oui , la voila :
[size=150]Sur la machine hôte:[/size]
ifconfig -a
[code]eth0 Link encap:Ethernet HWaddr 00:14:5E:30:66:B4
inet adr:194.146.14.176 Bcast:194.146.14.255 Masque:255.255.255.0
adr inet6: fe80::214:5eff:fe30:66b4/64 Scope:Lien
RX packets:86691 errors:0 dropped:0 overruns:0 frame:0
TX packets:112257 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:6508869 (6.2 MiB) TX bytes:134181218 (127.9 MiB)
Interruption:16
eth0:0 Link encap:Ethernet HWaddr 00:14:5E:30:66:B4
inet adr:194.146.14.249 Bcast:194.146.14.255 Masque:255.255.255.0
Interruption:16
eth0:1 Link encap:Ethernet HWaddr 00:14:5E:30:66:B4
inet adr:192.168.96.219 Bcast:192.168.96.255 Masque:255.255.255.0
Interruption:16
eth0:2 Link encap:Ethernet HWaddr 00:14:5E:30:66:B4
inet adr:194.146.14.38 Bcast:194.146.14.255 Masque:255.255.255.0
Interruption:16
eth0:3 Link encap:Ethernet HWaddr 00:14:5E:30:66:B4
inet adr:192.168.128.1 Bcast:192.168.128.255 Masque:255.255.255.0
Interruption:16
eth0:4 Link encap:Ethernet HWaddr 00:14:5E:30:66:B4
inet adr:192.168.32.1 Bcast:192.168.32.255 Masque:255.255.255.0
Interruption:16
eth0:5 Link encap:Ethernet HWaddr 00:14:5E:30:66:B4
inet adr:194.5.174.252 Bcast:194.5.174.255 Masque:255.255.255.0
Interruption:16
eth0:6 Link encap:Ethernet HWaddr 00:14:5E:30:66:B4
inet adr:192.168.150.1 Bcast:192.168.150.255 Masque:255.255.255.0
Interruption:16
eth0:7 Link encap:Ethernet HWaddr 00:14:5E:30:66:B4
inet adr:192.168.64.253 Bcast:192.168.64.255 Masque:255.255.255.0
Interruption:16
eth0:8 Link encap:Ethernet HWaddr 00:14:5E:30:66:B4
inet adr:10.8.3.1 Bcast:10.8.3.255 Masque:255.255.255.0
Interruption:16
eth1 Link encap:Ethernet HWaddr 00:14:5E:30:66:B5
inet adr:192.168.1.250 Bcast:192.168.1.255 Masque:255.255.255.0
adr inet6: fe80::214:5eff:fe30:66b5/64 Scope:Lien
RX packets:193 errors:0 dropped:0 overruns:0 frame:0
TX packets:53 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:31983 (31.2 KiB) TX bytes:11925 (11.6 KiB)
eth1:1 Link encap:Ethernet HWaddr 00:14:5E:30:66:B5
inet adr:192.168.3.250 Bcast:192.168.3.255 Masque:255.255.255.0
lo Link encap:Boucle locale
adr inet6: ::1/128 Scope:Hôte
RX packets:1895 errors:0 dropped:0 overruns:0 frame:0
TX packets:1895 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2718996 (2.5 MiB) TX bytes:2718996 (2.5 MiB)
pan0 Link encap:Ethernet HWaddr 00:00:00:00:00:00
adr inet6: fe80::200:ff:fe00:0/64 Scope:Lien
TX packets:6 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 b) TX bytes:468 (468.0 b)
peth1 Link encap:Ethernet HWaddr 00:14:5E:30:66:B5
TX packets:59 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:35457 (34.6 KiB) TX bytes:12689 (12.3 KiB)
Interruption:16
tap0 Link encap:Ethernet HWaddr 76:D0:36:7B:02:C1
inet adr:192.168.201.1 Bcast:192.168.201.255 Masque:255.255.255.0
adr inet6: fe80::74d0:36ff:fe7b:2c1/64 Scope:Lien
RX packets:104 errors:0 dropped:0 overruns:0 frame:0
TX packets:34 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 lg file transmission:500
RX bytes:14889 (14.5 KiB) TX bytes:6491 (6.3 KiB)
tap1 Link encap:Ethernet HWaddr 96:28:EF:AA:E8:AE
inet adr:192.168.202.1 Bcast:192.168.201.255 Masque:255.255.255.0
adr inet6: fe80::9428:efff:feaa:e8ae/64 Scope:Lien
RX packets:111 errors:0 dropped:0 overruns:0 frame:0
TX packets:27 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:15663 (15.2 KiB) TX bytes:5717 (5.5 KiB)
tap2 Link encap:Ethernet HWaddr 52:E1:B3:58:B7:88
inet adr:192.168.1.248 Bcast:192.168.1.255 Masque:255.255.255.0
adr inet6: fe80::50e1:b3ff:fe58:b788/64 Scope:Lien
RX packets:108 errors:0 dropped:0 overruns:0 frame:0
TX packets:30 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:15322 (14.9 KiB) TX bytes:6058 (5.9 KiB)
virbr0 Link encap:Ethernet HWaddr 00:00:00:00:00:00
inet adr:192.168.122.1 Bcast:192.168.122.255 Masque:255.255.255.0
TX packets:37 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 b) TX bytes:6511 (6.3 KiB)
route -n
Destination Passerelle Genmask Indic Metric Ref Use Iface
xxxxxxxxxxxxxx 194.146.14.47 255.255.255.255 UGH 0 0 0 eth0
192.168.1.252 0.0.0.0 255.255.255.255 UH 0 0 0 tap2
192.168.128.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
194.146.14.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
192.168.3.0 0.0.0.0 255.255.255.0 U 0 0 0 eth1
192.168.151.0 192.168.64.254 255.255.255.0 UG 0 0 0 eth0
192.168.96.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
10.8.3.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
192.168.64.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
192.168.150.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
192.168.1.0 0.0.0.0 255.255.255.0 U 1 0 0 eth1
192.168.32.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
192.168.201.0 0.0.0.0 255.255.255.0 U 0 0 0 tap0
194.5.174.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
192.168.202.0 0.0.0.0 255.255.255.0 U 0 0 0 tap1
192.168.152.0 192.168.64.254 255.255.255.0 UG 0 0 0 eth0
192.168.122.0 0.0.0.0 255.255.255.0 U 0 0 0 virbr0
0.0.0.0 194.146.14.47 0.0.0.0 UG 0 0 0 eth0
brtcl show
bridge name bridge id STP enabled interfaces
eth1 8000.00145e3066b5 no peth1
pan0 8000.000000000000 no
virbr0 8000.000000000000 yes
[size=150]Machine virtuelle[/size]
ifconfig -a
eth0 Lien encap:Ethernet HWaddr 52:54:00:12:34:56
inet adr:192.168.201.249 Bcast:192.168.201.255 Masque:255.255.255.0
adr inet6: fe80::5054:ff:fe12:3456/64 Scope:Lien
RX packets:14 errors:0 dropped:0 overruns:0 frame:0
TX packets:13 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:644 (644.0 b) TX bytes:714 (714.0 b)
Interruption:9 Adresse de base:0x4000
eth1 Lien encap:Ethernet HWaddr 52:54:00:12:34:57
inet adr:192.168.202.2 Bcast:192.168.202.255 Masque:255.255.255.0
adr inet6: fe80::5054:ff:fe12:3457/64 Scope:Lien
RX packets:110 errors:0 dropped:0 overruns:0 frame:0
TX packets:126 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:9477 (9.2 KiB) TX bytes:13181 (12.8 KiB)
Interruption:9 Adresse de base:0x6000
eth2 Lien encap:Ethernet HWaddr 52:54:00:12:34:58
inet adr:192.168.1.252 Bcast:192.168.1.255 Masque:255.255.255.0
adr inet6: fe80::5054:ff:fe12:3458/64 Scope:Lien
RX packets:15 errors:0 dropped:0 overruns:0 frame:0
RX bytes:790 (790.0 b) TX bytes:714 (714.0 b)
Interruption:10 Adresse de base:0x8000
lo Lien encap:Boucle locale
RX packets:8 errors:0 dropped:0 overruns:0 frame:0
TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:624 (624.0 b) TX bytes:624 (624.0 b)
sit0 Lien encap:IPv6-dans-IPv4
NOARP MTU:1480 Metric:1
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
route -n
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 eth2
192.168.201.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
192.168.202.0 0.0.0.0 255.255.255.0 U 0 0 0 eth1
169.254.0.0 0.0.0.0 255.255.0.0 U 0 0 0 lo
0.0.0.0 192.168.202.1 0.0.0.0 UG 0 0 0 eth1
Voila , PascalHambourg , j’espère avoir répondu à ta demande.
S’il te faut plus d’information n’hésite pas , encore merci.
