Je n’arrive pas a installer un scanner sur mon reseau local.
J’ai installé un serveur sous debian qui me permet de partager mon imprimante multifonction epson rx700, ça marche pour l’imprimante avec cups (sauf l’administration depuis la machine distante mais je peux contourner le problème avec ssh) mais pas pour le scanner avec sane.
Voici ma configuration:
côté serveur:
ip fixe 192.168.0.7
paquets installés : inetutils-inetd et sane-utils.
fichier /etc/sane.d/saned.conf:
[code]#
saned.conf
The contents of the saned.conf file is a list of host names, IP
addresses or IP subnets (CIDR notation) that are permitted to use local
SANE devices. IPv6 addresses must be enclosed in brackets, and should
always be specified in their compressed form.
The hostname matching is not case-sensitive.
#scan-client.somedomain.firm
#192.168.0.1
192.168.0.*
#[2001:7a8:185e::42:12]
#[2001:7a8:185e::42:12]/64
NOTE: /etc/inetd.conf (or /etc/xinetd.conf) and
/etc/services must also be properly configured to start
the saned daemon as documented in saned(8), services(4)
and inetd.conf(4) (or xinetd.conf(5)).
fichier /etc/inetd.conf:
le user appartient aux groupes saned et scanner
Un sane-find-scanner renvoit :
[code]# sane-find-scanner will now attempt to detect your scanner. If the
result is different from what you expected, first make sure your
scanner is powered up and properly connected to your computer.
No SCSI scanners found. If you expected something different, make sure that
you have loaded a kernel SCSI driver for your SCSI adapter.
Also you need support for SCSI Generic (sg) in your operating system.
If using Linux, try “modprobe sg”.
found USB scanner (vendor=0x04b8 [EPSON], product=0x0810 [USB2.0 MFP(Hi-Speed)]) at libusb:005:004
Your USB scanner was (probably) detected. It may or may not be supported by
SANE. Try scanimage -L and read the backend’s manpage.
Not checking for parallel port scanners.
Most Scanners connected to the parallel port or other proprietary ports
can’t be detected by this program.
donc le scanner est trouvé.
Le fichier/etc/services a bien la ligne :
Après configuration j’ai fait un /etc/init.d/inetutils-inetd restart
Sur ce serveur je n’ai pas encore défini de règle iptabes ni sur le client d’ailleur.
sur le client:
le fichier /etc/sane.d/net.conf a bien l’adresse du serveur 192.168.0.7
et xsane est installé.
Quand je lance xsane il ne trouve pas de périphérique.
J’ai surement merdé dans un truc mais je ne trouve pas où si quelqu’un a une idée je suis preneur merci d’avance.
