hello
Voici un résumer :
Comme a son habitude j’ai fait un scan et i en ressort ceci:
rien sur google de concret ?
bon je voudrai bien verifier le md5 de ces fichier suite a une mise a jour mai comment je m’y prend aux juste ?
sa permettrai d’y voir un peux plus clair
Merci d’avance
pour ce qui est de la sortie complete:
# rkhunter --update
[ Rootkit Hunter version 1.3.6 ]
Checking rkhunter data files...
Checking file mirrors.dat [ No update ]
Checking file programs_bad.dat [ Updated ]
Checking file backdoorports.dat [ Updated ]
Checking file suspscan.dat [ No update ]
Checking file i18n/cn [ No update ]
Checking file i18n/de [ No update ]
Checking file i18n/en [ No update ]
Checking file i18n/zh [ No update ]
Checking file i18n/zh.utf8 [ No update ]
Checking system commands...
Performing 'strings' command checks
Checking 'strings' command [ OK ]
Performing 'shared libraries' checks
Checking for preloading variables [ None found ]
Checking for preloaded libraries [ None found ]
Checking LD_LIBRARY_PATH variable [ Not found ]
Performing file properties checks
Checking for prerequisites [ OK ]
/bin/bash [ OK ]
/bin/cat [ OK ]
/bin/chmod [ OK ]
/bin/chown [ OK ]
/bin/cp [ OK ]
/bin/date [ OK ]
/bin/df [ OK ]
/bin/dmesg [ Warning ]
/bin/echo [ OK ]
/bin/ed [ Warning ]
/bin/egrep [ OK ]
/bin/fgrep [ OK ]
/bin/fuser [ OK ]
/bin/grep [ OK ]
/bin/ip [ Warning ]
/bin/kill [ OK ]
/bin/less [ OK ]
/bin/login [ Warning ]
/bin/ls [ OK ]
/bin/lsmod [ Warning ]
/bin/mktemp [ OK ]
/bin/more [ Warning ]
/bin/mount [ Warning ]
/bin/mv [ OK ]
/bin/netstat [ OK ]
/bin/ps [ OK ]
/bin/pwd [ OK ]
/bin/readlink [ OK ]
/bin/sed [ OK ]
/bin/sh [ Warning ]
/bin/su [ Warning ]
/bin/touch [ OK ]
/bin/uname [ OK ]
/bin/which [ Warning ]
/bin/dash [ Warning ]
/usr/bin/awk [ OK ]
/usr/bin/basename [ OK ]
/usr/bin/chattr [ Warning ]
/usr/bin/cut [ OK ]
/usr/bin/diff [ OK ]
/usr/bin/dirname [ OK ]
/usr/bin/dpkg [ Warning ]
/usr/bin/dpkg-query [ Warning ]
/usr/bin/du [ OK ]
/usr/bin/env [ OK ]
/usr/bin/file [ Warning ]
/usr/bin/find [ Warning ]
/usr/bin/groups [ OK ]
/usr/bin/head [ OK ]
/usr/bin/id [ OK ]
/usr/bin/killall [ OK ]
/usr/bin/last [ Warning ]
/usr/bin/lastlog [ Warning ]
/usr/bin/ldd [ Warning ]
/usr/bin/less [ OK ]
/usr/bin/locate [ OK ]
/usr/bin/logger [ Warning ]
/usr/bin/lsattr [ Warning ]
/usr/bin/lsof [ OK ]
/usr/bin/lynx [ Warning ]
/usr/bin/mail [ Warning ]
/usr/bin/md5sum [ OK ]
/usr/bin/mlocate [ OK ]
/usr/bin/newgrp [ Warning ]
/usr/bin/passwd [ Warning ]
/usr/bin/perl [ Warning ]
/usr/bin/pgrep [ OK ]
/usr/bin/pstree [ OK ]
/usr/bin/rkhunter [ OK ]
/usr/bin/runcon [ OK ]
/usr/bin/sha1sum [ OK ]
/usr/bin/sha224sum [ OK ]
/usr/bin/sha256sum [ OK ]
/usr/bin/sha384sum [ OK ]
/usr/bin/sha512sum [ OK ]
/usr/bin/size [ Warning ]
/usr/bin/sort [ OK ]
/usr/bin/stat [ OK ]
/usr/bin/strings [ Warning ]
/usr/bin/tail [ OK ]
/usr/bin/test [ OK ]
/usr/bin/top [ OK ]
/usr/bin/touch [ OK ]
/usr/bin/tr [ OK ]
/usr/bin/uniq [ OK ]
/usr/bin/users [ OK ]
/usr/bin/vmstat [ OK ]
/usr/bin/w [ OK ]
/usr/bin/watch [ OK ]
/usr/bin/wc [ OK ]
/usr/bin/wget [ Warning ]
/usr/bin/whatis [ Warning ]
/usr/bin/whereis [ Warning ]
/usr/bin/which [ Warning ]
/usr/bin/who [ OK ]
/usr/bin/whoami [ OK ]
/usr/bin/mawk [ OK ]
/usr/bin/lynx.cur [ Warning ]
/usr/bin/heirloom-mailx [ Warning ]
/usr/bin/w.procps [ OK ]
/sbin/depmod [ Warning ]
/sbin/ifconfig [ OK ]
/sbin/ifdown [ OK ]
/sbin/ifup [ OK ]
/sbin/init [ Warning ]
/sbin/insmod [ Warning ]
/sbin/ip [ Warning ]
/sbin/lsmod [ Warning ]
/sbin/modinfo [ Warning ]
/sbin/modprobe [ Warning ]
/sbin/rmmod [ Warning ]
/sbin/runlevel [ Warning ]
/sbin/sulogin [ Warning ]
/sbin/sysctl [ OK ]
/usr/sbin/adduser [ Warning ]
/usr/sbin/chroot [ OK ]
/usr/sbin/cron [ Warning ]
/usr/sbin/groupadd [ Warning ]
/usr/sbin/groupdel [ Warning ]
/usr/sbin/groupmod [ Warning ]
/usr/sbin/grpck [ Warning ]
/usr/sbin/inetd [ Warning ]
/usr/sbin/nologin [ Warning ]
/usr/sbin/pwck [ Warning ]
/usr/sbin/rsyslogd [ Warning ]
/usr/sbin/tcpd [ Warning ]
/usr/sbin/useradd [ Warning ]
/usr/sbin/userdel [ Warning ]
/usr/sbin/usermod [ Warning ]
/usr/sbin/vipw [ Warning ]
/usr/sbin/unhide-linux26 [ OK ]
[Press <ENTER> to continue]
Checking for rootkits...
Performing check of known rootkit files and directories
55808 Trojan - Variant A [ Not found ]
ADM Worm [ Not found ]
AjaKit Rootkit [ Not found ]
Adore Rootkit [ Not found ]
aPa Kit [ Not found ]
Apache Worm [ Not found ]
Ambient (ark) Rootkit [ Not found ]
Balaur Rootkit [ Not found ]
BeastKit Rootkit [ Not found ]
beX2 Rootkit [ Not found ]
BOBKit Rootkit [ Not found ]
cb Rootkit [ Not found ]
CiNIK Worm (Slapper.B variant) [ Not found ]
Danny-Boy's Abuse Kit [ Not found ]
Devil RootKit [ Not found ]
Dica-Kit Rootkit [ Not found ]
Dreams Rootkit [ Not found ]
Duarawkz Rootkit [ Not found ]
Enye LKM [ Not found ]
Flea Linux Rootkit [ Not found ]
FreeBSD Rootkit [ Not found ]
Fu Rootkit [ Not found ]
Fuck`it Rootkit [ Not found ]
GasKit Rootkit [ Not found ]
Heroin LKM [ Not found ]
HjC Kit [ Not found ]
ignoKit Rootkit [ Not found ]
iLLogiC Rootkit [ Not found ]
IntoXonia-NG Rootkit [ Not found ]
Irix Rootkit [ Not found ]
Kitko Rootkit [ Not found ]
Knark Rootkit [ Not found ]
ld-linuxv.so Rootkit [ Not found ]
Li0n Worm [ Not found ]
Lockit / LJK2 Rootkit [ Not found ]
Mood-NT Rootkit [ Not found ]
MRK Rootkit [ Not found ]
Ni0 Rootkit [ Not found ]
Ohhara Rootkit [ Not found ]
Optic Kit (Tux) Worm [ Not found ]
Oz Rootkit [ Not found ]
Phalanx Rootkit [ Not found ]
Phalanx2 Rootkit [ Not found ]
Phalanx2 Rootkit (extended tests) [ Not found ]
Portacelo Rootkit [ Not found ]
R3dstorm Toolkit [ Not found ]
RH-Sharpe's Rootkit [ Not found ]
RSHA's Rootkit [ Not found ]
Scalper Worm [ Not found ]
Sebek LKM [ Not found ]
Shutdown Rootkit [ Not found ]
SHV4 Rootkit [ Not found ]
SHV5 Rootkit [ Not found ]
Sin Rootkit [ Not found ]
Slapper Worm [ Not found ]
Sneakin Rootkit [ Not found ]
'Spanish' Rootkit [ Not found ]
Suckit Rootkit [ Not found ]
SunOS Rootkit [ Not found ]
SunOS / NSDAP Rootkit [ Not found ]
Superkit Rootkit [ Not found ]
TBD (Telnet BackDoor) [ Not found ]
TeLeKiT Rootkit [ Not found ]
T0rn Rootkit [ Not found ]
trNkit Rootkit [ Not found ]
Trojanit Kit [ Not found ]
Tuxtendo Rootkit [ Not found ]
URK Rootkit [ Not found ]
Vampire Rootkit [ Not found ]
VcKit Rootkit [ Not found ]
Volc Rootkit [ Not found ]
Xzibit Rootkit [ Not found ]
X-Org SunOS Rootkit [ Not found ]
zaRwT.KiT Rootkit [ Not found ]
ZK Rootkit [ Not found ]
Performing additional rootkit checks
Suckit Rookit additional checks [ OK ]
Checking for possible rootkit files and directories [ None found ]
Checking for possible rootkit strings [ Warning ]
Performing malware checks
Checking running processes for suspicious files [ None found ]
Checking for login backdoors [ None found ]
Checking for suspicious directories [ None found ]
Checking for sniffer log files [ None found ]
Performing trojan specific checks
Checking for enabled inetd services [ OK ]
Checking for Apache backdoor [ Not found ]
Performing Linux specific checks
Checking loaded kernel modules [ OK ]
Checking kernel module names [ OK ]
Checking the network...
Performing check for backdoor ports
Checking for TCP port 1524 [ Not found ]
Checking for TCP port 1984 [ Not found ]
Checking for UDP port 2001 [ Not found ]
Checking for TCP port 2006 [ Not found ]
Checking for TCP port 2128 [ Not found ]
Checking for TCP port 6666 [ Not found ]
Checking for TCP port 6667 [ Not found ]
Checking for TCP port 6668 [ Not found ]
Checking for TCP port 6669 [ Not found ]
Checking for TCP port 7000 [ Not found ]
Checking for TCP port 13000 [ Not found ]
Checking for TCP port 14856 [ Not found ]
Checking for TCP port 25000 [ Not found ]
Checking for TCP port 29812 [ Not found ]
Checking for TCP port 31337 [ Not found ]
Checking for TCP port 32982 [ Not found ]
Checking for TCP port 33369 [ Not found ]
Checking for TCP port 47107 [ Not found ]
Checking for TCP port 47018 [ Not found ]
Checking for TCP port 60922 [ Not found ]
Checking for TCP port 62883 [ Not found ]
Checking for TCP port 65535 [ Not found ]
Performing checks on the network interfaces
Checking for promiscuous interfaces [ None found ]
Checking the local host...
Performing system boot checks
Checking for local host name [ Found ]
Checking for system startup files [ Found ]
Checking system startup files for malware [ None found ]
Performing group and account checks
Checking for passwd file [ Found ]
Checking for root equivalent (UID 0) accounts [ None found ]
Checking for passwordless accounts [ None found ]
Checking for passwd file changes [ None found ]
Checking for group file changes [ None found ]
Checking root account shell history files [ OK ]
Performing system configuration file checks
Checking for SSH configuration file [ Found ]
Checking if SSH root access is allowed [ Warning ]
Checking if SSH protocol v1 is allowed [ Not allowed ]
Checking for running syslog daemon [ Found ]
Checking for syslog configuration file [ Found ]
Checking if syslog remote logging is allowed [ Not allowed ]
Performing filesystem checks
Checking /dev for suspicious file types [ None found ]
Checking for hidden files and directories [ Warning ]
System checks summary
File properties checks...
Files checked: 130
Suspect files: 59
Rootkit checks...
Rootkits checked : 245
Possible rootkits: 1
Rootkit names : Xzibit Rootkit
Applications checks...
All checks skipped
The system checks took: 1 minute and 1 second
All results have been written to the log file (/var/log/rkhunter.log)
One or more warnings have been found while checking the system.
Please check the log file (/var/log/rkhunter.log)
