Désolé de mon absence de nouvelle, j’ai dû m’absenter cette semaine.
J’ai fait ce que tu m’as dit: dmesg. Ca donne:
[ 0.280017] pnp 00:06: io min 0x778 max 0x778 align 1 size 8 flags 0x1
[ 0.280017] pnp 00:06: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00001cf8 flags 0x1
[ 0.280017] pnp 00:06: dma bitmask 0xf flags 0x0
[ 0.280017] pnp 00:06: new dependent option (priority 0x1)
[ 0.280017] pnp 00:06: io min 0x278 max 0x278 align 1 size 8 flags 0x1
[ 0.280017] pnp 00:06: io min 0x678 max 0x678 align 1 size 8 flags 0x1
[ 0.280017] pnp 00:06: io min 0x3bc max 0x3bc align 1 size 4 flags 0x1
[ 0.280017] pnp 00:06: io min 0x7bc max 0x7bc align 1 size 4 flags 0x1
[ 0.280017] pnp 00:06: end dependent options
[ 0.280017] pnp 00:06: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.280017] pnp 00:07: parse allocated resources
[ 0.280017] pnp 00:07: add io 0x10-0x1f flags 0x1
[ 0.280017] pnp 00:07: add io 0x22-0x3f flags 0x1
[ 0.280017] pnp 00:07: add io 0x44-0x5f flags 0x1
[ 0.280017] pnp 00:07: add io 0x62-0x63 flags 0x1
[ 0.280017] pnp 00:07: add io 0x65-0x6f flags 0x1
[ 0.280017] pnp 00:07: add io 0x72-0x7f flags 0x1
[ 0.280017] pnp 00:07: add io 0x80-0x80 flags 0x1
[ 0.280017] pnp 00:07: add io 0x84-0x86 flags 0x1
[ 0.280017] pnp 00:07: add io 0x88-0x88 flags 0x1
[ 0.280017] pnp 00:07: add io 0x8c-0x8e flags 0x1
[ 0.280017] pnp 00:07: add io 0x90-0x9f flags 0x1
[ 0.280017] pnp 00:07: add io 0xa2-0xbf flags 0x1
[ 0.280017] pnp 00:07: add io 0xe0-0xef flags 0x1
[ 0.280017] pnp 00:07: add io 0x4d0-0x4d1 flags 0x1
[ 0.280017] pnp 00:07: add io 0x4000-0x407f flags 0x1
[ 0.280017] pnp 00:07: add io 0x4080-0x40ff flags 0x1
[ 0.280017] pnp 00:07: PNP0c02: calling quirk_system_pci_resources+0x0/0x15c
[ 0.280017] pnp 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.280017] pnp 00:08: parse allocated resources
[ 0.280017] pnp 00:08: add mem 0xfec00000-0xfec00fff flags 0x0
[ 0.280017] pnp 00:08: add mem 0xfee00000-0xfeefffff flags 0x0
[ 0.280017] pnp 00:08: add mem 0xff380000-0xffffffff flags 0x0
[ 0.280017] pnp 00:08: add mem 0xfec10000-0xfec10fff flags 0x0
[ 0.280017] pnp 00:08: PNP0c02: calling quirk_system_pci_resources+0x0/0x15c
[ 0.280017] pnp 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.280017] pnp 00:09: parse allocated resources
[ 0.280017] pnp 00:09: add io 0x60-0x60 flags 0x1
[ 0.280017] pnp 00:09: add io 0x64-0x64 flags 0x1
[ 0.280017] pnp 00:09: add irq 1 flags 0x1
[ 0.280017] pnp 00:09: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.280017] pnp 00:0a: parse allocated resources
[ 0.280017] pnp 00:0a: add irq 12 flags 0x1
[ 0.280017] pnp 00:0a: Plug and Play ACPI device, IDs PNP0f03 PNP0f13 (active)
[ 0.280017] pnp 00:0b: parse allocated resources
[ 0.280017] pnp 00:0b: add io 0x3f8-0x3ff flags 0x1
[ 0.280017] pnp 00:0b: add irq 4 flags 0x1
[ 0.280017] pnp 00:0b: parse resource options
[ 0.280017] pnp 00:0b: new independent option
[ 0.280017] pnp 00:0b: new dependent option (priority 0x0)
[ 0.280017] pnp 00:0b: io min 0x3f8 max 0x3f8 align 1 size 8 flags 0x1
[ 0.280017] pnp 00:0b: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000010 flags 0x1
[ 0.280017] pnp 00:0b: new dependent option (priority 0x1)
[ 0.280017] pnp 00:0b: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00001cf8 flags 0x1
[ 0.280017] pnp 00:0b: io min 0x2f8 max 0x2f8 align 1 size 8 flags 0x1
[ 0.280017] pnp 00:0b: io min 0x3e8 max 0x3e8 align 1 size 8 flags 0x1
[ 0.280017] pnp 00:0b: io min 0x2e8 max 0x2e8 align 1 size 8 flags 0x1
[ 0.280017] pnp 00:0b: end dependent options
[ 0.280017] pnp 00:0b: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.280017] pnp 00:0c: parse allocated resources
[ 0.280017] pnp 00:0c: add io 0x0-0xffffffffffffffff flags 0x10000001
[ 0.280017] pnp 00:0c: add io 0x290-0x29f flags 0x1
[ 0.280017] pnp 00:0c: PNP0c02: calling quirk_system_pci_resources+0x0/0x15c
[ 0.280017] pnp 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.280017] pnp 00:0d: parse allocated resources
[ 0.280017] pnp 00:0d: add mem 0xe0000000-0xefffffff flags 0x0
[ 0.280017] pnp 00:0d: PNP0c02: calling quirk_system_pci_resources+0x0/0x15c
[ 0.280017] pnp 00:0d: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.280017] pnp 00:0e: parse allocated resources
[ 0.280017] pnp 00:0e: add mem 0x0-0x9ffff flags 0x1
[ 0.280017] pnp 00:0e: add mem 0xc0000-0xcffff flags 0x0
[ 0.280017] pnp 00:0e: add mem 0xe0000-0xfffff flags 0x0
[ 0.280017] pnp 00:0e: add mem 0x100000-0xdfffffff flags 0x1
[ 0.280017] pnp 00:0e: add mem 0x0-0xffffffffffffffff flags 0x10000000
[ 0.280017] pnp 00:0e: PNP0c01: calling quirk_system_pci_resources+0x0/0x15c
[ 0.280017] pnp 00:0e: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.284429] pnp: PnP ACPI: found 15 devices
[ 0.284431] ACPI: ACPI bus type pnp unregistered
[ 0.285663] usbcore: registered new interface driver usbfs
[ 0.286012] usbcore: registered new interface driver hub
[ 0.286360] usbcore: registered new device driver usb
[ 0.287562] PCI: Using ACPI for IRQ routing
[ 0.287570] PCI: Cannot allocate resource region 0 of device 0000:00:00.0
[ 0.310913] agpgart: Detected AGP bridge 0
[ 0.310919] agpgart: Setting up Nforce3 AGP.
[ 0.311789] agpgart: AGP aperture is 64M @ 0xf0000000
[ 0.311789] PCI-DMA: using GART IOMMU.
[ 0.311789] PCI-DMA: Warning: Small IOMMU 32MB. Consider increasing the AGP aperture in BIOS
[ 0.311789] PCI-DMA: Reserving 32MB of IOMMU area in the AGP aperture
[ 0.312527] ACPI: RTC can wake from S4
[ 0.332020] pnp: the driver ‘system’ has been registered
[ 0.332043] system 00:07: ioport range 0x4d0-0x4d1 has been reserved
[ 0.332045] system 00:07: ioport range 0x4000-0x407f has been reserved
[ 0.332047] system 00:07: ioport range 0x4080-0x40ff has been reserved
[ 0.332049] system 00:07: driver attached
[ 0.332057] system 00:08: iomem range 0xfec00000-0xfec00fff has been reserved
[ 0.332059] system 00:08: iomem range 0xfee00000-0xfeefffff has been reserved
[ 0.332065] system 00:08: iomem range 0xff380000-0xffffffff could not be reserved
[ 0.332067] system 00:08: iomem range 0xfec10000-0xfec10fff has been reserved
[ 0.332069] system 00:08: driver attached
[ 0.332076] system 00:0c: ioport range 0x290-0x29f has been reserved
[ 0.332078] system 00:0c: driver attached
[ 0.332083] system 00:0d: iomem range 0xe0000000-0xefffffff has been reserved
[ 0.332085] system 00:0d: driver attached
[ 0.332090] system 00:0e: iomem range 0x0-0x9ffff could not be reserved
[ 0.332092] system 00:0e: iomem range 0xc0000-0xcffff has been reserved
[ 0.332094] system 00:0e: iomem range 0xe0000-0xfffff could not be reserved
[ 0.332096] system 00:0e: iomem range 0x100000-0xdfffffff could not be reserved
[ 0.332097] system 00:0e: driver attached
[ 0.335794] PCI: Bridge: 0000:00:0b.0
[ 0.335794] IO window: d000-dfff
[ 0.335794] MEM window: 0xfea00000-0xfeafffff
[ 0.335794] PREFETCH window: 0x00000000f8000000-0x00000000fbffffff
[ 0.335794] PCI: Bridge: 0000:00:0e.0
[ 0.335794] IO window: e000-efff
[ 0.335794] MEM window: 0xfeb00000-0xfebfffff
[ 0.335794] PREFETCH window: disabled.
[ 0.335794] PCI: Bridge: 0000:00:11.0
[ 0.335794] IO window: disabled.
[ 0.335794] MEM window: disabled.
[ 0.335794] PREFETCH window: 0x00000000f7f00000-0x00000000f7ffffff
[ 0.335794] PCI: Bridge: 0000:00:12.0
[ 0.335794] IO window: b000-bfff
[ 0.335794] MEM window: 0xfe800000-0xfe8fffff
[ 0.335794] PCI: Bridge: 0000:00:13.0
[ 0.335794] IO window: c000-cfff
[ 0.335794] MEM window: 0xfe900000-0xfe9fffff
[ 0.335794] PCI: Setting latency timer of device 0000:00:0e.0 to 64
[ 0.335794] ACPI: PCI Interrupt 0000:00:11.0[A] -> GSI 29 (level, low) -> IRQ 29
[ 0.335794] PCI: Setting latency timer of device 0000:00:11.0 to 64
[ 0.335794] ACPI: PCI Interrupt 0000:00:12.0[A] -> GSI 34 (level, low) -> IRQ 34
[ 0.335794] PCI: Setting latency timer of device 0000:00:12.0 to 64
[ 0.335794] ACPI: PCI Interrupt 0000:00:13.0[A] -> GSI 39 (level, low) -> IRQ 39
[ 0.335794] PCI: Setting latency timer of device 0000:00:13.0 to 64
[ 0.335794] NET: Registered protocol family 2
[ 0.371731] IP route cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.372274] TCP established hash table entries: 524288 (order: 11, 8388608 bytes)
[ 0.375734] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.376127] TCP: Hash tables configured (established 524288 bind 65536)
[ 0.376130] TCP reno registered
[ 0.387355] NET: Registered protocol family 1
[ 0.387434] checking if image is initramfs… it is
[ 0.700632] Freeing initrd memory: 6534k freed
[ 0.704632] audit: initializing netlink socket (disabled)
[ 0.704632] type=2000 audit(1304773134.696:1): initialized
[ 0.704632] Total HugeTLB memory allocated, 0
[ 0.704632] VFS: Disk quotas dquot_6.5.1
[ 0.704632] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.704632] msgmni has been set to 12104
[ 0.704632] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.704632] io scheduler noop registered
[ 0.704632] io scheduler anticipatory registered
[ 0.704632] io scheduler deadline registered
[ 0.704632] io scheduler cfq registered (default)
[ 1.163120] pci 0000:00:10.0: Enabling HT MSI Mapping
[ 1.163136] pci 0000:00:11.0: Enabling HT MSI Mapping
[ 1.163148] pci 0000:00:12.0: Enabling HT MSI Mapping
[ 1.163160] pci 0000:00:13.0: Enabling HT MSI Mapping
[ 1.163170] pci 0000:04:00.0: Boot video device
[ 1.163858] PCI: Setting latency timer of device 0000:00:11.0 to 64
[ 1.163877] assign_interrupt_mode Found MSI capability
[ 1.163896] Allocate Port Service[0000:00:11.0:pcie00]
[ 1.164504] Allocate Port Service[0000:00:11.0:pcie01]
[ 1.164649] Allocate Port Service[0000:00:11.0:pcie03]
[ 1.164649] PCI: Setting latency timer of device 0000:00:12.0 to 64
[ 1.164649] assign_interrupt_mode Found MSI capability
[ 1.164649] Allocate Port Service[0000:00:12.0:pcie00]
[ 1.164649] Allocate Port Service[0000:00:12.0:pcie01]
[ 1.164649] Allocate Port Service[0000:00:12.0:pcie03]
[ 1.164649] PCI: Setting latency timer of device 0000:00:13.0 to 64
[ 1.164649] Allocate Port Service[0000:00:13.0:pcie00]
[ 1.164649] Allocate Port Service[0000:00:13.0:pcie01]
[ 1.164649] Allocate Port Service[0000:00:13.0:pcie03]
[ 1.164649] Load service driver aer on pcie device 0000:00:11.0:pcie01
[ 1.168305] Load service driver aer on pcie device 0000:00:12.0:pcie01
[ 1.170184] Load service driver aer on pcie device 0000:00:13.0:pcie01
[ 1.174183] Linux agpgart interface v0.103
[ 1.174183] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
[ 1.174183] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.174183] pnp: the driver ‘serial’ has been registered
[ 1.174183] 00:0b: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.174183] serial 00:0b: driver attached
[ 1.174184] brd: module loaded
[ 1.174184] input: Macintosh mouse button emulation as /class/input/input0
[ 1.174184] pnp: the driver ‘i8042 kbd’ has been registered
[ 1.174184] i8042 kbd 00:09: driver attached
[ 1.174184] pnp: the driver ‘i8042 aux’ has been registered
[ 1.174184] i8042 aux 00:0a: driver attached
[ 1.174184] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[ 1.176591] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.176597] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.196125] mice: PS/2 mouse device common for all mice
[ 1.196470] pnp: the driver ‘rtc_cmos’ has been registered
[ 1.196839] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[ 1.196857] rtc0: alarms up to one year, y3k
[ 1.196858] rtc_cmos 00:02: driver attached
[ 1.197192] cpuidle: using governor ladder
[ 1.197194] cpuidle: using governor menu
[ 1.197199] No iBFT detected.
[ 1.197458] TCP cubic registered
[ 1.197461] NET: Registered protocol family 17
[ 1.198185] registered taskstats version 1
[ 1.198185] rtc_cmos 00:02: setting system clock to 2011-05-07 12:58:56 UTC (1304773136)
[ 1.198185] Freeing unused kernel memory: 392k freed
[ 1.225911] input: AT Translated Set 2 keyboard as /class/input/input1
[ 1.254585] ACPI: ACPI0007:00 is registered as cooling_device0
[ 1.254585] ACPI: ACPI0007:01 is registered as cooling_device1
[ 1.259268] Switched to high resolution mode on CPU 1
[ 1.262491] Switched to high resolution mode on CPU 0
[ 1.694360] ohci_hcd: 2006 August 04 USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.694360] ACPI: PCI Interrupt Link [LUS0] enabled at IRQ 22
[ 1.694360] ACPI: PCI Interrupt 0000:00:02.0[A] -> Link [LUS0] -> GSI 22 (level, low) -> IRQ 22
[ 1.694360] PCI: Setting latency timer of device 0000:00:02.0 to 64
[ 1.694360] ohci_hcd 0000:00:02.0: OHCI Host Controller
[ 1.694360] ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 1
[ 1.694360] ohci_hcd 0000:00:02.0: irq 22, io mem 0xfe7fd000
[ 1.694360] No dock devices found.
[ 1.694360] SCSI subsystem initialized
[ 1.694360] libata version 3.00 loaded.
[ 1.694360] usb usb1: configuration #1 chosen from 1 choice
[ 1.694360] hub 1-0:1.0: USB hub found
[ 1.694360] hub 1-0:1.0: 4 ports detected
[ 1.694360] Floppy drive(s): fd0 is 1.44M
[ 1.694360] FDC 0 is a post-1991 82077
[ 1.694361] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.694361] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.694361] usb usb1: Product: OHCI Host Controller
[ 1.694361] usb usb1: Manufacturer: Linux 2.6.26-2-amd64 ohci_hcd
[ 1.694361] usb usb1: SerialNumber: 0000:00:02.0
[ 1.694361] ACPI: PCI Interrupt Link [LUS1] enabled at IRQ 21
[ 1.694361] ACPI: PCI Interrupt 0000:00:02.1[B] -> Link [LUS1] -> GSI 21 (level, low) -> IRQ 21
[ 1.694361] PCI: Setting latency timer of device 0000:00:02.1 to 64
[ 1.694361] ohci_hcd 0000:00:02.1: OHCI Host Controller
[ 1.694361] ohci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 2
[ 1.694361] ohci_hcd 0000:00:02.1: irq 21, io mem 0xfe7fe000
[ 1.694361] usb usb2: configuration #1 chosen from 1 choice
[ 1.694361] hub 2-0:1.0: USB hub found
[ 1.694361] hub 2-0:1.0: 4 ports detected
[ 1.762326] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.762326] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.762326] usb usb2: Product: OHCI Host Controller
[ 1.762326] usb usb2: Manufacturer: Linux 2.6.26-2-amd64 ohci_hcd
[ 1.762326] usb usb2: SerialNumber: 0000:00:02.1
[ 1.798347] ACPI: PCI Interrupt Link [LUS2] enabled at IRQ 20
[ 1.798356] ACPI: PCI Interrupt 0000:00:02.2[C] -> Link [LUS2] -> GSI 20 (level, low) -> IRQ 20
[ 1.798370] PCI: Setting latency timer of device 0000:00:02.2 to 64
[ 1.798372] ehci_hcd 0000:00:02.2: EHCI Host Controller
[ 1.798430] ehci_hcd 0000:00:02.2: new USB bus registered, assigned bus number 3
[ 1.798456] ehci_hcd 0000:00:02.2: debug port 1
[ 1.798459] PCI: cache line size of 64 is not supported by device 0000:00:02.2
[ 1.798469] ehci_hcd 0000:00:02.2: irq 20, io mem 0xfe7ffc00
[ 1.810340] ehci_hcd 0000:00:02.2: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 1.810420] usb usb3: configuration #1 chosen from 1 choice
[ 1.810439] hub 3-0:1.0: USB hub found
[ 1.810445] hub 3-0:1.0: 8 ports detected
[ 1.914425] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.914428] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.914430] usb usb3: Product: EHCI Host Controller
[ 1.914431] usb usb3: Manufacturer: Linux 2.6.26-2-amd64 ehci_hcd
[ 1.914432] usb usb3: SerialNumber: 0000:00:02.2
[ 1.914425] sata_nv 0000:00:0a.0: version 3.5
[ 1.914425] ACPI: PCI Interrupt Link [LTID] enabled at IRQ 22
[ 1.914425] ACPI: PCI Interrupt 0000:00:0a.0[A] -> Link [LTID] -> GSI 22 (level, low) -> IRQ 22
[ 1.914425] PCI: Setting latency timer of device 0000:00:0a.0 to 64
[ 1.914425] scsi0 : sata_nv
[ 1.914425] scsi1 : sata_nv
[ 1.914425] ata1: SATA max UDMA/133 cmd 0xf80 ctl 0xf00 bmdma 0xa000 irq 22
[ 1.914425] ata2: SATA max UDMA/133 cmd 0xe80 ctl 0xe00 bmdma 0xa008 irq 22
[ 2.406783] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.415316] ata1.00: ATA-8: WDC WD3200AAKS-00V1A0, 05.01D05, max UDMA/133
[ 2.415320] ata1.00: 625142448 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 2.431810] ata1.00: configured for UDMA/133
[ 2.526283] usb 2-4: new full speed USB device using ohci_hcd and address 2
[ 2.743323] usb 2-4: configuration #1 chosen from 1 choice
[ 2.752505] usb 2-4: New USB device found, idVendor=0d8c, idProduct=0201
[ 2.752508] usb 2-4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.752510] usb 2-4: Product: PnP Audio Device
[ 2.752609] scsi 0:0:0:0: Direct-Access ATA WDC WD3200AAKS-0 05.0 PQ: 0 ANSI: 5
[ 2.759813] Uniform Multi-Platform E-IDE driver
[ 2.759813] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
[ 2.760565] ahci 0000:01:00.0: version 3.0
[ 2.760596] ACPI: PCI Interrupt 0000:01:00.0[A] -> GSI 30 (level, low) -> IRQ 30
[ 2.760565] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 19
[ 2.760565] ACPI: PCI Interrupt 0000:05:06.0[A] -> Link [LNKC] -> GSI 19 (level, low) -> IRQ 19
[ 2.760565] 3c59x: Donald Becker and others.
[ 2.760565] 0000:05:06.0: 3Com PCI 3c905B Cyclone 100baseTx at ffffc20000c3cc00.
[ 3.806124] ahci 0000:01:00.0: AHCI 0001.0000 32 slots 2 ports 3 Gbps 0x3 impl SATA mode
[ 3.806127] ahci 0000:01:00.0: flags: 64bit ncq pm led clo pmp pio slum part
[ 3.806132] PCI: Setting latency timer of device 0000:01:00.0 to 64
[ 3.810080] scsi2 : ahci
[ 3.810080] scsi3 : ahci
[ 3.810080] ata3: SATA max UDMA/133 abar m8192@0xfe8fe000 port 0xfe8fe100 irq 30
[ 3.810080] ata4: SATA max UDMA/133 abar m8192@0xfe8fe000 port 0xfe8fe180 irq 30
[ 4.650113] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 4.650084] ata3.00: ATA-8: Hitachi HDP725050GLA360, GM4OA5CA, max UDMA/133
[ 4.650084] ata3.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 4.650084] ata3.00: configured for UDMA/133
[ 5.366119] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 5.366089] ata4.00: ATA-8: WDC WD5000AADS-00S9B0, 01.00A01, max UDMA/133
[ 5.366089] ata4.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 5.366089] ata4.00: configured for UDMA/133
[ 5.690188] scsi 2:0:0:0: Direct-Access ATA Hitachi HDP72505 GM4O PQ: 0 ANSI: 5
[ 5.690295] scsi 3:0:0:0: Direct-Access ATA WDC WD5000AADS-0 01.0 PQ: 0 ANSI: 5
[ 5.694086] r8169 Gigabit Ethernet driver 2.2LK-NAPI loaded
[ 5.694086] ACPI: PCI Interrupt 0000:02:00.0[A] -> GSI 35 (level, low) -> IRQ 35
[ 5.694086] PCI: Setting latency timer of device 0000:02:00.0 to 64
[ 5.694086] eth1: RTL8168b/8111b at 0xffffc20000c32000, 00:19:66:ec:b1:f9, XID 38000000 IRQ 1276
[ 5.694572] NFORCE3-250: 0000:00:08.0 (rev a2) UDMA133 controller
[ 5.694572] NFORCE3-250: IDE controller (0x10de:0x00e5 rev 0xa2) at PCI slot 0000:00:08.0
[ 5.694572] NFORCE3-250: not 100% native mode: will probe irqs later
[ 5.694572] NFORCE3-250: BIOS didn’t set cable bits correctly. Enabling workaround.
[ 5.694572] ide0: BM-DMA at 0xffa0-0xffa7
[ 5.694572] ide1: BM-DMA at 0xffa8-0xffaf
[ 5.694572] Probing IDE interface ide0…
[ 5.722327] Driver ‘sd’ needs updating - please use bus_type methods
[ 5.722417] sd 0:0:0:0: [sda] 625142448 512-byte hardware sectors (320073 MB)
[ 5.722427] sd 0:0:0:0: [sda] Write Protect is off
[ 5.722429] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 5.722442] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 5.722478] sd 0:0:0:0: [sda] 625142448 512-byte hardware sectors (320073 MB)
[ 5.722485] sd 0:0:0:0: [sda] Write Protect is off
[ 5.722487] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 5.722499] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 5.722502] sda: sda1
[ 5.730073] sd 0:0:0:0: [sda] Attached SCSI disk
[ 5.730073] sd 2:0:0:0: [sdb] 976773168 512-byte hardware sectors (500108 MB)
[ 5.730073] sd 2:0:0:0: [sdb] Write Protect is off
[ 5.730073] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 5.730073] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 5.730073] sdb: sdb1 sdb2 < sdb5 >
[ 5.787515] sd 2:0:0:0: [sdb] Attached SCSI disk
[ 5.787515] sd 3:0:0:0: [sdc] 976773168 512-byte hardware sectors (500108 MB)
[ 5.787515] sd 3:0:0:0: [sdc] Write Protect is off
[ 5.787515] sd 3:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[ 5.787515] sd 3:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 5.787515] sdc: sdc1
[ 6.207022] sd 3:0:0:0: [sdc] Attached SCSI disk
[ 6.438127] hda: HL-DT-ST DVDRAM GSA-H10A, ATAPI CD/DVD-ROM drive
[ 7.228985] hdb: CDRW2224 PLUS, ATAPI CD/DVD-ROM drive
[ 7.284920] hda: host max PIO5 wanted PIO255(auto-tune) selected PIO4
[ 7.289349] hda: UDMA/33 mode selected
[ 7.289349] hdb: host max PIO5 wanted PIO255(auto-tune) selected PIO4
[ 7.289349] hdb: MWDMA2 mode selected
[ 7.289349] Probing IDE interface ide1…
[ 7.573522] hdc: ST3120022A, ATA DISK drive
[ 8.246250] hdc: host max PIO5 wanted PIO255(auto-tune) selected PIO4
[ 8.246452] hdc: UDMA/100 mode selected
[ 8.250675] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
[ 8.252019] ide1 at 0x170-0x177,0x376 on irq 15
[ 8.262648] JMB: IDE controller (0x197b:0x2363 rev 0x03) at PCI slot 0000:01:00.1
[ 8.262648] JMicron IDE 0000:01:00.1: enabling device (0000 -> 0001)
[ 8.262648] ACPI: PCI Interrupt 0000:01:00.1[B] -> GSI 31 (level, low) -> IRQ 31
[ 8.262648] JMB: 100% native mode on irq 31
[ 8.262648] PCI: Setting latency timer of device 0000:01:00.1 to 64
[ 8.262648] ide2: BM-DMA at 0xb400-0xb407
[ 8.262648] ide3: BM-DMA at 0xb408-0xb40f
[ 8.262648] Probing IDE interface ide2…
[ 8.284644] hdc: max request size: 512KiB
[ 8.285284] hdc: 234441648 sectors (120034 MB) w/2048KiB Cache, CHS=16383/255/63
[ 8.286534] hdc: cache flushes supported
[ 8.286534] hdc:<6>hda: ATAPI 48X DVD-ROM DVD-R-RAM CD-R/RW drive, 2048kB Cache
[ 8.288464] Uniform CD-ROM driver Revision: 3.20
[ 8.294706] hdc1 hdc2 <<6>hdb: ATAPI 24X CD-ROM CD-R/RW drive, 768kB Cache
[ 8.318316] hdc5 >
[ 8.830377] Probing IDE interface ide3…
[ 9.593375] ide2 at 0xbc00-0xbc07,0xb882 on irq 31
[ 9.593388] ide3 at 0xb800-0xb807,0xb482 on irq 31
[ 10.093659] PM: Starting manual resume from disk
[ 10.133272] kjournald starting. Commit interval 5 seconds
[ 10.133287] EXT3-fs: mounted filesystem with ordered data mode.
[ 11.863730] udevd version 125 started
[ 12.384214] input: Power Button (FF) as /class/input/input2
[ 12.443030] ACPI: Power Button (FF) [PWRF]
[ 12.443103] input: Power Button (CM) as /class/input/input3
[ 12.505718] ACPI: Power Button (CM) [PWRB]
[ 12.609645] i2c-adapter i2c-0: nForce2 SMBus adapter at 0x5000
[ 12.609660] i2c-adapter i2c-1: nForce2 SMBus adapter at 0x5040
[ 12.839171] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 12.857602] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 12.922171] input: PC Speaker as /class/input/input4
[ 13.345135] usbcore: registered new interface driver snd-usb-audio
[ 13.641176] input: ImPS/2 Logitech Wheel Mouse as /class/input/input5
[ 13.672650] pnp: the driver ‘parport_pc’ has been registered
[ 13.672650] parport_pc 00:06: reported by Plug and Play ACPI
[ 13.672650] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 13.770074] parport_pc 00:06: driver attached
[ 14.906169] Adding 4803392k swap on /dev/hdc5. Priority:-1 extents:1 across:4803392k
[ 15.233824] EXT3 FS on hdc1, internal journal
[ 15.905535] loop: module loaded
[ 17.364767] eth0: setting full-duplex.
[ 17.483379] NET: Registered protocol family 10
[ 17.483692] lo: Disabled Privacy Extensions
[ 24.947332] powernow-k8: Found 1 AMD Athlon™ II X2 245 Processor processors (2 cpu cores) (version 2.20.00)
[ 24.943589] powernow-k8: 0 : pstate 0 (2900 MHz)
[ 24.943589] powernow-k8: 1 : pstate 1 (2200 MHz)
[ 24.943589] powernow-k8: 2 : pstate 2 (1700 MHz)
[ 24.943589] powernow-k8: 3 : pstate 3 (800 MHz)
[ 29.874612] eth0: no IPv6 routers present
[ 36.951757] lp0: using parport0 (interrupt-driven).
[ 36.982302] ppdev: user-space parallel port driver
[ 40.330378] r8169: eth1: link down
[ 40.334163] ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 44.026739] [drm] Initialized drm 1.1.0 20060810
[ 44.218721] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 18
[ 44.218721] ACPI: PCI Interrupt 0000:04:00.0[A] -> Link [LNKD] -> GSI 18 (level, low) -> IRQ 18
[ 44.218721] [drm] Initialized r128 2.5.0 20030725 on minor 0
[ 44.222757] agpgart: Found an AGP 2.0 compliant device at 0000:00:00.0.
[ 44.222789] agpgart: Putting AGP V2 device at 0000:00:00.0 into 1x mode
[ 44.222885] agpgart: Putting AGP V2 device at 0000:04:00.0 into 1x mode
[ 55.203269] eth0: no IPv6 routers present
[ 1129.979544] agpgart: Found an AGP 2.0 compliant device at 0000:00:00.0.
[ 1129.979544] agpgart: Putting AGP V2 device at 0000:00:00.0 into 1x mode
[ 1129.979544] agpgart: Putting AGP V2 device at 0000:04:00.0 into 1x mode
