Ca ne fonctionne pas
Voici mon xorg.0.log. Désolé de faire un long post, j’éditerai pour le réduire une fois le problème trouvé.
X Window System Version 7.1.1
Release Date: 12 May 2006
X Protocol Version 11, Revision 0, Release 7.1.1
Build Operating System: UNKNOWN
Current Operating System: Linux debian 2.6.18-6-686 #1 SMP Sun Feb 10 22:11:31 UTC 2008 i686
Build Date: 29 May 2008
Before reporting problems, check http://wiki.x.org
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.0.log", Time: Sun Sep 28 17:43:47 2008
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "Default Layout"
(**) |-->Screen "Default Screen" (0)
(**) | |-->Monitor "Écran générique"
(**) | |-->Device "nVidia Corporation NVIDIA Default Card"
(**) |-->Input Device "Generic Keyboard"
(**) |-->Input Device "Configured Mouse"
(**) |-->Input Device "Synaptics Touchpad"
(WW) The directory "/usr/X11R6/lib/X11/fonts/misc" does not exist.
Entry deleted from font path.
(WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/cyrillic" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/100dpi/" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/75dpi/" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/Type1" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/100dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/75dpi" does not exist.
(**) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType
(==) RgbPath set to "/etc/X11/rgb"
(==) ModulePath set to "/usr/lib/xorg/modules"
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 1.0
X.Org XInput driver : 0.6
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) Module bitmap: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.0.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.5
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules/libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
ABI class: X.Org Video Driver, version 1.0
(--) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,2a00 card 103c,30cc rev 0c class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,2a01 card 0000,0000 rev 0c class 06,04,00 hdr 01
(II) PCI: 00:1a:0: chip 8086,2834 card 103c,30cc rev 03 class 0c,03,00 hdr 80
(II) PCI: 00:1a:1: chip 8086,2835 card 103c,30cc rev 03 class 0c,03,00 hdr 00
(II) PCI: 00:1a:7: chip 8086,283a card 103c,30cc rev 03 class 0c,03,20 hdr 00
(II) PCI: 00:1b:0: chip 8086,284b card 103c,30cc rev 03 class 04,03,00 hdr 00
(II) PCI: 00:1c:0: chip 8086,283f card 0000,0000 rev 03 class 06,04,00 hdr 81
(II) PCI: 00:1c:1: chip 8086,2841 card 0000,0000 rev 03 class 06,04,00 hdr 81
(II) PCI: 00:1c:5: chip 8086,2849 card 0000,0000 rev 03 class 06,04,00 hdr 81
(II) PCI: 00:1d:0: chip 8086,2830 card 103c,30cc rev 03 class 0c,03,00 hdr 80
(II) PCI: 00:1d:1: chip 8086,2831 card 103c,30cc rev 03 class 0c,03,00 hdr 00
(II) PCI: 00:1d:2: chip 8086,2832 card 103c,30cc rev 03 class 0c,03,00 hdr 00
(II) PCI: 00:1d:7: chip 8086,2836 card 103c,30cc rev 03 class 0c,03,20 hdr 00
(II) PCI: 00:1e:0: chip 8086,2448 card 0000,0000 rev f3 class 06,04,01 hdr 01
(II) PCI: 00:1f:0: chip 8086,2815 card 103c,30cc rev 03 class 06,01,00 hdr 80
(II) PCI: 00:1f:1: chip 8086,2850 card 103c,30cc rev 03 class 01,01,8a hdr 00
(II) PCI: 00:1f:2: chip 8086,2829 card 103c,30cc rev 03 class 01,06,01 hdr 00
(II) PCI: 00:1f:3: chip 8086,283e card 103c,30cc rev 03 class 0c,05,00 hdr 00
(II) PCI: 01:00:0: chip 10de,0427 card 103c,30cc rev a1 class 03,00,00 hdr 00
(II) PCI: 02:00:0: chip 8086,4229 card 8086,1101 rev 61 class 02,80,00 hdr 00
(II) PCI: 06:00:0: chip 10ec,8136 card 103c,30cc rev 01 class 02,00,00 hdr 00
(II) PCI: 07:09:0: chip 1180,0832 card 103c,30cc rev 05 class 0c,00,10 hdr 80
(II) PCI: 07:09:1: chip 1180,0822 card 103c,30cc rev 22 class 08,05,00 hdr 80
(II) PCI: 07:09:2: chip 1180,0843 card 103c,30cc rev 12 class 08,80,00 hdr 80
(II) PCI: 07:09:3: chip 1180,0592 card 103c,30cc rev 12 class 08,80,00 hdr 80
(II) PCI: 07:09:4: chip 1180,0852 card 103c,30cc rev 12 class 08,80,00 hdr 80
(II) PCI: End of PCI scan
(II) Intel Bridge workaround enabled
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,7), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x001a (VGA_EN is set)
(II) Bus 1 I/O range:
[0] -1 0 0x00002000 - 0x00002fff (0x1000) IX[B]
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xc4000000 - 0xc6ffffff (0x3000000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B]
(II) Bus 2: bridge is at (0:28:0), (0,2,3), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 2 I/O range:
[0] -1 0 0x00004000 - 0x000040ff (0x100) IX[B]
[1] -1 0 0x00004400 - 0x000044ff (0x100) IX[B]
[2] -1 0 0x00004800 - 0x000048ff (0x100) IX[B]
[3] -1 0 0x00004c00 - 0x00004cff (0x100) IX[B]
[4] -1 0 0x00005000 - 0x000050ff (0x100) IX[B]
[5] -1 0 0x00005400 - 0x000054ff (0x100) IX[B]
[6] -1 0 0x00005800 - 0x000058ff (0x100) IX[B]
[7] -1 0 0x00005c00 - 0x00005cff (0x100) IX[B]
[8] -1 0 0x00006000 - 0x000060ff (0x100) IX[B]
[9] -1 0 0x00006400 - 0x000064ff (0x100) IX[B]
[10] -1 0 0x00006800 - 0x000068ff (0x100) IX[B]
[11] -1 0 0x00006c00 - 0x00006cff (0x100) IX[B]
[12] -1 0 0x00007000 - 0x000070ff (0x100) IX[B]
[13] -1 0 0x00007400 - 0x000074ff (0x100) IX[B]
[14] -1 0 0x00007800 - 0x000078ff (0x100) IX[B]
[15] -1 0 0x00007c00 - 0x00007cff (0x100) IX[B]
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xf4000000 - 0xf7ffffff (0x4000000) MX[B]
(II) Bus 2 prefetchable memory range:
[0] -1 0 0xf0000000 - 0xf3ffffff (0x4000000) MX[B]
(II) Bus 4: bridge is at (0:28:1), (0,4,5), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 4 I/O range:
[0] -1 0 0x00008000 - 0x000080ff (0x100) IX[B]
[1] -1 0 0x00008400 - 0x000084ff (0x100) IX[B]
[2] -1 0 0x00008800 - 0x000088ff (0x100) IX[B]
[3] -1 0 0x00008c00 - 0x00008cff (0x100) IX[B]
[4] -1 0 0x00009000 - 0x000090ff (0x100) IX[B]
[5] -1 0 0x00009400 - 0x000094ff (0x100) IX[B]
[6] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]
[7] -1 0 0x00009c00 - 0x00009cff (0x100) IX[B]
[8] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]
[9] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX[B]
[10] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX[B]
[11] -1 0 0x0000ac00 - 0x0000acff (0x100) IX[B]
[12] -1 0 0x0000b000 - 0x0000b0ff (0x100) IX[B]
[13] -1 0 0x0000b400 - 0x0000b4ff (0x100) IX[B]
[14] -1 0 0x0000b800 - 0x0000b8ff (0x100) IX[B]
[15] -1 0 0x0000bc00 - 0x0000bcff (0x100) IX[B]
(II) Bus 4 prefetchable memory range:
[0] -1 0 0xc8000000 - 0xcbffffff (0x4000000) MX[B]
(II) Bus 6: bridge is at (0:28:5), (0,6,6), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 6 I/O range:
[0] -1 0 0x0000c000 - 0x0000c0ff (0x100) IX[B]
[1] -1 0 0x0000c400 - 0x0000c4ff (0x100) IX[B]
[2] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B]
[3] -1 0 0x0000cc00 - 0x0000ccff (0x100) IX[B]
(II) Bus 6 non-prefetchable memory range:
[0] -1 0 0xf8000000 - 0xf80fffff (0x100000) MX[B]
(II) Bus 6 prefetchable memory range:
[0] -1 0 0xc2000000 - 0xc20fffff (0x100000) MX[B]
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 7: bridge is at (0:30:0), (0,7,7), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 7 non-prefetchable memory range:
[0] -1 0 0xf8100000 - 0xf81fffff (0x100000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI:*(1:0:0) nVidia Corporation unknown chipset (0x0427) rev 161, Mem @ 0xc6000000/24, 0xd0000000/28, 0xc4000000/25, I/O @ 0x2000/7
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
[0] -1 0 0xf8101400 - 0xf81014ff (0x100) MX[B]
[1] -1 0 0xf8101000 - 0xf81010ff (0x100) MX[B]
[2] -1 0 0xf8100c00 - 0xf8100cff (0x100) MX[B]
[3] -1 0 0xf8100800 - 0xf81008ff (0x100) MX[B]
[4] -1 0 0xf8100000 - 0xf81007ff (0x800) MX[B]
[5] -1 0 0xf8000000 - 0xf8000fff (0x1000) MX[B]
[6] -1 0 0xf4000000 - 0xf4001fff (0x2000) MX[B]
[7] -1 0 0xc2100000 - 0xc21000ff (0x100) MX[B]
[8] -1 0 0xf8404000 - 0xf84047ff (0x800) MX[B]
[9] -1 0 0xf8404c00 - 0xf8404fff (0x400) MX[B]
[10] -1 0 0xf8400000 - 0xf8403fff (0x4000) MX[B]
[11] -1 0 0xf8404800 - 0xf8404bff (0x400) MX[B]
[12] -1 0 0xc4000000 - 0xc5ffffff (0x2000000) MX[B](B)
[13] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B](B)
[14] -1 0 0xc6000000 - 0xc6ffffff (0x1000000) MX[B](B)
[15] -1 0 0x0000c000 - 0x0000c0ff (0x100) IX[B]
[16] -1 0 0x00001c00 - 0x00001c1f (0x20) IX[B]
[17] -1 0 0x000018e0 - 0x000018ff (0x20) IX[B]
[18] -1 0 0x000018c8 - 0x000018cb (0x4) IX[B]
[19] -1 0 0x000018d0 - 0x000018d7 (0x8) IX[B]
[20] -1 0 0x000018cc - 0x000018cf (0x4) IX[B]
[21] -1 0 0x000018d8 - 0x000018df (0x8) IX[B]
[22] -1 0 0x000018a0 - 0x000018af (0x10) IX[B]
[23] -1 0 0x00001880 - 0x0000189f (0x20) IX[B]
[24] -1 0 0x00001860 - 0x0000187f (0x20) IX[B]
[25] -1 0 0x00001840 - 0x0000185f (0x20) IX[B]
[26] -1 0 0x00001820 - 0x0000183f (0x20) IX[B]
[27] -1 0 0x00001800 - 0x0000181f (0x20) IX[B]
[28] -1 0 0x00002000 - 0x0000207f (0x80) IX[B](B)
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xf8101400 - 0xf81014ff (0x100) MX[B]
[5] -1 0 0xf8101000 - 0xf81010ff (0x100) MX[B]
[6] -1 0 0xf8100c00 - 0xf8100cff (0x100) MX[B]
[7] -1 0 0xf8100800 - 0xf81008ff (0x100) MX[B]
[8] -1 0 0xf8100000 - 0xf81007ff (0x800) MX[B]
[9] -1 0 0xf8000000 - 0xf8000fff (0x1000) MX[B]
[10] -1 0 0xf4000000 - 0xf4001fff (0x2000) MX[B]
[11] -1 0 0xc2100000 - 0xc21000ff (0x100) MX[B]
[12] -1 0 0xf8404000 - 0xf84047ff (0x800) MX[B]
[13] -1 0 0xf8404c00 - 0xf8404fff (0x400) MX[B]
[14] -1 0 0xf8400000 - 0xf8403fff (0x4000) MX[B]
[15] -1 0 0xf8404800 - 0xf8404bff (0x400) MX[B]
[16] -1 0 0xc4000000 - 0xc5ffffff (0x2000000) MX[B](B)
[17] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B](B)
[18] -1 0 0xc6000000 - 0xc6ffffff (0x1000000) MX[B](B)
[19] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[20] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[21] -1 0 0x0000c000 - 0x0000c0ff (0x100) IX[B]
[22] -1 0 0x00001c00 - 0x00001c1f (0x20) IX[B]
[23] -1 0 0x000018e0 - 0x000018ff (0x20) IX[B]
[24] -1 0 0x000018c8 - 0x000018cb (0x4) IX[B]
[25] -1 0 0x000018d0 - 0x000018d7 (0x8) IX[B]
[26] -1 0 0x000018cc - 0x000018cf (0x4) IX[B]
[27] -1 0 0x000018d8 - 0x000018df (0x8) IX[B]
[28] -1 0 0x000018a0 - 0x000018af (0x10) IX[B]
[29] -1 0 0x00001880 - 0x0000189f (0x20) IX[B]
[30] -1 0 0x00001860 - 0x0000187f (0x20) IX[B]
[31] -1 0 0x00001840 - 0x0000185f (0x20) IX[B]
[32] -1 0 0x00001820 - 0x0000183f (0x20) IX[B]
[33] -1 0 0x00001800 - 0x0000181f (0x20) IX[B]
[34] -1 0 0x00002000 - 0x0000207f (0x80) IX[B](B)
(II) Reloading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) LoadModule: "ddc"
(II) Loading /usr/lib/xorg/modules/libddc.so
(II) Module ddc: vendor="X.Org Foundation"
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
ABI class: X.Org Server Extension, version 0.3
(II) Loading sub module "drm"
(II) LoadModule: "drm"
(II) Loading /usr/lib/xorg/modules/linux/libdrm.so
(II) Module drm: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
Module class: X.Org Server Extension
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules/fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 7.1.1, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules/libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules/libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.1.0
(II) LoadModule: "nv"
(II) Loading /usr/lib/xorg/modules/drivers/nv_drv.so
(II) Module nv: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 2.0.3
Module class: X.Org Video Driver
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input/kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.6
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input/mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.1.1
(II) LoadModule: "synaptics"
(II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
(II) Module synaptics: vendor="The XFree86 Project"
compiled for 4.2.0, module version = 1.0.0
Module class: XFree86 XInput Driver
ABI class: XFree86 XInput driver, version 0.3
(II) NV: driver for NVIDIA chipsets: RIVA 128, RIVA TNT, RIVA TNT2,
Unknown TNT2, Vanta, RIVA TNT2 Ultra, RIVA TNT2 Model 64,
Aladdin TNT2, GeForce 256, GeForce DDR, Quadro, GeForce2 MX/MX 400,
GeForce2 MX 100/200, GeForce2 Go, Quadro2 MXR/EX/Go,
GeForce2 Integrated GPU, GeForce2 GTS, GeForce2 Ti, GeForce2 Ultra,
Quadro2 Pro, GeForce4 MX 460, GeForce4 MX 440, GeForce4 MX 420,
GeForce4 MX 440-SE, GeForce4 440 Go, GeForce4 420 Go,
GeForce4 420 Go 32M, GeForce4 460 Go, Quadro4 550 XGL,
GeForce4 440 Go 64M, Quadro NVS, Quadro4 500 GoGL,
GeForce4 410 Go 16M, GeForce4 MX 440 with AGP8X,
GeForce4 MX 440SE with AGP8X, GeForce4 MX 420 with AGP8X,
GeForce4 MX 4000, GeForce4 448 Go, GeForce4 488 Go, Quadro4 580 XGL,
Quadro4 NVS 280 SD, Quadro4 380 XGL, Quadro NVS 50 PCI,
GeForce4 448 Go, GeForce4 MX Integrated GPU, GeForce3,
GeForce3 Ti 200, GeForce3 Ti 500, Quadro DCC, GeForce4 Ti 4600,
GeForce4 Ti 4400, GeForce4 Ti 4200, Quadro4 900 XGL, Quadro4 750 XGL,
Quadro4 700 XGL, GeForce4 Ti 4800, GeForce4 Ti 4200 with AGP8X,
GeForce4 Ti 4800 SE, GeForce4 4200 Go, Quadro4 700 GoGL,
Quadro4 980 XGL, Quadro4 780 XGL, GeForce FX 5800 Ultra,
GeForce FX 5800, Quadro FX 2000, Quadro FX 1000,
GeForce FX 5600 Ultra, GeForce FX 5600, GeForce FX 5600XT,
GeForce FX Go5600, GeForce FX Go5650, Quadro FX Go700,
GeForce FX 5200, GeForce FX 5200 Ultra, GeForce FX 5200,
GeForce FX 5200LE, GeForce FX Go5200, GeForce FX Go5250,
GeForce FX 5500, GeForce FX 5100, GeForce FX Go5200 32M/64M,
Quadro NVS 55/280 PCI, Quadro FX 500/600 PCI,
GeForce FX Go53xx Series, GeForce FX Go5100, GeForce FX 5900 Ultra,
GeForce FX 5900, GeForce FX 5900XT, GeForce FX 5950 Ultra,
GeForce FX 5900ZT, Quadro FX 3000, Quadro FX 700,
GeForce FX 5700 Ultra, GeForce FX 5700, GeForce FX 5700LE,
GeForce FX 5700VE, GeForce FX Go5700, GeForce FX Go5700,
Quadro FX Go1000, Quadro FX 1100, GeForce 6800 Ultra, GeForce 6800,
GeForce 6800 LE, GeForce 6800 XE, GeForce 6800 XT, GeForce 6800 GT,
GeForce 6800 GT, GeForce 6800 GS, GeForce 6800 XT, Quadro FX 4000,
GeForce 6800 GS, GeForce 6800, GeForce 6800 LE, GeForce 6800 XT,
GeForce Go 6800, GeForce Go 6800 Ultra, Quadro FX Go1400,
Quadro FX 3450/4000 SDI, Quadro FX 1400, GeForce 6600 GT,
GeForce 6600, GeForce 6600 LE, GeForce 6600 VE, GeForce Go 6600,
GeForce 6610 XL, GeForce Go 6600 TE/6200 TE, GeForce 6700 XL,
GeForce Go 6600, GeForce Go 6600 GT, Quadro FX 550, Quadro FX 550,
Quadro FX 540, GeForce 6200, GeForce 6500,
GeForce 6200 TurboCache(TM), GeForce 6200SE TurboCache(TM),
GeForce 6200 LE, GeForce Go 6200, Quadro NVS 285, GeForce Go 6400,
GeForce Go 6200, GeForce Go 6400, GeForce 6250, GeForce 6800,
GeForce 6800 LE, GeForce 6800 GT, GeForce 6800 XT, GeForce 6200,
GeForce 6200 A-LE, GeForce 7800 GTX, GeForce 7800 GTX,
GeForce 7800 GT, GeForce 7800 GS, GeForce 7800 SLI, GeForce Go 7800,
GeForce Go 7800 GTX, Quadro FX 4500, GeForce 7300 LE,
GeForce 7300 SE, GeForce Go 7200, GeForce Go 7300, GeForce Go 7400,
GeForce Go 7400 GS, Quadro NVS 110M, Quadro NVS 120M, Quadro FX 350M,
GeForce 7500 LE, Quadro FX 350, GeForce 7300 GS, GeForce 7600 GT,
GeForce 7600 GS, GeForce 7300 GT, GeForce 7600 LE, GeForce 7300 GT,
GeForce Go 7700, GeForce Go 7600, GeForce Go 7600 GT,
Quadro NVS 300M, GeForce Go 7900 SE, Quadro FX 550M, Quadro FX 560,
GeForce 7900 GTX, GeForce 7900 GT, GeForce 7900 GS,
GeForce Go 7900 GS, GeForce Go 7900 GTX, Quadro FX 2500M,
Quadro FX 1500M, Quadro FX 5500, Quadro FX 3500, Quadro FX 1500,
Quadro FX 4500 X2, GeForce 6150, GeForce 6150 LE, GeForce 6100,
GeForce Go 6150, GeForce Go 6100, GeForce 8800 GTX, GeForce 8800 GTS,
GeForce 8800 Ultra, Quadro FX 5600, Quadro FX 4600, GeForce 8600 GTS,
GeForce 8600 GT, GeForce 8400 GS, GeForce 8600M GT, GeForce 8700M GT,
Quadro FX 370, Quadro NVS 320M, Quadro FX 570M, Quadro FX 1600M,
Quadro FX 570, Quadro FX 1700, GeForce 8500 GT, GeForce 8400 GS,
GeForce 8300 GS, GeForce 8600M GS, GeForce 8400M GT,
GeForce 8400M GS, GeForce 8400M G, Quadro NVS 140M, Quadro NVS 130M,
Quadro NVS 135M, Quadro FX 360M, Quadro NVS 290, GeForce 8800 GT,
Quadro FX 3700
(II) Primary Device is: PCI 01:00:0
(--) Chipset GeForce 8400M GS found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[19] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[20] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[21] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[22] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[23] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[24] -1 0 0x0000c000 - 0x0000c0ff (0x100) IX[B]
[25] -1 0 0x00001c00 - 0x00001c1f (0x20) IX[B]
[26] -1 0 0x000018e0 - 0x000018ff (0x20) IX[B]
[27] -1 0 0x000018c8 - 0x000018cb (0x4) IX[B]
[28] -1 0 0x000018d0 - 0x000018d7 (0x8) IX[B]
[29] -1 0 0x000018cc - 0x000018cf (0x4) IX[B]
[30] -1 0 0x000018d8 - 0x000018df (0x8) IX[B]
[31] -1 0 0x000018a0 - 0x000018af (0x10) IX[B]
[32] -1 0 0x00001880 - 0x0000189f (0x20) IX[B]
[33] -1 0 0x00001860 - 0x0000187f (0x20) IX[B]
[34] -1 0 0x00001840 - 0x0000185f (0x20) IX[B]
[35] -1 0 0x00001820 - 0x0000183f (0x20) IX[B]
[36] -1 0 0x00001800 - 0x0000181f (0x20) IX[B]
[37] -1 0 0x00002000 - 0x0000207f (0x80) IX[B](B)
[38] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[39] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) Loading sub module "int10"
(II) Reloading /usr/lib/xorg/modules/libint10.so
(II) NV(0): Initializing int10
(II) Loading sub module "vm86"
(II) LoadModule: "vm86"
(II) Loading /usr/lib/xorg/modules/libvm86.so
(II) Module vm86: vendor="X.Org Foundation"
(II) NV(0): Primary V_BIOS segment is: 0xc000
(--) NV(0): Console is VGA mode 0x3
(**) NV(0): Depth 24, (--) framebuffer bpp 32
(==) NV(0): RGB weight 888
(==) NV(0): Default visual is TrueColor
(==) NV(0): Using hardware cursor
(==) NV(0): Using gamma correction (1.0, 1.0, 1.0)
(--) NV(0): MMIO registers at 0xc6000000
(--) NV(0): Linear framebuffer at 0xd0000000
(II) NV(0): MMIO registers mapped at 0xb6b48000
(--) NV(0): Total video RAM: 256.0 MB
(--) NV(0): BAR1 size: 256.0 MB
(--) NV(0): Mapped memory: 255.0 MB
(II) NV(0): Linear framebuffer mapped at 0xa6c48000
(II) Loading sub module "i2c"
(II) LoadModule: "i2c"
(II) Loading /usr/lib/xorg/modules/libi2c.so
(II) Module i2c: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.2.0
(II) Loading sub module "ddc"
(II) Reloading /usr/lib/xorg/modules/libddc.so
(--) NV(0): I2C map:
(--) NV(0): Bus 0 -> DAC1
(--) NV(0): Bus 1 -> SOR1
(--) NV(0): Bus 2 -> SOR0
(--) NV(0): Load detection: 279
(II) NV(0): I2C bus "DDC" initialized.
(II) NV(0): Probing for EDID on I2C bus 0...
(II) NV(0): I2C device "DDC:ddc2" registered at address 0xA0.
(II) NV(0): I2C device "DDC:ddc2" removed.
(II) NV(0): ... none found
(II) NV(0): I2C bus "DDC" removed.
(II) NV(0): Probing for EDID on I2C bus 1...
(II) NV(0): Probing for EDID on I2C bus 2...
(--) NV(0): Trying load detection on DAC1 ... nothing.
(--) NV(0): Trying load detection on DAC2 ... nothing.
(EE) NV(0): No display devices found
(II) UnloadModule: "nv"
(II) UnloadModule: "ddc"
(II) UnloadModule: "i2c"
(II) Unloading /usr/lib/xorg/modules/libi2c.so
(II) UnloadModule: "vm86"
(II) Unloading /usr/lib/xorg/modules/libvm86.so
(II) UnloadModule: "int10"
(EE) Screen(s) found, but none have a usable configuration.
Fatal server error:
no screens found
tu y verras peut etre plus clair que moi
edit : j’ai trouvé sur le wiki de X.org un problème similaire mais je n’ai pas les logs sugerés
edit 2 :par contre sur le forum de ubuntu, cette personne semble avoir le +/- même soucis mais pas de solutions proposées. Je ne perds pas espoire et continue de chercher
