root@localhost:/home/daniel# cat /etc/ssh/sshd_config
# Package generated configuration file
# See the sshd_config(5) manpage for details
# What ports, IPs and protocols we listen for
Port 666
# Use these options to restrict which interfaces/protocols sshd will bind to
#ListenAddress ::
#ListenAddress 0.0.0.0
Protocol 2
# HostKeys for protocol version 2
HostKey /etc/ssh/ssh_host_rsa_key
HostKey /etc/ssh/ssh_host_dsa_key
HostKey /etc/ssh/ssh_host_ecdsa_key
#Privilege Separation is turned on for security
UsePrivilegeSeparation yes
# Lifetime and size of ephemeral version 1 server key
KeyRegenerationInterval 3600
ServerKeyBits 768
# Logging
SyslogFacility AUTH
LogLevel INFO
# Authentication:
LoginGraceTime 120
PermitRootLogin no
StrictModes yes
RSAAuthentication yes
PubkeyAuthentication yes
#AuthorizedKeysFile %h/.ssh/authorized_keys
# Don't read the user's ~/.rhosts and ~/.shosts files
IgnoreRhosts yes
# For this to work you will also need host keys in /etc/ssh_known_hosts
RhostsRSAAuthentication no
# similar for protocol version 2
HostbasedAuthentication no
# Uncomment if you don't trust ~/.ssh/known_hosts for RhostsRSAAuthentication
#IgnoreUserKnownHosts yes
# To enable empty passwords, change to yes (NOT RECOMMENDED)
PermitEmptyPasswords no
# Change to yes to enable challenge-response passwords (beware issues with
# some PAM modules and threads)
ChallengeResponseAuthentication no
# Change to no to disable tunnelled clear text passwords
#PasswordAuthentication yes
# Kerberos options
#KerberosAuthentication no
#KerberosGetAFSToken no
#KerberosOrLocalPasswd yes
#KerberosTicketCleanup yes
# GSSAPI options
#GSSAPIAuthentication no
#GSSAPICleanupCredentials yes
X11Forwarding no
X11DisplayOffset 10
PrintMotd no
PrintLastLog yes
TCPKeepAlive yes
#UseLogin no
#MaxStartups 10:30:60
#Banner /etc/issue.net
# Allow client to pass locale environment variables
AcceptEnv LANG LC_*
Subsystem sftp /usr/lib/openssh/sftp-server
# Set this to 'yes' to enable PAM authentication, account processing,
# and session processing. If this is enabled, PAM authentication will
# be allowed through the ChallengeResponseAuthentication and
# PasswordAuthentication. Depending on your PAM configuration,
# PAM authentication via ChallengeResponseAuthentication may bypass
# the setting of "PermitRootLogin without-password".
# If you just want the PAM account and session checks to run without
# PAM authentication, then enable this but set PasswordAuthentication
# and ChallengeResponseAuthentication to 'no'.
UsePAM yes
#utilisateurs autorisés
AllowUsers thorhyeux
AllowUsers jessie
merci je me sens lourd
bon voila ce que me dit maintenant :
daniel@localhost:~$ sftp -P 666 jessie@localhost
The authenticity of host '[localhost]:666 ([::1]:666)' can't be established.
ECDSA key fingerprint is e6:d1:ec:d6:da:bd:3d:45:c2:24:06:60:26:78:b5:d9.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added '[localhost]:666' (ECDSA) to the list of known hosts.
jessie@localhost's password:
Connection closed
Ce qui suit est tout-à fait normal, il viens de te proposer d’ajouter ce serveur à la liste des serveurs connus,
donc il ne te le redemandera pas la fois suivante.
Et là, il l’ajoute à la liste vu que tu as répondu yes:
Donc, jusque là tout va bien.
Par contre, là
On a l’impression que le mot de passe a été refusé ou que la connexion s’est coupée…
Essaie avec l’option « -v » => (verbeuse) pour voir :
Pour les quelques différences, c’est normal vu que je n’avais pas encore créé le répertoire dev et autres détails.
J’aurais dû terminer le tuto avant de te demander ça.
Désolé. Mais ça donne quand même une idée.
Pourrais-tu me transmettre le retour de la commande suivante ? (histoire de vérifier les attributs des fichiers)
ls -l /home/sftp/dev /usr/lib/rssh/rssh_chroot_helper /home/sftp/etc/passwd
