Un descriptif de mon matos se trouve dans ma signature.
J’ai une Sid et une Lenny sur deux partitions différentes branchées sur le même home.
J’ai installé la Sid avec le noyau 2.6.29-1 et j’ai tenté d’installer les pilotes nvidia d’après le fil de DebianHadic :
[quote]$ su
apt-get install module-assistant
m-a prepare
m-a clean nvidia-kernel
m-a a-i -i nvidia-kernel-source
apt-get install nvidia-glx[/quote]
Ensuite, j’ai ouvert mon fichier xorg.conf qui était vide. J’ai donc récupéré le fichier xorg.conf de ma lenny pour laquelle les pilotes nvidia fonctionnent nickel que j’ai collé dans le fichier vide de ma Sid.
Au passage voici le xorg.conf en question :
[code]# xorg.conf (X.Org X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the xorg.conf manual page.
(Type “man xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
Option “XkbOptions” "lv3:ralt_switch"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
EndSection
Section "Device"
Identifier "Configured Video Device"
Driver "nvidia"
Option “XAANoOffscreenPixmaps” "true"
Option “AllowGLXWithComposite” "true"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
Option “AddARGBGLXVisuals” "True"
EndSection
Section "Extensions"
Option “Composite” "enable"
EndSection
Section “Module”
#Load “dri”
#Load "GLcore"
EndSection
Bizarrement après redémarrage du PC, le logo nvidia ne s’affiche pas juste avant le démarrage de gdm.
Ensuite quand je tente d’activer compiz avec la commande compiz --replace en console, voici ce que j’obtiens :
[quote]laurent@debian:~$ compiz --replace
Checking for Xgl: not present.
xset q doesn’t reveal the location of the log file. Using fallback /var/log/Xorg.0.log
Detected PCI ID for VGA: 01:00.0 0300: 10de:0402 (rev a1) (prog-if 00 [VGA controller])
Checking for texture_from_pixmap: present.
Checking for non power of two support: present.
Checking for Composite extension: present.
Checking screen 1Comparing resolution (1680x1050) to maximum 3D texture size (8192): Passed.
Checking for Software Rasterizer: Not present.
Checking for nVidia: present.
Checking for FBConfig: present.
/usr/bin/compiz: line 455: 8224 Erreur de segmentation ${COMPIZ_BIN_PATH}${COMPIZ_NAME} $COMPIZ_OPTIONS “$@” $COMPIZ_PLUGINS[/quote]
Apparement, il y a eu des messages d’erreur lors de la compilation des pilotes, mais comme ça défile trop vite, je n’ai pas vu et je n’ai aucune idée d’où je pourrais les retrouver.
J’ai cherché vite fait xgl, mais ça ne se trouve pas dans les dépôts et apparemment d’après des infos sur le forum ubuntu ça ne concernerait que les possesseurs de cartes vidéo ATI ce qui n’est pas mon cas.
Je précise que la méthode d’installation des pilotes avec une 100% lenny, n’a posé aucun problème.
Des idées, des problèmes similaires chez quelqu’un d’autre?
