018] (–) NVIDIA(0): CRT-0
[ 9.019] (–) NVIDIA(0): AU Optronics Corporation (DFP-0) (connected)
[ 9.019] (–) NVIDIA(0): DFP-1
[ 9.019] (–) NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
[ 9.019] (–) NVIDIA(0): AU Optronics Corporation (DFP-0): 330.0 MHz maximum pixel clock
[ 9.019] (–) NVIDIA(0): AU Optronics Corporation (DFP-0): Internal Dual Link LVDS
[ 9.019] (–) NVIDIA(0): DFP-1: 165.0 MHz maximum pixel clock
[ 9.019] (–) NVIDIA(0): DFP-1: Internal Single Link TMDS
[ 9.019] () NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 9.019] (
) NVIDIA(0): device AU Optronics Corporation (DFP-0) (Using EDID
[ 9.019] () NVIDIA(0): frequencies has been enabled on all display devices.)
[ 9.019] (==) NVIDIA(0):
[ 9.019] (==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
[ 9.019] (==) NVIDIA(0): will be used as the requested mode.
[ 9.019] (II) NVIDIA(0): Validated modes:
[ 9.020] (II) NVIDIA(0): “DFP-0:nvidia-auto-select”
[ 9.020] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[ 10.088] (
) NVIDIA(0): DPI set to (96, 96); computed from “DPI” X config option
[ 10.091] (–) Depth 24 pixmap format is 32 bpp
[ 10.091] (II) NVIDIA: Using 1024.00 MB of virtual memory for indirect memory
[ 10.091] (II) NVIDIA: access.
[ 10.152] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 10.152] (II) NVIDIA(0): may not be running or the “AcpidSocketPath” X
[ 10.152] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 10.152] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 10.152] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 10.152] (II) NVIDIA(0): details, please see the “ConnectToAcpid” and
[ 10.152] (II) NVIDIA(0): “AcpidSocketPath” X configuration options in Appendix B: X
[ 10.152] (II) NVIDIA(0): Config Options in the README.
[ 10.159] (II) NVIDIA(0): Setting mode “DFP-0:nvidia-auto-select”
[ 10.443] (II) Loading extension NV-GLX
[ 10.503] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 10.503] (==) NVIDIA(0): Backing store disabled
[ 10.503] (==) NVIDIA(0): Silken mouse enabled
[ 10.503] () NVIDIA(0): DPMS enabled
[ 10.503] (II) Loading extension NV-CONTROL
[ 10.504] (II) Loading extension XINERAMA
[ 10.504] (II) Loading sub module “dri2”
[ 10.504] (II) LoadModule: “dri2”
[ 10.504] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 10.504] (II) Module dri2: vendor=“X.Org Foundation”
[ 10.504] compiled for 1.12.1.902, module version = 1.2.0
[ 10.504] ABI class: X.Org Server Extension, version 6.0
[ 10.504] (II) NVIDIA(0): [DRI2] Setup complete
[ 10.504] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 10.504] (–) RandR disabled
[ 10.504] (II) Initializing built-in extension Generic Event Extension
[ 10.504] (II) Initializing built-in extension SHAPE
[ 10.504] (II) Initializing built-in extension MIT-SHM
[ 10.504] (II) Initializing built-in extension XInputExtension
[ 10.504] (II) Initializing built-in extension XTEST
[ 10.504] (II) Initializing built-in extension BIG-REQUESTS
[ 10.504] (II) Initializing built-in extension SYNC
[ 10.504] (II) Initializing built-in extension XKEYBOARD
[ 10.504] (II) Initializing built-in extension XC-MISC
[ 10.504] (II) Initializing built-in extension SECURITY
[ 10.504] (II) Initializing built-in extension XINERAMA
[ 10.504] (II) Initializing built-in extension XFIXES
[ 10.504] (II) Initializing built-in extension RENDER
[ 10.504] (II) Initializing built-in extension RANDR
[ 10.504] (II) Initializing built-in extension COMPOSITE
[ 10.504] (II) Initializing built-in extension DAMAGE
[ 10.504] (II) SELinux: Disabled on system
[ 10.505] (II) Initializing extension GLX
[ 10.567] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 10.567] (
) Power Button: Applying InputClass “evdev keyboard catchall”
[ 10.567] (II) LoadModule: “evdev”
[ 10.568] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 10.568] (II) Module evdev: vendor=“X.Org Foundation”
[ 10.568] compiled for 1.12.1, module version = 2.7.0
[ 10.568] Module class: X.Org XInput Driver
[ 10.568] ABI class: X.Org XInput driver, version 16.0
[ 10.568] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 10.568] () Power Button: always reports core events
[ 10.568] (
) evdev: Power Button: Device: “/dev/input/event3”
[ 10.569] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 10.569] (–) evdev: Power Button: Found keys
[ 10.569] (II) evdev: Power Button: Configuring as keyboard
[ 10.569] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3”
[ 10.569] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 10.569] (
) Option “xkb_rules” “evdev”
[ 10.569] () Option “xkb_model” “pc105”
[ 10.569] (
) Option “xkb_layout” “fr”
[ 10.569] () Option “xkb_variant” “latin9”
[ 10.616] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[ 10.616] (
) Sleep Button: Applying InputClass “evdev keyboard catchall”
[ 10.616] (II) Using input driver ‘evdev’ for ‘Sleep Button’
[ 10.616] () Sleep Button: always reports core events
[ 10.616] (
) evdev: Sleep Button: Device: “/dev/input/event2”
[ 10.616] (–) evdev: Sleep Button: Vendor 0 Product 0x3
[ 10.616] (–) evdev: Sleep Button: Found keys
[ 10.616] (II) evdev: Sleep Button: Configuring as keyboard
[ 10.616] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/PNP0C0E:00/input/input2/event2”
[ 10.616] (II) XINPUT: Adding extended input device “Sleep Button” (type: KEYBOARD, id 7)
[ 10.616] (
[ 10.617] () Option “xkb_model” “pc105”
[ 10.617] (
[ 10.617] () Option “xkb_variant” “latin9”
[ 10.618] (II) config/udev: Adding input device Video Bus (/dev/input/event6)
[ 10.618] (
) Video Bus: Applying InputClass “evdev keyboard catchall”
[ 10.618] (II) Using input driver ‘evdev’ for ‘Video Bus’
[ 10.618] () Video Bus: always reports core events
[ 10.618] (
) evdev: Video Bus: Device: “/dev/input/event6”
[ 10.618] (–) evdev: Video Bus: Vendor 0 Product 0x6
[ 10.618] (–) evdev: Video Bus: Found keys
[ 10.618] (II) evdev: Video Bus: Configuring as keyboard
[ 10.618] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/device:00/PNP0A08:00/device:2c/LNXVIDEO:00/input/input6/event6”
[ 10.618] (II) XINPUT: Adding extended input device “Video Bus” (type: KEYBOARD, id 8)
[ 10.618] (
[ 10.618] () Option “xkb_model” “pc105”
[ 10.618] (
[ 10.618] () Option “xkb_variant” “latin9”
[ 10.619] (II) config/udev: Adding input device Lid Switch (/dev/input/event1)
[ 10.619] (II) No input driver specified, ignoring this device.
[ 10.619] (II) This device may have been added with another device file.
[ 10.620] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event10)
[ 10.620] (II) No input driver specified, ignoring this device.
[ 10.620] (II) This device may have been added with another device file.
[ 10.621] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event11)
[ 10.621] (II) No input driver specified, ignoring this device.
[ 10.621] (II) This device may have been added with another device file.
[ 10.621] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event12)
[ 10.622] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event13)
[ 10.622] (II) No input driver specified, ignoring this device.
[ 10.622] (II) This device may have been added with another device file.
[ 10.623] (II) config/udev: Adding input device USB Camera Device (/dev/input/event5)
[ 10.623] (
) USB Camera Device: Applying InputClass “evdev keyboard catchall”
[ 10.623] (II) Using input driver ‘evdev’ for ‘USB Camera Device’
[ 10.623] () USB Camera Device: always reports core events
[ 10.623] (
) evdev: USB Camera Device: Device: “/dev/input/event5”
[ 10.623] (–) evdev: USB Camera Device: Vendor 0x174f Product 0x1441
[ 10.623] (–) evdev: USB Camera Device: Found keys
[ 10.623] (II) evdev: USB Camera Device: Configuring as keyboard
[ 10.623] () Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1.3/3-1.3:1.0/input/input5/event5”
[ 10.623] (II) XINPUT: Adding extended input device “USB Camera Device” (type: KEYBOARD, id 9)
[ 10.623] (
[ 10.623] () Option “xkb_model” “pc105”
[ 10.623] (
[ 10.623] () Option “xkb_variant” “latin9”
[ 10.624] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event7)
[ 10.624] (II) No input driver specified, ignoring this device.
[ 10.624] (II) This device may have been added with another device file.
[ 10.625] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event8)
[ 10.625] (II) No input driver specified, ignoring this device.
[ 10.625] (II) This device may have been added with another device file.
[ 10.625] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event9)
[ 10.626] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[ 10.626] (
) AT Translated Set 2 keyboard: Applying InputClass “evdev keyboard catchall”
[ 10.626] (II) Using input driver ‘evdev’ for ‘AT Translated Set 2 keyboard’
[ 10.626] () AT Translated Set 2 keyboard: always reports core events
[ 10.626] (
) evdev: AT Translated Set 2 keyboard: Device: “/dev/input/event0”
[ 10.626] (–) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[ 10.626] (–) evdev: AT Translated Set 2 keyboard: Found keys
[ 10.626] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[ 10.626] () Option “config_info” “udev:/sys/devices/platform/i8042/serio0/input/input0/event0”
[ 10.626] (II) XINPUT: Adding extended input device “AT Translated Set 2 keyboard” (type: KEYBOARD, id 10)
[ 10.626] (
[ 10.626] () Option “xkb_model” “pc105”
[ 10.626] (
[ 10.626] () Option “xkb_variant” “latin9”
[ 10.628] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event14)
[ 10.628] (
) SynPS/2 Synaptics TouchPad: Applying InputClass “evdev touchpad catchall”
[ 10.628] () SynPS/2 Synaptics TouchPad: Applying InputClass “touchpad catchall”
[ 10.628] (
) SynPS/2 Synaptics TouchPad: Applying InputClass “Default clickpad buttons”
[ 10.628] (II) LoadModule: “synaptics”
[ 10.628] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[ 10.630] (II) Module synaptics: vendor=“X.Org Foundation”
[ 10.630] compiled for 1.12.1.902, module version = 1.6.2
[ 10.630] Module class: X.Org XInput Driver
[ 10.630] ABI class: X.Org XInput driver, version 16.0
[ 10.630] (II) Using input driver ‘synaptics’ for ‘SynPS/2 Synaptics TouchPad’
[ 10.630] () SynPS/2 Synaptics TouchPad: always reports core events
[ 10.630] (
) Option “Device” “/dev/input/event14”
[ 10.820] (II) synaptics: SynPS/2 Synaptics TouchPad: ignoring touch events for semi-multitouch device
[ 10.820] (–) synaptics: SynPS/2 Synaptics TouchPad: x-axis range 1472 - 5608
[ 10.820] (–) synaptics: SynPS/2 Synaptics TouchPad: y-axis range 1408 - 4638
[ 10.820] (–) synaptics: SynPS/2 Synaptics TouchPad: pressure range 0 - 255
[ 10.820] (–) synaptics: SynPS/2 Synaptics TouchPad: finger width range 0 - 15
[ 10.820] (–) synaptics: SynPS/2 Synaptics TouchPad: buttons: left right double triple
[ 10.820] (–) synaptics: SynPS/2 Synaptics TouchPad: Vendor 0x2 Product 0x7
[ 10.820] (–) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[ 10.820] () SynPS/2 Synaptics TouchPad: always reports core events
[ 10.821] (
) Option “config_info” “udev:/sys/devices/platform/i8042/serio1/input/input14/event14”
[ 10.821] (II) XINPUT: Adding extended input device “SynPS/2 Synaptics TouchPad” (type: TOUCHPAD, id 11)
[ 10.821] () synaptics: SynPS/2 Synaptics TouchPad: (accel) MinSpeed is now constant deceleration 2.5
[ 10.821] (
) synaptics: SynPS/2 Synaptics TouchPad: MaxSpeed is now 1.75
[ 10.821] () synaptics: SynPS/2 Synaptics TouchPad: AccelFactor is now 0.038
[ 10.822] (
) SynPS/2 Synaptics TouchPad: (accel) keeping acceleration scheme 1
[ 10.822] () SynPS/2 Synaptics TouchPad: (accel) acceleration profile 1
[ 10.822] (
) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 10.822] () SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 10.822] (–) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[ 10.822] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[ 10.822] (
) SynPS/2 Synaptics TouchPad: Ignoring device from InputClass “touchpad ignore duplicates”
[ 10.823] (II) config/udev: Adding input device PC Speaker (/dev/input/event4)
[ 10.823] (II) No input driver specified, ignoring this device.
[ 10.823] (II) This device may have been added with another device file.
[ 16.103] () NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 16.103] (
[ 16.103] () NVIDIA(0): frequencies has been enabled on all display devices.)
[ 16.104] (
[ 16.104] () NVIDIA(0): device AU Optronics Corporation (DFP-0) (Using EDID
[ 16.104] (
[ 2248.210] () NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 2248.210] (
[ 2248.210] (**) NVIDIA(0): frequencies has been enabled on all display devices.)[/code]
lowje@byiiana:~$ lsmod Module Size Used by rfcomm 28590 0 bnep 17288 2 bluetooth 103750 10 bnep,rfcomm cpufreq_userspace 12520 0 cpufreq_stats 12762 0 cpufreq_powersave 12422 0 cpufreq_conservative 12987 0 loop 17810 0 fuse 52153 3 joydev 17010 0 snd_hda_codec_hdmi 26319 4 nvidia 9817158 33 snd_hda_codec_realtek 142221 1 arc4 12418 2 battery 12957 0 uvcvideo 56896 0 videodev 61658 1 uvcvideo media 13692 2 videodev,uvcvideo coretemp 12770 0 iwlwifi 146798 0 snd_hda_intel 21856 1 crc32c_intel 12659 0 mac80211 171359 1 iwlwifi snd_hda_codec 63477 3 snd_hda_intel,snd_hda_codec_realtek,snd_hda_codec_hdmi snd_hwdep 12943 1 snd_hda_codec aesni_intel 17913 1 snd_pcm 53390 3 snd_hda_codec,snd_hda_intel,snd_hda_codec_hdmi aes_i586 16608 1 aesni_intel snd_page_alloc 12867 2 snd_pcm,snd_hda_intel aes_generic 32970 2 aes_i586,aesni_intel cryptd 14125 1 aesni_intel cfg80211 117454 2 mac80211,iwlwifi psmouse 54927 0 iTCO_wdt 16945 0 snd_seq 39487 0 pcspkr 12515 0 serio_raw 12803 0 i2c_i801 12670 0 evdev 17225 7 snd_seq_device 13016 1 snd_seq iTCO_vendor_support 12632 1 iTCO_wdt snd_timer 22356 2 snd_seq,snd_pcm rfkill 18516 4 cfg80211,bluetooth ac 12552 0 snd 42691 11 snd_timer,snd_seq_device,snd_seq,snd_pcm,snd_hwdep,snd_hda_codec,snd_hda_intel,snd_hda_codec_realtek,snd_hda_codec_hdmi acpi_cpufreq 12807 1 power_supply 13283 2 ac,battery mperf 12421 1 acpi_cpufreq video 17412 0 i2c_core 19116 3 i2c_i801,videodev,nvidia soundcore 12921 1 snd processor 27565 1 acpi_cpufreq button 12817 0 ext4 302665 1 crc16 12327 2 ext4,bluetooth jbd2 52246 1 ext4 mbcache 12897 1 ext4 ums_realtek 13012 0 usb_storage 35142 1 ums_realtek uas 13096 0 sd_mod 35425 3 sr_mod 17468 0 crc_t10dif 12332 1 sd_mod cdrom 34813 1 sr_mod ehci_hcd 35509 0 ahci 20821 2 xhci_hcd 63573 0 libahci 18308 1 ahci libata 124981 2 libahci,ahci scsi_mod 135124 5 libata,sr_mod,sd_mod,uas,usb_storage usbcore 104352 7 xhci_hcd,ehci_hcd,uas,usb_storage,ums_realtek,uvcvideo r8169 41810 0 mii 12595 1 r8169 usb_common 12338 1 usbcore fan 12594 0 thermal 13103 0 thermal_sys 17752 4 thermal,fan,processor,video
J’ai aussi essayer d’ajouter des résolutions dans le /etc/x11/xorg.conf, section “Screen”, SubSection “Display” mais rien n’y fait :confused:
De plus, quand je boot avec un ancien noyau (en le choisissant dans GRUB), j’ai un message d’erreur qui me dit que le serveur X n’arrive pas à démarer (surement dû à une mauvaise configuration).
Je ne sais vraiment plus de quel côté chercher :s
et hop poste ton xorg.conf :wink:
Généré par nvidia-xconfig sauf une grosse partie de “Device” et la ligne “Modes”
[code]lowje@byiiana:~$ cat /etc/X11/xorg.conf
nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 302.17 (buildd@biber) Sat Jun 30 20:51:21 UTC 2012
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice “Keyboard0” "CoreKeyboard"
InputDevice “Mouse0” "CorePointer"
EndSection
Section "Files"
EndSection
Section “InputDevice”
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option “Protocol” "auto"
Option “Device” "/dev/psaux"
Option “Emulate3Buttons” "no"
Option “ZAxisMapping” "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName “NVIDIA Corporation”
# Disables Nvidia logo
#Option “NoLogo” “true”
# Fix Large fonts
# Power saving setting for Nvidia drivers
# Enables overclocking gui
#Option “Coolbits” "1"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
Modes “1920x1080” “1360x768” "1024x768"
EndSubSection
EndSection[/code]
Est ce que ce xorg.conf correspond au Xorg.log précédent ?
Ce que je vois dans ton log:
[quote]Using HorizSync/VertRefresh ranges from the EDID for display
[ 9.019] () NVIDIA(0): device AU Optronics Corporation (DFP-0) (Using EDID
[ 9.019] (
) NVIDIA(0): frequencies has been enabled on all display devices.)[/quote]
[quote][ 16.103] () NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 16.103] (
[ 16.104] (
[ 16.104] (
[ 2248.210] (
[ 2248.210] (**) NVIDIA(0): frequencies has been enabled on all display devices.)[/quote]
Si xrandr ne te propose das d’autre résolution, c’est que ton écran lui dit qu’il n’en supporte pas d’autres.
à toi de les forcer dans ton xorg.conf
Il y a aussi ça d’étrange:
perso je n’utilise pas de «Modes “1920x1080” “1360x768” “1024x768”» a la section screen et j’ai les mode bel et bien reconnu jusqu’au max , chez moi de 400600 au 1400 (j’arrondie évidement)
[quote=“piratebab”]Est ce que ce xorg.conf correspond au Xorg.log précédent ?[/quote]Oui
[quote=“piratebab”][ 9.019] () NVIDIA(0): device AU Optronics Corporation (DFP-0) (Using EDID
[ 9.019] (
Est-ce que tu pourrais m’éclairer sur ce que cela signifie (je vais faire des recherches sur ce qu’est l’EDID) ? :s
[quote=“piratebab”]Si xrandr ne te propose das d’autre résolution, c’est que ton écran lui dit qu’il n’en supporte pas d’autres.
à toi de les forcer dans ton xorg.conf[/quote]
Oui mais pourquoi l’écran me les proposait avant changement de noyau ? Et je pensais les forcer en ayant rajouter le
Modes "1920x1080" "1360x768" "1024x768" dans le xorg.conf ; il y aurait un autre moyen de le forcer ?
[quote=“Grhim”]perso je n’utilise pas de «Modes “1920x1080” “1360x768” “1024x768”» a la section screen et j’ai les mode bel et bien reconnu jusqu’au max , chez moi de 400600 au 1400 (j’arrondie évidement)[/quote]Jusqu’au changement de noyau, je ne les avait pas non plus et je pouvais changer de résolution. C’est un ajout de ma part pour essayer de corriger le problème (en vain).
et tu les a re enlever ?? pour voir si ca peux fonctionner comme tu le souhaite ??
ps: t’aurais pas virtual box d’installer ?
EDID est une norme qui permet, entre autre, à un écran de définir à la carte graphique les résolutions qu’il supporte.
Cela est normalement utilisé lorsqu’il n’y a pas de xorg.conf, ou que ce fichier n’impose pas de résolution particulière.
ubuntuforums.org/showthread.php?t=1721927 ???
