[quote=“Victorien”]je vais essayé merci
et cette ligne sert a quoi ?
apt-get install x11-common xorg xserver-xorg gdm[/quote]
à installer x11-common xorg xserver-xorg et gdm:
[code]roc@roc:/usr/src/linux-source-2.6.22$ aptitude show x11-common xorg xserver-xorg gdm
Paquet : x11-common
État: installé
Automatiquement installé: oui
Version : 1:7.3+3
Priorité : optionnel
Section : x11
Responsable : Debian X Strike Force debian-x@lists.debian.org
Taille décompressée : 733k
Dépend: libc6 (>= 2.6.1-1), debconf (>= 0.5) | debconf-2.0, debianutils (>= 1.13), lsb-base (>= 1.3-9ubuntu2)
Pré-dépend: debconf | debconf-2.0
Est en conflit: xfree86-common, xorg-common, xserver-common, x-common, xserver-xorg (< 1:7.0.12), xserver-xfree86 (< 1:7.0), libxft-dev (<= 2.1.8.2-5), aee
(<= 2.2.15b-1), ascd (<= 0.13.2-3), bibview (<= 2.2-8), fvwm1 (<= 1.24r-46), grace (<= 1:5.1.18-1), groff (<= 1.18.1.1-7), hfsutils-tcltk
(<= 3.2.6-7), login.app (<= 1.2.1-18), oneko (<= 1.2.sakura.6-1), procmeter (<= 2.5.1-11), propsel (<= 971130-5.3), regexplorer (<=
0.1.6-12), tkseti (<= 3.06-1), wdm (<= 1.28-1), wily (<= 0.13.41-6), wmnetselect (<= 0.85-5.5), wmsensors (<= 1.0.4-3.4), wmtv (<=
0.6.5-15), xbanner (<= 1.31-23), xcolors (<= 1.5a-2), xcolorsel (<= 1.1a-11), xezmlm (<= 1.0.3-11), xfs-xtt (<= 1:1.4.1.xf430-6), xgdipc (<=
1.2-0.3), xgmod (<= 3.1-9), xgraph (<= 12.1-3), xlogmaster (<= 1.6.0-8), xmailbox (<= 2.5-9), xmem (<= 1.20-19), xnecview (<= 1.34-2), xodo
(<= 1.2-9.2), xturqstat (<= 2.2.2sarge1), xwit (<= 3.4-6), lbxproxy (< 7.0), proxymngr (< 7.0), twm (< 7.0), xbase-clients (< 1:7.0), xdm
(<= 1:1.0.1-6), xfs (< 1:1.0), xfwp (< 7.0), xutils (< 1:7.0), xvfb (< 1:1.0), qcam (<= 0.91-11.1), twlog (<= 1.3-4), xdmx (< 1:1.0), bugsx
(<= 1.08-8), buici-clock (<= 0.4.5+b1), ctwm (<= 3.7-2), emelfm (<= 0.9.2-7), fte-xwindow (<= 0.50.0-1.3), fvwm95 (<= 2.0.43ba-23+b1),
gerstensaft (<= 0.2-5.1), gipsc (<= 0.4.3-2), gradio (<= 1.0.1-6), hanterm-classic (<= 3.1.6.0-4), hanterm-xf (<= 1:3.3.1p18-9.2), ibp (<=
0.21-4), isdnutils-xtools (<= 1:3.8.2005-12-06-4), ivtools-bin (<= 1.1.3-5), kdrill (<= 6.4-2.1), kinput2-canna (<= 3.1-7),
kinput2-canna-wnn (<= 3.1-7), kinput2-wnn (<= 3.1-7), kterm (<= 6.2.0-45), lm-batmon (<= 0.96-3), lwm (<= 1.2.1-1), mctools-lite (<=
970129-16), mgp (<= 1.11b-6), olvwm (<= 4.4.3.2p1.4-21), olwm (<= 3.2p1.4-21), pixmap (<= 2.6pl4-14.1), plotmtv (<= 1.4.4t-8.1), ppxp-x11
(<= 0.2001080415-14), seyon (<= 2.20c-20), skkinput (<= 1:2.06.4-4), tkdesk (<= 2.0-5), videogen (<= 0.32-1), vtwm (<= 5.4.7-2), w9wm (<=
0.4.2-4), wmavgload (<= 0.7.0-6.1), wmcpu (<= 1.3-4.1), wmdate (<= 0.5-7.1), wmnet (<= 1.05-12), wmscope (<= 3.0-9.1), xautolock (<=
1:2.1-6), xbatt (<= 1.2.1-4), xbattbar (<= 1.4.2-3.1), xcal (<= 4.1-18.2), xcalendar-i18n (<= 4.0.0.i18p1-13.1), xcb (<= 2.4-4), xclip (<=
0.08-5), xclips (<= 6.21-6), xdkcal (<= 0.9d-2.1), xdu (<= 3.0-14), xengine (<= 1.11-9), xfaces (<= 3.3-25), xfishtank (<= 2.2-23.1), xfm
(<= 1.4.3-8), xinput (<= 1.2-5.2), xipmsg (<= 0.8088-1.1), xlbiff (< 4.1-4), xli (<= 1.17.0-21), xlockmore (<= 1:5.21-1), xlockmore-gl (<=
1:5.21-1), xmeter (<= 1.15-6), xmix (<= 2.1-5), xmon (<= 1.5.6-1.3), xpostit (<= 3.3.1-8.2), xprint (<= 1:0.1.0.alpha1-13), xrn (<=
9.02-7.1), xsysinfo (<= 1.7-2), xtel (<= 3.3.0-5.4), xtoolwait (<= 1.3-6), xtrlock (<= 2.0-11), xview-clients (<= 3.2p1.4-21), xviewg (<=
3.2p1.4-21), xviewg-dev (<= 3.2p1.4-21), xvkbd (<= 2.6-2.1), xxkb (<= 1.10-2.1), xzoom (<= 0.3-17), pgaccess (<= 1:0.98.8.20030520-2),
xearth (<= 1.1-10.2), libmotif-dev (<= 2.2.3-1.3), motif-clients (<= 2.2.3-1.3), xslideshow (<= 3.1-8.1), xtrkcad (<= 3.1.4-1), pmud (<=
0.10-9), xnest (< 1:1.0), xterm (< 208-1), xmh (<= 6.8.2.dfsg.1-4), beaver (<= 0.2.5-2), lsb-core (<= 3.1-4), yank (<= 0.2.1-7.2), xpmumon
(<= 1.3.0), ivtools-dev (<= 1.1.3-5), ppxp (<= 0.2001080415-14), guitar (<= 0.1.4-11), xftp, xext, xpaste, ghostview, xv (<= 3.10a-26),
xserver-xfree86-dbg, grace6 (<= 5.99.0+final-4), xephem (<= 3.4-5), opera (< 9.10-20060616), hamsoft (< 0.2.3-1), phototk, tkworld,
ucbmpeg-play (< 2.3p-13), netscape-base-4, communicator-smotif-477, epan, navigator-smotif-477, stella (< 2.2-1), xfractint (< 20.3.01-1),
xgobi, xpostitplus, xisp, vide (<= 1.21-3)
Remplace: xfree86-common, xorg-common, xserver-common, x-common
Description : X Window System (X.Org) infrastructure
x11-common contains the filesystem infrastructure required for further installation of the X Window System in any configuration; it does not provide a full
installation of clients, servers, libraries, and utilities required to run the X Window System.
A number of terms are used to refer to the X Window System, including “X”, “X Version 11”, “X11”, “X11R6”, and “X11R7”. The version of X used in Debian is
derived from the version released by the X.Org Foundation, and is thus often also referred to as “X.Org”. All of the preceding quoted terms are
functionally interchangeable in an Debian system.
Marqueurs: admin::configuring, implemented-in::shell, role::app-data, role::program, scope::utility, special::auto-inst-parts, x11::xserver
Paquet : xorg
État: installé
Version : 1:7.3+3
Section : x11
Taille décompressée : 49,2k
Dépend: xserver-xorg, libgl1-mesa-glx | libgl1, libglu1-mesa, xfonts-base (>= 1:1.0.0-1), xfonts-100dpi (>= 1:1.0.0-1), xfonts-75dpi (>= 1:1.0.0-1),
xfonts-scalable (>= 1:1.0.0-1), xbase-clients (>= 1:1.0.1-1), xutils (>= 1:1.0.1-1), xkb-data, xterm | x-terminal-emulator, sparc-utils | not+sparc
Recommande: xorg-docs
Fournit: x-window-system, x-window-system-core
Description : X.Org X Window System
This metapackage provides the components for a standalone workstation running the X Window System. It provides the X libraries, an X server, a set of
fonts, and a group of basic X clients and utilities.
Higher level metapackages, such as those for desktop environments, can depend on this package and simplify their dependencies.
It should be noted that a package providing x-window-manager should also be installed to ensure a comfortable X experience.
Marqueurs: hardware::input, hardware::video, interface::x11, network::server, role::dummy, role::metapackage, special::meta, use::driver, x11::xserver
Paquet : xserver-xorg
État: installé
Automatiquement installé: non
Version : 1:7.3+3
Section : x11
Taille décompressée : 1036k
Dépend: xserver-xorg-core (>= 2:1.4-3), xserver-xorg-video-all | xserver-xorg-video-2, xserver-xorg-input-all | xserver-xorg-input-2, debconf (>= 0.5) |
debconf-2.0, xkb-data | xkb-data-legacy, xbase-clients
Pré-dépend: x11-common (>= 1:7.3+3)
Recommande: libgl1-mesa-dri, udev, laptop-detect, xresprobe, discover1 | discover, dmidecode
Est en conflit: xserver-xfree86 (< 6.8.2.dfsg.1-1), xserver-common
Remplace: xserver-common
Description : the X.Org X server
This package depends on the full suite of the server and drivers for the X.Org X server, as well as providing a configuration infrastructure to manage
xorg.conf. It does not provide the actual server itself, but removing it is strongly discouraged.
Marqueurs: hardware::input, hardware::video, interface::x11, network::server, role::dummy, role::metapackage, special::meta, uitoolkit::xlib, use::driver,
x11::xserver
Paquet : gdm
État: non installé
Version : 2.20.0-2
Section : gnome
Responsable : Debian GNOME Maintainers pkg-gnome-maintainers@lists.alioth.debian.org
Taille décompressée : 15,9M
Dépend: libart-2.0-2 (>= 2.3.18), libatk1.0-0 (>= 1.20.0), libattr1 (>= 2.4.4-1), libc6 (>= 2.6.1-1), libcairo2 (>= 1.4.0), libdbus-1-3 (>= 1.1.1),
libdbus-glib-1-2 (>= 0.74), libdmx1, libfontconfig1 (>= 2.4.0), libglade2-0 (>= 1:2.6.1), libglib2.0-0 (>= 2.14.0), libgnomecanvas2-0 (>= 2.11.1),
libgtk2.0-0 (>= 2.12.0), libpam0g (>= 0.99.7.1), libpango1.0-0 (>= 1.18.2), librsvg2-2 (>= 2.18.1), libselinux1 (>= 2.0.15), libwrap0, libx11-6,
libxau6, libxcomposite1 (>= 1:0.3-1), libxcursor1 (> 1.1.2), libxdamage1 (>= 1:1.1), libxdmcp6, libxext6, libxfixes3 (>= 1:4.0.1), libxi6,
libxinerama1, libxml2 (>= 2.6.29), libxrandr2 (>= 2:1.2.0), libxrender1, debconf (>= 0.5) | debconf-2.0, adduser, libpam-modules (>= 0.72-1),
libpam-runtime (>= 0.76-13.1), gnome-session | xterm | x-window-manager | x-terminal-emulator, xbase-clients, gksu (>= 1.0.7), lsb-base (>=
3.0-10), librsvg2-common
Recommande: whiptail | dialog, zenity, gdm-themes, xserver-xephyr | xnest, xserver-xorg
Suggère: locales, uswsusp
Est en conflit: fast-user-switch-applet (< 2.17.4), gnome-session (< 2.19.2), gnome-screensaver (< 2.17.7)
Fournit: x-display-manager
Description : GNOME Display Manager
gdm provides the equivalent of a “login:” prompt for X displays- it pops up a login window and starts an X session.
It provides all the functionality of xdm, including XDMCP support for managing remote displays.
The greeting window is written using the GNOME libraries and hence looks like a GNOME application- even to the extent of supporting themes! By default, the
greeter is run as an unprivileged user for security.
Marqueurs: admin::login, interface::daemon, network::server, role::program, security::authentication, suite::gnome, uitoolkit::gtk, use::login,
x11::display-manager[/code]
mais gdm n’est à installer que si tu veux gnome. si tu préfères installer kde, c’est plutot kdm qu’il faut installer.
Je dirais d’ailleurs que préciser qu’on veut x11-common xorg et xserver-xorg est inutile car si l’on installe n’importe lequel des gestionnaires de login (gdm, kdm, xdm, entrance, etc…), les autres paquets s’installeront d’office.
