Ce domaine est inaccessible.
[code][19:20:00] ~ # ping -c3 moments-photos.com
ping: unknown host moments-photos.com
[19:20:27] ~ #
[19:20:29] ~ # host moments-photos.com
;; connection timed out; no servers could be reached
[19:20:59] ~ #
[19:21:06] ~ # nslookup moments-photos.com
;; Got SERVFAIL reply from 213.186.33.99, trying next server
[19:21:38] ~ #
Contrairement à ton ip.
[code][19:21:42] ~ # host KS206158.KIMSUFI.COM
KS206158.KIMSUFI.COM has address 94.23.42.172
[19:21:55] ~ #
[19:21:57] ~ # ping -c3 94.23.42.172
PING 94.23.42.172 (94.23.42.172) 56(84) bytes of data.
64 bytes from 94.23.42.172: icmp_req=1 ttl=62 time=0.809 ms
64 bytes from 94.23.42.172: icmp_req=2 ttl=62 time=0.804 ms
64 bytes from 94.23.42.172: icmp_req=3 ttl=62 time=0.784 ms
— 94.23.42.172 ping statistics —
3 packets transmitted, 3 received, 0% packet loss, time 2002ms
rtt min/avg/max/mdev = 0.784/0.799/0.809/0.010 ms
[19:22:11] ~ #
[19:22:12] ~ # dig KS206158.KIMSUFI.COM
; <<>> DiG 9.8.4-rpz2+rl005.12-P1 <<>> KS206158.KIMSUFI.COM
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 16912
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;KS206158.KIMSUFI.COM. IN A
;; ANSWER SECTION:
KS206158.KIMSUFI.COM. 85351 IN A 94.23.42.172
;; Query time: 0 msec
;; SERVER: 127.0.0.1#53(127.0.0.1)
;; WHEN: Thu Oct 10 19:22:24 2013
;; MSG SIZE rcvd: 54
[19:22:24] ~ #
[19:27:26] ~ #
[19:27:26] ~ # host KS206158.KIMSUFI.COM
[19:27:44] ~ #
[19:27:47] ~ # ping -c3 94.23.42.172
64 bytes from 94.23.42.172: icmp_req=1 ttl=62 time=0.830 ms
64 bytes from 94.23.42.172: icmp_req=2 ttl=62 time=0.809 ms
64 bytes from 94.23.42.172: icmp_req=3 ttl=62 time=0.802 ms
3 packets transmitted, 3 received, 0% packet loss, time 2000ms
rtt min/avg/max/mdev = 0.802/0.813/0.830/0.035 ms
[19:27:53] ~ #
[19:27:54] ~ # nslookup KS206158.KIMSUFI.COM
Server: 127.0.0.1
Address: 127.0.0.1#53
Non-authoritative answer:
Address: 94.23.42.172
[19:28:03] ~ #
[19:28:07] ~ # dig KS206158.KIMSUFI.COM
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 61974
;; ANSWER SECTION:
KS206158.KIMSUFI.COM. 85004 IN A 94.23.42.172
;; WHEN: Thu Oct 10 19:28:11 2013
[19:28:11] ~ # [/code]
Tu as bon nombre d’incohérences dans tes configurations et déclarations.
D’autre part, l’indien et mysql sont-ils fonctionnels …
T’es tu informés de ces dysfonctionnements en /var/log/apache2/… log
