Je suis en train de monter un serveur syslog pour mon travail et nous avons plusieurs réseaux.
Je souhaite faire en sorte que chaque réseau « logger » soit mis dans un répertoire différent.
Voici mon fichier de conf
# /etc/rsyslog.conf configuration file for rsyslog
# For more information install rsyslog-doc and see
# /usr/share/doc/rsyslog-doc/html/configuration/index.html
#### MODULES ####
module(load="imuxsock") # provides support for local system logging
module(load="imklog") # provides kernel logging support
#module(load="immark") # provides --MARK-- message capability
# provides UDP syslog reception
module(load="imudp")
input(type="imudp" port="514")
# provides TCP syslog reception
module(load="imtcp")
input(type="imtcp" port="514")
#### GLOBAL DIRECTIVES ####
# Use traditional timestamp format.
# To enable high precision timestamps, comment out the following line.
#$ActionFileDefaultTemplate RSYSLOG_TraditionalFileFormat
$template energySaving,"%$MONTH%-%$DAY% %$HOUR%:%$MINUTE% %HOSTNAME% %APP-NAME%: %msg%\n"
$ActionFileDefaultTemplate energySaving
# Set the default permissions for all log files.
$FileOwner root
$FileGroup adm
$FileCreateMode 0640
$DirCreateMode 0755
$Umask 0022
$AllowedSender UDP, 127.0.0.1, 192.168.5.0/24, 192.168.2.0/24
# Where to place spool and state files
$WorkDirectory /var/spool/rsyslog
# Include all config files in /etc/rsyslog.d/
$IncludeConfig /etc/rsyslog.d/*.conf
#template
$template RemoteLogs,"/var/log/RSO1/%HOSTNAME%/logging.log
*.* ?RemoteLogs
#### RULES ####
# First some standard log files. Log by facility.
auth,authpriv.* /var/log/auth.log
*.*;auth,authpriv.none -/var/log/syslog
#cron.* /var/log/cron.log
daemon.* -/var/log/daemon.log
kern.* -/var/log/kern.log
lpr.* -/var/log/lpr.log
mail.* -/var/log/mail.log
user.* -/var/log/user.log
# Logging for the mail system. Split it up so that
# it is easy to write scripts to parse these files.
mail.info -/var/log/mail.info
mail.warn -/var/log/mail.warn
mail.err /var/log/mail.err
# Some "catch-all" log files.
*.=debug;\
auth,authpriv.none;\
news.none;mail.none -/var/log/debug
*.=info;*.=notice;*.=warn;\
cron,daemon.none;\
mail,news.none -/var/log/messages
# Emergencies are sent to everybody logged in.
*.emerg :omusrmsg:*
*.* @@syslog:514
