[quote]GForce N6200 128 MB DDR opengl support AGP 8X DVI/TVout [/quote]
[code]
# dmidecode 2.9
SMBIOS 2.3 present.
47 structures occupying 1363 bytes.
Table at 0x000F2A80.
Handle 0x0000, DMI type 0, 20 bytes
BIOS Information
Vendor: Award Software, Inc.
Version: ASUS A7V266-E ACPI BIOS Rev 1004B
Release Date: 11/07/2001
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 256 kB
Characteristics:
PCI is supported
PNP is supported
APM is supported
BIOS is upgradeable
BIOS shadowing is allowed
ESCD support is available
Boot from CD is supported
Selectable boot is supported
BIOS ROM is socketed
EDD is supported
5.25"/360 KB floppy services are supported (int 13h)
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 KB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
CGA/mono video services are supported (int 10h)
ACPI is supported
AGP is supported
Handle 0x0001, DMI type 1, 25 bytes
System Information
Manufacturer: System Manufacturer
Product Name: System Name
Version: System Version
Serial Number: SYS-1234567890
UUID: Not Settable
Wake-up Type: Power Switch
Handle 0x0002, DMI type 2, 8 bytes
Base Board Information
Manufacturer: ASUSTeK Computer INC.
Product Name: A7V266-E
Version: REV 1.xx
Serial Number: xxxxxxxxxxx
Handle 0x0003, DMI type 3, 17 bytes
Chassis Information
Manufacturer: Chassis Manufacture
Type: Tower
Lock: Not Present
Version: Chassis Version
Serial Number: Chassis Serial Number
Asset Tag: Asset-1234567890
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Safe
Security Status: Unknown
OEM Information: 0x00000000
Handle 0x0004, DMI type 4, 32 bytes
Processor Information
Socket Designation: SOCKET A
Type: Central Processor
Family: Other
Manufacturer: AuthenticAMD
ID: 62 06 00 00 FF F9 83 03
Signature: Family 6, Model 6, Stepping 2
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
MMX (MMX technology supported)
FXSR (Fast floating-point save and restore)
SSE (Streaming SIMD extensions)
Version: AMD Athlon(TM) Processor
Voltage: 1.7 V
External Clock: 100 MHz
Max Speed: 1700 MHz
Current Speed: 1050 MHz
Status: Populated, Enabled
Upgrade: Other
L1 Cache Handle: 0x0009
L2 Cache Handle: 0x000A
L3 Cache Handle: Not Provided
Handle 0x0005, DMI type 5, 22 bytes
Memory Controller Information
Error Detecting Method: None
Error Correcting Capabilities:
Other
Supported Interleave: Unknown
Current Interleave: Unknown
Maximum Memory Module Size: 512 MB
Maximum Total Memory Size: 1536 MB
Supported Speeds:
70 ns
60 ns
50 ns
Supported Memory Types:
DIMM
SDRAM
Memory Module Voltage: 3.3 V
Associated Memory Slots: 3
0x0006
0x0007
0x0008
Enabled Error Correcting Capabilities:
Unknown
Handle 0x0006, DMI type 6, 12 bytes
Memory Module Information
Socket Designation: DDR DIMM 1
Bank Connections: 0 1
Current Speed: Unknown
Type: DIMM SDRAM
Installed Size: 512 MB (Double-bank Connection)
Enabled Size: 512 MB (Double-bank Connection)
Error Status: OK
Handle 0x0007, DMI type 6, 12 bytes
Socket Designation: DDR DIMM 2
Bank Connections: 2 3
Type: DIMM SDRAM
Installed Size: 1024 MB (Double-bank Connection)
Enabled Size: 1024 MB (Double-bank Connection)
Error Status: OK
Handle 0x0008, DMI type 6, 12 bytes
Socket Designation: DDR DIMM 3
Bank Connections: 4 5
Type: DIMM SDRAM
Installed Size: Not Installed
Enabled Size: Not Installed
Error Status: OK
Handle 0x0009, DMI type 7, 19 bytes
Cache Information
Socket Designation: L1 Cache
Configuration: Enabled, Not Socketed, Level 1
Operational Mode: Write Back
Installed Size: 32 KB
Maximum Size: 32 KB
Supported SRAM Types:
Pipeline Burst
Synchronous
Installed SRAM Type: Pipeline Burst Synchronous
Speed: Unknown
Error Correction Type: Unknown
System Type: Data
Associativity: 4-way Set-associative
Handle 0x000A, DMI type 7, 19 bytes
Cache Information
Socket Designation: L2 Cache
Configuration: Enabled, Not Socketed, Level 2
Installed Size: 256 KB
Maximum Size: 256 KB
Pipeline Burst
Synchronous
Speed: Unknown
System Type: Data
Handle 0x000B, DMI type 8, 9 bytes
Port Connector Information
Internal Reference Designator: PRIMARY IDE/HDD
Internal Connector Type: On Board IDE
External Reference Designator: Not Specified
External Connector Type: None
Port Type: None
Handle 0x000C, DMI type 8, 9 bytes
Internal Reference Designator: SECONDARY IDE/HDD
Port Type: None
Handle 0x000D, DMI type 8, 9 bytes
Internal Reference Designator: FLOPPY
Internal Connector Type: On Board Floppy
Port Type: None
Handle 0x000E, DMI type 8, 9 bytes
Internal Reference Designator: Not Specified
Internal Connector Type: None
External Reference Designator: USB1
External Connector Type: Access Bus (USB)
Port Type: USB
Handle 0x000F, DMI type 8, 9 bytes
External Reference Designator: USB2
Port Type: USB
Handle 0x0010, DMI type 8, 9 bytes
External Reference Designator: USB3
Port Type: USB
Handle 0x0011, DMI type 8, 9 bytes
External Reference Designator: PS/2 Keybaord
External Connector Type: PS/2
Port Type: Keyboard Port
Handle 0x0012, DMI type 8, 9 bytes
External Reference Designator: PS/2 Mouse
Port Type: Mouse Port
Handle 0x0013, DMI type 8, 9 bytes
External Reference Designator: Parallel Port
External Connector Type: DB-25 female
Port Type: Parallel Port ECP/EPP
Handle 0x0014, DMI type 8, 9 bytes
External Reference Designator: Serial Port
External Connector Type: DB-9 male
Port Type: Serial Port 16550 Compatible
Handle 0x0015, DMI type 8, 9 bytes
External Reference Designator: Serial Port 2
Handle 0x0016, DMI type 8, 9 bytes
External Reference Designator: Joystick Port
External Connector Type: DB-15 female
Port Type: Joystick Port
Handle 0x0017, DMI type 8, 9 bytes
External Reference Designator: MIDI Port
Port Type: MIDI Port
Handle 0x0018, DMI type 8, 9 bytes
External Reference Designator: Video Port
External Connector Type: Mini Jack (headphones)
Port Type: Video Port
Handle 0x0019, DMI type 9, 13 bytes
System Slot Information
Designation: PCI 1
Type: 32-bit PCI
Current Usage: Available
Length: Short
Characteristics:
PME signal is supported
Handle 0x001A, DMI type 9, 13 bytes
Designation: PCI 2
Type: 32-bit PCI
Current Usage: In Use
Length: Short
Characteristics:
Handle 0x001B, DMI type 9, 13 bytes
Designation: PCI 3
Type: 32-bit PCI
Length: Short
Characteristics:
Handle 0x001C, DMI type 9, 13 bytes
Designation: PCI 4
Type: 32-bit PCI
Length: Short
Characteristics:
Handle 0x001D, DMI type 9, 13 bytes
Designation: PCI 5
Type: 32-bit PCI
Length: Short
Characteristics:
Handle 0x001E, DMI type 9, 13 bytes
Designation: AGP
Type: 32-bit PCI
Length: Short
Characteristics:
Handle 0x001F, DMI type 9, 13 bytes
Designation: ACR
Type: 32-bit I/O Riser Card
Length: Long
Characteristics:
5.0 V is provided
3.3 V is provided
Handle 0x0020, DMI type 10, 6 bytes
On Board Device Information
Type: Sound
Status: Disabled
Description: CMEDIA CMI8738
Handle 0x0021, DMI type 10, 6 bytes
Type: Other
Status: Disabled
Description: Promise PDC20265
Handle 0x0022, DMI type 13, 22 bytes
BIOS Language Information
Installable Languages: 1
en|US|iso8859-1
Currently Installed Language: en|US|iso8859-1
Handle 0x0023, DMI type 14, 14 bytes
Group Associations
Items: 3
0x0004 (Processor)
0x0009 (Cache)
0x000A (Cache)
Handle 0x0024, DMI type 14, 29 bytes
Group Associations
Name: Memory Module Set
Items: 8
0x0025 (Physical Memory Array)
0x0026 (Memory Device)
0x002A (Memory Device Mapped Address)
0x0027 (Memory Device)
0x002B (Memory Device Mapped Address)
0x0028 (Memory Device)
0x002C (Memory Device Mapped Address)
0x0029 (Memory Array Mapped Address)
Handle 0x0025, DMI type 16, 15 bytes
Use: System Memory
Error Correction Type: None
Maximum Capacity: 3 GB
Error Information Handle: Not Provided
Number Of Devices: 3
Handle 0x0026, DMI type 17, 23 bytes
Memory Device
Array Handle: 0x0025
Error Information Handle: No Error
Total Width: 72 bits
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: DIMM 1
Bank Locator: Not Specified
Type: DRAM
Type Detail: Synchronous
Speed: Unknown
Handle 0x0027, DMI type 17, 23 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 2
Locator: DIMM 2
Type: DRAM
Speed: Unknown
Handle 0x0028, DMI type 17, 23 bytes
Memory Device
Total Width: Unknown
Data Width: Unknown
Size: No Module Installed
Form Factor: DIMM
Set: 2
Locator: DIMM 3
Type: DRAM
Speed: Unknown
Handle 0x0029, DMI type 19, 15 bytes
Starting Address: 0x00000000000
Ending Address: 0x180000003FF
Range Size: 1610612737 kB
Physical Array Handle: 0x0025
Partition Width: 0
Handle 0x002A, DMI type 20, 19 bytes
Ending Address: 0x0001FFFFFFF
Range Size: 512 MB
Physical Device Handle: 0x0026
Memory Array Mapped Address Handle: 0x0029
Partition Row Position: 1
Handle 0x002B, DMI type 20, 19 bytes
Starting Address: 0x00020000000
Ending Address: 0x0005FFFFFFF
Range Size: 1 GB
Physical Device Handle: 0x0027
Partition Row Position: 2
Handle 0x002C, DMI type 126, 19 bytes
Inactive
Handle 0x002D, DMI type 32, 11 bytes
System Boot Information
Status: No errors detected
Handle 0x002E, DMI type 127, 4 bytes
End Of Table
[quote]dis moi aussi la carte mere ainsi que la carte graph,la memoire,le processeur[/quote]
ma signature .... ;p
# dmidecode 2.9
SMBIOS 2.3 present.
BIOS Information
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 256 kB
Characteristics:
PCI is supported
PNP is supported
APM is supported
BIOS is upgradeable
EDD is supported
ACPI is supported
AGP is supported
System Information
UUID: Not Settable
Version: REV 1.xx
Chassis Information
Type: Tower
Lock: Not Present
Boot-up State: Safe
Thermal State: Safe
Family: Other
Flags:
Voltage: 1.7 V
Max Speed: 1700 MHz
Upgrade: Other
Other
Supported Speeds:
70 ns
60 ns
50 ns
DIMM
SDRAM
0x0006
0x0007
0x0008
Unknown
Type: DIMM SDRAM
Error Status: OK
Type: DIMM SDRAM
Error Status: OK
Type: DIMM SDRAM
Error Status: OK
Cache Information
Maximum Size: 32 KB
Pipeline Burst
Synchronous
Speed: Unknown
System Type: Data
Cache Information
Pipeline Burst
Synchronous
Speed: Unknown
System Type: Data
Port Type: None
Port Type: None
Port Type: None
Port Type: USB
Port Type: USB
Port Type: USB
Designation: PCI 1
Type: 32-bit PCI
Length: Short
Characteristics:
Designation: PCI 2
Type: 32-bit PCI
Length: Short
Characteristics:
Designation: PCI 3
Type: 32-bit PCI
Length: Short
Characteristics:
Designation: PCI 4
Type: 32-bit PCI
Length: Short
Characteristics:
Designation: PCI 5
Type: 32-bit PCI
Length: Short
Characteristics:
Designation: AGP
Type: 32-bit PCI
Length: Short
Characteristics:
Designation: ACR
Length: Long
Characteristics:
5.0 V is provided
3.3 V is provided
Type: Sound
Status: Disabled
Type: Other
Status: Disabled
en|US|iso8859-1
Group Associations
Items: 3
0x0004 (Processor)
0x0009 (Cache)
0x000A (Cache)
Group Associations
Items: 8
Use: System Memory
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: DIMM 1
Type: DRAM
Speed: Unknown
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 2
Locator: DIMM 2
Type: DRAM
Speed: Unknown
Memory Device
Data Width: Unknown
Form Factor: DIMM
Set: 2
Locator: DIMM 3
Type: DRAM
Speed: Unknown
Partition Width: 0
Range Size: 512 MB
Range Size: 1 GB
Inactive
End Of Table
ma signature … ;p
