effectivement en changeant cela fonctionne… enfin pas tout à fait.
j’ai pu connecter mon client XP au domaine samba mais maintenant je n’arrive plus à configurer le ldap avec samba avec ton tuto…
j’ai une erreur quand je fait le “net getlocalsid” et le smb-populate!
de plus quand je tente d’accéder au ldap avec phpldapadmin il me dit que mon mot de passe est érroné…
[2011/06/28 14:02:05.049108, 0] lib/smbldap.c:1151(smbldap_connect_system)
failed to bind to server ldap://127.0.0.1 with dn="cn=admin,dc=netrt1,dc=local" Error: Invalid credentials
(unknown)
SID for domain SRV-DC is: S-1-5-21-1376097600-3723839687-1356423239
pour le le smbldap-populate :
[code]Use of uninitialized value $value in substitution (s///) at /usr/share/perl5/smbldap_tools.pm line 140, line 1.
Populating LDAP directory for domain netrt1.local (S-1-5-21-1376097600-3723839687-1356423239)
(using builtin directory structure)
adding new entry: dc=netrt1,dc=local
failed to add entry: no global superior knowledge at /usr/sbin/smbldap-populate line 498, line 7.
adding new entry: ou=Users,dc=netrt1,dc=local
failed to add entry: no global superior knowledge at /usr/sbin/smbldap-populate line 498, line 12.
adding new entry: ou=Groups,dc=netrt1,dc=local
failed to add entry: no global superior knowledge at /usr/sbin/smbldap-populate line 498, line 17.
adding new entry: ou=Machines,dc=netrt1,dc=local
failed to add entry: no global superior knowledge at /usr/sbin/smbldap-populate line 498, line 22.
adding new entry: ou=Idmap,dc=netrt1,dc=local
failed to add entry: no global superior knowledge at /usr/sbin/smbldap-populate line 498, line 27.
adding new entry: uid=root,ou=Users,dc=netrt1,dc=local
failed to add entry: no global superior knowledge at /usr/sbin/smbldap-populate line 498, line 55.
adding new entry: uid=nobody,ou=Users,dc=netrt1,dc=local
failed to add entry: no global superior knowledge at /usr/sbin/smbldap-populate line 498, line 83.
adding new entry: cn=Domain Admins,ou=Groups,dc=netrt1,dc=local
failed to add entry: no global superior knowledge at /usr/sbin/smbldap-populate line 498, line 95.
adding new entry: cn=Domain Users,ou=Groups,dc=netrt1,dc=local
failed to add entry: no global superior knowledge at /usr/sbin/smbldap-populate line 498, line 106.
adding new entry: cn=Domain Guests,ou=Groups,dc=netrt1,dc=local
failed to add entry: no global superior knowledge at /usr/sbin/smbldap-populate line 498, line 117.
adding new entry: cn=Domain Computers,ou=Groups,dc=netrt1,dc=local
failed to add entry: no global superior knowledge at /usr/sbin/smbldap-populate line 498, line 128.
adding new entry: cn=Administrators,ou=Groups,dc=netrt1,dc=local
failed to add entry: no global superior knowledge at /usr/sbin/smbldap-populate line 498, line 173.
adding new entry: cn=Account Operators,ou=Groups,dc=netrt1,dc=local
failed to add entry: no global superior knowledge at /usr/sbin/smbldap-populate line 498, line 195.
adding new entry: cn=Print Operators,ou=Groups,dc=netrt1,dc=local
failed to add entry: no global superior knowledge at /usr/sbin/smbldap-populate line 498, line 206.
adding new entry: cn=Backup Operators,ou=Groups,dc=netrt1,dc=local
failed to add entry: no global superior knowledge at /usr/sbin/smbldap-populate line 498, line 217.
adding new entry: cn=Replicators,ou=Groups,dc=netrt1,dc=local
failed to add entry: no global superior knowledge at /usr/sbin/smbldap-populate line 498, line 228.
adding new entry: sambaDomainName=netrt1.local,dc=netrt1,dc=local
failed to add entry: no global superior knowledge at /usr/sbin/smbldap-populate line 498, line 236.
Please provide a password for the domain root:
No such object at /usr/share/perl5/smbldap_tools.pm line 406.
sinon j’ai une autre question, dans mon projet je doit ajouter 2 groupes (production et direction) avec un disque qui pointe sur un serveur de fichier sur un autre serveur sais tu comment faire ?
