[SAMBA] messages d'erreur
Hello,
Voilà ce que j’attends de samba : un partage tout con, sans sécurité, local, accessible en RW à tout le monde.
Voici ma conf samba, toute simple :
[code]
[global]
workgroup = Workgroup
netbios name = cthulhu
security = share
log file = /var/log/samba/log.%m
max log size = 50
[Partage]
path = /media/Partage
read only = no
writeable = yes
guest only = Yes[/code]
Absolument pas à me plaindre, ça fonctionne très bien. Par contre, quand je check mon /var/log/syslog, j’ai ceci dedans :
[quote]May 10 09:40:30 cthulhu nmbd[13129]: [2011/05/10 09:40:30.539607, 0] nmbd/nmbd.c:71(terminate)
May 10 09:40:30 cthulhu nmbd[13129]: Got SIGTERM: going down…
May 10 09:40:33 cthulhu smbd[13162]: [2011/05/10 09:40:33.580635, 0] printing/print_cups.c:108(cups_connect)
May 10 09:40:33 cthulhu smbd[13162]: Unable to connect to CUPS server localhost:631 - Connexion refusée
May 10 09:40:33 cthulhu smbd[13163]: [2011/05/10 09:40:33.584555, 0] printing/print_cups.c:108(cups_connect)
May 10 09:40:33 cthulhu smbd[13163]: Unable to connect to CUPS server localhost:631 - Connexion refusée
May 10 09:40:33 cthulhu smbd[13164]: [2011/05/10 09:40:33.594980, 0] smbd/server.c:500(smbd_open_one_socket)
May 10 09:40:33 cthulhu smbd[13164]: smbd_open_once_socket: open_socket_in: Adresse déjà utilisée
May 10 09:40:33 cthulhu smbd[13164]: [2011/05/10 09:40:33.595580, 0] smbd/server.c:500(smbd_open_one_socket)
May 10 09:40:33 cthulhu nmbd[13160]: [2011/05/10 09:40:33.636503, 0] nmbd/nmbd_namequery.c:108(query_name_response)
May 10 09:40:33 cthulhu nmbd[13160]: query_name_response: Multiple (2) responses received for a query on subnet 192.168.1.18 for name WORKGROUP<1d>.
May 10 09:40:33 cthulhu nmbd[13160]: This response was from IP 192.168.1.13, reporting an IP address of 192.168.1.13.
May 10 09:40:33 cthulhu nmbd[13160]: [2011/05/10 09:40:33.740425, 0] nmbd/nmbd_namequery.c:108(query_name_response)
May 10 09:40:33 cthulhu nmbd[13160]: query_name_response: Multiple (3) responses received for a query on subnet 192.168.1.18 for name WORKGROUP<1d>.
May 10 09:40:33 cthulhu nmbd[13160]: [2011/05/10 09:40:33.885059, 0] nmbd/nmbd_namequery.c:108(query_name_response)
May 10 09:40:33 cthulhu nmbd[13160]: query_name_response: Multiple (4) responses received for a query on subnet 192.168.1.18 for name WORKGROUP<1d>.
May 10 09:40:34 cthulhu nmbd[13160]: [2011/05/10 09:40:34.033183, 0] nmbd/nmbd_namequery.c:108(query_name_response)
May 10 09:40:34 cthulhu nmbd[13160]: query_name_response: Multiple (5) responses received for a query on subnet 192.168.1.18 for name WORKGROUP<1d>.
May 10 09:40:34 cthulhu nmbd[13160]: This response was from IP 192.168.1.13, reporting an IP address of 192.168.1.13.
May 10 09:40:34 cthulhu nmbd[13160]: [2011/05/10 09:40:34.186639, 0] nmbd/nmbd_namequery.c:108(query_name_response)
May 10 09:40:34 cthulhu nmbd[13160]: query_name_response: Multiple (6) responses received for a query on subnet 192.168.1.18 for name WORKGROUP<1d>.
May 10 09:45:46 cthulhu nmbd[13160]: [2011/05/10 09:45:46.545316, 0] nmbd/nmbd_namequery.c:108(query_name_response)
May 10 09:45:46 cthulhu nmbd[13160]: query_name_response: Multiple (2) responses received for a query on subnet 192.168.1.18 for name WORKGROUP<1d>.
May 10 09:45:46 cthulhu nmbd[13160]: This response was from IP 192.168.1.13, reporting an IP address of 192.168.1.13.
May 10 09:45:46 cthulhu nmbd[13160]: [2011/05/10 09:45:46.698557, 0] nmbd/nmbd_namequery.c:108(query_name_response)
May 10 09:45:46 cthulhu nmbd[13160]: query_name_response: Multiple (3) responses received for a query on subnet 192.168.1.18 for name WORKGROUP<1d>.
May 10 09:45:46 cthulhu nmbd[13160]: [2011/05/10 09:45:46.844758, 0] nmbd/nmbd_namequery.c:108(query_name_response)
May 10 09:45:46 cthulhu nmbd[13160]: query_name_response: Multiple (4) responses received for a query on subnet 192.168.1.18 for name WORKGROUP<1d>.
May 10 09:45:46 cthulhu nmbd[13160]: [2011/05/10 09:45:46.984586, 0] nmbd/nmbd_namequery.c:108(query_name_response)
May 10 09:45:46 cthulhu nmbd[13160]: query_name_response: Multiple (5) responses received for a query on subnet 192.168.1.18 for name WORKGROUP<1d>.
May 10 09:45:47 cthulhu nmbd[13160]: [2011/05/10 09:45:47.135981, 0] nmbd/nmbd_namequery.c:108(query_name_response)
May 10 09:45:47 cthulhu nmbd[13160]: query_name_response: Multiple (6) responses received for a query on subnet 192.168.1.18 for name WORKGROUP<1d>.
May 10 09:45:47 cthulhu nmbd[13160]: This response was from IP 192.168.1.13, reporting an IP address of 192.168.1.13.
May 10 09:45:47 cthulhu nmbd[13160]: [2011/05/10 09:45:47.284502, 0] nmbd/nmbd_namequery.c:108(query_name_response)
May 10 09:45:47 cthulhu nmbd[13160]: query_name_response: Multiple (7) responses received for a query on subnet 192.168.1.18 for name WORKGROUP<1d>.
May 10 09:50:50 cthulhu nmbd[13160]: [2011/05/10 09:50:50.012952, 0] nmbd/nmbd_namequery.c:108(query_name_response)
May 10 09:50:50 cthulhu nmbd[13160]: query_name_response: Multiple (2) responses received for a query on subnet 192.168.1.18 for name WORKGROUP<1d>.
Et je le purge régulièrement, sinon j’en aurais des tonnes et des tonnes… Et ça ça ne me plait pas du tout, pour deux raisons :
  1. des logs samba n’ont rien à faire ici, vu que j’ai précisé que je les voulait dans /var/log/samba/
  2. pourquoi ces messages d’erreur ? à quoi ça correspond ? Toutes mes machines ont un nom netbios unique, j’ai pas de conf particulière (tout est géré en amont par une pauvre livebox). J’ai pas déclaré de serveur wins ni rien.
le .13 est mon serveur linux, et parfois j’ai aussi l’erreur vers le .18 qui est un poste en vista, j’imagine que si je laisse les logs se remplir, j’aurai des messages impliquant d’autres postes.
Qu’en pensez-vous ?
