Voici mon soucis.
J’ai installé un serveur de fichier à l’aide de samba4. Je l’ai intégré au domaine et réussi bien à récupérer les users/groups via winbind (wbinfo -u/-g)
par contre, getent ne me donne que les utilisateurs locaux. j’ai fouillé un peu partout mais je n’ai pas trouvé de solution.
Merci de votre aide
Voici ma conf
Debian Jessie
Samba 4.1.17
Mon controleur de domaine est en samba 4.2.3
krb5.conf
[libdefaults]
dns_lookup_realm = true
dns_lookup_kdc = true
default_realm = MONDOMAINE.LAN
clockskew = 3600
# The following krb5.conf variables are only for MIT Kerberos.
krb4_config = /etc/krb.conf
krb4_realms = /etc/krb.realms
kdc_timesync = 1
ccache_type = 4
forwardable = true
proxiable = true
# The following encryption type specification will be used by MIT Kerberos
# if uncommented. In general, the defaults in the MIT Kerberos code are
# correct and overriding these specifications only serves to disable new
# encryption types as they are added, creating interoperability problems.
# Thie only time when you might need to uncomment these lines and change
# the enctypes is if you have local software that will break on ticket
# caches containing ticket encryption types it doesn't know about (such as
# old versions of Sun Java).
# default_tgs_enctypes = des3-hmac-sha1
# default_tkt_enctypes = des3-hmac-sha1
# permitted_enctypes = des3-hmac-sha1
# The following libdefaults parameters are only for Heimdal Kerberos.
v4_instance_resolve = false
v4_name_convert = {
host = {
rcmd = host
ftp = ftp
plain = {
something = something-else
fcc-mit-ticketflags = true
[realms]
ATHENA.MIT.EDU = {
kdc = kerberos.mit.edu:88
kdc = kerberos-1.mit.edu:88
kdc = kerberos-2.mit.edu:88
admin_server = kerberos.mit.edu
default_domain = mit.edu
MEDIA-LAB.MIT.EDU = {
kdc = kerberos.media.mit.edu
admin_server = kerberos.media.mit.edu
ZONE.MIT.EDU = {
kdc = casio.mit.edu
kdc = seiko.mit.edu
admin_server = casio.mit.edu
MOOF.MIT.EDU = {
kdc = three-headed-dogcow.mit.edu:88
kdc = three-headed-dogcow-1.mit.edu:88
admin_server = three-headed-dogcow.mit.edu
CSAIL.MIT.EDU = {
kdc = kerberos-1.csail.mit.edu
kdc = kerberos-2.csail.mit.edu
admin_server = kerberos.csail.mit.edu
default_domain = csail.mit.edu
krb524_server = krb524.csail.mit.edu
IHTFP.ORG = {
kdc = kerberos.ihtfp.org
admin_server = kerberos.ihtfp.org
GNU.ORG = {
kdc = kerberos.gnu.org
kdc = kerberos-2.gnu.org
kdc = kerberos-3.gnu.org
admin_server = kerberos.gnu.org
1TS.ORG = {
kdc = kerberos.1ts.org
admin_server = kerberos.1ts.org
GRATUITOUS.ORG = {
kdc = kerberos.gratuitous.org
admin_server = kerberos.gratuitous.org
DOOMCOM.ORG = {
kdc = kerberos.doomcom.org
admin_server = kerberos.doomcom.org
ANDREW.CMU.EDU = {
kdc = kerberos.andrew.cmu.edu
kdc = kerberos2.andrew.cmu.edu
kdc = kerberos3.andrew.cmu.edu
admin_server = kerberos.andrew.cmu.edu
default_domain = andrew.cmu.edu
CS.CMU.EDU = {
kdc = kerberos.cs.cmu.edu
kdc = kerberos-2.srv.cs.cmu.edu
admin_server = kerberos.cs.cmu.edu
DEMENTIA.ORG = {
kdc = kerberos.dementix.org
kdc = kerberos2.dementix.org
admin_server = kerberos.dementix.org
stanford.edu = {
kdc = krb5auth1.stanford.edu
kdc = krb5auth2.stanford.edu
kdc = krb5auth3.stanford.edu
master_kdc = krb5auth1.stanford.edu
admin_server = krb5-admin.stanford.edu
default_domain = stanford.edu
UTORONTO.CA = {
kdc = kerberos1.utoronto.ca
kdc = kerberos2.utoronto.ca
kdc = kerberos3.utoronto.ca
admin_server = kerberos1.utoronto.ca
default_domain = utoronto.ca
[domain_realm]
.mit.edu = ATHENA.MIT.EDU
.media.mit.edu = MEDIA-LAB.MIT.EDU
.csail.mit.edu = CSAIL.MIT.EDU
.whoi.edu = ATHENA.MIT.EDU
.stanford.edu = stanford.edu
.slac.stanford.edu = SLAC.STANFORD.EDU
.toronto.edu = UTORONTO.CA
.utoronto.ca = UTORONTO.CA
[login]
krb4_convert = true
krb4_get_tickets = false
smb.conf
[code][global]
netbios name = SRVFICHIERS2
workgroup = MONDOMAINE
security = ADS
encrypt passwords = yes
idmap config *:backend = tdb
idmap config *:range = 70001-80000
idmap config MONDOMAINE:backend = ad
idmap config MONDOMAINE:schema_mode = rfc2307
idmap config MONDOMAINE:range = 3000000-4000000
winbind nss info = rfc2307
winbind trusted domains only = no
winbind use default domain = yes
winbind enum users = yes
winbind enum groups = yes
vfs objects = acl_xattr
map acl inherit = Yes
store dos attributes = Yes
[test]
path=/home/test
browseable = yes
read only = no
guest ok = yes
writeable = yes
admin users = “@MONDOMAINE\Domain Admins”
nsswitch
[code]# /etc/nsswitch.conf
Example configuration of GNU Name Service Switch functionality.
If you have the glibc-doc-reference' andinfo’ packages installed, try:
`info libc “Name Service Switch”’ for information about this file.
passwd: compat winbind
group: compat winbind
shadow: compat winbind
gshadow: files
hosts: files dns
networks: files
protocols: db files
services: db files
ethers: db files
rpc: db files
netgroup: nis
