Merci de ton aide voici mes 3 fichiers:
nmbd
[code][2012/04/15 23:35:30.751781, 0] nmbd/nmbd.c:71(terminate)
Got SIGTERM: going down…
[2012/04/15 23:36:46, 0] nmbd/nmbd.c:857(main)
nmbd version 3.5.6 started.
Copyright Andrew Tridgell and the Samba Team 1992-2010
[2012/04/15 23:37:09.770581, 0] nmbd/nmbd_become_lmb.c:395(become_local_master_stage2)
Samba name server PETITPONEY is now a local master browser for workgroup WORKGROUP on subnet 192.168.0.3
[2012/04/16 00:25:04.579749, 0] nmbd/nmbd.c:71(terminate)
[2012/04/16 00:25:07, 0] nmbd/nmbd.c:857(main)
[2012/04/16 00:25:31.957997, 0] nmbd/nmbd_become_lmb.c:395(become_local_master_stage2)
[2012/04/16 17:54:30.408015, 0] nmbd/nmbd_incomingrequests.c:117(process_name_release_request)
process_name_release_request: Attempt to release name WORKGROUP<1d> from IP 192.168.0.8 on subnet 192.168.0.3 being rejected as it is one of our names.
[2012/04/17 08:47:45.674365, 0] nmbd/nmbd.c:71(terminate)
[2012/04/17 08:47:48, 0] nmbd/nmbd.c:857(main)
[2012/04/17 08:48:11.854340, 0] nmbd/nmbd_become_lmb.c:395(become_local_master_stage2)
smbd
[2012/04/17 04:52:16.258241, 0] printing/print_cups.c:108(cups_connect)
Unable to connect to CUPS server localhost:631 - Connexion terminée par expiration du délai d'attente
[2012/04/17 04:52:37.258240, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 05:01:30.166242, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 05:01:51.166241, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 05:05:16.834243, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 05:05:37.834240, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 05:14:30.186243, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 05:14:51.186239, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 05:18:17.422243, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 05:18:38.422241, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 05:27:30.206240, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 05:27:51.206243, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 05:31:17.966244, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 05:31:38.966242, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 05:40:30.226242, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 05:40:51.226241, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 05:44:18.598241, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 05:44:39.598244, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 05:53:30.246243, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 05:53:51.246243, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 05:57:19.214241, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 05:57:40.214244, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 06:06:30.266240, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 06:06:51.266240, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 06:10:19.814243, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 06:10:40.814240, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 06:19:30.298241, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 06:19:51.298270, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 06:23:20.398241, 0] printing/print_cups.c:108(cups_connect)
[2012/04/17 06:23:41.398241, 0] printing/print_cups.c:108(cups_connect)
winbindd
root@PETITPONEY:/var/log/samba# vim log.smbd
root@PETITPONEY:/var/log/samba# vim log.winbindd
[2012/04/15 06:25:04.064448, 0] param/loadparm.c:7617(lp_do_parameter)
Global parameter guest account found in service section!
[2012/04/15 23:35:30.968561, 0] winbindd/winbindd.c:195(winbindd_sig_term_handler)
Got sig[15] terminate (is_parent=1)
[2012/04/15 23:36:47, 0] winbindd/winbindd.c:1105(main)
winbindd version 3.5.6 started.
[2012/04/15 23:36:47.780873, 0] param/loadparm.c:7617(lp_do_parameter)
[2012/04/15 23:36:47.830068, 0] winbindd/winbindd_cache.c:3076(initialize_winbindd_cache)
initialize_winbindd_cache: clearing cache and re-creating with version number 1
winbindd-imap
[2012/04/15 22:21:00.380480, 1] winbindd/idmap.c:321(idmap_init_domain)
idmap initialization returned NT_STATUS_UNSUCCESSFUL
[2012/04/15 22:21:00.434073, 0] winbindd/idmap.c:201(smb_register_idmap_alloc)
idmap_alloc module tdb already registered!
[2012/04/15 22:21:00.434098, 0] winbindd/idmap.c:149(smb_register_idmap)
Idmap module passdb already registered!
[2012/04/15 22:21:00.434116, 0] winbindd/idmap.c:149(smb_register_idmap)
Idmap module nss already registered!
[2012/04/15 22:21:00.434135, 1] winbindd/idmap_tdb.c:214(idmap_tdb_load_ranges)
idmap uid missing
[2012/04/15 22:21:00.434160, 0] winbindd/idmap_tdb.c:287(idmap_tdb_open_db)
Upgrade of IDMAP_VERSION from -1 to 2 is not possible with incomplete configuration
[2012/04/15 22:21:00.434188, 1] winbindd/idmap.c:321(idmap_init_domain)
[2012/04/15 22:21:00.434705, 0] winbindd/idmap.c:201(smb_register_idmap_alloc)
[2012/04/15 22:21:00.434728, 0] winbindd/idmap.c:149(smb_register_idmap)
[2012/04/15 22:21:00.434745, 0] winbindd/idmap.c:149(smb_register_idmap)
[2012/04/15 22:21:00.434763, 1] winbindd/idmap_tdb.c:214(idmap_tdb_load_ranges)
idmap uid missing
[2012/04/15 22:21:00.434786, 0] winbindd/idmap_tdb.c:287(idmap_tdb_open_db)
[2012/04/15 22:21:00.434809, 1] winbindd/idmap.c:321(idmap_init_domain)
[2012/04/15 22:21:00.434820, 0] winbindd/idmap.c:201(smb_register_idmap_alloc)
[2012/04/15 22:21:00.434838, 0] winbindd/idmap.c:149(smb_register_idmap)
[2012/04/15 22:21:00.435035, 0] winbindd/idmap.c:149(smb_register_idmap)
[2012/04/15 22:21:00.435114, 1] winbindd/idmap_tdb.c:214(idmap_tdb_load_ranges)
idmap uid missing
[2012/04/15 22:21:00.435139, 0] winbindd/idmap_tdb.c:287(idmap_tdb_open_db)
[2012/04/15 22:21:00.435219, 1] winbindd/idmap.c:321(idmap_init_domain)
[2012/04/15 22:21:00.435445, 0] winbindd/idmap.c:201(smb_register_idmap_alloc)
[2012/04/15 22:21:00.435525, 0] winbindd/idmap.c:149(smb_register_idmap)
[2012/04/15 22:21:00.435600, 0] winbindd/idmap.c:149(smb_register_idmap)
[2012/04/15 22:21:00.435677, 1] winbindd/idmap_tdb.c:214(idmap_tdb_load_ranges)
idmap uid missing
[2012/04/15 22:21:00.435702, 0] winbindd/idmap_tdb.c:287(idmap_tdb_open_db)
[2012/04/15 22:21:00.435781, 1] winbindd/idmap.c:321(idmap_init_domain)
[2012/04/15 22:21:00.435793, 0] winbindd/idmap.c:201(smb_register_idmap_alloc)
[2012/04/15 22:21:00.435873, 0] winbindd/idmap.c:149(smb_register_idmap)
[2012/04/15 22:21:00.435946, 0] winbindd/idmap.c:149(smb_register_idmap)
[2012/04/15 22:21:00.436022, 1] winbindd/idmap_tdb.c:214(idmap_tdb_load_ranges)
idmap uid missing
[2012/04/15 22:21:00.436046, 0] winbindd/idmap_tdb.c:287(idmap_tdb_open_db)
