Serveur Debian Jessie reboot intenpestif
Salut à tous,
J’ai un serveur debian jessie: fresh install avec virtualmin.
et 2 à 3 fois par jour il freeze et reboot ! je precise qu’il est neuf (5jours).
Raid 5 hardware avec 3 disques et 64G de RAM…
[quote]
uname -a
linux 3.14.32-xxxx-grs-ipv6-64 #5 SMP Wed Sep 9 17:24:34 CEST 2015 x86_64 GNU/Linux[/quote]
quand il redemarre voici les logs que j’ai isolé:
[quote]grep -iEw ‘error|fail|enable|warning|no|munin|uninstal|bios|not’ /var/log/kern.log
Jan 24 10:51:38 s06 kernel: e820: BIOS-provided physical RAM map:
Jan 24 10:51:38 s06 kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009afff] usable
Jan 24 10:51:38 s06 kernel: BIOS-e820: [mem 0x000000000009b000-0x000000000009ffff] reserved
Jan 24 10:51:38 s06 kernel: BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
Jan 24 10:51:38 s06 kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000079736fff] usable
Jan 24 10:51:38 s06 kernel: BIOS-e820: [mem 0x0000000079737000-0x0000000079905fff] reserved
Jan 24 10:51:38 s06 kernel: BIOS-e820: [mem 0x0000000079906000-0x00000000799f6fff] usable
Jan 24 10:51:38 s06 kernel: BIOS-e820: [mem 0x00000000799f7000-0x0000000079e79fff] ACPI NVS
Jan 24 10:51:38 s06 kernel: BIOS-e820: [mem 0x0000000079e7a000-0x000000007bdc7fff] reserved
Jan 24 10:51:38 s06 kernel: BIOS-e820: [mem 0x000000007bdc8000-0x000000007bdc8fff] usable
Jan 24 10:51:38 s06 kernel: BIOS-e820: [mem 0x000000007bdc9000-0x000000007be4efff] reserved
Jan 24 10:51:38 s06 kernel: BIOS-e820: [mem 0x000000007be4f000-0x000000007bffffff] usable
Jan 24 10:51:38 s06 kernel: BIOS-e820: [mem 0x0000000080000000-0x000000008fffffff] reserved
Jan 24 10:51:38 s06 kernel: BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
Jan 24 10:51:38 s06 kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
Jan 24 10:51:38 s06 kernel: BIOS-e820: [mem 0x0000000100000000-0x000000107fffffff] usable
Jan 24 10:51:38 s06 kernel: DMI: Supermicro Super Server/X10SDV-4C-TLN2F, BIOS 1.0b 09/09/2015
Jan 24 10:51:38 s06 kernel: No AGP bridge found
Jan 24 10:51:38 s06 kernel: No NUMA configuration found
Jan 24 10:51:38 s06 kernel: [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
Jan 24 10:51:38 s06 kernel: acpi PNP0A08:00: OSC: platform does not support [PME AER]
Jan 24 10:51:38 s06 kernel: system 00:06: [io 0x0400-0x047f] could not be reserved
Jan 24 10:51:38 s06 kernel: system 00:06: [mem 0xfed1c000-0xfed3ffff] could not be reserved
Jan 24 10:51:38 s06 kernel: SGI XFS with ACLs, security attributes, large block/inode numbers, no debug enabled
Jan 24 10:51:38 s06 kernel: ioapic: probe of 0000:00:05.4 failed with error -22
Jan 24 10:51:38 s06 kernel: intel_idle: does not run on family 6 model 86
Jan 24 10:51:38 s06 kernel: ERST: Error Record Serialization Table (ERST) support is initialized.
Jan 24 10:51:38 s06 kernel: ghes_edac: This EDAC driver relies on BIOS to enumerate memory and get error reports.
Jan 24 10:51:38 s06 kernel: ghes_edac: Unfortunately, not all BIOSes reflect the memory layout correctly.
Jan 24 10:51:38 s06 kernel: ghes_edac: to correct its BIOS.
Jan 24 10:51:38 s06 kernel: slram: not enough parameters.
Jan 24 10:51:38 s06 kernel: ACPI Warning: _SB
.PCI0.BR2C.PRT: Return Package has no elements (empty) (20131218/nsprepkg-126)
Jan 24 10:51:38 s06 kernel: ixgbe 0000:03:00.0 eth0: MAC: 5, PHY: 6, PBA No: 020000-000
.PCI0.BR2C._PRT: Return Package has no elements (empty) (20131218/nsprepkg-126)
Jan 24 10:51:38 s06 kernel: floppy0: no floppy controllers found
Jan 24 10:51:38 s06 kernel: ixgbe 0000:03:00.1 eth1: MAC: 5, PHY: 6, PBA No: 020000-000
Jan 24 10:51:38 s06 kernel: ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
Jan 24 10:51:38 s06 kernel: ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
Jan 24 10:51:38 s06 kernel: xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
Jan 24 10:51:38 s06 kernel: i8042: PNP: No PS/2 controller found. Probing ports directly.
Jan 24 10:51:38 s06 kernel: i8042: No controller found
Jan 24 10:51:38 s06 kernel: No iBFT detected.
Jan 24 10:51:38 s06 kernel: EXT3-fs (sda2): error: couldn’t mount because of unsupported optional features (240)
Jan 24 10:51:38 s06 kernel: EXT2-fs (sda2): error: couldn’t mount because of unsupported optional features (244)
Jan 24 10:51:38 s06 kernel: IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready[/quote]
je vois bien que ca coince sur sda2 voici les infos qui pourraient intéresser:
[quote]fdisk -l
Device Start End Sectors Size Type
/dev/sda1 40 2048 2009 1004,5K BIOS boot
/dev/sda2 4096 40962047 40957952 19,5G Linux filesystem
/dev/sda3 40962048 7810836479 7769874432 3,6T Linux filesystem
/dev/sda4 7810836480 7811883007 1046528 511M Linux swap[/quote]
[quote]df
Sys. de fichiers blocs de 1K Utilisé Disponible Uti% Monté sur
/dev/root 20026236 2401412 16584492 13% /
devtmpfs 32931784 0 32931784 0% /dev
tmpfs 32965288 0 32965288 0% /dev/shm
tmpfs 32965288 10088 32955200 1% /run
tmpfs 5120 0 5120 0% /run/lock
tmpfs 32965288 0 32965288 0% /sys/fs/cgroup
/dev/sda3 3823845800 713444 3628869112 1% /home[/quote]
Si quelqu’un a une idée ou une piste !
THX
Tu as essayé en mettant à jour le noyau car il y a plus récent que le 3.14.32
Un apt-get update && apt-get upgrade ne donne rien concernant une mise à jour du kernel… et mon sources.list est à jour.
Mauvaise piste ! :frowning:
Dommage, j’en suis à 3.16.0-4 chez moi mais je suis en Jessie classique sur un seul disque.
depuis hier 15h pas de reboot !
J’ai fait quelques mise à jour système… mais je vois pas trop le rapport !
j’ai chaque jour dans kern.log:
[quote]
mcelog --client
Memory errors
SOCKET 0 CHANNEL any DIMM any
corrected memory errors:
4 total
4 in 24h
uncorrected memory errors:
0 total
0 in 24h
SOCKET 0 CHANNEL 0 DIMM any
4 total
4 in 24h
0 total
0 in 24h
Per page corrected memory statistics:
7f09a5000: total 4 seen “4 in 24h” online[/quote]
4 erreurs qui correspond à mon nombre de reboot !!!
Tu as testé ta ram ?
Non, mais je crois que je vais devoir y passer…!!
