J’ai installé sid récemment (avant hier), et je n’ai jusque là pas réussis à afficher quoique ce soit en graphique.
Voici le log d’Xorg
pour ce qui est du fichier de configuration (généré par X -configure)
[code]Section "ServerLayout"
Identifier "X.org Configured"
Screen 0 “Screen0” 0 0
InputDevice “Mouse0” "CorePointer"
InputDevice “Keyboard0” "CoreKeyboard"
EndSection
Section "Files"
ModulePath "/usr/lib/xorg/modules"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
FontPath "built-ins"
EndSection
Section "Module"
Load "record"
Load "glx"
Load "extmod"
Load "dri2"
Load "dri"
Load "dbe"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "kbd"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option “Protocol” "auto"
Option “Device” "/dev/input/mice"
Option “ZAxisMapping” "4 5 6 7"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Monitor Model"
EndSection
Section “Device”
### Available Driver options are:-
### Values: : integer, : float, : “True”/“False”,
### : “String”, : " Hz/kHz/MHz"
### [arg]: arg optional
#Option “ShadowFB” # []
#Option “Rotate” #
#Option “fbdev” #
#Option “debug” # []
Identifier "Card0"
Driver "fbdev"
VendorName "ATI Technologies Inc"
BoardName "Unknown Board"
BusID "PCI:2:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
SubSection "Display"
Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Je pense que ça ne pose pas de problème. Peut être que je me trompe, mais ça me semble simplement venir de Xorg, et non d’une erreur de configuration.
Est-ce que je dois simplement attendre une mise à jour ? Je peux tenter d’autres choses ?
Edit : J’installe les pilote fglrx avec smxi, je repasse dire si ça marche mieux
Edit 2 : après installation des pilotes recommandés (10-1), Xorg produit toujours la même erreur. Je tente la configuration qui avait fonctionnée pour moi sur lenny 64…
