Je commence à devenir fou avec l’installation de Sketchup avec wine sur ma Wheezy amd64 (drivers ati proprio).
J’ai installé les librairies 32bit. J’obtiens des messages de ce genre.
remy@jilipolla:~$ env WINEPREFIX="/home/remy/.wine" wine C:\\Program\ Files\\Google\\Google\ SketchUp\ 8\\SketchUp.exe
err:module:load_builtin_dll failed to load .so lib for builtin L"OPENGL32.dll": libGL.so.1: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce type
err:module:import_dll Loading library OPENGL32.dll (which is needed by L"C:\\Program Files\\Google\\Google SketchUp 8\\SketchUp.exe") failed (error c000007a).
err:module:load_builtin_dll failed to load .so lib for builtin L"GLU32.dll": libGL.so.1: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce type
err:module:import_dll Loading library GLU32.dll (which is needed by L"C:\\Program Files\\Google\\Google SketchUp 8\\SketchUp.exe") failed (error c000007a).
err:module:import_dll Loading library OPENGL32.dll (which is needed by L"C:\\Program Files\\Google\\Google SketchUp 8\\IGGfx.dll") failed (error c000007a).
err:module:import_dll Library IGGfx.dll (which is needed by L"C:\\Program Files\\Google\\Google SketchUp 8\\IGAttrs.dll") not found
err:module:import_dll Library IGAttrs.dll (which is needed by L"C:\\Program Files\\Google\\Google SketchUp 8\\IGSg.dll") not found
err:module:import_dll Library IGGfx.dll (which is needed by L"C:\\Program Files\\Google\\Google SketchUp 8\\IGSg.dll") not found
err:module:import_dll Library IGSg.dll (which is needed by L"C:\\Program Files\\Google\\Google SketchUp 8\\SketchUp.exe") not found
err:module:import_dll Library IGAttrs.dll (which is needed by L"C:\\Program Files\\Google\\Google SketchUp 8\\SketchUp.exe") not found
err:module:import_dll Library IGGfx.dll (which is needed by L"C:\\Program Files\\Google\\Google SketchUp 8\\SketchUp.exe") not found
err:module:import_dll Library IGSg.dll (which is needed by L"C:\\Program Files\\Google\\Google SketchUp 8\\alchemyext.dll") not found
err:module:import_dll Library IGAttrs.dll (which is needed by L"C:\\Program Files\\Google\\Google SketchUp 8\\alchemyext.dll") not found
err:module:import_dll Library IGGfx.dll (which is needed by L"C:\\Program Files\\Google\\Google SketchUp 8\\alchemyext.dll") not found
err:module:import_dll Library alchemyext.dll (which is needed by L"C:\\Program Files\\Google\\Google SketchUp 8\\SketchUp.exe") not found
err:module:LdrInitializeThunk Main exe initialization for L"C:\\Program Files\\Google\\Google SketchUp 8\\SketchUp.exe" failed, status c0000135
Après avoir regardé divers forum, je suis à cours d’idée.
Mimosa
