bonjour
je suis nouveau sur ce forum et ne sait pas si c’est ici qu’il faut écrire pour pour avoir votre aide
merci
mon touchpad de mon necemotion ne fonctionne pas , sans doute non reconnu fonctionnant parfaitement avec autre OS !
root@nec:/home/jfgtz# xinput list
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ PixArt USB Optical Mouse id=9 [slave pointer (2)]
⎜ ↳ FSPPS/2 Sentelic FingerSensingPad id=11 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Power Button id=8 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=10 [slave keyboard (3)]
↳ ACPI Virtual Keyboard Device id=12 [slave keyboard (3)]
root@nec:/home/jfgtz# dmesg | grep -i sentel
[ 5.863170] psmouse serio1: sentelic: Finger Sensing Pad, hw: 7.0.1, sw: 1.0.0-K, buttons: 4
[ 6.319580] input: FSPPS/2 Sentelic FingerSensingPad as /devices/platform/i8042/serio1/input/input6
oot@nec:/home/jfgtz# hwinfo --mouse
hal.1: read hal dataprocess 6972: arguments to dbus_move_error() were incorrect, assertion “(dest) == NULL || !dbus_error_is_set ((dest))” failed in file …/…/dbus/dbus-errors.c line 282.
This is normally a bug in some application using the D-Bus library.
libhal.c 3483 : Error unsubscribing to signals, error=The name org.freedesktop.Hal was not provided by any .service files
35: USB 00.0: 10503 USB Mouse
[Created at usb.122]
Unique ID: mZxt.ywu2euu9AfE
Parent ID: uIhY.gkSaZmjGyhD
SysFS ID: /devices/pci0000:00/0000:00:1d.1/usb3/3-2/3-2:1.0
SysFS BusID: 3-2:1.0
Hardware Class: mouse
Model: "Pixart Imaging USB Optical Mouse"
Hotplug: USB
Vendor: usb 0x093a "Pixart Imaging, Inc."
Device: usb 0x2510 "USB Optical Mouse"
Revision: "1.00"
Compatible to: int 0x0210 0x0013
Driver: "usbhid"
Driver Modules: "usbhid"
Device File: /dev/input/mice (/dev/input/mouse1)
Device Files: /dev/input/mice, /dev/input/mouse1, /dev/input/event11, /dev/input/by-id/usb-PixArt_USB_Optical_Mouse-event-mouse, /dev/input/by-path/pci-0000:00:1d.1-usb-0:2:1.0-event-mouse, /dev/input/by-id/usb-PixArt_USB_Optical_Mouse-mouse, /dev/input/by-path/pci-0000:00:1d.1-usb-0:2:1.0-mouse
Device Number: char 13:63 (char 13:33)
Speed: 1.5 Mbps
Module Alias: "usb:v093Ap2510d0100dc00dsc00dp00ic03isc01ip02"
Driver Info #0:
Buttons: 3
Wheels: 1
XFree86 Protocol: explorerps/2
GPM Protocol: exps2
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #32 (Hub)
42: PS/2 00.0: 10500 PS/2 Mouse
[Created at input.183]
Unique ID: AH6Q.E+tlAXm68p6
Model: "FSPPS/2 Sentelic FingerSensingPad"
Vendor: 0x0002
Device: 0x000f "FSPPS/2 Sentelic FingerSensingPad"
Compatible to: int 0x0210 0x0025
Device File: /dev/input/mice (/dev/input/mouse0)
Device Files: /dev/input/mice, /dev/input/mouse0, /dev/input/event6, /dev/input/by-path/platform-i8042-serio-1-event-mouse, /dev/input/by-path/platform-i8042-serio-1-mouse
Device Number: char 13:63 (char 13:32)
Driver Info #0:
Buttons: 5
Wheels: 2
GPM Protocol: exps2
installation de fspc_1.0.1_i386.deb
j’ai essayé la solution non simple pour moi à
ubuntuforums.org/showthread.php?t=1502560
