[Sid] Installation serveur X, kdm se lance mais pas le reste
Bonjour, je viens d’installer une Sid via debootstrap : jusque là tout c’est bien passé, sauf à l’installation du serveur X : j’ai en gros installé : xfonts-base, xorg, kdm.
Mais lorsque je lance “startx”, l’écran clignotte 3-4 fois puis revient en console, sana afficher d’erreur, seulement ces warnings :
(WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist. [...] (WW) intel: No matching Device section for instance (BusID PCI:0:2:1) found [...] (WW) intel(0): Register 0x61200 (PP_STATUS) changed from 0xc0000008 to 0xd000000a (WW) intel(0): PP_STATUS before: on, ready, sequencing idle (WW) intel(0): PP_STATUS after: on, ready, sequencing on [...] (WW) AIGLX: 3D driver claims to not support visual 0x2a [×15]
Le plus étrange, c’est que kdm se lance, avec la souris et l’affichage qui fonctionne, mais il m’est impossible de me loggué ! L’écran clignotte 3-4 fois puis revient à kdm.
Mon xorg.conf est un générique :
[code]# xorg.conf (X.Org X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the xorg.conf manual page.
(Type “man xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option “XkbRules” "xorg"
Option “XkbModel” "pc104"
Option “XkbLayout” "fr"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
EndSection
Section "Device"
Identifier "Configured Video Device"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
EndSection[/code]
Merci !
