non justement il ne part pas (removed) je pense que ça veux dire qu’il est détruit non ?
Voici plus de logs
May 27 11:09:38 vps3006 postfix/cleanup[3505]: 46E6E1C9E09A: message-id=20130527090938.46E6E1C9E09A@vps3006.lws-hosting.com
May 27 11:09:39 vps3006 postfix/qmgr[10196]: 46E6E1C9E09A: from=www-data@swgroupe.fr, size=724, nrcpt=1 (queue active)
May 27 11:09:40 vps3006 postfix/smtp[3507]: 46E6E1C9E09A: to=xyport@gmail.com, relay=gmail-smtp-in.l.google.com[173.194.66.27]:25, delay=8.7, delays=8.4/0.01/0.07/0.23, dsn=2$
May 27 11:09:40 vps3006 postfix/qmgr[10196]: 46E6E1C9E09A: removed
May 27 11:11:36 vps3006 dkim-filter[3639]: Sendmail DKIM Filter v2.8.2 starting (args: -b v -x /etc/dkim-filter.conf -u dkim-filter -P /var/run/dkim-filter/dkim-filter.pid -p l$
May 27 11:28:24 vps3006 dkim-filter[3968]: Sendmail DKIM Filter v2.8.2 starting (args: -x /etc/dkim-filter.conf -u dkim-filter -P /var/run/dkim-filter/dkim-filter.pid -p inet:8$
May 27 11:30:04 vps3006 postfix/master[10185]: terminating on signal 15
May 27 11:30:04 vps3006 postfix/master[4082]: daemon started – version 2.7.1, configuration /etc/postfix
May 27 11:31:57 vps3006 postfix/pickup[4089]: 6A6111C9E09A: uid=33 from=
May 27 11:31:57 vps3006 postfix/cleanup[5146]: 6A6111C9E09A: message-id=20130527093157.6A6111C9E09A@vps3006.lws-hosting.com
May 27 11:31:57 vps3006 dkim-filter[3968]: 6A6111C9E09A: no signature data
May 27 11:31:57 vps3006 postfix/qmgr[4088]: 6A6111C9E09A: from=www-data@swgroupe.fr, size=726, nrcpt=1 (queue active)
May 27 11:31:57 vps3006 postfix/smtp[5148]: 6A6111C9E09A: to=xyport@gmail.com, relay=gmail-smtp-in.l.google.com[173.194.66.26]:25, delay=0.18, delays=0.06/0.01/0.06/0.06, dsn$
May 27 11:31:57 vps3006 postfix/qmgr[4088]: 6A6111C9E09A: removed
May 27 11:44:21 vps3006 postfix/pickup[4089]: E18FC1C9E09A: uid=33 from=
May 27 11:44:21 vps3006 postfix/cleanup[5358]: E18FC1C9E09A: message-id=20130527094420.E18FC1C9E09A@vps3006.lws-hosting.com
May 27 11:44:21 vps3006 dkim-filter[3968]: E18FC1C9E09A: no signature data
May 27 11:44:21 vps3006 postfix/qmgr[4088]: E18FC1C9E09A: from=www-data@swgroupe.fr, size=735, nrcpt=1 (queue active)
May 27 11:44:24 vps3006 postfix/smtp[5361]: E18FC1C9E09A: to=xyport@gmail.com, relay=gmail-smtp-in.l.google.com[173.194.66.27]:25, delay=3.7, delays=1.1/0.01/2.5/0.16, dsn=2.$
May 27 11:44:24 vps3006 postfix/qmgr[4088]: E18FC1C9E09A: removed
May 27 12:07:10 vps3006 postfix/smtpd[5775]: connect from unknown[82.221.102.245]
May 27 12:07:11 vps3006 postfix/smtpd[5775]: lost connection after CONNECT from unknown[82.221.102.245]
May 27 12:07:11 vps3006 postfix/smtpd[5775]: disconnect from unknown[82.221.102.245]
May 27 12:10:31 vps3006 postfix/anvil[5778]: statistics: max connection rate 1/60s for (smtp:82.221.102.245) at May 27 12:07:10
May 27 12:10:31 vps3006 postfix/anvil[5778]: statistics: max connection count 1 for (smtp:82.221.102.245) at May 27 12:07:10
May 27 12:10:31 vps3006 postfix/anvil[5778]: statistics: max cache size 1 at May 27 12:07:10
