bonjour, j’etais entrain d’installer phpmotion et phpshield et depuis j’ai une page blanche sur mon site,
[code]~# php -i|grep php.ini
Failed loading /usr/local/ioncube/ioncube_loader_lin_.so: /usr/local/ioncube/ioncube_loader_lin_.so: cannot open shared object file: No such file or directory
Zend Optimizer requires Zend Engine API version 220060519.
The Zend Engine API version 220090626 which is installed, is newer.
Contact Zend Technologies at http://www.zend.com/ for a later version of Zend Optimizer.
PHP Warning: Module ‘SourceGuardian’ already loaded in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library ‘/usr/lib/php5/20090626/curl.so’ - /usr/lib/php5/20090626/curl.so: cannot open shared object file: No such file or directory in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library ‘/usr/lib/php5/20090626/gd.so’ - /usr/lib/php5/20090626/gd.so: cannot open shared object file: No such file or directory in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library ‘/usr/lib/php5/20090626/mcrypt.so’ - /usr/lib/php5/20090626/mcrypt.so: cannot open shared object file: No such file or directory in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library ‘/usr/lib/php5/20090626/mysql.so’ - /usr/lib/php5/20090626/mysql.so: cannot open shared object file: No such file or directory in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library ‘/usr/lib/php5/20090626/mysqli.so’ - /usr/lib/php5/20090626/mysqli.so: cannot open shared object file: No such file or directory in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library ‘/usr/lib/php5/20090626/pdo.so’ - /usr/lib/php5/20090626/pdo.so: cannot open shared object file: No such file or directory in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library ‘/usr/lib/php5/20090626/pdo_mysql.so’ - /usr/lib/php5/20090626/pdo_mysql.so: cannot open shared object file: No such file or directory in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library ‘/usr/lib/php5/20090626/suhosin.so’ - /usr/lib/php5/20090626/suhosin.so: cannot open shared object file: No such file or directory in Unknown on line 0
Configuration File (php.ini) Path => /etc/php5/cli
Loaded Configuration File => /etc/php5/cli/php.ini
je pense que j’ai du touché a ce qu’il ne fallais pas,
merci
