Non je n’ai rien des mes fichiers de log. Ci dessous mon fichier main.cf (config de postfix)
[b]# See /usr/share/postfix/main.cf.dist for a commented, more complete version
smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
biff = no
appending .domain is the MUA’s job.
append_dot_mydomain = no
Uncomment the next line to generate “delayed mail” warnings
#delay_warning_time = 4h
alias_maps = hash:/etc/aliases
alias_database = hash:/etc/aliases
myorigin = /etc/mailname
mydestination = mondomaine.com
mailbox_size_limit = 0
recipient_delimiter = +
myhostname = srvmail.mondomaine.com
mynetworks = 127.0.0.1 xx.xx.xxx.xx (IP hébergeur ovh)
home_mailbox = Maildir/[/b]
Mon fichier de config de NetFilter:
Generated by iptables-save v1.2.11 on Mon Feb 19 20:52:50 2007
*mangle
REROUTING ACCEPT [169:16648]
:INPUT ACCEPT [169:16648]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [160:85065]
OSTROUTING ACCEPT [160:85065]
COMMIT
Completed on Mon Feb 19 20:52:50 2007
*nat
REROUTING ACCEPT [11:3039]
OSTROUTING ACCEPT [1:73]
:OUTPUT ACCEPT [1:73]
COMMIT
*filter
:INPUT DROP [6:2799]
:FORWARD DROP [0:0]
:OUTPUT ACCEPT [150:84543]
-A INPUT -i ! eth0 -j ACCEPT
-A INPUT -p tcp -m tcp --tcp-flags ACK ACK -j ACCEPT
-A INPUT -m state --state ESTABLISHED -j ACCEPT
-A INPUT -m state --state RELATED -j ACCEPT
-A INPUT -p udp -m udp --sport 53 --dport 1024:65535 -j ACCEPT
-A INPUT -p icmp -m icmp --icmp-type 0 -j ACCEPT
-A INPUT -p icmp -m icmp --icmp-type 3 -j ACCEPT
-A INPUT -p icmp -m icmp --icmp-type 4 -j ACCEPT
-A INPUT -p icmp -m icmp --icmp-type 11 -j ACCEPT
-A INPUT -p icmp -m icmp --icmp-type 12 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 22 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 113 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 80 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 10000 -j ACCEPT
-A INPUT -p udp -m udp --sport 123 --dport 123 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 53 -j ACCEPT
-A INPUT -p udp -m udp --dport 53 -j ACCEPT
-A INPUT -p icmp -m icmp --icmp-type 8 -j ACCEPT
-A INPUT -d xx.xx.xxx.xx (IP hébergeur ovh)-p tcp -m tcp -m multiport --ports 25 -j ACCEPT
-A INPUT -d xx.xx.xxx.xx (IP hébergeur ovh)-p tcp -m tcp -m multiport --ports 110 -j ACCEPT
-A INPUT -d xx.xx.xxx.xx (IP hébergeur ovh)-p tcp -m tcp -m multiport --ports 143 -j ACCEPT
-A OUTPUT -p tcp -m tcp --dport 10000 -j ACCEPT
-A OUTPUT -p udp -m udp --sport 123 --dport 123 -j ACCEPT
-A OUTPUT -p udp -m udp --dport 53 -j ACCEPT
-A OUTPUT -p tcp -m tcp -m multiport --ports 143 -j ACCEPT
-A OUTPUT -p tcp -m tcp -m multiport --ports 110 -j ACCEPT
-A OUTPUT -p tcp -m tcp -m multiport --ports 25 -j ACCEPT
COMMIT
Merci pour ton aide
Cordialement
