c’est bon j’ai retrouvé l’install !!! regarde :
[quote]Password:
root@wbn:/home/williams# sensors-detect
This program will help you determine which I2C/SMBus modules you need to
load to use lm_sensors most effectively. You need to have i2c and
lm_sensors installed before running this program.
Also, you need to be `root’, or at least have access to the /dev/i2c-*
files, for most things.
If you have patched your kernel and have some drivers built in, you can
safely answer NO if asked to load some modules. In this case, things may
seem a bit confusing, but they will still work.
It is generally safe and recommended to accept the default answers to all
questions, unless you know what you’re doing.
We can start with probing for (PCI) I2C or SMBus adapters.
You do not need any special privileges for this.
Do you want to probe now? (YES/no):
Probing for PCI bus adapters…
Use driver `i2c-i801’ for device 00:1f.3: Intel 82801EB ICH5
Probe succesfully concluded.
We will now try to load each adapter module in turn.
Module `i2c-i801’ already loaded.
If you have undetectable or unsupported adapters, you can have them
scanned by manually loading the modules before running this script.
To continue, we need module `i2c-dev’ to be loaded.
If it is built-in into your kernel, you can safely skip this.
i2c-dev is already loaded.
We are now going to do the adapter probings. Some adapters may hang halfway
through; we can’t really help that. Also, some chips will be double detected;
we choose the one with the highest confidence value in that case.
If you found that the adapter hung after probing a certain address, you can
specify that address to remain unprobed. That often
includes address 0x69 (clock chip).
Next adapter: SMBus I801 adapter at 0400
Do you want to scan it? (YES/no/selectively):
Client found at address 0x08
Client found at address 0x44
Probing for Maxim MAX6633/MAX6634/MAX6635'... Failed! Client found at address 0x50 Probing forSPD EEPROM’… Success!
(confidence 8, driver eeprom') Probing forDDC monitor’… Failed!
Probing for Maxim MAX6900'... Failed! Client found at address 0x51 Probing forSPD EEPROM’… Success!
(confidence 8, driver eeprom') Client found at address 0x52 Probing forSPD EEPROM’… Success!
(confidence 8, driver eeprom') Client found at address 0x53 Probing forSPD EEPROM’… Success!
(confidence 8, driver `eeprom’)
Client found at address 0x69
Some chips are also accessible through the ISA bus. ISA probes are
typically a bit more dangerous, as we have to write to I/O ports to do
this. This is usually safe though.
Do you want to scan the ISA bus? (YES/no):
Probing for National Semiconductor LM78' Trying address 0x0290... Failed! Probing forNational Semiconductor LM78-J’
Trying address 0x0290… Failed!
Probing for National Semiconductor LM79' Trying address 0x0290... Failed! Probing forWinbond W83781D’
Probing for Winbond W83782D' Trying address 0x0290... Failed! Probing forWinbond W83627HF’
Probing for Winbond W83627EHF' Trying address 0x0290... Failed! Probing forWinbond W83697HF’
Probing for Silicon Integrated Systems SIS5595' Trying general detect... Failed! Probing forVIA Technologies VT82C686 Integrated Sensors’
Trying general detect… Failed!
Probing for VIA Technologies VT8231 Integrated Sensors' Trying general detect... Failed! Probing forITE IT8712F’
Probing for ITE IT8705F / SiS 950' Trying address 0x0290... Failed! Probing forIPMI BMC KCS’
Trying address 0x0ca0… Failed!
Probing for `IPMI BMC SMIC’
Trying address 0x0ca8… Failed!
Some Super I/O chips may also contain sensors. Super I/O probes are
Do you want to scan for Super I/O sensors? (YES/no):
Probing for ITE 8702F Super IO Sensors' Failed! (0x8863) Probing forITE 8705F Super IO Sensors’
Failed! (0x8863)
Probing for ITE 8712F Super IO Sensors' Failed! (0x8863) Probing forNat. Semi. PC87351 Super IO Fan Sensors’
Failed! (0x88)
Probing for Nat. Semi. PC87360 Super IO Fan Sensors' Failed! (0x88) Probing forNat. Semi. PC87363 Super IO Fan Sensors’
Failed! (0x88)
Probing for Nat. Semi. PC87364 Super IO Fan Sensors' Failed! (0x88) Probing forNat. Semi. PC87365 Super IO Fan Sensors’
Failed! (0x88)
Probing for Nat. Semi. PC87365 Super IO Voltage Sensors' Failed! (0x88) Probing forNat. Semi. PC87365 Super IO Thermal Sensors’
Failed! (0x88)
Probing for Nat. Semi. PC87366 Super IO Fan Sensors' Failed! (0x88) Probing forNat. Semi. PC87366 Super IO Voltage Sensors’
Failed! (0x88)
Probing for Nat. Semi. PC87366 Super IO Thermal Sensors' Failed! (0x88) Probing forNat. Semi. PC87372 Super IO Fan Sensors’
Failed! (0x88)
Probing for Nat. Semi. PC87373 Super IO Fan Sensors' Failed! (0x88) Probing forNat. Semi. PC87591 Super IO’
Failed! (0x88)
Probing for Nat. Semi. PC87371 Super IO' Failed! (0x88) Probing forNat. Semi. PC97371 Super IO’
Failed! (0x88)
Probing for Nat. Semi. PC8739x Super IO' Failed! (0x88) Probing forNat. Semi. PC8741x Super IO’
Failed! (0x88)
Probing for SMSC 47B27x Super IO Fan Sensors' Failed! (0x88) Probing forSMSC 47M10x/13x Super IO Fan Sensors’
Failed! (0x88)
Probing for SMSC 47M14x Super IO Fan Sensors' Failed! (0x88) Probing forSMSC 47M15x/192 Super IO Fan Sensors’
Failed! (0x88)
Probing for SMSC 47S42x Super IO Fan Sensors' Failed! (0x88) Probing forSMSC 47S45x Super IO Fan Sensors’
Failed! (0x88)
Probing for SMSC 47M172 Super IO' Failed! (0x88) Probing forSMSC LPC47B397-NC Super IO’
Failed! (0x88)
Probing for VT1211 Super IO Sensors' Failed! (0x88) Probing forWinbond W83627HF Super IO Sensors’
Failed! (0x88)
Probing for Winbond W83627THF Super IO Sensors' Failed! (0x88) Probing forWinbond W83637HF Super IO Sensors’
Failed! (0x88)
Probing for Winbond W83697HF Super IO Sensors' Failed! (0x88) Probing forWinbond W83697SF/UF Super IO PWM’
Failed! (0x88)
Probing for Winbond W83L517D Super IO' Failed! (0x88) Probing forWinbond W83627EHF Super IO Sensors’
Success… found at address 0x0290
Do you want to scan for secondary Super I/O sensors? (YES/no):
Probing for ITE 8702F Super IO Sensors' Failed! (skipping family) Probing forNat. Semi. PC87351 Super IO Fan Sensors’
Probing for SMSC 47B27x Super IO Fan Sensors' Failed! (skipping family) Probing forVT1211 Super IO Sensors’
Probing for `Winbond W83627EHF Super IO Sensors’
Now follows a summary of the probes I have just done.
Just press ENTER to continue:
Driver `eeprom’ (should be inserted):
Detects correctly:
- Bus
SMBus I801 adapter at 0400' Busdriveri2c-i801’, I2C address 0x50
Chip `SPD EEPROM’ (confidence: Cool
- Bus
SMBus I801 adapter at 0400' Busdriveri2c-i801’, I2C address 0x51
- Bus
SMBus I801 adapter at 0400' Busdriveri2c-i801’, I2C address 0x52
- Bus
SMBus I801 adapter at 0400' Busdriveri2c-i801’, I2C address 0x53
Driver `to-be-written’ (should be inserted):
Detects correctly:
- ISA bus address 0x0290 (Busdriver
i2c-isa') ChipWinbond W83627EHF Super IO Sensors’ (confidence: 9)
I will now generate the commands needed to load the I2C modules.
Sometimes, a chip is available both through the ISA bus and an I2C bus.
ISA bus access is faster, but you need to load an additional driver module
for it. If you have the choice, do you want to use the ISA bus or the
I2C/SMBus (ISA/smbus)?
To make the sensors modules behave correctly, add these lines to
/etc/modules:
#----cut here----
I2C adapter drivers
i2c-i801
i2c-isa
I2C chip drivers
eeprom
no driver for Winbond W83627EHF Super IO Sensors yet
#----cut here----
Do you want to add these lines to /etc/modules automatically? (yes/NO)yes
root@wbn:/home/williams# [/quote]
faut faire quoi selon toi ?
