Script chroot-ssh
J’ai trouvé un script chroot-ssh et j’aurais voulu savoir si ce script est sécurisé ou pas, aussi, pouvez-vous donner des conseils pour l’améliorer. (le nom de l’auteur du script est indiqué ci-dessous:
[code]#!/bin/sh
Gregory Colpart reg@evolix.fr
chroot script for OpenSSH
$Id: chroot-ssh.sh,v 1.10 2009-04-25 10:38:52 gcolpart Exp $
tested on Debian Etch and recently on Lenny
Exec�this script for jail creation:
./chroot-ssh.sh /backup/jails/192.168.1.4
Note: etc/ssh{sshd_config,group,passwd} files should be present
For Etch
Start: chroot /backup/jails/myserver /usr/sbin/sshd > /dev/null
Reload: kill -HUP chroot /backup/jails/myserver cat /var/run/sshd.pid
Stop: kill -9 chroot /backup/jails/myserver cat /var/run/sshd.pid
Restart: Stop + Start
For Lenny
Start :
chroot /backup/jails/192.168.1.4 mount -t proc proc-chroot /proc/
chroot /backup/jails/192.168.1.4 mount -t devpts devpts-chroot /dev/pts/
chroot /backup/jails/192.168.1.4 /usr/sbin/sshd > /dev/null
Reload: kill -HUP chroot /backup/jails/192.168.1.4 cat /var/run/sshd.pid
Stop: kill -9 chroot /backup/jails/192.168.1.4 cat /var/run/sshd.pid
Restart:
After each ssh upgrade or libs upgrade:
sh chroot-ssh.sh updateall
And restart all sshd daemons
bincopy() {
chrootdir=$1
TODO : better detection of amd64 arch
cp -f /lib/ld-linux.so.2 $chrootdir/lib/ || cp -f /lib64/ld-linux-x86-64.so.2 $chrootdir/lib64/
cp /lib/libnss* $chrootdir/lib/
for dbin in /bin/bash /bin/cat /bin/chown /bin/mknod /bin/rm /bin/sed /bin/sh /bin/uname /bin/mount /usr/bin/rsync /usr/sbin/sshd ; do
cp -f $dbin $chrootdir/$dbin;
# (comme dans http://www.gcolpart.com/hacks/chroot-bind.sh)
for lib in ldd $dbin | cut -d">" -f2 | cut -d"(" -f1; do
cp -p $lib $chrootdir/$lib
done
done
synopsis
if [ $# -ne 1 ]; then
echo "Vous devez indiquer un repertoire."
echo "Exemple : chroot-ssh.sh /backup/jails/myserver"
exit 0
fi
are u root?
if [ whoami != “root” ]; then
echo "Vous devez executer le script en �tant root."
exit 0
fi
if [ -e $1 ]; then
echo "Le repertoire $1 existe deja…"
fi
if [ “$1” = “updateall” ]; then
for i in `ls -1 /backup/jails/*/lib/libnss_compat.so.2`; do
    chrootdir=`echo $i | cut -d"/" -f1,2,3,4`
    echo -n "MaJ $chrootdir ..."
    bincopy $chrootdir
    echo "...OK"
done
else
where is jail
chrootdir=$1
mkdir -p $chrootdir
chown root:root $chrootdir
create jail
echo -n “1 - Creation de la prison…”
mkdir -p $chrootdir/{bin,dev,etc/ssh,lib,lib64}
mkdir -p $chrootdir/lib/tls/i686/cmov/
mkdir -p $chrootdir/proc
mkdir -p $chrootdir/root/.ssh
mkdir -p $chrootdir/usr/lib/i686/cmov/
mkdir -p $chrootdir/lib/i686/cmov/
mkdir -p $chrootdir/usr/{bin,lib,sbin}
mkdir -p $chrootdir/var/log/
mkdir -p $chrootdir/var/run/sshd
touch $chrootdir/var/log/{authlog,lastlog,messages,syslog}
touch $chrootdir/etc/fstab
echo “…OK”
echo -n "2 - Copie des donnees…"
cp /proc/devices $chrootdir/proc
cp /etc/ssh/{ssh_host_rsa_key,ssh_host_dsa_key} $chrootdir/etc/ssh/
cp /etc/ssh/sshd_config $chrootdir/etc/ssh/
cp /etc/passwd $chrootdir/etc/
cp /etc/shadow $chrootdir/etc/
cp /etc/group  $chrootdir/etc/
echo “…OK”
echo -n “3 - Copie des binaires…”
bincopy $chrootdir
echo “…OK”
echo -n "4 - Creation des devices…"
cd $chrootdir/dev/
cp /dev/MAKEDEV ./
./MAKEDEV {null,random,urandom,pty}
mkdir pts
mknod ptmx c 5 2
echo “…OK”
echo -n “5 - Termine.”
end
echo “”
fi
Rie ne t’interdit d’avoir ce genre de conversation au café du coin, mais franchement j’aurais plutôt vu cela dans Support Debian :laughing:
Petite remarque, si tu utilises des bashismes ( ex : $chrootdir/{bin,dev,etc/ssh,lib,lib64} ), prends l’habitude de commencer tes scripts par :
(/bin/sh ne pointe pas vers bash pour tout le monde)
