Je suppose donc que le service n’est pas lancé.
En effet les erreurs nfs n’ont pas été copiées… J’ai fais le post rapidement en fin de journée et j’ai du les oublier. Elles sont dans le syslog.
Syslog:
[quote]May 1 12:05:12 sd-29229 kernel: imklog 4.6.4, log source = /proc/kmsg started.
May 1 12:05:12 sd-29229 rsyslogd: [origin software=“rsyslogd” swVersion=“4.6.4” x-pid=“1362” x-info=“http://www.rsyslog.com”] (re)start
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Initializing cgroup subsys cpuset
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Linux version 2.6.32-5-amd64 (Debian 2.6.32-48squeeze1) (dannf@debian.org) (gcc version 4.3.5 (Debian 4.3.5-4) ) #1 SMP Mon Feb 25 00:26:11 UTC 2013
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Command line: BOOT_IMAGE=/vmlinuz-2.6.32-5-amd64 root=UUID=cb36686c-2a6b-440e-b201-4e1b69320512 ro ghes.disable=1
May 1 12:05:12 sd-29229 kernel: [ 0.000000] KERNEL supported cpus:
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Intel GenuineIntel
May 1 12:05:12 sd-29229 kernel: [ 0.000000] AMD AuthenticAMD
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Centaur CentaurHauls
May 1 12:05:12 sd-29229 kernel: [ 0.000000] BIOS-provided physical RAM map:
May 1 12:05:12 sd-29229 kernel: [ 0.000000] BIOS-e820: 0000000000000000 - 00000000000a0000 (usable)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] BIOS-e820: 0000000000100000 - 00000000cf379000 (usable)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] BIOS-e820: 00000000cf379000 - 00000000cf38f000 (reserved)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] BIOS-e820: 00000000cf38f000 - 00000000cf3ce000 (ACPI data)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] BIOS-e820: 00000000cf3ce000 - 00000000d0000000 (reserved)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] BIOS-e820: 00000000fe000000 - 0000000100000000 (reserved)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] BIOS-e820: 0000000100000000 - 0000000630000000 (usable)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] DMI 2.6 present.
May 1 12:05:12 sd-29229 kernel: [ 0.000000] last_pfn = 0x630000 max_arch_pfn = 0x400000000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] MTRR default type: uncachable
May 1 12:05:12 sd-29229 kernel: [ 0.000000] MTRR fixed ranges enabled:
May 1 12:05:12 sd-29229 kernel: [ 0.000000] 00000-9FFFF write-back
May 1 12:05:12 sd-29229 kernel: [ 0.000000] A0000-BFFFF uncachable
May 1 12:05:12 sd-29229 kernel: [ 0.000000] C0000-D3FFF write-protect
May 1 12:05:12 sd-29229 kernel: [ 0.000000] D4000-EBFFF uncachable
May 1 12:05:12 sd-29229 kernel: [ 0.000000] EC000-FFFFF write-protect
May 1 12:05:12 sd-29229 kernel: [ 0.000000] MTRR variable ranges enabled:
May 1 12:05:12 sd-29229 kernel: [ 0.000000] 0 base 0000000000 mask FF80000000 write-back
May 1 12:05:12 sd-29229 kernel: [ 0.000000] 1 base 0080000000 mask FFC0000000 write-back
May 1 12:05:12 sd-29229 kernel: [ 0.000000] 2 base 00C0000000 mask FFF0000000 write-back
May 1 12:05:12 sd-29229 kernel: [ 0.000000] 3 base 0100000000 mask FF00000000 write-back
May 1 12:05:12 sd-29229 kernel: [ 0.000000] 4 base 0200000000 mask FE00000000 write-back
May 1 12:05:12 sd-29229 kernel: [ 0.000000] 5 base 0400000000 mask FE00000000 write-back
May 1 12:05:12 sd-29229 kernel: [ 0.000000] 6 base 0600000000 mask FFE0000000 write-back
May 1 12:05:12 sd-29229 kernel: [ 0.000000] 7 base 0620000000 mask FFF0000000 write-back
May 1 12:05:12 sd-29229 kernel: [ 0.000000] 8 disabled
May 1 12:05:12 sd-29229 kernel: [ 0.000000] 9 disabled
May 1 12:05:12 sd-29229 kernel: [ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
May 1 12:05:12 sd-29229 kernel: [ 0.000000] e820 update range: 00000000d0000000 - 0000000100000000 (usable) ==> (reserved)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] last_pfn = 0xcf379 max_arch_pfn = 0x400000000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] initial memory mapped : 0 - 20000000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Using GB pages for direct mapping
May 1 12:05:12 sd-29229 kernel: [ 0.000000] init_memory_mapping: 0000000000000000-00000000cf379000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] 0000000000 - 00c0000000 page 1G
May 1 12:05:12 sd-29229 kernel: [ 0.000000] 00c0000000 - 00cf200000 page 2M
May 1 12:05:12 sd-29229 kernel: [ 0.000000] 00cf200000 - 00cf379000 page 4k
May 1 12:05:12 sd-29229 kernel: [ 0.000000] kernel direct mapping tables up to cf379000 @ 8000-b000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] init_memory_mapping: 0000000100000000-0000000630000000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] 0100000000 - 0600000000 page 1G
May 1 12:05:12 sd-29229 kernel: [ 0.000000] 0600000000 - 0630000000 page 2M
May 1 12:05:12 sd-29229 kernel: [ 0.000000] kernel direct mapping tables up to 630000000 @ a000-c000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] RAMDISK: 376a4000 - 37fef60f
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: RSDP 00000000000f1610 00024 (v02 DELL )
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: XSDT 00000000000f1714 0009C (v01 DELL PE_SC3 00000001 DELL 00000001)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: FACP 00000000cf3b3f9c 000F4 (v03 DELL PE_SC3 00000001 DELL 00000001)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: DSDT 00000000cf38f000 03AE6 (v01 DELL PE_SC3 00000001 INTL 20050624)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: FACS 00000000cf3b6000 00040
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: APIC 00000000cf3b3478 0015E (v01 DELL PE_SC3 00000001 DELL 00000001)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: SPCR 00000000cf3b35d8 00050 (v01 DELL PE_SC3 00000001 DELL 00000001)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: HPET 00000000cf3b362c 00038 (v01 DELL PE_SC3 00000001 DELL 00000001)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: DMAR 00000000cf3b3668 001D0 (v01 DELL PE_SC3 00000001 DELL 00000001)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: MCFG 00000000cf3b38c4 0003C (v01 DELL PE_SC3 00000001 DELL 00000001)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: WD__ 00000000cf3b3904 00134 (v01 DELL PE_SC3 00000001 DELL 00000001)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: SLIC 00000000cf3b3a3c 00024 (v01 DELL PE_SC3 00000001 DELL 00000001)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: ERST 00000000cf392c68 00270 (v01 DELL PE_SC3 00000001 DELL 00000001)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: HEST 00000000cf392ed8 003A8 (v01 DELL PE_SC3 00000001 DELL 00000001)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: BERT 00000000cf392ae8 00030 (v01 DELL PE_SC3 00000001 DELL 00000001)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: EINJ 00000000cf392b18 00150 (v01 DELL PE_SC3 00000001 DELL 00000001)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: SRAT 00000000cf3b3bc0 00370 (v01 DELL PE_SC3 00000001 DELL 00000001)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: TCPA 00000000cf3b3f34 00064 (v02 DELL PE_SC3 00000001 DELL 00000001)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: SSDT 00000000cf3b7000 043F4 (v01 INTEL PPM RCM 80000001 INTL 20061109)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: Local APIC address 0xfee00000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] SRAT: PXM 1 -> APIC 32 -> Node 0
May 1 12:05:12 sd-29229 kernel: [ 0.000000] SRAT: PXM 2 -> APIC 0 -> Node 1
May 1 12:05:12 sd-29229 kernel: [ 0.000000] SRAT: PXM 1 -> APIC 34 -> Node 0
May 1 12:05:12 sd-29229 kernel: [ 0.000000] SRAT: PXM 2 -> APIC 2 -> Node 1
May 1 12:05:12 sd-29229 kernel: [ 0.000000] SRAT: PXM 1 -> APIC 50 -> Node 0
May 1 12:05:12 sd-29229 kernel: [ 0.000000] SRAT: PXM 2 -> APIC 18 -> Node 1
May 1 12:05:12 sd-29229 kernel: [ 0.000000] SRAT: PXM 1 -> APIC 52 -> Node 0
May 1 12:05:12 sd-29229 kernel: [ 0.000000] SRAT: PXM 2 -> APIC 20 -> Node 1
May 1 12:05:12 sd-29229 kernel: [ 0.000000] SRAT: PXM 1 -> APIC 33 -> Node 0
May 1 12:05:12 sd-29229 kernel: [ 0.000000] SRAT: PXM 2 -> APIC 1 -> Node 1
May 1 12:05:12 sd-29229 kernel: [ 0.000000] SRAT: PXM 1 -> APIC 35 -> Node 0
May 1 12:05:12 sd-29229 kernel: [ 0.000000] SRAT: PXM 2 -> APIC 3 -> Node 1
May 1 12:05:12 sd-29229 kernel: [ 0.000000] SRAT: PXM 1 -> APIC 51 -> Node 0
May 1 12:05:12 sd-29229 kernel: [ 0.000000] SRAT: PXM 2 -> APIC 19 -> Node 1
May 1 12:05:12 sd-29229 kernel: [ 0.000000] SRAT: PXM 1 -> APIC 53 -> Node 0
May 1 12:05:12 sd-29229 kernel: [ 0.000000] SRAT: PXM 2 -> APIC 21 -> Node 1
May 1 12:05:12 sd-29229 kernel: [ 0.000000] SRAT: Node 1 PXM 2 0-d0000000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] SRAT: Node 1 PXM 2 100000000-330000000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] SRAT: Node 0 PXM 1 330000000-630000000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] NUMA: Allocated memnodemap from b000 - b100
May 1 12:05:12 sd-29229 kernel: [ 0.000000] NUMA: Using 28 for the hash shift.
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Bootmem setup node 0 0000000330000000-0000000630000000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] NODE_DATA [0000000330000000 - 0000000330007fff]
May 1 12:05:12 sd-29229 kernel: [ 0.000000] bootmap [0000000330008000 - 0000000330067fff] pages 60
May 1 12:05:12 sd-29229 kernel: [ 0.000000] (9 early reservations) ==> bootmem [0330000000 - 0630000000]
May 1 12:05:12 sd-29229 kernel: [ 0.000000] #0 [0000000000 - 0000001000] BIOS data page
May 1 12:05:12 sd-29229 kernel: [ 0.000000] #1 [0000006000 - 0000008000] TRAMPOLINE
May 1 12:05:12 sd-29229 kernel: [ 0.000000] #2 [0001000000 - 00016db584] TEXT DATA BSS
May 1 12:05:12 sd-29229 kernel: [ 0.000000] #3 [00376a4000 - 0037fef60f] RAMDISK
May 1 12:05:12 sd-29229 kernel: [ 0.000000] #4 [000009e800 - 0000100000] BIOS reserved
May 1 12:05:12 sd-29229 kernel: [ 0.000000] #5 [00016dc000 - 00016dc32d] BRK
May 1 12:05:12 sd-29229 kernel: [ 0.000000] #6 [0000008000 - 000000a000] PGTABLE
May 1 12:05:12 sd-29229 kernel: [ 0.000000] #7 [000000a000 - 000000b000] PGTABLE
May 1 12:05:12 sd-29229 kernel: [ 0.000000] #8 [000000b000 - 000000b100] MEMNODEMAP
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Bootmem setup node 1 0000000000000000-0000000330000000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] NODE_DATA [000000000000b100 - 00000000000130ff]
May 1 12:05:12 sd-29229 kernel: [ 0.000000] bootmap [0000000000014000 - 0000000000079fff] pages 66
May 1 12:05:12 sd-29229 kernel: [ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 0330000000]
May 1 12:05:12 sd-29229 kernel: [ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
May 1 12:05:12 sd-29229 kernel: [ 0.000000] #1 [0000006000 - 0000008000] TRAMPOLINE ==> [0000006000 - 0000008000]
May 1 12:05:12 sd-29229 kernel: [ 0.000000] #2 [0001000000 - 00016db584] TEXT DATA BSS ==> [0001000000 - 00016db584]
May 1 12:05:12 sd-29229 kernel: [ 0.000000] #3 [00376a4000 - 0037fef60f] RAMDISK ==> [00376a4000 - 0037fef60f]
May 1 12:05:12 sd-29229 kernel: [ 0.000000] #4 [000009e800 - 0000100000] BIOS reserved ==> [000009e800 - 0000100000]
May 1 12:05:12 sd-29229 kernel: [ 0.000000] #5 [00016dc000 - 00016dc32d] BRK ==> [00016dc000 - 00016dc32d]
May 1 12:05:12 sd-29229 kernel: [ 0.000000] #6 [0000008000 - 000000a000] PGTABLE ==> [0000008000 - 000000a000]
May 1 12:05:12 sd-29229 kernel: [ 0.000000] #7 [000000a000 - 000000b000] PGTABLE ==> [000000a000 - 000000b000]
May 1 12:05:12 sd-29229 kernel: [ 0.000000] #8 [000000b000 - 000000b100] MEMNODEMAP ==> [000000b000 - 000000b100]
May 1 12:05:12 sd-29229 kernel: [ 0.000000] found SMP MP-table at [ffff8800000fe710] fe710
May 1 12:05:12 sd-29229 kernel: [ 0.000000] [ffffea000b280000-ffffea000b3fffff] potential offnode page_structs
May 1 12:05:12 sd-29229 kernel: [ 0.000000] [ffffea0000000000-ffffea000b3fffff] PMD -> [ffff880001800000-ffff88000c1fffff] on node 1
May 1 12:05:12 sd-29229 kernel: [ 0.000000] [ffffea000b400000-ffffea0015bfffff] PMD -> [ffff880330200000-ffff88033a9fffff] on node 0
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Zone PFN ranges:
May 1 12:05:12 sd-29229 kernel: [ 0.000000] DMA 0x00000000 -> 0x00001000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] DMA32 0x00001000 -> 0x00100000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Normal 0x00100000 -> 0x00630000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Movable zone start PFN for each node
May 1 12:05:12 sd-29229 kernel: [ 0.000000] early_node_map[4] active PFN ranges
May 1 12:05:12 sd-29229 kernel: [ 0.000000] 1: 0x00000000 -> 0x000000a0
May 1 12:05:12 sd-29229 kernel: [ 0.000000] 1: 0x00000100 -> 0x000cf379
May 1 12:05:12 sd-29229 kernel: [ 0.000000] 1: 0x00100000 -> 0x00330000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] 0: 0x00330000 -> 0x00630000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] On node 0 totalpages: 3145728
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Normal zone: 43008 pages used for memmap
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Normal zone: 3102720 pages, LIFO batch:31
May 1 12:05:12 sd-29229 kernel: [ 0.000000] On node 1 totalpages: 3142425
May 1 12:05:12 sd-29229 kernel: [ 0.000000] DMA zone: 56 pages used for memmap
May 1 12:05:12 sd-29229 kernel: [ 0.000000] DMA zone: 103 pages reserved
May 1 12:05:12 sd-29229 kernel: [ 0.000000] DMA zone: 3841 pages, LIFO batch:0
May 1 12:05:12 sd-29229 kernel: [ 0.000000] DMA32 zone: 14280 pages used for memmap
May 1 12:05:12 sd-29229 kernel: [ 0.000000] DMA32 zone: 830385 pages, LIFO batch:31
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Normal zone: 31360 pages used for memmap
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Normal zone: 2262400 pages, LIFO batch:31
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: PM-Timer IO Port: 0x808
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x20] enabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x00] enabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x22] enabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x02] enabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x05] lapic_id[0x32] enabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x06] lapic_id[0x12] enabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x07] lapic_id[0x34] enabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x08] lapic_id[0x14] enabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x09] lapic_id[0x21] enabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x0a] lapic_id[0x01] enabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x0b] lapic_id[0x23] enabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x0c] lapic_id[0x03] enabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x0d] lapic_id[0x33] enabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x0e] lapic_id[0x13] enabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x0f] lapic_id[0x35] enabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x10] lapic_id[0x15] enabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x11] lapic_id[0x30] disabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x12] lapic_id[0x31] disabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x13] lapic_id[0x32] disabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x14] lapic_id[0x33] disabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x15] lapic_id[0x34] disabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x16] lapic_id[0x35] disabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x17] lapic_id[0x36] disabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x18] lapic_id[0x37] disabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x19] lapic_id[0x38] disabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x1a] lapic_id[0x39] disabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x1b] lapic_id[0x3a] disabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x1c] lapic_id[0x3b] disabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x1d] lapic_id[0x3c] disabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x1e] lapic_id[0x3d] disabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x1f] lapic_id[0x3e] disabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC (acpi_id[0x20] lapic_id[0x3f] disabled)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: IOAPIC (id[0x00] address[0xfec00000] gsi_base[0])
May 1 12:05:12 sd-29229 kernel: [ 0.000000] IOAPIC[0]: apic_id 0, version 32, address 0xfec00000, GSI 0-23
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec80000] gsi_base[32])
May 1 12:05:12 sd-29229 kernel: [ 0.000000] IOAPIC[1]: apic_id 1, version 32, address 0xfec80000, GSI 32-55
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: IRQ0 used by override.
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: IRQ2 used by override.
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: IRQ9 used by override.
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Using ACPI (MADT) for SMP configuration information
May 1 12:05:12 sd-29229 kernel: [ 0.000000] ACPI: HPET id: 0x8086a301 base: 0xfed00000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] SMP: Allowing 32 CPUs, 16 hotplug CPUs
May 1 12:05:12 sd-29229 kernel: [ 0.000000] nr_irqs_gsi: 56
May 1 12:05:12 sd-29229 kernel: [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 0000000000100000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] PM: Registered nosave memory: 00000000cf379000 - 00000000cf38f000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] PM: Registered nosave memory: 00000000cf38f000 - 00000000cf3ce000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] PM: Registered nosave memory: 00000000cf3ce000 - 00000000d0000000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] PM: Registered nosave memory: 00000000d0000000 - 00000000e0000000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] PM: Registered nosave memory: 00000000e0000000 - 00000000f0000000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] PM: Registered nosave memory: 00000000f0000000 - 00000000fe000000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] PM: Registered nosave memory: 00000000fe000000 - 0000000100000000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Allocating PCI resources starting at d0000000 (gap: d0000000:10000000)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Booting paravirtualized kernel on bare hardware
May 1 12:05:12 sd-29229 kernel: [ 0.000000] NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:32 nr_node_ids:2
May 1 12:05:12 sd-29229 kernel: [ 0.000000] PERCPU: Embedded 30 pages/cpu @ffff88000c400000 s90392 r8192 d24296 u131072
May 1 12:05:12 sd-29229 kernel: [ 0.000000] pcpu-alloc: s90392 r8192 d24296 u131072 alloc=1*2097152
May 1 12:05:12 sd-29229 kernel: [ 0.000000] pcpu-alloc: [0] 00 02 04 06 08 10 12 14 16 18 20 22 24 26 28 30
May 1 12:05:12 sd-29229 kernel: [ 0.000000] pcpu-alloc: [1] 01 03 05 07 09 11 13 15 17 19 21 23 25 27 29 31
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Built 2 zonelists in Zone order, mobility grouping on. Total pages: 6199346
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Policy zone: Normal
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Kernel command line: BOOT_IMAGE=/vmlinuz-2.6.32-5-amd64 root=UUID=cb36686c-2a6b-440e-b201-4e1b69320512 ro ghes.disable=1
May 1 12:05:12 sd-29229 kernel: [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Initializing CPU#0
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Checking aperture…
May 1 12:05:12 sd-29229 kernel: [ 0.000000] No AGP bridge found
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
May 1 12:05:12 sd-29229 kernel: [ 0.000000] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Placing 64MB software IO TLB between ffff88000c5fe000 - ffff8800105fe000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] software IO TLB at phys 0xc5fe000 - 0x105fe000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Memory: 24719576k/25952256k available (3087k kernel code, 799644k absent, 433036k reserved, 2053k data, 592k init)
May 1 12:05:12 sd-29229 kernel: [ 0.000000] SLUB: Genslabs=14, HWalign=64, Order=0-3, MinObjects=0, CPUs=32, Nodes=2
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Hierarchical RCU implementation.
May 1 12:05:12 sd-29229 kernel: [ 0.000000] NR_IRQS:4352 nr_irqs:1208
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Extended CMOS year: 2000
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Console: colour VGA+ 80x25
May 1 12:05:12 sd-29229 kernel: [ 0.000000] console [tty0] enabled
May 1 12:05:12 sd-29229 kernel: [ 0.000000] hpet clockevent registered
May 1 12:05:12 sd-29229 kernel: [ 0.000000] Fast TSC calibration using PIT
May 1 12:05:12 sd-29229 kernel: [ 0.004000] Detected 2400.611 MHz processor.
May 1 12:05:12 sd-29229 kernel: [ 0.000009] Calibrating delay loop (skipped), value calculated using timer frequency… 4801.22 BogoMIPS (lpj=9602444)
May 1 12:05:12 sd-29229 kernel: [ 0.000156] Security Framework initialized
May 1 12:05:12 sd-29229 kernel: [ 0.000223] SELinux: Disabled at boot.
May 1 12:05:12 sd-29229 kernel: [ 0.002181] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes)
May 1 12:05:12 sd-29229 kernel: [ 0.009047] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes)
May 1 12:05:12 sd-29229 kernel: [ 0.012002] Mount-cache hash table entries: 256
May 1 12:05:12 sd-29229 kernel: [ 0.012263] Initializing cgroup subsys ns
May 1 12:05:12 sd-29229 kernel: [ 0.012328] Initializing cgroup subsys cpuacct
May 1 12:05:12 sd-29229 kernel: [ 0.012399] Initializing cgroup subsys devices
May 1 12:05:12 sd-29229 kernel: [ 0.012467] Initializing cgroup subsys freezer
May 1 12:05:12 sd-29229 kernel: [ 0.012535] Initializing cgroup subsys net_cls
May 1 12:05:12 sd-29229 kernel: [ 0.012622] CPU: Physical Processor ID: 1
May 1 12:05:12 sd-29229 kernel: [ 0.012707] CPU: Processor Core ID: 0
May 1 12:05:12 sd-29229 kernel: [ 0.012773] CPU: L1 I cache: 32K, L1 D cache: 32K
May 1 12:05:12 sd-29229 kernel: [ 0.012880] CPU: L2 cache: 256K
May 1 12:05:12 sd-29229 kernel: [ 0.012949] CPU: L3 cache: 12288K
May 1 12:05:12 sd-29229 kernel: [ 0.013014] CPU 0/0x20 -> Node 0
May 1 12:05:12 sd-29229 kernel: [ 0.013078] mce: CPU supports 9 MCE banks
May 1 12:05:12 sd-29229 kernel: [ 0.013150] CPU0: Thermal monitoring enabled (TM1)
May 1 12:05:12 sd-29229 kernel: [ 0.013217] CPU 0 MCA banks CMCI:2 CMCI:3 CMCI:5 CMCI:6 CMCI:8
May 1 12:05:12 sd-29229 kernel: [ 0.013546] using mwait in idle threads.
May 1 12:05:12 sd-29229 kernel: [ 0.013610] Performance Events: Westmere events, Intel PMU driver.
May 1 12:05:12 sd-29229 kernel: [ 0.013765] … version: 3
May 1 12:05:12 sd-29229 kernel: [ 0.013834] … bit width: 48
May 1 12:05:12 sd-29229 kernel: [ 0.013898] … generic registers: 4
May 1 12:05:12 sd-29229 kernel: [ 0.013962] … value mask: 0000ffffffffffff
May 1 12:05:12 sd-29229 kernel: [ 0.014028] … max period: 000000007fffffff
May 1 12:05:12 sd-29229 kernel: [ 0.014094] … fixed-purpose events: 3
May 1 12:05:12 sd-29229 kernel: [ 0.014157] … event mask: 000000070000000f
May 1 12:05:12 sd-29229 kernel: [ 0.015004] ACPI: Core revision 20090903
May 1 12:05:12 sd-29229 kernel: [ 0.022339] DMAR: Host address width 40
May 1 12:05:12 sd-29229 kernel: [ 0.022404] DMAR: DRHD base: 0x000000fed90000 flags: 0x1
May 1 12:05:12 sd-29229 kernel: [ 0.022477] IOMMU fed90000: ver 1:0 cap c90780106f0462 ecap f020fe
May 1 12:05:12 sd-29229 kernel: [ 0.022546] DMAR: RMRR base: 0x000000cf4c8000 end: 0x000000cf4dffff
May 1 12:05:12 sd-29229 kernel: [ 0.022615] DMAR: RMRR base: 0x000000cf4b1000 end: 0x000000cf4bffff
May 1 12:05:12 sd-29229 kernel: [ 0.022685] DMAR: RMRR base: 0x000000cf4a1000 end: 0x000000cf4a1fff
May 1 12:05:12 sd-29229 kernel: [ 0.022755] DMAR: RMRR base: 0x000000cf4a3000 end: 0x000000cf4a3fff
May 1 12:05:12 sd-29229 kernel: [ 0.022824] DMAR: RMRR base: 0x000000cf4a5000 end: 0x000000cf4a5fff
May 1 12:05:12 sd-29229 kernel: [ 0.022893] DMAR: RMRR base: 0x000000cf4a7000 end: 0x000000cf4a7fff
May 1 12:05:12 sd-29229 kernel: [ 0.022963] DMAR: RMRR base: 0x000000cf4a9000 end: 0x000000cf4a9fff
May 1 12:05:12 sd-29229 kernel: [ 0.023032] DMAR: RMRR base: 0x000000cf4c0000 end: 0x000000cf4c0fff
May 1 12:05:12 sd-29229 kernel: [ 0.023101] DMAR: RMRR base: 0x000000cf4c2000 end: 0x000000cf4c2fff
May 1 12:05:12 sd-29229 kernel: [ 0.023170] DMAR: ATSR flags: 0x0
May 1 12:05:12 sd-29229 kernel: [ 0.023238] IOAPIC id 0 under DRHD base 0xfed90000
May 1 12:05:12 sd-29229 kernel: [ 0.023304] IOAPIC id 1 under DRHD base 0xfed90000
May 1 12:05:12 sd-29229 kernel: [ 0.023556] Enabled Interrupt-remapping
May 1 12:05:12 sd-29229 kernel: [ 0.023622] Setting APIC routing to physical flat
May 1 12:05:12 sd-29229 kernel: [ 0.023956] alloc irq_desc for 56 on node 0
May 1 12:05:12 sd-29229 kernel: [ 0.023958] alloc kstat_irqs on node 0
May 1 12:05:12 sd-29229 kernel: [ 0.023982] alloc irq_2_iommu on node 0
May 1 12:05:12 sd-29229 kernel: [ 0.023988] alloc irq_2_iommu on node 0
May 1 12:05:12 sd-29229 kernel: [ 0.023993] alloc irq_2_iommu on node 0
May 1 12:05:12 sd-29229 kernel: [ 0.023998] alloc irq_2_iommu on node 0
May 1 12:05:12 sd-29229 kernel: [ 0.024003] alloc irq_2_iommu on node 0
May 1 12:05:12 sd-29229 kernel: [ 0.024008] alloc irq_2_iommu on node 0
May 1 12:05:12 sd-29229 kernel: [ 0.024013] alloc irq_2_iommu on node 0
May 1 12:05:12 sd-29229 kernel: [ 0.024018] alloc irq_2_iommu on node 0
May 1 12:05:12 sd-29229 kernel: [ 0.024023] alloc irq_2_iommu on node 0
May 1 12:05:12 sd-29229 kernel: [ 0.024028] alloc irq_2_iommu on node 0
May 1 12:05:12 sd-29229 kernel: [ 0.024033] alloc irq_2_iommu on node 0
May 1 12:05:12 sd-29229 kernel: [ 0.024038] alloc irq_2_iommu on node 0
May 1 12:05:12 sd-29229 kernel: [ 0.024043] alloc irq_2_iommu on node 0
May 1 12:05:12 sd-29229 kernel: [ 0.024048] alloc irq_2_iommu on node 0
May 1 12:05:12 sd-29229 kernel: [ 0.024053] alloc irq_2_iommu on node 0
May 1 12:05:12 sd-29229 kernel: [ 0.024196] …TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
May 1 12:05:12 sd-29229 kernel: [ 0.063894] CPU0: Intel® Xeon® CPU E5620 @ 2.40GHz stepping 02
May 1 12:05:12 sd-29229 kernel: [ 0.168553] Booting processor 1 APIC 0x0 ip 0x6000
May 1 12:05:12 sd-29229 kernel: [ 0.179155] Initializing CPU#1
May 1 12:05:12 sd-29229 kernel: [ 0.256294] CPU: Physical Processor ID: 0
May 1 12:05:12 sd-29229 kernel: [ 0.256296] CPU: Processor Core ID: 0
May 1 12:05:12 sd-29229 kernel: [ 0.256299] CPU: L1 I cache: 32K, L1 D cache: 32K
May 1 12:05:12 sd-29229 kernel: [ 0.256301] CPU: L2 cache: 256K
May 1 12:05:12 sd-29229 kernel: [ 0.256302] CPU: L3 cache: 12288K
May 1 12:05:12 sd-29229 kernel: [ 0.256305] CPU 1/0x0 -> Node 1
May 1 12:05:12 sd-29229 kernel: [ 0.256319] CPU1: Thermal monitoring enabled (TM1)
May 1 12:05:12 sd-29229 kernel: [ 0.256322] CPU 1 MCA banks CMCI:2 CMCI:3 CMCI:5 CMCI:6 CMCI:8
May 1 12:05:12 sd-29229 kernel: [ 0.256338] CPU1: Intel® Xeon® CPU E5620 @ 2.40GHz stepping 02
May 1 12:05:12 sd-29229 kernel: [ 0.257058] checking TSC synchronization [CPU#0 -> CPU#1]: passed.
May 1 12:05:12 sd-29229 kernel: [ 0.277208] Booting processor 2 APIC 0x22 ip 0x6000
May 1 12:05:12 sd-29229 kernel: [ 0.288050] Initializing CPU#2
May 1 12:05:12 sd-29229 kernel: [ 0.368120] CPU: Physical Processor ID: 1
May 1 12:05:12 sd-29229 kernel: [ 0.368121] CPU: Processor Core ID: 1
May 1 12:05:12 sd-29229 kernel: [ 0.368123] CPU: L1 I cache: 32K, L1 D cache: 32K
May 1 12:05:12 sd-29229 kernel: [ 0.368124] CPU: L2 cache: 256K
May 1 12:05:12 sd-29229 kernel: [ 0.368125] CPU: L3 cache: 12288K
May 1 12:05:12 sd-29229 kernel: [ 0.368127] CPU 2/0x22 -> Node 0
May 1 12:05:12 sd-29229 kernel: [ 0.368137] CPU2: Thermal monitoring enabled (TM1)
May 1 12:05:12 sd-29229 kernel: [ 0.368140] CPU 2 MCA banks CMCI:2 CMCI:3 CMCI:5 SHD:6 SHD:8
May 1 12:05:12 sd-29229 kernel: [ 0.368166] CPU2: Intel® Xeon® CPU E5620 @ 2.40GHz stepping 02
May 1 12:05:12 sd-29229 kernel: [ 0.368888] checking TSC synchronization [CPU#0 -> CPU#2]: passed.
May 1 12:05:12 sd-29229 kernel: [ 0.389079] Booting processor 3 APIC 0x2 ip 0x6000
May 1 12:05:12 sd-29229 kernel: [ 0.399682] Initializing CPU#3
May 1 12:05:12 sd-29229 kernel: [ 0.479948] CPU: Physical Processor ID: 0
May 1 12:05:12 sd-29229 kernel: [ 0.479950] CPU: Processor Core ID: 1
May 1 12:05:12 sd-29229 kernel: [ 0.479953] CPU: L1 I cache: 32K, L1 D cache: 32K
May 1 12:05:12 sd-29229 kernel: [ 0.479955] CPU: L2 cache: 256K
May 1 12:05:12 sd-29229 kernel: [ 0.479956] CPU: L3 cache: 12288K
May 1 12:05:12 sd-29229 kernel: [ 0.479959] CPU 3/0x2 -> Node 1
May 1 12:05:12 sd-29229 kernel: [ 0.479972] CPU3: Thermal monitoring enabled (TM1)
May 1 12:05:12 sd-29229 kernel: [ 0.479976] CPU 3 MCA banks CMCI:2 CMCI:3 CMCI:5 SHD:6 SHD:8
May 1 12:05:12 sd-29229 kernel: [ 0.480018] CPU3: Intel® Xeon® CPU E5620 @ 2.40GHz stepping 02
May 1 12:05:12 sd-29229 kernel: [ 0.480737] checking TSC synchronization [CPU#0 -> CPU#3]: passed.
May 1 12:05:12 sd-29229 kernel: [ 0.500891] Booting processor 4 APIC 0x32 ip 0x6000
May 1 12:05:12 sd-29229 kernel: [ 0.511373] Initializing CPU#4
May 1 12:05:12 sd-29229 kernel: [ 0.591774] CPU: Physical Processor ID: 1
May 1 12:05:12 sd-29229 kernel: [ 0.591775] CPU: Processor Core ID: 9
May 1 12:05:12 sd-29229 kernel: [ 0.591777] CPU: L1 I cache: 32K, L1 D cache: 32K
May 1 12:05:12 sd-29229 kernel: [ 0.591779] CPU: L2 cache: 256K
May 1 12:05:12 sd-29229 kernel: [ 0.591780] CPU: L3 cache: 12288K
May 1 12:05:12 sd-29229 kernel: [ 0.591782] CPU 4/0x32 -> Node 0
May 1 12:05:12 sd-29229 kernel: [ 0.591792] CPU4: Thermal monitoring enabled (TM1)
May 1 12:05:12 sd-29229 kernel: [ 0.591794] CPU 4 MCA banks CMCI:2 CMCI:3 CMCI:5 SHD:6 SHD:8
May 1 12:05:12 sd-29229 kernel: [ 0.591849] CPU4: Intel® Xeon® CPU E5620 @ 2.40GHz stepping 02
May 1 12:05:12 sd-29229 kernel: [ 0.592570] checking TSC synchronization [CPU#0 -> CPU#4]: passed.
May 1 12:05:12 sd-29229 kernel: [ 0.612759] Booting processor 5 APIC 0x12 ip 0x6000
May 1 12:05:12 sd-29229 kernel: [ 0.623362] Initializing CPU#5
May 1 12:05:12 sd-29229 kernel: [ 0.703603] CPU: Physical Processor ID: 0
May 1 12:05:12 sd-29229 kernel: [ 0.703605] CPU: Processor Core ID: 9
May 1 12:05:12 sd-29229 kernel: [ 0.703608] CPU: L1 I cache: 32K, L1 D cache: 32K
May 1 12:05:12 sd-29229 kernel: [ 0.703610] CPU: L2 cache: 256K
May 1 12:05:12 sd-29229 kernel: [ 0.703611] CPU: L3 cache: 12288K
May 1 12:05:12 sd-29229 kernel: [ 0.703614] CPU 5/0x12 -> Node 1
May 1 12:05:12 sd-29229 kernel: [ 0.703627] CPU5: Thermal monitoring enabled (TM1)
May 1 12:05:12 sd-29229 kernel: [ 0.703631] CPU 5 MCA banks CMCI:2 CMCI:3 CMCI:5 SHD:6 SHD:8
May 1 12:05:12 sd-29229 kernel: [ 0.703717] CPU5: Intel® Xeon® CPU E5620 @ 2.40GHz stepping 02
May 1 12:05:12 sd-29229 kernel: [ 0.704437] checking TSC synchronization [CPU#0 -> CPU#5]: passed.
May 1 12:05:12 sd-29229 kernel: [ 0.724587] Booting processor 6 APIC 0x34 ip 0x6000
May 1 12:05:12 sd-29229 kernel: [ 0.735069] Initializing CPU#6
May 1 12:05:12 sd-29229 kernel: [ 0.815429] CPU: Physical Processor ID: 1
May 1 12:05:12 sd-29229 kernel: [ 0.815430] CPU: Processor Core ID: 10
May 1 12:05:12 sd-29229 kernel: [ 0.815432] CPU: L1 I cache: 32K, L1 D cache: 32K
May 1 12:05:12 sd-29229 kernel: [ 0.815433] CPU: L2 cache: 256K
May 1 12:05:12 sd-29229 kernel: [ 0.815434] CPU: L3 cache: 12288K
May 1 12:05:12 sd-29229 kernel: [ 0.815436] CPU 6/0x34 -> Node 0
May 1 12:05:12 sd-29229 kernel: [ 0.815446] CPU6: Thermal monitoring enabled (TM1)
May 1 12:05:12 sd-29229 kernel: [ 0.815449] CPU 6 MCA banks CMCI:2 CMCI:3 CMCI:5 SHD:6 SHD:8
May 1 12:05:12 sd-29229 kernel: [ 0.815545] CPU6: Intel® Xeon® CPU E5620 @ 2.40GHz stepping 02
May 1 12:05:12 sd-29229 kernel: [ 0.816268] checking TSC synchronization [CPU#0 -> CPU#6]: passed.
May 1 12:05:12 sd-29229 kernel: [ 0.836460] Booting processor 7 APIC 0x14 ip 0x6000
May 1 12:05:12 sd-29229 kernel: [ 0.847062] Initializing CPU#7
May 1 12:05:12 sd-29229 kernel: [ 0.927258] CPU: Physical Processor ID: 0
May 1 12:05:12 sd-29229 kernel: [ 0.927259] CPU: Processor Core ID: 10
May 1 12:05:12 sd-29229 kernel: [ 0.927262] CPU: L1 I cache: 32K, L1 D cache: 32K
May 1 12:05:12 sd-29229 kernel: [ 0.927264] CPU: L2 cache: 256K
May 1 12:05:12 sd-29229 kernel: [ 0.927265] CPU: L3 cache: 12288K
May 1 12:05:12 sd-29229 kernel: [ 0.927268] CPU 7/0x14 -> Node 1
May 1 12:05:12 sd-29229 kernel: [ 0.927281] CPU7: Thermal monitoring enabled (TM1)
May 1 12:05:12 sd-29229 kernel: [ 0.927285] CPU 7 MCA banks CMCI:2 CMCI:3 CMCI:5 SHD:6 SHD:8
May 1 12:05:12 sd-29229 kernel: [ 0.927318] CPU7: Intel® Xeon® CPU E5620 @ 2.40GHz stepping 02
May 1 12:05:12 sd-29229 kernel: [ 0.928038] checking TSC synchronization [CPU#0 -> CPU#7]: passed.
May 1 12:05:12 sd-29229 kernel: [ 0.948192] Booting processor 8 APIC 0x21 ip 0x6000
May 1 12:05:12 sd-29229 kernel: [ 0.958706] Initializing CPU#8
May 1 12:05:12 sd-29229 kernel: [ 1.039084] CPU: Physical Processor ID: 1
May 1 12:05:12 sd-29229 kernel: [ 1.039085] CPU: Processor Core ID: 0
May 1 12:05:12 sd-29229 kernel: [ 1.039088] CPU: L1 I cache: 32K, L1 D cache: 32K
May 1 12:05:12 sd-29229 kernel: [ 1.039089] CPU: L2 cache: 256K
May 1 12:05:12 sd-29229 kernel: [ 1.039091] CPU: L3 cache: 12288K
May 1 12:05:12 sd-29229 kernel: [ 1.039093] CPU 8/0x21 -> Node 0
May 1 12:05:12 sd-29229 kernel: [ 1.039104] CPU8: Thermal monitoring enabled (TM1)
May 1 12:05:12 sd-29229 kernel: [ 1.039106] CPU 8 MCA banks SHD:2 SHD:3 SHD:5 SHD:6 SHD:8
May 1 12:05:12 sd-29229 kernel: [ 1.039125] CPU8: Intel® Xeon® CPU E5620 @ 2.40GHz stepping 02
May 1 12:05:12 sd-29229 kernel: [ 1.039860] checking TSC synchronization [CPU#0 -> CPU#8]: passed.
May 1 12:05:12 sd-29229 kernel: [ 1.060055] Booting processor 9 APIC 0x1 ip 0x6000
May 1 12:05:12 sd-29229 kernel: [ 1.070658] Initializing CPU#9
May 1 12:05:12 sd-29229 kernel: [ 1.150912] CPU: Physical Processor ID: 0
May 1 12:05:12 sd-29229 kernel: [ 1.150914] CPU: Processor Core ID: 0
May 1 12:05:12 sd-29229 kernel: [ 1.150916] CPU: L1 I cache: 32K, L1 D cache: 32K
May 1 12:05:12 sd-29229 kernel: [ 1.150918] CPU: L2 cache: 256K
May 1 12:05:12 sd-29229 kernel: [ 1.150920] CPU: L3 cache: 12288K
May 1 12:05:12 sd-29229 kernel: [ 1.150922] CPU 9/0x1 -> Node 1
May 1 12:05:12 sd-29229 kernel: [ 1.150936] CPU9: Thermal monitoring enabled (TM1)
May 1 12:05:12 sd-29229 kernel: [ 1.150939] CPU 9 MCA banks SHD:2 SHD:3 SHD:5 SHD:6 SHD:8
May 1 12:05:12 sd-29229 kernel: [ 1.151014] CPU9: Intel® Xeon® CPU E5620 @ 2.40GHz stepping 02
May 1 12:05:12 sd-29229 kernel: [ 1.151733] checking TSC synchronization [CPU#0 -> CPU#9]: passed.
May 1 12:05:12 sd-29229 kernel: [ 1.171886] Booting processor 10 APIC 0x23 ip 0x6000
May 1 12:05:12 sd-29229 kernel: [ 1.182371] Initializing CPU#10
May 1 12:05:12 sd-29229 kernel: [ 1.262738] CPU: Physical Processor ID: 1
May 1 12:05:12 sd-29229 kernel: [ 1.262739] CPU: Processor Core ID: 1
May 1 12:05:12 sd-29229 kernel: [ 1.262741] CPU: L1 I cache: 32K, L1 D cache: 32K
May 1 12:05:12 sd-29229 kernel: [ 1.262742] CPU: L2 cache: 256K
May 1 12:05:12 sd-29229 kernel: [ 1.262743] CPU: L3 cache: 12288K
May 1 12:05:12 sd-29229 kernel: [ 1.262745] CPU 10/0x23 -> Node 0
May 1 12:05:12 sd-29229 kernel: [ 1.262755] CPU10: Thermal monitoring enabled (TM1)
May 1 12:05:12 sd-29229 kernel: [ 1.262757] CPU 10 MCA banks SHD:2 SHD:3 SHD:5 SHD:6 SHD:8
May 1 12:05:12 sd-29229 kernel: [ 1.262846] CPU10: Intel® Xeon® CPU E5620 @ 2.40GHz stepping 02
May 1 12:05:12 sd-29229 kernel: [ 1.268618] checking TSC synchronization [CPU#0 -> CPU#10]: passed.
May 1 12:05:12 sd-29229 kernel: [ 1.288819] Booting processor 11 APIC 0x3 ip 0x6000
May 1 12:05:12 sd-29229 kernel: [ 1.299421] Initializing CPU#11
May 1 12:05:12 sd-29229 kernel: [ 1.378560] CPU: Physical Processor ID: 0
May 1 12:05:12 sd-29229 kernel: [ 1.378562] CPU: Processor Core ID: 1
May 1 12:05:12 sd-29229 kernel: [ 1.378564] CPU: L1 I cache: 32K, L1 D cache: 32K
May 1 12:05:12 sd-29229 kernel: [ 1.378566] CPU: L2 cache: 256K
May 1 12:05:12 sd-29229 kernel: [ 1.378568] CPU: L3 cache: 12288K
May 1 12:05:12 sd-29229 kernel: [ 1.378571] CPU 11/0x3 -> Node 1
May 1 12:05:12 sd-29229 kernel: [ 1.378584] CPU11: Thermal monitoring enabled (TM1)
May 1 12:05:12 sd-29229 kernel: [ 1.378587] CPU 11 MCA banks SHD:2 SHD:3 SHD:5 SHD:6 SHD:8
May 1 12:05:12 sd-29229 kernel: [ 1.378686] CPU11: Intel® Xeon® CPU E5620 @ 2.40GHz stepping 02
May 1 12:05:12 sd-29229 kernel: [ 1.379421] checking TSC synchronization [CPU#0 -> CPU#11]: passed.
May 1 12:05:12 sd-29229 kernel: [ 1.399569] Booting processor 12 APIC 0x33 ip 0x6000
May 1 12:05:12 sd-29229 kernel: [ 1.410616] Initializing CPU#12
May 1 12:05:12 sd-29229 kernel: [ 1.490386] CPU: Physical Processor ID: 1
May 1 12:05:12 sd-29229 kernel: [ 1.490387] CPU: Processor Core ID: 9
May 1 12:05:12 sd-29229 kernel: [ 1.490389] CPU: L1 I cache: 32K, L1 D cache: 32K
May 1 12:05:12 sd-29229 kernel: [ 1.490390] CPU: L2 cache: 256K
May 1 12:05:12 sd-29229 kernel: [ 1.490391] CPU: L3 cache: 12288K
May 1 12:05:12 sd-29229 kernel: [ 1.490393] CPU 12/0x33 -> Node 0
May 1 12:05:12 sd-29229 kernel: [ 1.490403] CPU12: Thermal monitoring enabled (TM1)
May 1 12:05:12 sd-29229 kernel: [ 1.490406] CPU 12 MCA banks SHD:2 SHD:3 SHD:5 SHD:6 SHD:8
May 1 12:05:12 sd-29229 kernel: [ 1.490475] CPU12: Intel® Xeon® CPU E5620 @ 2.40GHz stepping 02
May 1 12:05:12 sd-29229 kernel: [ 1.491212] checking TSC synchronization [CPU#0 -> CPU#12]: passed.
May 1 12:05:12 sd-29229 kernel: [ 1.511404] Booting processor 13 APIC 0x13 ip 0x6000
May 1 12:05:12 sd-29229 kernel: [ 1.522007] Initializing CPU#13
May 1 12:05:12 sd-29229 kernel: [ 1.602215] CPU: Physical Processor ID: 0
May 1 12:05:12 sd-29229 kernel: [ 1.602216] CPU: Processor Core ID: 9
May 1 12:05:12 sd-29229 kernel: [ 1.602219] CPU: L1 I cache: 32K, L1 D cache: 32K
May 1 12:05:12 sd-29229 kernel: [ 1.602221] CPU: L2 cache: 256K
May 1 12:05:12 sd-29229 kernel: [ 1.602222] CPU: L3 cache: 12288K
May 1 12:05:12 sd-29229 kernel: [ 1.602225] CPU 13/0x13 -> Node 1
May 1 12:05:12 sd-29229 kernel: [ 1.602238] CPU13: Thermal monitoring enabled (TM1)
May 1 12:05:12 sd-29229 kernel: [ 1.602241] CPU 13 MCA banks SHD:2 SHD:3 SHD:5 SHD:6 SHD:8
May 1 12:05:12 sd-29229 kernel: [ 1.602263] CPU13: Intel® Xeon® CPU E5620 @ 2.40GHz stepping 02
May 1 12:05:12 sd-29229 kernel: [ 1.602999] checking TSC synchronization [CPU#0 -> CPU#13]: passed.
May 1 12:05:12 sd-29229 kernel: [ 1.623153] Booting processor 14 APIC 0x35 ip 0x6000
May 1 12:05:12 sd-29229 kernel: [ 1.633636] Initializing CPU#14
May 1 12:05:12 sd-29229 kernel: [ 1.714040] CPU: Physical Processor ID: 1
May 1 12:05:12 sd-29229 kernel: [ 1.714041] CPU: Processor Core ID: 10
May 1 12:05:12 sd-29229 kernel: [ 1.714043] CPU: L1 I cache: 32K, L1 D cache: 32K
May 1 12:05:12 sd-29229 kernel: [ 1.714045] CPU: L2 cache: 256K
May 1 12:05:12 sd-29229 kernel: [ 1.714045] CPU: L3 cache: 12288K
May 1 12:05:12 sd-29229 kernel: [ 1.714047] CPU 14/0x35 -> Node 0
May 1 12:05:12 sd-29229 kernel: [ 1.714057] CPU14: Thermal monitoring enabled (TM1)
May 1 12:05:12 sd-29229 kernel: [ 1.714060] CPU 14 MCA banks SHD:2 SHD:3 SHD:5 SHD:6 SHD:8
May 1 12:05:12 sd-29229 kernel: [ 1.714111] CPU14: Intel® Xeon® CPU E5620 @ 2.40GHz stepping 02
May 1 12:05:12 sd-29229 kernel: [ 1.714847] checking TSC synchronization [CPU#0 -> CPU#14]: passed.
May 1 12:05:12 sd-29229 kernel: [ 1.735047] Booting processor 15 APIC 0x15 ip 0x6000
May 1 12:05:12 sd-29229 kernel: [ 1.745649] Initializing CPU#15
May 1 12:05:12 sd-29229 kernel: [ 1.825869] CPU: Physical Processor ID: 0
May 1 12:05:12 sd-29229 kernel: [ 1.825871] CPU: Processor Core ID: 10
May 1 12:05:12 sd-29229 kernel: [ 1.825874] CPU: L1 I cache: 32K, L1 D cache: 32K
May 1 12:05:12 sd-29229 kernel: [ 1.825876] CPU: L2 cache: 256K
May 1 12:05:12 sd-29229 kernel: [ 1.825877] CPU: L3 cache: 12288K
May 1 12:05:12 sd-29229 kernel: [ 1.825880] CPU 15/0x15 -> Node 1
May 1 12:05:12 sd-29229 kernel: [ 1.825893] CPU15: Thermal monitoring enabled (TM1)
May 1 12:05:12 sd-29229 kernel: [ 1.825896] CPU 15 MCA banks SHD:2 SHD:3 SHD:5 SHD:6 SHD:8
May 1 12:05:12 sd-29229 kernel: [ 1.825906] CPU15: Intel® Xeon® CPU E5620 @ 2.40GHz stepping 02
May 1 12:05:12 sd-29229 kernel: [ 1.826646] checking TSC synchronization [CPU#0 -> CPU#15]: passed.
May 1 12:05:12 sd-29229 kernel: [ 1.846753] Brought up 16 CPUs
May 1 12:05:12 sd-29229 kernel: [ 1.846817] Total of 16 processors activated (76804.60 BogoMIPS).
May 1 12:05:12 sd-29229 kernel: [ 1.859813] CPU0 attaching sched-domain:
May 1 12:05:12 sd-29229 kernel: [ 1.859818] domain 0: span 0,8 level SIBLING
May 1 12:05:12 sd-29229 kernel: [ 1.859819] groups: group ffff88033ac0fae0 cpus 0 (cpu_power = 589) group ffff88033ac8fae0 cpus 8 (cpu_power = 589)
May 1 12:05:12 sd-29229 kernel: [ 1.859826] domain 1: span 0,2,4,6,8,10,12,14 level MC
May 1 12:05:12 sd-29229 kernel: [ 1.859828] groups: group ffff88033ac0fbf0 cpus 0,8 (cpu_power = 1178) group ffff88033ac2fbf0 cpus 2,10 (cpu_power = 1178) group ffff88033ac4fbf0 cpus 4,12 (cpu_power = 1178) group ffff88033ac6fbf0 cpus 6,14 (cpu_power = 1178)
May 1 12:05:12 sd-29229 kernel: [ 1.859836] domain 2: span 0-15 level NODE
May 1 12:05:12 sd-29229 kernel: [ 1.859837] groups: group ffff88062e63c000 cpus 0,2,4,6,8,10,12,14 (cpu_power = 4712) group ffff88062e63c060 cpus 1,3,5,7,9,11,13,15 (cpu_power = 4712)
May 1 12:05:12 sd-29229 kernel: [ 1.859846] CPU1 attaching sched-domain:
May 1 12:05:12 sd-29229 kernel: [ 1.859848] domain 0: span 1,9 level SIBLING
May 1 12:05:12 sd-29229 kernel: [ 1.859849] groups: group ffff88000c40fae0 cpus 1 (cpu_power = 589) group ffff88000c48fae0 cpus 9 (cpu_power = 589)
May 1 12:05:12 sd-29229 kernel: [ 1.859855] domain 1: span 1,3,5,7,9,11,13,15 level MC
May 1 12:05:12 sd-29229 kernel: [ 1.859856] groups: group ffff88000c40fbf0 cpus 1,9 (cpu_power = 1178) group ffff88000c42fbf0 cpus 3,11 (cpu_power = 1178) group ffff88000c44fbf0 cpus 5,13 (cpu_power = 1178) group ffff88000c46fbf0 cpus 7,15 (cpu_power = 1178)
May 1 12:05:12 sd-29229 kernel: [ 1.859864] domain 2: span 0-15 level NODE
May 1 12:05:12 sd-29229 kernel: [ 1.859866] groups: group ffff88032e42ef60 cpus 1,3,5,7,9,11,13,15 (cpu_power = 4712) group ffff88032e42ef00 cpus 0,2,4,6,8,10,12,14 (cpu_power = 4712)
May 1 12:05:12 sd-29229 kernel: [ 1.859873] CPU2 attaching sched-domain:
May 1 12:05:12 sd-29229 kernel: [ 1.859875] domain 0: span 2,10 level SIBLING
May 1 12:05:12 sd-29229 kernel: [ 1.859876] groups: group ffff88033ac2fae0 cpus 2 (cpu_power = 589) group ffff88033acafae0 cpus 10 (cpu_power = 589)
May 1 12:05:12 sd-29229 kernel: [ 1.859881] domain 1: span 0,2,4,6,8,10,12,14 level MC
May 1 12:05:12 sd-29229 kernel: [ 1.859883] groups: group ffff88033ac2fbf0 cpus 2,10 (cpu_power = 1178) group ffff88033ac4fbf0 cpus 4,12 (cpu_power = 1178) group ffff88033ac6fbf0 cpus 6,14 (cpu_power = 1178) group ffff88033ac0fbf0 cpus 0,8 (cpu_power = 1178)
May 1 12:05:12 sd-29229 kernel: [ 1.859891] domain 2: span 0-15 level NODE
May 1 12:05:12 sd-29229 kernel: [ 1.859893] groups: group ffff88062e63c000 cpus 0,2,4,6,8,10,12,14 (cpu_power = 4712) group ffff88062e63c060 cpus 1,3,5,7,9,11,13,15 (cpu_power = 4712)
May 1 12:05:12 sd-29229 kernel: [ 1.859900] CPU3 attaching sched-domain:
May 1 12:05:12 sd-29229 kernel: [ 1.859901] domain 0: span 3,11 level SIBLING
May 1 12:05:12 sd-29229 kernel: [ 1.859902] groups: group ffff88000c42fae0 cpus 3 (cpu_power = 589) group ffff88000c4afae0 cpus 11 (cpu_power = 589)
May 1 12:05:12 sd-29229 kernel: [ 1.859908] domain 1: span 1,3,5,7,9,11,13,15 level MC
May 1 12:05:12 sd-29229 kernel: [ 1.859909] groups: group ffff88000c42fbf0 cpus 3,11 (cpu_power = 1178) group ffff88000c44fbf0 cpus 5,13 (cpu_power = 1178) group ffff88000c46fbf0 cpus 7,15 (cpu_power = 1178) group ffff88000c40fbf0 cpus 1,9 (cpu_power = 1178)
May 1 12:05:12 sd-29229 kernel: [ 1.859917] domain 2: span 0-15 level NODE
May 1 12:05:12 sd-29229 kernel: [ 1.859919] groups: group ffff88032e42ef60 cpus 1,3,5,7,9,11,13,15 (cpu_power = 4712) group ffff88032e42ef00 cpus 0,2,4,6,8,10,12,14 (cpu_power = 4712)
May 1 12:05:12 sd-29229 kernel: [ 1.859926] CPU4 attaching sched-domain:
May 1 12:05:12 sd-29229 kernel: [ 1.859927] domain 0: span 4,12 level SIBLING
May 1 12:05:12 sd-29229 kernel: [ 1.859929] groups: group ffff88033ac4fae0 cpus 4 (cpu_power = 589) group ffff88033accfae0 cpus 12 (cpu_power = 589)
May 1 12:05:12 sd-29229 kernel: [ 1.859934] domain 1: span 0,2,4,6,8,10,12,14 level MC
May 1 12:05:12 sd-29229 kernel: [ 1.859936] groups: group ffff88033ac4fbf0 cpus 4,12 (cpu_power = 1178) group ffff88033ac6fbf0 cpus 6,14 (cpu_power = 1178) group ffff88033ac0fbf0 cpus 0,8 (cpu_power = 1178) group ffff88033ac2fbf0 cpus 2,10 (cpu_power = 1178)
May 1 12:05:12 sd-29229 kernel: [ 1.859944] domain 2: span 0-15 level NODE
May 1 12:05:12 sd-29229 kernel: [ 1.859945] groups: group ffff88062e63c000 cpus 0,2,4,6,8,10,12,14 (cpu_power = 4712) group ffff88062e63c060 cpus 1,3,5,7,9,11,13,15 (cpu_power = 4712)
May 1 12:05:12 sd-29229 kernel: [ 1.859952] CPU5 attaching sched-domain:
May 1 12:05:12 sd-29229 kernel: [ 1.859954] domain 0: span 5,13 level SIBLING
May 1 12:05:12 sd-29229 kernel: [ 1.859955] groups: group ffff88000c44fae0 cpus 5 (cpu_power = 589) group ffff88000c4cfae0 cpus 13 (cpu_power = 589)
May 1 12:05:12 sd-29229 kernel: [ 1.859960] domain 1: span 1,3,5,7,9,11,13,15 level MC
May 1 12:05:12 sd-29229 kernel: [ 1.859962] groups: group ffff88000c44fbf0 cpus 5,13 (cpu_power = 1178) group ffff88000c46fbf0 cpus 7,15 (cpu_power = 1178) group ffff88000c40fbf0 cpus 1,9 (cpu_power = 1178) group ffff88000c42fbf0 cpus 3,11 (cpu_power = 1178)
May 1 12:05:12 sd-29229 kernel: [ 1.859970] domain 2: span 0-15 level NODE
May 1 12:05:12 sd-29229 kernel: [ 1.859972] groups: group ffff88032e42ef60 cpus 1,3,5,7,9,11,13,15 (cpu_power = 4712) group ffff88032e42ef00 cpus 0,2,4,6,8,10,12,14 (cpu_power = 4712)
May 1 12:05:12 sd-29229 kernel: [ 1.859979] CPU6 attaching sched-domain:
May 1 12:05:12 sd-29229 kernel: [ 1.859980] domain 0: span 6,14 level SIBLING
May 1 12:05:12 sd-29229 kernel: [ 1.859982] groups: group ffff88033ac6fae0 cpus 6 (cpu_power = 589) group ffff88033acefae0 cpus 14 (cpu_power = 589)
May 1 12:05:12 sd-29229 kernel: [ 1.859987] domain 1: span 0,2,4,6,8,10,12,14 level MC
May 1 12:05:12 sd-29229 kernel: [ 1.859989] groups: group ffff88033ac6fbf0 cpus 6,14 (cpu_power = 1178) group ffff88033ac0fbf0 cpus 0,8 (cpu_power = 1178) group ffff88033ac2fbf0 cpus 2,10 (cpu_power = 1178) group ffff88033ac4fbf0 cpus 4,12 (cpu_power = 1178)
May 1 12:05:12 sd-29229 kernel: [ 1.859997] domain 2: span 0-15 level NODE
May 1 12:05:12 sd-29229 kernel: [ 1.859998] groups: group ffff88062e63c000 cpus 0,2,4,6,8,10,12,14 (cpu_power = 4712) group ffff88062e63c060 cpus 1,3,5,7,9,11,13,15 (cpu_power = 4712)
May 1 12:05:12 sd-29229 kernel: [ 1.860005] CPU7 attaching sched-domain:
May 1 12:05:12 sd-29229 kernel: [ 1.860006] domain 0: span 7,15 level SIBLING
May 1 12:05:12 sd-29229 kernel: [ 1.860008] groups: group ffff88000c46fae0 cpus 7 (cpu_power = 589) group ffff88000c4efae0 cpus 15 (cpu_power = 589)
May 1 12:05:12 sd-29229 kernel: [ 1.860013] domain 1: span 1,3,5,7,9,11,13,15 level MC
May 1 12:05:12 sd-29229 kernel: [ 1.860015] groups: group ffff88000c46fbf0 cpus 7,15 (cpu_power = 1178) group ffff88000c40fbf0 cpus 1,9 (cpu_power = 1178) group ffff88000c42fbf0 cpus 3,11 (cpu_power = 1178) group ffff88000c44fbf0 cpus 5,13 (cpu_power = 1178)
May 1 12:05:12 sd-29229 kernel: [ 1.860023] domain 2: span 0-15 level NODE
May 1 12:05:12 sd-29229 kernel: [ 1.860024] groups: group ffff88032e42ef60 cpus 1,3,5,7,9,11,13,15 (cpu_power = 4712) group ffff88032e42ef00 cpus 0,2,4,6,8,10,12,14 (cpu_power = 4712)
May 1 12:05:12 sd-29229 kernel: [ 1.860031] CPU8 attaching sched-domain:
May 1 12:05:12 sd-29229 kernel: [ 1.860033] domain 0: span 0,8 level SIBLING
May 1 12:05:12 sd-29229 kernel: [ 1.860034] groups: group ffff88033ac8fae0 cpus 8 (cpu_power = 589) group ffff88033ac0fae0 cpus 0 (cpu_power = 589)
May 1 12:05:12 sd-29229 kernel: [ 1.860040] domain 1: span 0,2,4,6,8,10,12,14 level MC
May 1 12:05:12 sd-29229 kernel: [ 1.860041] groups: group ffff88033ac0fbf0 cpus 0,8 (cpu_power = 1178) group ffff88033ac2fbf0 cpus 2,10 (cpu_power = 1178) group ffff88033ac4fbf0 cpus 4,12 (cpu_power = 1178) group ffff88033ac6fbf0 cpus 6,14 (cpu_power = 1178)
May 1 12:05:12 sd-29229 kernel: [ 1.860049] domain 2: span 0-15 level NODE
May 1 12:05:12 sd-29229 kernel: [ 1.860051] groups: group ffff88062e63c000 cpus 0,2,4,6,8,10,12,14 (cpu_power = 4712) group ffff88062e63c060 cpus 1,3,5,7,9,11,13,15 (cpu_power = 4712)
May 1 12:05:12 sd-29229 kernel: [ 1.860057] CPU9 attaching sched-domain:
May 1 12:05:12 sd-29229 kernel: [ 1.860059] domain 0: span 1,9 level SIBLING
May 1 12:05:12 sd-29229 kernel: [ 1.860060] groups: group ffff88000c48fae0 cpus 9 (cpu_power = 589) group ffff88000c40fae0 cpus 1 (cpu_power = 589)
May 1 12:05:12 sd-29229 kernel: [ 1.860066] domain 1: span 1,3,5,7,9,11,13,15 level MC
May 1 12:05:12 sd-29229 kernel: [ 1.860067] groups: group ffff88000c40fbf0 cpus 1,9 (cpu_power = 1178) group ffff88000c42fbf0 cpus 3,11 (cpu_power = 1178) group ffff88000c44fbf0 cpus 5,13 (cpu_power = 1178) group ffff88000c46fbf0 cpus 7,15 (cpu_power = 1178)
May 1 12:05:12 sd-29229 kernel: [ 1.860075] domain 2: span 0-15 level NODE
May 1 12:05:12 sd-29229 kernel: [ 1.860077] groups: group ffff88032e42ef60 cpus 1,3,5,7,9,11,13,15 (cpu_power = 4712) group ffff88032e42ef00 cpus 0,2,4,6,8,10,12,14 (cpu_power = 4712)
May 1 12:05:12 sd-29229 kernel: [ 1.860084] CPU10 attaching sched-domain:
May 1 12:05:12 sd-29229 kernel: [ 1.860085] domain 0: span 2,10 level SIBLING
May 1 12:05:12 sd-29229 kernel: [ 1.860087] groups: group ffff88033acafae0 cpus 10 (cpu_power = 589) group ffff88033ac2fae0 cpus 2 (cpu_power = 589)
May 1 12:05:12 sd-29229 kernel: [ 1.860092] domain 1: span 0,2,4,6,8,10,12,14 level MC
May 1 12:05:12 sd-29229 kernel: [ 1.860094] groups: group ffff88033ac2fbf0 cpus 2,10 (cpu_power = 1178) group ffff88033ac4fbf0 cpus 4,12 (cpu_power = 1178) group ffff88033ac6fbf0 cpus 6,14 (cpu_power = 1178) group ffff88033ac0fbf0 cpus 0,8 (cpu_power = 1178)
