Je voudrai rendre mon server debian squeeze en Controleur de domaine Samba.
j’ai installé samba et configurer :
[global]
workgroup = ITGROUP
netbios name = DEBIAN
server string = %h server
; wins server = w.x.y.z
dns proxy = no
; name resolve order = lmhosts host wins bcast
interfaces = tun0 10.1.0.1/24 , eth0 lo
bind interfaces only = yes
log file = /var/log/samba/log.%m
max log size = 1000
syslog = 0
panic action = /usr/share/samba/panic-action %d
time server = Yes
encrypt passwords = true
passdb backend = tdbsam
obey pam restrictions = yes
unix password sync = yes
passwd program = /usr/bin/passwd %u
passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
pam password change = yes
domain logons = yes
logon path = \\%N\profiles\%U
logon drive = H:
logon home = \\%N\%U
logon script = logon.cmd
add user script = /usr/sbin/adduser --quiet --disabled-password --gecos "" %u
add machine script = /usr/sbin/useradd -g machines -c "%u machine account" -d /var/lib/samba -s /bin/false %u
add group script = /usr/sbin/addgroup --force-badname %g
; printing = bsd
; printcap name = /etc/printcap
; printing = cups
; printcap name = cups
; include = /home/samba/etc/smb.conf.%m
socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
; message command = /bin/sh -c '/usr/bin/linpopup "%f" "%m" %s; rm %s' &
domain master = yes
; idmap uid = 10000-20000
; idmap gid = 10000-20000
; template shell = /bin/bash
; winbind enum groups = yes
; winbind enum users = yes
; usershare max shares = 100
[homes]
comment = Documents Personnels
browseable = no
read only = no
create mask = 0700
directory mask = 0700
valid users = %S
[netlogon]
comment = Network Logon Service
path = /srv/samba/netlogon
guest ok = yes
read only = yes
browseable = no
[profiles]
comment = Users profiles
path = /srv/samba/profils
guest ok = no
browseable = no
create mask = 0600
[code]root@debian:/etc/samba# net rpc info
Enter root’s password:
Domain Name: ITGROUP
Domain SID: S-1-5-21-37xxx35033-35187xxx78-13135xxx79
Sequence number: 1332238135
Num users: 4
Num domain groups: 4
Num local groups: 0
root@debian:/etc/samba# net rpc join
Joined domain ITGROUP
root@debian:/etc/samba# net rpc testjoin
Join to ‘ITGROUP’ is OK
root@debian:/etc/samba# testparm
Load smb config files from /etc/samba/smb.conf
rlimit_max: rlimit_max (1024) below minimum Windows limit (16384)
Processing section "[homes]"
Processing section "[netlogon]"
Processing section "[profiles]"
Loaded services file OK.
Server role: ROLE_DOMAIN_PDC
Press enter to see a dump of your service definitions
$IPTABLES -A INPUT -s 10.1.0.0/24 -m state --state NEW -p tcp --dport 135 -j ACCEPT
$IPTABLES -A INPUT -s 10.1.0.0/24 -m state --state NEW -p tcp --dport 137 -j ACCEPT
$IPTABLES -A INPUT -s 10.1.0.0/24 -m state --state NEW -p udp --dport 137 -j ACCEPT
$IPTABLES -A INPUT -s 10.1.0.0/24 -m state --state NEW -p udp --dport 138 -j ACCEPT
$IPTABLES -A INPUT -s 10.1.0.0/24 -m state --state NEW -p tcp --dport 139 -j ACCEPT
$IPTABLES -A INPUT -s 10.1.0.0/24 -m state --state NEW -p tcp --dport 445 -j ACCEPT
$IPTABLES -A INPUT -s 10.1.0.0/24 -m state --state NEW -p udp --dport 445 -j ACCEPT
Voila mes configuration . Mais lorsque je veux integrer un pc windows j’ai ce message :
Remarque : ces informations sont conçues pour un administrateur réseau. Si vous n'êtes pas l’administrateur de votre réseau, contactez votre administrateur pour lui indiquer que vous avez reçu cette information, qui a été enregistrée dans le fichier C:\Windows\debug\dcdiag.txt.
Le nom de domaine « ITGROUP » est peut-être un nom de domaine NetBIOS. Si cela est le cas, vérifiez que ce nom de domaine est correctement enregistré auprès de WINS.
Si vous êtes sûr que ce nom n’est pas un nom de domaine NetBIOS, les informations suivantes peuvent vous aider à diagnostiquer votre configuration DNS.
L’erreur suivante s’est produite lors de la demande au DNS de l’enregistrement de ressource SRV (Service Location) permettant de localiser un contrôleur de domaine Active Directory pour le domaine ITGROUP :
L'erreur était : "Le nom DNS n’existe pas."
(code d’erreur 0x0000232B RCODE_NAME_ERROR)
La requête portait sur l’enregistrement SRV pour _ldap._tcp.dc._msdcs.ITGROUP
Les causes de cette erreur peuvent être :
- Les enregistrements DNS SRV requis pour localiser un contrôleur de domaine Active Directory pour le domaine ne sont pas enregistrés dans le DNS. Ces enregistrements sont enregistrés automatiquement par un serveur quand un contrôleur de domaine Active Directory est ajouté au domaine. Ils sont mis à jour par le contrôleur de domaine Active Directory à des intervalles définis. Cet ordinateur est configuré pour utiliser des serveurs DNS avec les adresses IP suivantes :
xxx.xxx.xxx.2
xxx.xxx.xxx.1
- Une ou plusieurs des zones suivantes n’incluent pas la délégation à leur zone enfant :
ITGOUP
. (zone racine)
Je n’arrive toujours pas à ajouter un pc dans mon domaine
Merci de votre aide
) et je n’aurai pas trop de temps pour l’instant…
