Bonsoir
J’a fait un upgrade de Woody vers Sarge et KDE ne s’est pas installé.
apt-get install kde me donne :
debian:/home/jerome# apt-get install kde
Reading Package Lists… Done
Building Dependency Tree… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
kde: Depends: kdelibs3 but it is not going to be installed
Depends: libarts or
libarts-alsa but it is not going to be installed or
libarts-bin but it is not installable
Depends: libkmid or
libkmid-alsa but it is not going to be installed or
libkmid-bin but it is not installable
Depends: kdebase but it is not going to be installed or
kdebase3 but it is not installable
Depends: kdebase-audiolibs but it is not going to be installed or
kdebase3-audiolibs but it is not installable
Depends: kdebase-libs but it is not going to be installed or
kdebase3-libs but it is not installable
Depends: konqueror but it is not going to be installed or
konqueror3 but it is not installable
Depends: kate but it is not going to be installed or
kate3 but it is not installable
Depends: kscreensaver but it is not going to be installed or
kscreensaver3 but it is not installable
Depends: kmail but it is not going to be installed
Depends: kab but it is not going to be installed
Depends: karm but it is not going to be installed
Depends: knotes but it is not going to be installed
Depends: kpm but it is not going to be installed
Depends: kfract but it is not going to be installed
Depends: koffice but it is not going to be installed
E: Broken packages
