Scanner non-accessible en tant qu'utilisateur [résolu]
Je viens vers vous avec un truc bizarre. Tout fonctionnait très bien jusqu’à une mise à jour récente de Debian. Mon scanner n’est plus reconnu que sous root. Voici quelques retours de commandes en utilisateur et en tant que root :
$ scanimage -L No scanners were identified. If you were expecting something different, check that the scanner is plugged in, turned on and detected by the sane-find-scanner tool (if appropriate). Please read the documentation which came with this software (README, FAQ, manpages).
# scanimage -L device `hpaio:/usb/psc_1310_series?serial=CN516C223RO2' is a Hewlett-Packard psc_1310_series all-in-one
$ sane-find-scanner # sane-find-scanner will now attempt to detect your scanner. If the # result is different from what you expected, first make sure your # scanner is powered up and properly connected to your computer. # No SCSI scanners found. If you expected something different, make sure that # you have loaded a kernel SCSI driver for your SCSI adapter. # Also you need support for SCSI Generic (sg) in your operating system. # If using Linux, try "modprobe sg". # No USB scanners found. If you expected something different, make sure that # you have loaded a kernel driver for your USB host controller and have setup # the USB system correctly. See man sane-usb for details. # Not checking for parallel port scanners. # Most Scanners connected to the parallel port or other proprietary ports # can't be detected by this program. # You may want to run this program as root to find all devices. Once you # found the scanner devices, be sure to adjust access permissions as # necessary.
[code] # sane-find-scanner
make sure that
system.
# If using Linux, try “modprobe sg”.
found USB scanner (vendor=0x03f0 [hp], product=0x3f11 [psc 1310
series ]) at libusb:002:002
# Your USB scanner was (probably) detected. It may or may not be
supported by
# SANE. Try scanimage -L and read the backend’s manpage.
proprietary ports
# can’t be detected by this program.[/code]
et confirmation
# lsusb Bus 003 Device 001: ID 0000:0000 Bus 002 Device 002: ID 03f0:3f11 Hewlett-Packard PSC-1315/PSC-1317 Bus 002 Device 001: ID 0000:0000 Bus 001 Device 003: ID 046d:c040 Logitech, Inc. Bus 001 Device 001: ID 0000:0000
J’ai alors donné des droits :
# chmod a+rw /proc/bus/usb/002/002
Toujours rien, “aucun périphérique disponible”.
Une autre idée de solution… merci
PS : je rajoute : Debian Lenny, kde 3.5.8, Imprimante tout en un Hppsc 1315
Tu as lu ce thread ?
Cver1
Non, je n’avais ni vu donc pas lu ce post. Ta solution est radicale. comme dirais Monsieur le gendarme dans “Oui-oui” à ma fille :
“Le problèem du scanner est résolu!” :wink:
Je répète la solution :
adduser nom_de_l_utilisateur scanner
  • reboot.
Merci de cette solution rapide et ô combien appréciée.
Tant mieux ! C’est pas souvent que je résous des problèmes.
PS : Il y a 18 ans, c’est moi qui lisait Oui-Oui :mrgreen:
