xx
J’ai acheter un Globalscale DreamPlug Multi Boot, il ne poséde pas de carte graphique, n’y clavier et n’y souris. Il ce commande depuis un PC qui ce connecte en SSH avec le terminal du pc.
Il a un processeur ARM.
Voir détail ici —> newit.co.uk/shop/proddetail. … ream_Multi
Mon serveur a un décalage de 2h00.
root@debian:~# date
Sun Apr 22 20:07:46 UTC 2012
root@debian:~# alors qu’il est 22h07.
Pour résoudre le problème je pensé installer ntp.
J’ai donc suivi le tuto Debian ici -----> isalo.org/wiki.debian-fr/index.php?title=NTP
Je constate que ntp est déja installé.
root@debian:~# apt-get install ntp
Reading package lists... Done
Building dependency tree
Reading state information... Done
ntp is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
root@debian:~#
Son fichier de configuration
[code]root@debian:~# cat /etc/ntp.conf
/etc/ntp.conf, configuration for ntpd; see ntp.conf(5) for help
driftfile /var/lib/ntp/ntp.drift
Enable this if you want statistics to be logged.
#statsdir /var/log/ntpstats/
statistics loopstats peerstats clockstats
filegen loopstats file loopstats type day enable
filegen peerstats file peerstats type day enable
filegen clockstats file clockstats type day enable
You do need to talk to an NTP server or two (or three).
#server ntp.your-provider.example
pool.ntp.org maps to about 1000 low-stratum NTP servers. Your server will
pick a different set every time it starts up. Please consider joining the
pool: http://www.pool.ntp.org/join.html
server 0.debian.pool.ntp.org iburst
server 1.debian.pool.ntp.org iburst
server 2.debian.pool.ntp.org iburst
server 3.debian.pool.ntp.org iburst
Access control configuration; see /usr/share/doc/ntp-doc/html/accopt.html for
details. The web page http://support.ntp.org/bin/view/Support/AccessRestrictions
might also be helpful.
Note that “restrict” applies to both servers and clients, so a configuration
that might be intended to block requests from certain clients could also end
up blocking replies from your own upstream servers.
By default, exchange time with everybody, but don’t allow configuration.
restrict -4 default kod notrap nomodify nopeer noquery
restrict -6 default kod notrap nomodify nopeer noquery
Local users may interrogate the ntp server more closely.
restrict 127.0.0.1
restrict ::1
Clients from this (example!) subnet have unlimited access, but only if
cryptographically authenticated.
#restrict 192.168.123.0 mask 255.255.255.0 notrust
If you want to provide time to your local subnet, change the next line.
(Again, the address is an example only.)
#broadcast 192.168.123.255
If you want to listen to time broadcasts on your local subnet, de-comment the
next lines. Please do this only if you trust everybody on the network!
#disable auth
#broadcastclient
root@debian:~#[/code]
Mais je ne trouve pas ou est situé le problème ?
Merci.
s’il sagit de 2heures complètes, le ntp doit fonctionner, tu dois avoir une erreur deconfig dans la timezone:
Bonsoir,
Merci de votre aide, c’est radicale
[code]root@debian:~# dpkg-reconfigure tzdata
Current default time zone: 'Europe/Paris’
Local time is now: Sun Apr 22 22:44:32 CEST 2012.
Universal Time is now: Sun Apr 22 20:44:32 UTC 2012.
root@debian:~# date
Sun Apr 22 22:44:46 CEST 2012
J’ai sélectionné “Europe” puis validé, en suite sélectionné “Paris” puis validé et c’est ok.
Merci.
Comme je te le disais le 11 avril dernier:
[quote=“lol”]Salut,
Pas de [Résolu] dans le titre SVP! La coche verte!!!
Merci.[/quote]
