Nouveau problème : wlan0 n’est plus dans le pont ??
J’ai changé de carte. Pourtant tout semble ok :
[quote] lspci -nn | grep -i network
03:02.0 Network controller [0280]: Qualcomm Atheros AR9227 Wireless Network Adapter [168c:002d] (rev 01)[/quote]
[quote]lspci -k | grep -i network -A 2
03:02.0 Network controller: Qualcomm Atheros AR9227 Wireless Network Adapter (rev 01)
Subsystem: Qualcomm Atheros Device 0300
Kernel driver in use: ath9k[/quote]
[quote] /sbin/ifconfig
br0       Link encap:Ethernet  HWaddr 00:21:9b:6e:13:cf
inet adr:192.168.1.21  Bcast:192.168.1.255  Masque:255.255.255.0
adr inet6: fe80::221:9bff:fe6e:13cf/64 Scope:Lien
UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
RX packets:100455 errors:0 dropped:0 overruns:0 frame:0
TX packets:52386 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:48533289 (46.2 MiB)  TX bytes:7677188 (7.3 MiB)
eth0      Link encap:Ethernet  HWaddr 00:21:9b:6e:13:cf
RX packets:103362 errors:0 dropped:0 overruns:0 frame:0
TX packets:53089 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:50554333 (48.2 MiB)  TX bytes:8015246 (7.6 MiB)
Interruption:16
lo        Link encap:Boucle locale
inet adr:127.0.0.1  Masque:255.0.0.0
adr inet6: ::1/128 Scope:Hôte
UP LOOPBACK RUNNING  MTU:65536  Metric:1
RX packets:75 errors:0 dropped:0 overruns:0 frame:0
TX packets:75 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:29706 (29.0 KiB)  TX bytes:29706 (29.0 KiB)
wlan0     Link encap:Ethernet  HWaddr a4:2b:b0:a6:51:f4
UP BROADCAST MULTICAST  MTU:1500  Metric:1
RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)[/quote]
[quote]brctl show
bridge name    bridge id        STP enabled    interfaces
br0        8000.00219b6e13cf    no        eth0[/quote]
[quote]dmesg | tail
[   24.236302] usblp1: removed
[   24.238676] usblp 5-6:1.0: usblp1: USB Bidirectional printer dev 5 if 0 alt 1 proto 2 vid 0x03F0 pid 0x2417
[   24.239736] usblp0: removed
[   24.241426] usblp 5-5:1.0: usblp0: USB Bidirectional printer dev 4 if 0 alt 0 proto 2 vid 0x04E8 pid 0x329F
[   27.164441] usblp1: removed
[   27.167412] usblp 5-6:1.0: usblp1: USB Bidirectional printer dev 5 if 0 alt 1 proto 2 vid 0x03F0 pid 0x2417
[   27.168724] usblp0: removed
[   27.170880] usblp 5-5:1.0: usblp0: USB Bidirectional printer dev 4 if 0 alt 0 proto 2 vid 0x04E8 pid 0x329F
[   31.068025] br0: port 1(eth0) entered forwarding state
[  340.669000] perf interrupt took too long (2503 > 2500), lowering kernel.perf_event_max_sample_rate to 50000[/quote]
[quote] iwlist wlan0 scan
wlan0     Scan completed :
Cell 01 - Address: 58:6D:8F:49:33:52
Channel:11
Frequency:2.462 GHz (Channel 11)
Quality=29/70  Signal level=-81 dBm
Encryption key:on
ESSID:"primaire"
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 18 Mb/s
24 Mb/s; 36 Mb/s; 54 Mb/s
Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 48 Mb/s
Mode:Master
Extra:tsf=000002e59f86066a
Extra: Last beacon: 5080ms ago
IE: Unknown: 00087072696D61697265
IE: Unknown: 010882848B962430486C
IE: Unknown: 03010B
IE: Unknown: 2A0100
IE: Unknown: 2F0100
IE: IEEE 802.11i/WPA2 Version 1
Group Cipher : TKIP
Pairwise Ciphers (2) : CCMP TKIP
Authentication Suites (1) : PSK
IE: Unknown: 32040C121860
IE: Unknown: 2D1AF0181BFF00000000000000000000000000000000000000000000
IE: Unknown: 3D160B080000000000000000000000000000000000000000
IE: Unknown: DD6E0050F204104A00011010440001021041000100103B00010310470010E9C41BDE3302CCC2DD58EA6A7090166F10210005436973636F102300054531323030102400063132333435361042000234321054000800060050F2040001101100054531323030100800020084103C000101
IE: Unknown: DD090010180200F0040000
IE: WPA Version 1
Group Cipher : TKIP
IE: Unknown: DD180050F2020101800003A4000027A4000042435E0062322F00[/quote]
Pige pas
Entre temps, je suis passé à gnome 3.
J’ai créé un point d’accès wifi (je voulais du had-hoc comme je n’arrivaits pas en AP) et voilà le résultat : je surf sur le net depuis mon netbook avec cette adresse là :
[quote]wlp5s0b1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
inet 10.42.0.206  netmask 255.255.255.0  broadcast 10.42.0.255
inet6 fe80::6073:71ef:44c7:ce18  prefixlen 64  scopeid 0x20
ether b4:74:9f:b3:d2:60  txqueuelen 1000  (Ethernet)
RX packets 24  bytes 6571 (6.4 KiB)
RX errors 0  dropped 0  overruns 0  frame 0
TX packets 55  bytes 12190 (11.9 KiB)
TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0[/quote]
Je pensais que ce n’était possible qu’en faisant du ‘nat’ via iptables ! Je n’ai rien fait !!!
En creusant j’ai trouvé que Networ Manager fait tout tout seul ! Il créé un fichier ‘Hotspot’ qui est en fait l’équivalent du fichier hostapd  qu’il place dans ‘/etc/NetworkManager/system-connections’.
Mais je ne parviens pas à l’effacer. Un rm -R Hotspot efface le fichier ; mais il est en fait recréé à l’identique ensuite. Network Manager doit donc conserver un double de ce fichier mais je ne sais pas où.
