Serveur SSH et keys [RÉSOLU]
voila le problème
je dois donner l’accès au serveur via ssh grâce a leurs clé dsa_pub
si j’ai bien compris, je prends leurs clé et je fais
cat dsa_pub >> /root/.ssh/authorized_keys
sur le serveur ?
je dois leurs créer un compte en local ? car ça ne marche pas ?
voila la config du serveur
Package generated configuration file
See the sshd(8) manpage for details
What ports, IPs and protocols we listen for
Port 22
Use these options to restrict which interfaces/protocols sshd will bind to
#ListenAddress ::
#ListenAddress 0.0.0.0
Protocol 2
HostKeys for protocol version 2
HostKey /etc/ssh/ssh_host_rsa_key
HostKey /etc/ssh/ssh_host_dsa_key
#Privilege Separation is turned on for security
UsePrivilegeSeparation yes
Lifetime and size of ephemeral version 1 server key
KeyRegenerationInterval 3600
ServerKeyBits 768
Logging
SyslogFacility AUTH
LogLevel INFO
Authentication:
LoginGraceTime 600
PermitRootLogin yes
StrictModes yes
RSAAuthentication yes
PubkeyAuthentication yes
AuthorizedKeysFile %h/.ssh/authorized_keys
Don’t read the user’s ~/.rhosts and ~/.shosts files
IgnoreRhosts yes
For this to work you will also need host keys in /etc/ssh_known_hosts
RhostsRSAAuthentication no
similar for protocol version 2
HostbasedAuthentication no
Uncomment if you don’t trust ~/.ssh/known_hosts for RhostsRSAAuthentication
#IgnoreUserKnownHosts yes
To enable empty passwords, change to yes (NOT RECOMMENDED)
PermitEmptyPasswords no
Change to no to disable s/key passwords
#ChallengeResponseAuthentication yes
Change to yes to enable tunnelled clear text passwords
PasswordAuthentication no
To change Kerberos options
#KerberosAuthentication no
#KerberosOrLocalPasswd yes
#AFSTokenPassing no
#KerberosTicketCleanup no
Kerberos TGT Passing does only work with the AFS kaserver
#KerberosTgtPassing yes
X11Forwarding no
X11DisplayOffset 10
PrintMotd no
PrintLastLog yes
KeepAlive yes
#UseLogin no
#MaxStartups 10:30:60
#Banner /etc/issue.net
Subsystem sftp /usr/lib/openssh/sftp-server
UsePAM yes
merci
http://forum.debian-fr.org/viewtopic.php?f=8&t=5472
j’ai une question
si un client me donne ça clé pub
que je la place dans /root/.ssh/authorized_keys
il va donc pouvoir ce connecter en root sans avoir le mot de passe de root
mais juste le mot de passe de ça clé
j’ai bon ou pas ?
merci
j’ai plusieurs serveurs , sous fedora,redhat et debian
j’ai le même problème sur les 3
j’ai fais un serveur ssh sur chaque
je peux me connecter de l’un a l’autre sans problème et aussi d’un client windows via putty
voila ou ça bloque:
j’ai généré des keys rsa et dsa sur chaque serveur pour faire du ssh avec keys+passphrase
cela marche d’un serveur à un autre sans problème …
la ou ça ne marche pas c’est avec putty
je génére des keys rsa,dsa avec “puttygen.exe” et j’utilise "pageant.exe"
mais rien à faire ?
Merci pour l’aide
Voir la suite
viewtopic.php?f=3&t=17062
Merci pour l’aide
