Sortie de la veille impossible
Bonjour a tous je vous contacte car j’ai un problème de sortie de veille sous Debian Jessie il a commencer a me faire sa plus ou moins souvent et maintenant c’est tout le temps! même la veille et l’hibernation ne fonctionne plus correctement (je ne suis plus capable d’en revenir il ne fait qu’afficher des dessins aléatoires) . merci a toute aide !
voici ce que j’ai dans xorg.log
[ 19.240]
X.Org X Server 1.16.4
Release Date: 2014-12-20
[ 19.240] X Protocol Version 11, Revision 0
[ 19.240] Build Operating System: Linux 3.16.0-4-amd64 x86_64 Debian
[ 19.240] Current Operating System: Linux debian 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt11-1+deb8u6 (2015-11-09) x86_64
[ 19.240] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.16.0-4-amd64 root=UUID=26c73aa0-b0db-4e0f-8a8e-d2368644fbd8 ro quiet
[ 19.240] Build Date: 11 February 2015 12:32:02AM
[ 19.240] xorg-server 2:1.16.4-1 (debian.org/support)
[ 19.240] Current version of pixman: 0.32.6
[ 19.240] Before reporting problems, check wiki.x.org
[ 19.240] Markers: (–) probed, () from config file, (==) default setting,
[ 19.240] (==) Log file: “/var/log/Xorg.0.log”, Time: Sat Nov 21 17:54:55 2015
[ 19.300] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 19.360] (==) No Layout section. Using the first Screen section.
[ 19.360] (==) No screen section available. Using defaults.
[ 19.360] (
) |–>Screen “Default Screen Section” (0)
[ 19.360] (**) | |–>Monitor “”
[ 19.360] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 19.360] (==) Automatically adding devices
[ 19.360] (==) Automatically enabling devices
[ 19.360] (==) Automatically adding GPU devices
[ 19.391] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 19.391] Entry deleted from font path.
[ 19.403] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 19.403] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 19.403] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 19.403] (II) Loader magic: 0x7f205f390d80
[ 19.403] (II) Module ABI versions:
[ 19.403] X.Org ANSI C Emulation: 0.4
[ 19.403] X.Org Video Driver: 18.0
[ 19.403] X.Org XInput driver : 21.0
[ 19.403] X.Org Server Extension : 8.0
[ 19.403] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 19.407] (–) PCI:*(0:96:0:0) 10de:040f:10de:049a rev 161, Mem @ 0xf2000000/16777216, 0xc0000000/536870912, 0xf0000000/33554432, I/O @ 0x00001000/128
[ 19.407] (II) LoadModule: “glx”
[ 19.490] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 19.582] (II) Module glx: vendor=“X.Org Foundation”
[ 19.582] compiled for 1.16.4, module version = 1.0.0
[ 19.582] ABI class: X.Org Server Extension, version 8.0
[ 19.582] (==) AIGLX enabled
[ 19.582] (==) Matched nouveau as autoconfigured driver 0
[ 19.582] (==) Matched nv as autoconfigured driver 1
[ 19.582] (==) Matched nouveau as autoconfigured driver 2
[ 19.582] (==) Matched nv as autoconfigured driver 3
[ 19.582] (==) Matched modesetting as autoconfigured driver 4
[ 19.582] (==) Matched fbdev as autoconfigured driver 5
[ 19.582] (==) Matched vesa as autoconfigured driver 6
[ 19.582] (==) Assigned the driver to the xf86ConfigLayout
[ 19.582] (II) LoadModule: “nouveau”
[ 19.582] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 19.604] (II) Module nouveau: vendor=“X.Org Foundation”
[ 19.604] compiled for 1.16.0, module version = 1.0.11
[ 19.604] Module class: X.Org Video Driver
[ 19.604] ABI class: X.Org Video Driver, version 18.0
[ 19.604] (II) LoadModule: “nv”
[ 19.625] (WW) Warning, couldn’t open module nv
[ 19.625] (II) UnloadModule: “nv”
[ 19.625] (II) Unloading nv
[ 19.625] (EE) Failed to load module “nv” (module does not exist, 0)
[ 19.625] (II) LoadModule: “modesetting”
[ 19.625] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 19.638] (II) Module modesetting: vendor=“X.Org Foundation”
[ 19.638] compiled for 1.16.4, module version = 0.9.0
[ 19.638] Module class: X.Org Video Driver
[ 19.638] ABI class: X.Org Video Driver, version 18.0
[ 19.638] (II) LoadModule: “fbdev”
[ 19.638] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 19.644] (II) Module fbdev: vendor=“X.Org Foundation”
[ 19.644] compiled for 1.15.99.904, module version = 0.4.4
[ 19.644] Module class: X.Org Video Driver
[ 19.644] ABI class: X.Org Video Driver, version 18.0
[ 19.644] (II) LoadModule: “vesa”
[ 19.644] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 19.658] (II) Module vesa: vendor=“X.Org Foundation”
[ 19.658] compiled for 1.15.99.904, module version = 2.3.3
[ 19.658] Module class: X.Org Video Driver
[ 19.658] ABI class: X.Org Video Driver, version 18.0
[ 19.658] (II) NOUVEAU driver Date: Thu Aug 28 03:57:48 2014 +0200
[ 19.658] (II) NOUVEAU driver for NVIDIA chipset families :
[ 19.658] RIVA TNT (NV04)
[ 19.658] RIVA TNT2 (NV05)
[ 19.658] GeForce 256 (NV10)
[ 19.658] GeForce 2 (NV11, NV15)
[ 19.658] GeForce 4MX (NV17, NV18)
[ 19.658] GeForce 3 (NV20)
[ 19.658] GeForce 4Ti (NV25, NV28)
[ 19.658] GeForce FX (NV3x)
[ 19.658] GeForce 6 (NV4x)
[ 19.659] GeForce 7 (G7x)
[ 19.659] GeForce 8 (G8x)
[ 19.659] GeForce GTX 200 (NVA0)
[ 19.659] GeForce GTX 400 (NVC0)
[ 19.659] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 19.659] (II) FBDEV: driver for framebuffer: fbdev
[ 19.659] (II) VESA: driver for VESA chipsets: vesa
[ 19.659] (++) using VT number 7
[ 19.660] (II) [drm] nouveau interface version: 1.1.2
[ 19.660] (WW) Falling back to old probe method for modesetting
[ 19.660] (WW) Falling back to old probe method for fbdev
[ 19.660] (II) Loading sub module “fbdevhw”
[ 19.660] (II) LoadModule: “fbdevhw”
[ 19.661] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 19.661] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 19.661] compiled for 1.16.4, module version = 0.0.2
[ 19.661] ABI class: X.Org Video Driver, version 18.0
[ 19.661] (WW) Falling back to old probe method for vesa
[ 19.661] (II) Loading sub module “dri2”
[ 19.661] (II) LoadModule: “dri2”
[ 19.661] (II) Module “dri2” already built-in
[ 19.661] (–) NOUVEAU(0): Chipset: “NVIDIA NV84”
[ 19.661] (II) NOUVEAU(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 19.661] (==) NOUVEAU(0): Depth 24, (–) framebuffer bpp 32
[ 19.661] (==) NOUVEAU(0): RGB weight 888
[ 19.661] (==) NOUVEAU(0): Default visual is TrueColor
[ 19.661] (==) NOUVEAU(0): Using HW cursor
[ 19.661] (==) NOUVEAU(0): GLX sync to VBlank enabled.
[ 19.661] (==) NOUVEAU(0): Page flipping enabled
[ 19.661] (==) NOUVEAU(0): Swap limit set to 1 [Max allowed 2]
[ 19.661] (==) NOUVEAU(0): Page flipping synced to vblank by kernel.
[ 19.661] (II) NOUVEAU(0): Initializing outputs …
[ 19.689] (II) NOUVEAU(0): Output DVI-I-1 has no monitor section
[ 19.717] (II) NOUVEAU(0): Output DVI-I-2 has no monitor section
[ 19.717] (II) NOUVEAU(0): 2 crtcs needed for screen.
[ 19.734] (II) NOUVEAU(0): Allocated crtc nr. 0 to this screen.
[ 19.734] (II) NOUVEAU(0): Allocated crtc nr. 1 to this screen.
[ 19.762] (II) NOUVEAU(0): EDID for output DVI-I-1
[ 19.762] (II) NOUVEAU(0): Manufacturer: LEN Model: 1152 Serial#: 16843009
[ 19.762] (II) NOUVEAU(0): Year: 2010 Week: 4
[ 19.762] (II) NOUVEAU(0): EDID Version: 1.3
[ 19.762] (II) NOUVEAU(0): Digital Display Input
[ 19.762] (II) NOUVEAU(0): Max Image Size [cm]: horiz.: 41 vert.: 26
[ 19.762] (II) NOUVEAU(0): Gamma: 2.20
[ 19.762] (II) NOUVEAU(0): DPMS capabilities: Off
[ 19.762] (II) NOUVEAU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 19.762] (II) NOUVEAU(0): First detailed timing is preferred mode
[ 19.762] (II) NOUVEAU(0): redX: 0.640 redY: 0.334 greenX: 0.285 greenY: 0.599
[ 19.762] (II) NOUVEAU(0): blueX: 0.153 blueY: 0.076 whiteX: 0.312 whiteY: 0.328
[ 19.762] (II) NOUVEAU(0): Supported established timings:
[ 19.762] (II) NOUVEAU(0): 720x400@70Hz
[ 19.762] (II) NOUVEAU(0): 640x480@60Hz
[ 19.762] (II) NOUVEAU(0): 640x480@67Hz
[ 19.762] (II) NOUVEAU(0): 640x480@72Hz
[ 19.762] (II) NOUVEAU(0): 640x480@75Hz
[ 19.762] (II) NOUVEAU(0): 800x600@56Hz
[ 19.762] (II) NOUVEAU(0): 800x600@60Hz
[ 19.762] (II) NOUVEAU(0): 800x600@72Hz
[ 19.762] (II) NOUVEAU(0): 800x600@75Hz
[ 19.762] (II) NOUVEAU(0): 1024x768@60Hz
[ 19.762] (II) NOUVEAU(0): 1024x768@70Hz
[ 19.762] (II) NOUVEAU(0): 1024x768@75Hz
[ 19.762] (II) NOUVEAU(0): 1280x1024@75Hz
[ 19.762] (II) NOUVEAU(0): Manufacturer’s mask: 0
[ 19.762] (II) NOUVEAU(0): Supported standard timings:
[ 19.762] (II) NOUVEAU(0): #0: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 19.762] (II) NOUVEAU(0): #1: hsize: 1280 vsize 1024 refresh: 70 vid: 35457
[ 19.762] (II) NOUVEAU(0): #2: hsize: 1280 vsize 1024 refresh: 72 vid: 35969
[ 19.762] (II) NOUVEAU(0): #3: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 19.762] (II) NOUVEAU(0): #4: hsize: 1440 vsize 900 refresh: 75 vid: 3989
[ 19.762] (II) NOUVEAU(0): Supported detailed timing:
[ 19.762] (II) NOUVEAU(0): clock: 88.8 MHz Image Size: 410 x 257 mm
[ 19.762] (II) NOUVEAU(0): h_active: 1440 h_sync: 1488 h_sync_end 1520 h_blank_end 1600 h_border: 0
[ 19.762] (II) NOUVEAU(0): v_active: 900 v_sync: 903 v_sync_end 909 v_blanking: 926 v_border: 0
[ 19.762] (II) NOUVEAU(0): Serial No: V1KYM22
[ 19.762] (II) NOUVEAU(0): Ranges: V min: 50 V max: 76 Hz, H min: 30 H max: 81 kHz, PixClock max 145 MHz
[ 19.762] (II) NOUVEAU(0): Monitor name: L197 Wide
[ 19.762] (II) NOUVEAU(0): EDID (in hex):
[ 19.762] (II) NOUVEAU(0): 00ffffffffffff0030ae521101010101
[ 19.762] (II) NOUVEAU(0): 0414010380291a782ae160a355499927
[ 19.762] (II) NOUVEAU(0): 135054bfcf008180818a818c9500950f
[ 19.762] (II) NOUVEAU(0): 010101010101ab22a0a050841a303020
[ 19.762] (II) NOUVEAU(0): 36009a011100001a000000ff0056314b
[ 19.762] (II) NOUVEAU(0): 594d32320a2020202020000000fd0032
[ 19.762] (II) NOUVEAU(0): 4c1e510e000a202020202020000000fc
[ 19.762] (II) NOUVEAU(0): 004c31393720576964650a20202000a7
[ 19.762] (II) NOUVEAU(0): Printing probed modes for output DVI-I-1
[ 19.762] (II) NOUVEAU(0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz eP)
[ 19.762] (II) NOUVEAU(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 19.762] (II) NOUVEAU(0): Modeline "1280x1024"x72.0 132.84 1280 1368 1504 1728 1024 1025 1028 1067 -hsync +vsync (76.9 kHz)
[ 19.762] (II) NOUVEAU(0): Modeline "1280x1024"x70.0 128.95 1280 1368 1504 1728 1024 1025 1028 1066 -hsync +vsync (74.6 kHz)
[ 19.762] (II) NOUVEAU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 19.762] (II) NOUVEAU(0): Modeline "1440x900"x75.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 19.762] (II) NOUVEAU(0): Modeline "1024x768"x75.1 78.80 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.1 kHz e)
[ 19.762] (II) NOUVEAU(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 19.762] (II) NOUVEAU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 19.763] (II) NOUVEAU(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 19.763] (II) NOUVEAU(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 19.763] (II) NOUVEAU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 19.763] (II) NOUVEAU(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 19.763] (II) NOUVEAU(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 19.763] (II) NOUVEAU(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 491 520 -hsync -vsync (37.9 kHz e)
[ 19.763] (II) NOUVEAU(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 19.763] (II) NOUVEAU(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 19.763] (II) NOUVEAU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 19.791] (II) NOUVEAU(0): EDID for output DVI-I-2
[ 19.791] (II) NOUVEAU(0): Manufacturer: LEN Model: 1152 Serial#: 16843009
[ 19.791] (II) NOUVEAU(0): Year: 2010 Week: 34
[ 19.791] (II) NOUVEAU(0): EDID Version: 1.3
[ 19.791] (II) NOUVEAU(0): Digital Display Input
[ 19.791] (II) NOUVEAU(0): Max Image Size [cm]: horiz.: 41 vert.: 26
[ 19.791] (II) NOUVEAU(0): Gamma: 2.20
[ 19.791] (II) NOUVEAU(0): DPMS capabilities: Off
[ 19.791] (II) NOUVEAU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 19.791] (II) NOUVEAU(0): First detailed timing is preferred mode
[ 19.791] (II) NOUVEAU(0): redX: 0.640 redY: 0.334 greenX: 0.285 greenY: 0.599
[ 19.791] (II) NOUVEAU(0): blueX: 0.153 blueY: 0.076 whiteX: 0.312 whiteY: 0.328
[ 19.791] (II) NOUVEAU(0): Supported established timings:
[ 19.791] (II) NOUVEAU(0): 720x400@70Hz
[ 19.791] (II) NOUVEAU(0): 640x480@60Hz
[ 19.791] (II) NOUVEAU(0): 640x480@67Hz
[ 19.791] (II) NOUVEAU(0): 640x480@72Hz
[ 19.791] (II) NOUVEAU(0): 640x480@75Hz
[ 19.791] (II) NOUVEAU(0): 800x600@56Hz
[ 19.791] (II) NOUVEAU(0): 800x600@60Hz
[ 19.791] (II) NOUVEAU(0): 800x600@72Hz
[ 19.791] (II) NOUVEAU(0): 800x600@75Hz
[ 19.791] (II) NOUVEAU(0): 1024x768@60Hz
[ 19.791] (II) NOUVEAU(0): 1024x768@70Hz
[ 19.791] (II) NOUVEAU(0): 1024x768@75Hz
[ 19.791] (II) NOUVEAU(0): 1280x1024@75Hz
[ 19.791] (II) NOUVEAU(0): Manufacturer’s mask: 0
[ 19.791] (II) NOUVEAU(0): Supported standard timings:
[ 19.791] (II) NOUVEAU(0): #0: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 19.791] (II) NOUVEAU(0): #1: hsize: 1280 vsize 1024 refresh: 70 vid: 35457
[ 19.791] (II) NOUVEAU(0): #2: hsize: 1280 vsize 1024 refresh: 72 vid: 35969
[ 19.791] (II) NOUVEAU(0): #3: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 19.791] (II) NOUVEAU(0): #4: hsize: 1440 vsize 900 refresh: 75 vid: 3989
[ 19.791] (II) NOUVEAU(0): Supported detailed timing:
[ 19.791] (II) NOUVEAU(0): clock: 88.8 MHz Image Size: 410 x 257 mm
[ 19.791] (II) NOUVEAU(0): h_active: 1440 h_sync: 1488 h_sync_end 1520 h_blank_end 1600 h_border: 0
[ 19.791] (II) NOUVEAU(0): v_active: 900 v_sync: 903 v_sync_end 909 v_blanking: 926 v_border: 0
[ 19.791] (II) NOUVEAU(0): Serial No: V1VVL30
[ 19.791] (II) NOUVEAU(0): Ranges: V min: 50 V max: 76 Hz, H min: 30 H max: 81 kHz, PixClock max 145 MHz
[ 19.791] (II) NOUVEAU(0): Monitor name: L197 Wide
[ 19.791] (II) NOUVEAU(0): EDID (in hex):
[ 19.791] (II) NOUVEAU(0): 00ffffffffffff0030ae521101010101
[ 19.791] (II) NOUVEAU(0): 2214010380291a782ae160a355499927
[ 19.791] (II) NOUVEAU(0): 135054bfcf008180818a818c9500950f
[ 19.791] (II) NOUVEAU(0): 010101010101ab22a0a050841a303020
[ 19.791] (II) NOUVEAU(0): 36009a011100001a000000ff00563156
[ 19.791] (II) NOUVEAU(0): 564c33300a2020202020000000fd0032
[ 19.791] (II) NOUVEAU(0): 4c1e510e000a202020202020000000fc
[ 19.791] (II) NOUVEAU(0): 004c31393720576964650a2020200083
[ 19.791] (II) NOUVEAU(0): Printing probed modes for output DVI-I-2
[ 19.791] (II) NOUVEAU(0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz eP)
[ 19.791] (II) NOUVEAU(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 19.791] (II) NOUVEAU(0): Modeline "1280x1024"x72.0 132.84 1280 1368 1504 1728 1024 1025 1028 1067 -hsync +vsync (76.9 kHz)
[ 19.791] (II) NOUVEAU(0): Modeline "1280x1024"x70.0 128.95 1280 1368 1504 1728 1024 1025 1028 1066 -hsync +vsync (74.6 kHz)
[ 19.791] (II) NOUVEAU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 19.791] (II) NOUVEAU(0): Modeline "1440x900"x75.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 19.791] (II) NOUVEAU(0): Modeline "1024x768"x75.1 78.80 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.1 kHz e)
[ 19.791] (II) NOUVEAU(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 19.791] (II) NOUVEAU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 19.791] (II) NOUVEAU(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 19.791] (II) NOUVEAU(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 19.791] (II) NOUVEAU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 19.791] (II) NOUVEAU(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 19.791] (II) NOUVEAU(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 19.791] (II) NOUVEAU(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 491 520 -hsync -vsync (37.9 kHz e)
[ 19.791] (II) NOUVEAU(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 19.791] (II) NOUVEAU(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 19.791] (II) NOUVEAU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 19.791] (II) NOUVEAU(0): Output DVI-I-1 connected
[ 19.791] (II) NOUVEAU(0): Output DVI-I-2 connected
[ 19.791] (II) NOUVEAU(0): Using exact sizes for initial modes
[ 19.791] (II) NOUVEAU(0): Output DVI-I-1 using initial mode 1440x900
[ 19.791] (II) NOUVEAU(0): Output DVI-I-2 using initial mode 1440x900
[ 19.791] (II) NOUVEAU(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 19.791] (–) NOUVEAU(0): Virtual size is 1440x900 (pitch 0)
[ 19.791] () NOUVEAU(0): Driver mode “1440x900”: 88.8 MHz (scaled from 0.0 MHz), 55.5 kHz, 59.9 Hz
[ 19.791] (
) NOUVEAU(0): Driver mode “1280x1024”: 135.0 MHz (scaled from 0.0 MHz), 80.0 kHz, 75.0 Hz
[ 19.791] () NOUVEAU(0): Mode “1280x1024”: 132.8 MHz (scaled from 0.0 MHz), 76.9 kHz, 72.0 Hz
[ 19.791] (
) NOUVEAU(0): Mode “1280x1024”: 128.9 MHz (scaled from 0.0 MHz), 74.6 kHz, 70.0 Hz
[ 19.791] () NOUVEAU(0): Driver mode “1280x1024”: 108.0 MHz (scaled from 0.0 MHz), 64.0 kHz, 60.0 Hz
[ 19.791] (
) NOUVEAU(0): Driver mode “1440x900”: 136.8 MHz (scaled from 0.0 MHz), 70.6 kHz, 75.0 Hz
[ 19.791] () NOUVEAU(0): Driver mode “1024x768”: 78.8 MHz (scaled from 0.0 MHz), 60.1 kHz, 75.1 Hz
[ 19.791] (
) NOUVEAU(0): Driver mode “1024x768”: 75.0 MHz (scaled from 0.0 MHz), 56.5 kHz, 70.1 Hz
[ 19.791] () NOUVEAU(0): Driver mode “1024x768”: 65.0 MHz (scaled from 0.0 MHz), 48.4 kHz, 60.0 Hz
[ 19.791] (
) NOUVEAU(0): Driver mode “800x600”: 50.0 MHz (scaled from 0.0 MHz), 48.1 kHz, 72.2 Hz
[ 19.791] () NOUVEAU(0): Driver mode “800x600”: 49.5 MHz (scaled from 0.0 MHz), 46.9 kHz, 75.0 Hz
[ 19.791] (
) NOUVEAU(0): Driver mode “800x600”: 40.0 MHz (scaled from 0.0 MHz), 37.9 kHz, 60.3 Hz
[ 19.791] () NOUVEAU(0): Driver mode “800x600”: 36.0 MHz (scaled from 0.0 MHz), 35.2 kHz, 56.2 Hz
[ 19.791] (
) NOUVEAU(0): Driver mode “640x480”: 31.5 MHz (scaled from 0.0 MHz), 37.5 kHz, 75.0 Hz
[ 19.791] () NOUVEAU(0): Driver mode “640x480”: 31.5 MHz (scaled from 0.0 MHz), 37.9 kHz, 72.8 Hz
[ 19.791] (
) NOUVEAU(0): Driver mode “640x480”: 30.2 MHz (scaled from 0.0 MHz), 35.0 kHz, 66.7 Hz
[ 19.791] () NOUVEAU(0): Driver mode “640x480”: 25.2 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz
[ 19.791] (
) NOUVEAU(0): Driver mode “720x400”: 28.3 MHz (scaled from 0.0 MHz), 31.5 kHz, 70.1 Hz
[ 19.791] (==) NOUVEAU(0): DPI set to (96, 96)
[ 19.791] (II) Loading sub module “fb”
[ 19.791] (II) LoadModule: “fb”
[ 19.791] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 19.798] (II) Module fb: vendor=“X.Org Foundation”
[ 19.798] compiled for 1.16.4, module version = 1.0.0
[ 19.798] ABI class: X.Org ANSI C Emulation, version 0.4
[ 19.798] (II) Loading sub module “shadowfb”
[ 19.798] (II) LoadModule: “shadowfb”
[ 19.799] (II) Loading /usr/lib/xorg/modules/libshadowfb.so
[ 19.807] (II) Module shadowfb: vendor=“X.Org Foundation”
[ 19.807] compiled for 1.16.4, module version = 1.0.0
[ 19.807] ABI class: X.Org ANSI C Emulation, version 0.4
[ 19.807] (II) UnloadModule: “modesetting”
[ 19.807] (II) Unloading modesetting
[ 19.807] (II) UnloadModule: “fbdev”
[ 19.807] (II) Unloading fbdev
[ 19.807] (II) UnloadSubModule: “fbdevhw”
[ 19.807] (II) Unloading fbdevhw
[ 19.807] (II) UnloadModule: “vesa”
[ 19.807] (II) Unloading vesa
[ 19.807] (–) Depth 24 pixmap format is 32 bpp
[ 19.815] (II) NOUVEAU(0): Channel setup complete.
[ 19.816] (EE) NOUVEAU(0): [COPY] failed to allocate class.
[ 19.830] (II) NOUVEAU(0): [DRI2] Setup complete
[ 19.830] (II) NOUVEAU(0): [DRI2] DRI driver: nouveau
[ 19.830] (II) NOUVEAU(0): [DRI2] VDPAU driver: nouveau
[ 19.833] (II) Loading sub module “exa”
[ 19.833] (II) LoadModule: “exa”
[ 19.833] (II) Loading /usr/lib/xorg/modules/libexa.so
[ 19.838] (II) Module exa: vendor=“X.Org Foundation”
[ 19.838] compiled for 1.16.4, module version = 2.6.0
[ 19.838] ABI class: X.Org Video Driver, version 18.0
[ 19.838] (II) EXA(0): Driver allocated offscreen pixmaps
[ 19.838] (II) EXA(0): Driver registered support for the following operations:
[ 19.838] (II) Solid
[ 19.838] (II) Copy
[ 19.838] (II) Composite (RENDER acceleration)
[ 19.838] (II) UploadToScreen
[ 19.838] (II) DownloadFromScreen
[ 19.838] (==) NOUVEAU(0): Backing store enabled
[ 19.838] (==) NOUVEAU(0): Silken mouse enabled
[ 19.839] (II) NOUVEAU(0): [XvMC] Associated with Nouveau GeForce 8/9 Textured Video.
[ 19.839] (II) NOUVEAU(0): [XvMC] Extension initialized.
[ 19.839] (==) NOUVEAU(0): DPMS enabled
[ 19.839] (II) NOUVEAU(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 19.840] (–) RandR disabled
[ 19.845] (II) SELinux: Disabled on system
[ 20.366] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 20.366] (II) AIGLX: enabled GLX_ARB_create_context
[ 20.366] (II) AIGLX: enabled GLX_ARB_create_context_profile
[ 20.366] (II) AIGLX: enabled GLX_EXT_create_context_es2_profile
[ 20.366] (II) AIGLX: enabled GLX_INTEL_swap_event
[ 20.366] (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
[ 20.366] (II) AIGLX: enabled GLX_EXT_framebuffer_sRGB
[ 20.366] (II) AIGLX: enabled GLX_ARB_fbconfig_float
[ 20.366] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[ 20.367] (II) AIGLX: Loaded and initialized nouveau
[ 20.367] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 20.368] (II) NOUVEAU(0): NVEnterVT is called.
[ 20.411] (II) NOUVEAU(0): Setting screen physical size to 381 x 238
[ 20.411] resize called 1440 900
[ 20.793] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 20.793] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 20.793] (II) LoadModule: “evdev”
[ 20.794] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 20.880] (II) Module evdev: vendor=“X.Org Foundation”
[ 20.880] compiled for 1.16.0, module version = 2.9.0
[ 20.880] Module class: X.Org XInput Driver
[ 20.880] ABI class: X.Org XInput driver, version 21.0
[ 20.880] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 20.880] (
) Power Button: always reports core events
[ 20.880] () evdev: Power Button: Device: “/dev/input/event2”
[ 20.880] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 20.880] (–) evdev: Power Button: Found keys
[ 20.880] (II) evdev: Power Button: Configuring as keyboard
[ 20.880] (
) Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event2”
[ 20.880] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 6)
[ 20.880] () Option “xkb_rules” “evdev”
[ 20.880] (
) Option “xkb_model” “pc105”
[ 20.880] () Option “xkb_layout” “ca”
[ 20.880] (
) Option “xkb_variant” “multi”
[ 20.923] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 20.924] () Power Button: Applying InputClass “evdev keyboard catchall”
[ 20.924] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 20.924] (
[ 20.924] () evdev: Power Button: Device: “/dev/input/event1”
[ 20.924] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 20.924] (–) evdev: Power Button: Found keys
[ 20.924] (II) evdev: Power Button: Configuring as keyboard
[ 20.924] (
) Option “config_info” “udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2/event1”
[ 20.924] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 7)
[ 20.924] () Option “xkb_rules” “evdev”
[ 20.924] (
[ 20.924] () Option “xkb_layout” “ca”
[ 20.924] (
[ 20.924] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event4)
[ 20.924] (II) No input driver specified, ignoring this device.
[ 20.924] (II) This device may have been added with another device file.
[ 20.924] (II) config/udev: Adding input device HDA Intel Line (/dev/input/event7)
[ 20.925] (II) config/udev: Adding input device HDA Intel Line Out (/dev/input/event8)
[ 20.925] (II) No input driver specified, ignoring this device.
[ 20.925] (II) This device may have been added with another device file.
[ 20.925] (II) config/udev: Adding input device HDA Intel Front Headphone (/dev/input/event9)
[ 20.925] (II) config/udev: Adding input device HDA Intel Rear Mic (/dev/input/event5)
[ 20.925] (II) config/udev: Adding input device HDA Intel Front Mic (/dev/input/event6)
[ 20.926] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[ 20.926] () AT Translated Set 2 keyboard: Applying InputClass “evdev keyboard catchall”
[ 20.926] (II) Using input driver ‘evdev’ for ‘AT Translated Set 2 keyboard’
[ 20.926] (
) AT Translated Set 2 keyboard: always reports core events
[ 20.926] () evdev: AT Translated Set 2 keyboard: Device: “/dev/input/event0”
[ 20.926] (–) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[ 20.926] (–) evdev: AT Translated Set 2 keyboard: Found keys
[ 20.926] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[ 20.926] (
) Option “config_info” “udev:/sys/devices/platform/i8042/serio0/input/input0/event0”
[ 20.926] (II) XINPUT: Adding extended input device “AT Translated Set 2 keyboard” (type: KEYBOARD, id 8)
[ 20.926] () Option “xkb_rules” “evdev”
[ 20.926] (
[ 20.926] () Option “xkb_layout” “ca”
[ 20.926] (
[ 20.926] (II) config/udev: Adding input device ImPS/2 Logitech Wheel Mouse (/dev/input/event11)
[ 20.926] () ImPS/2 Logitech Wheel Mouse: Applying InputClass “evdev pointer catchall”
[ 20.926] (II) Using input driver ‘evdev’ for ‘ImPS/2 Logitech Wheel Mouse’
[ 20.926] (
) ImPS/2 Logitech Wheel Mouse: always reports core events
[ 20.926] () evdev: ImPS/2 Logitech Wheel Mouse: Device: “/dev/input/event11”
[ 20.926] (–) evdev: ImPS/2 Logitech Wheel Mouse: Vendor 0x2 Product 0x5
[ 20.926] (–) evdev: ImPS/2 Logitech Wheel Mouse: Found 3 mouse buttons
[ 20.926] (–) evdev: ImPS/2 Logitech Wheel Mouse: Found scroll wheel(s)
[ 20.926] (–) evdev: ImPS/2 Logitech Wheel Mouse: Found relative axes
[ 20.926] (–) evdev: ImPS/2 Logitech Wheel Mouse: Found x and y relative axes
[ 20.926] (II) evdev: ImPS/2 Logitech Wheel Mouse: Configuring as mouse
[ 20.926] (II) evdev: ImPS/2 Logitech Wheel Mouse: Adding scrollwheel support
[ 20.926] (
) evdev: ImPS/2 Logitech Wheel Mouse: YAxisMapping: buttons 4 and 5
[ 20.926] () evdev: ImPS/2 Logitech Wheel Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 20.926] (
) Option “config_info” “udev:/sys/devices/platform/i8042/serio1/input/input4/event11”
[ 20.926] (II) XINPUT: Adding extended input device “ImPS/2 Logitech Wheel Mouse” (type: MOUSE, id 9)
[ 20.926] (II) evdev: ImPS/2 Logitech Wheel Mouse: initialized for relative axes.
[ 20.927] () ImPS/2 Logitech Wheel Mouse: (accel) keeping acceleration scheme 1
[ 20.927] (
) ImPS/2 Logitech Wheel Mouse: (accel) acceleration profile 0
[ 20.927] () ImPS/2 Logitech Wheel Mouse: (accel) acceleration factor: 2.000
[ 20.927] (
) ImPS/2 Logitech Wheel Mouse: (accel) acceleration threshold: 4
[ 20.927] (II) config/udev: Adding input device ImPS/2 Logitech Wheel Mouse (/dev/input/mouse0)
[ 20.927] (II) No input driver specified, ignoring this device.
[ 20.927] (II) This device may have been added with another device file.
[ 20.927] (II) config/udev: Adding input device PC Speaker (/dev/input/event3)
[ 20.927] (II) config/udev: Adding input device HP WMI hotkeys (/dev/input/event10)
[ 20.927] () HP WMI hotkeys: Applying InputClass “evdev keyboard catchall”
[ 20.927] (II) Using input driver ‘evdev’ for ‘HP WMI hotkeys’
[ 20.927] (
) HP WMI hotkeys: always reports core events
[ 20.927] () evdev: HP WMI hotkeys: Device: “/dev/input/event10”
[ 20.927] (–) evdev: HP WMI hotkeys: Vendor 0 Product 0
[ 20.927] (–) evdev: HP WMI hotkeys: Found keys
[ 20.927] (II) evdev: HP WMI hotkeys: Configuring as keyboard
[ 20.927] (
) Option “config_info” “udev:/sys/devices/virtual/input/input6/event10”
[ 20.927] (II) XINPUT: Adding extended input device “HP WMI hotkeys” (type: KEYBOARD, id 10)
[ 20.927] () Option “xkb_rules” “evdev”
[ 20.927] (
[ 20.928] () Option “xkb_layout” “ca”
[ 20.928] (
[ 29.792] (II) NOUVEAU(0): EDID vendor “LEN”, prod id 4434
[ 29.792] (II) NOUVEAU(0): Using EDID range info for horizontal sync
[ 29.792] (II) NOUVEAU(0): Using EDID range info for vertical refresh
[ 29.792] (II) NOUVEAU(0): Printing DDC gathered Modelines:
[ 29.792] (II) NOUVEAU(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz eP)
[ 29.792] (II) NOUVEAU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 29.792] (II) NOUVEAU(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 29.792] (II) NOUVEAU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 29.792] (II) NOUVEAU(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 29.792] (II) NOUVEAU(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 29.792] (II) NOUVEAU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 29.792] (II) NOUVEAU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 29.792] (II) NOUVEAU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 29.792] (II) NOUVEAU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 29.792] (II) NOUVEAU(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 29.792] (II) NOUVEAU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 29.792] (II) NOUVEAU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 29.792] (II) NOUVEAU(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 29.792] (II) NOUVEAU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 29.792] (II) NOUVEAU(0): Modeline "1280x1024"x70.0 128.94 1280 1368 1504 1728 1024 1025 1028 1066 -hsync +vsync (74.6 kHz e)
[ 29.792] (II) NOUVEAU(0): Modeline "1280x1024"x72.0 132.75 1280 1368 1504 1728 1024 1025 1028 1067 -hsync +vsync (76.8 kHz e)
[ 29.792] (II) NOUVEAU(0): Modeline "1440x900"x0.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 29.863] resize called 2880 900
[ 32.089] (II) NOUVEAU(0): EDID vendor “LEN”, prod id 4434
[ 32.089] (II) NOUVEAU(0): Using hsync ranges from config file
[ 32.089] (II) NOUVEAU(0): Using vrefresh ranges from config file
[ 32.089] (II) NOUVEAU(0): Printing DDC gathered Modelines:
[ 32.089] (II) NOUVEAU(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz eP)
[ 32.089] (II) NOUVEAU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 32.089] (II) NOUVEAU(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 32.089] (II) NOUVEAU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 32.089] (II) NOUVEAU(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 32.089] (II) NOUVEAU(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 32.089] (II) NOUVEAU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 32.089] (II) NOUVEAU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 32.089] (II) NOUVEAU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 32.089] (II) NOUVEAU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 32.089] (II) NOUVEAU(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 32.089] (II) NOUVEAU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 32.089] (II) NOUVEAU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 32.089] (II) NOUVEAU(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 32.089] (II) NOUVEAU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 32.089] (II) NOUVEAU(0): Modeline "1280x1024"x70.0 128.94 1280 1368 1504 1728 1024 1025 1028 1066 -hsync +vsync (74.6 kHz e)
[ 32.089] (II) NOUVEAU(0): Modeline "1280x1024"x72.0 132.75 1280 1368 1504 1728 1024 1025 1028 1067 -hsync +vsync (76.8 kHz e)
[ 32.089] (II) NOUVEAU(0): Modeline "1440x900"x0.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 32.145] (II) NOUVEAU(0): EDID vendor “LEN”, prod id 4434
[ 32.145] (II) NOUVEAU(0): Using hsync ranges from config file
[ 32.145] (II) NOUVEAU(0): Using vrefresh ranges from config file
[ 32.145] (II) NOUVEAU(0): Printing DDC gathered Modelines:
[ 32.145] (II) NOUVEAU(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz eP)
[ 32.145] (II) NOUVEAU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 32.145] (II) NOUVEAU(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 32.145] (II) NOUVEAU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 32.145] (II) NOUVEAU(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 32.145] (II) NOUVEAU(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 32.145] (II) NOUVEAU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 32.145] (II) NOUVEAU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 32.145] (II) NOUVEAU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 32.145] (II) NOUVEAU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 32.145] (II) NOUVEAU(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 32.145] (II) NOUVEAU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 32.145] (II) NOUVEAU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 32.145] (II) NOUVEAU(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 32.145] (II) NOUVEAU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 32.145] (II) NOUVEAU(0): Modeline "1280x1024"x70.0 128.94 1280 1368 1504 1728 1024 1025 1028 1066 -hsync +vsync (74.6 kHz e)
[ 32.145] (II) NOUVEAU(0): Modeline "1280x1024"x72.0 132.75 1280 1368 1504 1728 1024 1025 1028 1067 -hsync +vsync (76.8 kHz e)
[ 32.145] (II) NOUVEAU(0): Modeline "1440x900"x0.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
