Voilàa je me pose une petite colle pour le traitement de fichier texte.
En realité il s’agit d’un fichier de configuration Cisco que je dois “parser”.
Mon fichier va ressembler à ceci quand je le recupère :
[code]Ethernet107/1/20 is down (Link not connected)
Hardware: 100/1000 Ethernet, address: a4138.7589.1955 (bia a4138.7589.1955)
Description: – Libre –
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation ARPA
Port mode is access
auto-duplex, auto-speed
Beacon is turned off
Input flow-control is off, output flow-control is on
Switchport monitor is off
EtherType is 0x8100
Last link flapped never
Last clearing of “show interface” counters never
30 seconds input rate 0 bits/sec, 0 bytes/sec, 0 packets/sec
30 seconds output rate 0 bits/sec, 0 bytes/sec, 0 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
RX
0 unicast packets 0 multicast packets 0 broadcast packets
0 input packets 0 bytes
0 jumbo packets 0 storm suppression bytes
0 giants 0 input error 0 short frame 0 overrun 0 underrun
0 watchdog 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
0 output packets 0 bytes
0 jumbo packets
0 output errors 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble
0 Tx pause
0 interface resets
Ethernet107/1/21 is down (Link not connected)
Hardware: 100/1000 Ethernet, address: a418.7589.1956 (bia a418.7589.1956)
Encapsulation ARPA
Port mode is access
EtherType is 0x8100
RX
0 Rx pause
TX
0 jumbo packets
0 Tx pause
0 interface resets
Ethernet107/1/22 is down (Link not connected)
Hardware: 100/1000 Ethernet, address: a4138.7589.1957 (bia a4138.7589.1957)
Encapsulation ARPA
Port mode is access
EtherType is 0x8100
RX
0 Rx pause
TX
0 jumbo packets
0 Tx pause
0 interface resets
Pour l’exemple je n’ai pris que 3 interfaces ![]()
Il faudrait que le scipt récupère en fonction de la demande les informations suivantes :
Si l’utilisateur veut voir l’interface Ethernet107/1/22 le script ne doit retourner que ceci :
Description: -- Libre --
Encapsulation ARPA
Port mode is access
EtherType is 0x8100
Last clearing of "show interface" counters never
RX
0 Rx pause
TX
0 jumbo packets
0 Tx pause
0 interface resets
et non pas mes 5000 pages de conf
Donc pour le début il me suffit de faire un grep car l’utilisateur va saisir le nom exacte de l’interface.
Ensuite toutes les lignes, propre à cette interface sont indentés d’une tabulation, donc il suffit que je lui dise que le premier caractère est une tabulation.
Mais la ou je ne sais pas faire, c’est comment dire : ça commence à ça et ça se termine par une ligne vide.
Pour le moment j’ai donc mon début :
#Debut en trouvant le nom de l’interface
grep Ethernet107/1/20
#Milieu en disant “tant que tabulation” ou autre
#FIN en matchant la ligne de séparation
grep ^$
Malheureusement avec un grep il n’est pas possible de délimiter un paragraphe, avec awk en colonne je ne sais pas comment m’en sortir (sauf option utiles que je connais pas )
Connaissez-vous des outils pour le faire ?
