Je pensais que le script s’occupait de tout ?
Et pourquoi, il trouve un systeme SID alos que c’est une STABLE d’installée ?
[code]=========================================================
START sgfxi LOGGING:
Script started: 2011-02-20-11:00:30
Video Card Information: nVidia Corporation G84 [GeForce 8600 GT] (rev a1)
Video Card Type: 10de
Video Card Number: 0402
Xorg Version: 1.7
Installing driver to kernel: 2.6.32-5-686
sgfxi script version: 4.17.03
sgfxi start options:
SYSTEM_BASE: debian
SYSTEM_CODENAME: sid
DISTRIB_CODENAME: sid
DISTRIB_ID: debian
DISTRIB_RELEASE:
FG_DISTRIB_CODENAME: sid
FG_DISTRIB_ID: Debian
APT_TYPE: aptitude
X is Running: true
Current Runlevel: 2
Connection is live (0=true): 0
INSTALL_TO_KERNEL:
KERNEL_VERSION: 2.6.32-5-686
KERNEL_BASE: 2.6
KERNEL_THREE: 2.6.32
KERNEL_THIRD: 32
B_IS_XEN: false
Function: create_x_conf - Primary: Start
xorg is present with xorg.conf file
Function: create_x_conf - Primary: End
Function: check_package_manager_updated - Utility: Start
sizeWorking: 27
Function: check_package_manager_updated - Utility: End
Function: check_supported_driver - Utility: Start
Function: check_supported_driver - Utility: End
Function: set_cpu_data - Utility: Start
BITS: 32 - arch:
Function: set_cpu_data - Utility: End
Function: set_driver_install_version - Primary: Start
Args: last-check
Function: print_information_continue - Utility: Start
Args: standard The graphics installer will be installing the nvidia driver: 260.19.36
Function: print_information_continue - Utility: End
Installing this driver: 260.19.36
Function: set_driver_install_version - Primary: End
Function: driver_support_tests - Utility: Start
Args: supported-driver
Function: driver_support_tests - Utility: End
Function: check_kernel_headers - Utility: Start
Function: check_package_status - Utility: Start
Args: linux-headers-2.6.32-5-686 i
Package Version: (none)
Function: check_package_status - Utility: End
Args: linux-headers-2.6.32-5-686 c
Package Version: 2.6.32-30
headerName: linux-headers-2.6.32-5-686
headerInstalled: (none)
headerAvailable: 2.6.32-30
headerFile:
Function: check_kernel_headers - Utility: End
Function: check_run_package_tools - Primary: Start
Function: check_run_package_tools - Primary: End
Function: set_download_info - Primary: Start
download url: ftp://download.nvidia.com/XFree86/Linux-x86/260.19.36/ - driver file: NVIDIA-Linux-x86-260.19.36
Function: set_download_info - Primary: End
Function: test_module_build_ok - Primary: Start
Args: return
Function: list_installed_packages - Utility: Start
Args: nvidia (modalias|libvdpau)
packageList:
Function: list_installed_packages - Utility: End
returnValue: 3
Error Data: No Installed Nvidia:
Function: download_extract_driver - Primary: Start
Args: ftp://download.nvidia.com/XFree86/Linux-x86/260.19.36/ NVIDIA-Linux-x86-260.19.36
Function: pre_extract_clean_set_up - Utility: Start
Args: NVIDIA-Linux-x86-260.19.36
Function: pre_extract_clean_set_up - Utility: End
Creating directory NVIDIA-Linux-x86-260.19.36
Verifying archive integrity… OK
Uncompressing NVIDIA Accelerated Graphics Driver for Linux-x86 260.19.36…
Function: download_extract_driver - Primary: End
Function: set_install_directory - set to: /usr/src/sgfxi-downloads/NVIDIA-Linux-x86-260.19.36
Function: run_driver_patches - Primary: Start
Function: misc_fixes - Utility: Start
Args: linux-generated-patch
outcome: /usr/src/2.6.32-5-686/include/generated/ or /lib/modules/2.6.32-5-686/build/include/generated/ do not exist
Function: misc_fixes - Utility: End
Function: run_driver_patches - Primary: End
Function: x_start_stop_master - Primary: Start
Args: stop
Function: start_stop_x - Utility: Start
Args: stop
default runlevel: 2
current runlevel: 2
dmanCommand: service gdm3 stop
Function: x_is_running - Utility: Start
xIsRunning: false
Function: x_is_running - Utility: End
Function: start_stop_x - Utility: End
Function: x_start_stop_master - Primary: End
Function: check_driver_install_tools - Primary: Start
Args: module-assistant i
Args: build-essential i
Function: check_driver_install_tools - Primary: End
Function: prep_install - Primary: Start
Function: prep_install - Primary: End
Function: preinstall_cleanup - Primary: Start
nvidia.ko files:
Args: nvidia (modalias|libvdpau|nvidia-bl-dkms|nvidia-cg-toolkit)
packageList:
Function: remove_module - Primary: Start
Args: nvidia
operation outcome: unset
Function: remove_module - Primary: End
Args: nouveau
operation outcome: removed
Function: set_modesetting_off - Primary: End
Function: add_grub_nomodeset_blacklist_item - Utility: Start
Args: nouveau
Function: get_active_grub_files - Utility: Start
grub files: /boot/grub/grub.cfg /etc/default/grub
Function: get_active_grub_files - Utility: End
Function: add_grub_nomodeset_blacklist_item - Utility: End
Function: add_modprobe_d_blacklist_item - Utility: Start
Args: nouveau
Function: add_modprobe_d_blacklist_item - Utility: End
Function: set_modesetting_off - Primary: Start
Args: nouveau removed
Args: fglrx modalias
packageList:
Args: fglrx
Function: clean_dkms - Primary: Start
Function: clean_dkms - Primary: End
Function: preinstall_cleanup - Primary: End
Function: run_driver_installer - Primary: Start
driver: 260.19.36
ERROR: Unable to find the kernel source tree for the currently running
kernel. Please make sure you have installed the kernel source files
for your kernel and that they are properly configured; on Red Hat
Linux systems, for example, be sure you have the ‘kernel-source’ or
’kernel-devel’ RPM installed. If you know the correct kernel source
files are installed, you may specify the kernel source path with the
’–kernel-source-path’ command line option.
ERROR: Installation has failed. Please see the file
’/var/log/nvidia-installer.log’ for details. You may find
suggestions on fixing installation problems in the README available
on the Linux driver download page at www.nvidia.com.
Function: apply_module_patch - Primary: Start
Args: post
Function: apply_module_patch - Primary: End
Error logs from nvidia install:
nvidia-installer log file '/var/log/nvidia-installer.log’
creation time: Sun Feb 20 11:00:38 2011
installer version: 260.19.36
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
option status:
license pre-accepted : true
update : false
force update : false
expert : false
uninstall : false
driver info : false
precompiled interfaces : false
no ncurses color : false
query latest version : false
no questions : true
silent : true
no recursion : false
no backup : false
kernel module only : false
sanity : false
add this kernel : false
no runlevel check : false
no network : true
no ABI note : false
no RPMs : false
no kernel module : false
force SELinux : default
no X server check : false
no cc version check : true
run distro scripts : true
no nouveau check : false
run nvidia-xconfig : false
sigwinch work around : true
force tls : (not specified)
X install prefix : (not specified)
X library install path : /usr/lib
X module install path : /usr/lib/xorg/modules
OpenGL install prefix : (not specified)
OpenGL install libdir : (not specified)
utility install prefix : (not specified)
utility install libdir : (not specified)
installer prefix : (not specified)
doc install prefix : (not specified)
kernel name : 2.6.32-5-686
kernel include path : (not specified)
kernel source path : (not specified)
kernel output path : (not specified)
kernel install path : (not specified)
precompiled kernel interfaces path : (not specified)
precompiled kernel interfaces url : (not specified)
proc mount point : /proc
ui : none
tmpdir : /tmp
ftp mirror : ftp://download.nvidia.com
RPM file list : (not specified)
selinux chcon type : (not specified)
Using built-in stream user interface
-> License accepted by command line option.
-> Installing NVIDIA driver version 260.19.36.
-> Not probing for precompiled kernel interfaces.
-> Performing CC sanity check with CC="/usr/bin/gcc-4.3".
ERROR: Unable to find the kernel source tree for the currently running kernel.
Please make sure you have installed the kernel source files for your
kernel and that they are properly configured; on Red Hat Linux systems,
for example, be sure you have the ‘kernel-source’ or ‘kernel-devel’ RPM
installed. If you know the correct kernel source files are installed,
you may specify the kernel source path with the ‘–kernel-source-path’
’/var/log/nvidia-installer.log’ for details. You may find suggestions
on fixing installation problems in the README available on the Linux
ERROR: (245) The nvidia installer exited with the error: 1
A copy of this driver installer error log is also here: /var/log/sgfxi/sgfxi.log[/code]
