voila j ai un script upload/download et j ai des erreur qui peux m’aider merci
[code]Deprecated: Function eregi_replace() is deprecated in /usr/home/mservers/vhosts/sightlingevo/www/classes/SConfig.php on line 187
Deprecated: Function eregi() is deprecated in /usr/home/mservers/vhosts/sightlingevo/www/classes/SConfig.php on line 30
Deprecated: Function eregi_replace() is deprecated in /usr/home/mservers/vhosts/sightlingevo/www/classes/SConfig.php on line 31
Deprecated: Function eregi() is deprecated in /usr/home/mservers/vhosts/sightlingevo/www/classes/SConfig.php on line 35
[code]<?php
define (“CONF_COMMENT”, “#”);
class SConfig {
var $_def_file_name;
var $_filename;
var $_SConfig;
var $_errors;
function SConfig() {
global $SConfig;
if (!isset($SConfig)) $SConfig = $this;
$SConfig->_init();
function create() {
return new SConfig();
function _init () {
global $config;
$this->_def_file_name = $config['CONF_FILE'];
$filename = $this->_def_file_name;
$this->_filename = $filename;
if (!$file = $this->_read_file()) return false;
$ar = explode("\n", $file);
foreach ($ar as $item) {
if (eregi("\[.*\]", $item)) {
$section = trim(eregi_replace("\[|\]", "", $item));
} else {
$key = trim(substr($item, 0, strpos($item, "=")));
$value = trim(substr($item, strpos($item, "=")+1));
if ($key and !eregi("[[:space:]]*".CONF_COMMENT, $item)) {
$res[$section][$key] = $value;
$this->_SConfig = $res;
function _check_SConfig_loaded () {
if (isset($this->_SConfig)) {
return true;
} else {
SError::add("SConfiguration file hasen't been loaded");
return false;
function get ($section, $key) {
global $SConfig;
if (!isset($SConfig)) {
SConfig::create();
if (!$SConfig->_check_SConfig_loaded()) {
return false;
return $SConfig->_SConfig[$section][$key];
function getSection ($section) {
global $SConfig;
SConfig::create();
return false;
if (!isset($SConfig->_SConfig[$section])) {
SError::add("Section $section does not exist");
return false;
return $SConfig->_SConfig[$section];
function getAll () {
global $SConfig;
SConfig::create();
return false;
return $SConfig->_SConfig;
function checkSection ($section) {
global $SConfig;
SConfig::create();
return false;
return (isset($SConfig->_SConfig[$section]));
function set ($section, $key, $value, $create = true, $is_write = true) {
global $SConfig;
SConfig::create();
return false;
if (!$SConfig->checkSection($section)) {
SError::add("Invalid section name \"$section\"");
return false;
if (isset($this->_SConfig[$section][$key])) {
$SConfig->_SConfig[$section][$key] = $value;
} else {
if ($create) {
} else {
SError::add("Unable to create new key");
return false;
if ($is_write) {
$SConfig->_write();
return true;
function write ($filename = null) {
global $SConfig;
SConfig::create();
return false;
if (!$filename) {
$filename = $SConfig->_filename;
$out = "";
foreach ($this->_SConfig as $section => $values) {
$out .= "[$section]\n";
foreach ($values as $key => $value) {
$out .= "$key = $value\n";
if (is_writable($filename)) {
if (!$fp = fopen($filename, 'w')) {
SError::add("Cannot open file ($filename)");
return false;
if (!fwrite($fp, $out)) {
SError::add("Cannot write to file ($filename).");
return false;
fclose($fp);
} else {
SError::add("The file $filename is not writable.");
return false;
return true;
function _read_file () {
global $SConfig;
SConfig::create();
if (!file_exists($SConfig->_filename)) {
SError::add("file ".$SConfig->_filename." does not exists.");
return false;
$fd = fopen ($SConfig->_filename, "r");
if (!$fd) {
SError::add("error opening file for reading");
return false;
$buffer = "";
while (!feof ($fd)) {
$buffer .= fgets($fd, 4096);
fclose ($fd);
$buffer = eregi_replace("\n\n", "\n", $buffer);
return $buffer;
function getErrors () {
return SError::getErrors();
