bonjour tout le monde.
il m’arrive un soucis et je ne sais plus quoi faire. voilà j’ai suivit ce tuto car j’aimerai qu’avec une page de mon site web (machine a) je puisse exécuter des scripts sur une machine b.
Donc j’ai suivi ce tuto, je l’ai même fait et refais mais rien a faire:ici.
et quand j’essaye de me connecté il me demande toujours le mot de passe. je vous met le lancement en mod debug.
ks*****:~# su www-data
ks*****:/root$ cd /var/www
ks*****:~$ ssh -vvv script@91.121.96.55
OpenSSH_5.1p1 Debian-5, OpenSSL 0.9.8g 19 Oct 2007
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: Applying options for *
debug2: ssh_connect: needpriv 0
debug1: Connecting to ip2 [ip2] port 22.
debug1: Connection established.
debug1: identity file /var/www/.ssh/identity type -1
debug3: Not a RSA1 key file /var/www/.ssh/id_rsa.
debug2: key_type_from_name: unknown key type '-----BEGIN'
debug3: key_read: missing keytype
debug3: key_read: missing whitespace
debug2: key_type_from_name: unknown key type '-----END'
debug1: identity file /var/www/.ssh/id_rsa type 1
debug1: Checking blacklist file /usr/share/ssh/blacklist.RSA-2048
debug1: Checking blacklist file /etc/ssh/blacklist.RSA-2048
debug3: Not a RSA1 key file /var/www/.ssh/id_dsa.
debug1: identity file /var/www/.ssh/id_dsa type 2
debug1: Checking blacklist file /usr/share/ssh/blacklist.DSA-1024
debug1: Checking blacklist file /etc/ssh/blacklist.DSA-1024
debug1: Remote protocol version 2.0, remote software version OpenSSH_5.1p1 Debian-5
debug1: match: OpenSSH_5.1p1 Debian-5 pat OpenSSH*
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_5.1p1 Debian-5
debug2: fd 3 setting O_NONBLOCK
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug2: kex_parse_kexinit: diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
debug2: kex_parse_kexinit: ssh-rsa,ssh-dss
debug2: kex_parse_kexinit: aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,arcfour128,arcfour256,arcfour,aes192-cbc,aes256-cbc,rijndael-cbc@lysator.liu.se,aes128-ctr,aes192-ctr,aes256-ctr
debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,umac-64@openssh.com,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96
debug2: kex_parse_kexinit: none,zlib@openssh.com,zlib
debug2: kex_parse_kexinit: first_kex_follows 0
debug2: kex_parse_kexinit: reserved 0
debug2: mac_setup: found hmac-md5
debug1: kex: server->client aes128-cbc hmac-md5 none
debug1: kex: client->server aes128-cbc hmac-md5 none
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(1024<1024<8192) sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
debug2: dh_gen_key: priv key bits set: 138/256
debug2: bits set: 486/1024
debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_REPLY
debug3: check_host_in_hostfile: filename /var/www/.ssh/known_hosts
debug3: check_host_in_hostfile: match line 1
debug1: Host '91.121.96.55' is known and matches the RSA host key.
debug1: Found key in /var/www/.ssh/known_hosts:1
debug2: bits set: 507/1024
debug1: ssh_rsa_verify: signature correct
debug2: kex_derive_keys
debug2: set_newkeys: mode 1
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug2: set_newkeys: mode 0
debug1: SSH2_MSG_NEWKEYS received
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug2: key: /var/www/.ssh/identity ((nil))
debug2: key: /var/www/.ssh/id_rsa (0xb7868268)
debug2: key: /var/www/.ssh/id_dsa (0xb7868280)
debug1: Authentications that can continue: publickey,password
debug3: start over, passed a different list publickey,password
debug3: preferred gssapi-keyex,gssapi-with-mic,gssapi,publickey,keyboard-interactive,password
debug3: authmethod_lookup publickey
debug3: remaining preferred: keyboard-interactive,password
debug3: authmethod_is_enabled publickey
debug1: Next authentication method: publickey
debug1: Trying private key: /var/www/.ssh/identity
debug3: no such identity: /var/www/.ssh/identity
debug1: Offering public key: /var/www/.ssh/id_rsa
debug3: send_pubkey_test
debug2: we sent a publickey packet, wait for reply
debug1: Offering public key: /var/www/.ssh/id_dsa
debug2: we did not send a packet, disable method
debug3: authmethod_lookup password
debug3: remaining preferred: ,password
debug3: authmethod_is_enabled password
debug1: Next authentication method: password
script@ip2's password:
pourriez vous me dire ce qui ne va pas. Alors pour toutes les questions d’usage:
pour la partie client donc machine A. j’ai bien la clef publique, la clef privée, et le known_hosts.
Cela ce trouve dans le répertoire parent de www-data, c’est a dire: /var/www/.ssh/
pour la partie serveur j’ai bien copié la clef publique dans le fichier authorized_keys qui est dans le dossier parent de script, c’est a dire: /home/script/.SSH
ps: j’ai utilisé ssh-copy-id pour évité les erreurs, j’ai testé la commande par rapport au bug écrit sur ce même site
