Bonsoir,
Je suis embêté car j’aimerais brancher mon ordinateur portable à mon écran fixe en HDMI mais cela ne fonctionne pas. Pour commencer cela fonctionne avec Windows, donc le matériel est bon a priori. Ensuite voilà ce que renvoie xrandr
$ xrandr
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
1920x1080 60.06*+ 60.01 59.97 59.96 59.93 48.04
1680x1050 59.95 59.88
1600x1024 60.17
1400x1050 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 60.02
1440x900 59.89
1400x900 59.96 59.88
1280x960 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1360x768 59.80 59.96
1280x800 59.99 59.97 59.81 59.91
1152x864 60.00
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
800x512 60.17
700x525 59.98
800x450 59.95 59.82
640x512 60.02
720x450 59.89
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
680x384 59.80 59.96
640x400 59.88 59.98
576x432 60.06
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
HDMI-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
SI je comprends bien, l’écran du PC portable est connecté et pas les autres. Ensuite, j’ai des choses bizarres quand je demande des informations à lshw :
# lshw -C display
*-display NON-RÉCLAMÉ
description: VGA compatible controller
produit: NVIDIA Corporation
fabriquant: NVIDIA Corporation
identifiant matériel: 0
information bus: pci@0000:01:00.0
version: a1
bits: 64 bits
horloge: 33MHz
fonctionnalités: pm msi pciexpress vga_controller cap_list
configuration: latency=0
ressources: mémoire:b4000000-b4ffffff mémoire:70000000-7fffffff mémoire:80000000-81ffffff portE/S:3000(taille=128) mémoire:b5000000-b507ffff
*-display
produit: Intel Corporation
fabriquant: Intel Corporation
identifiant matériel: 2
information bus: pci@0000:00:02.0
version: 02
bits: 64 bits
horloge: 33MHz
fonctionnalités: pciexpress msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
ressources: irq:165 mémoire:b3000000-b3ffffff mémoire:60000000-6fffffff portE/S:4000(taille=64) mémoire:c0000-dffff
Pas de pilote, et « NON-RÉCLAMÉ » que je ne comprends pas. J’ai essayé d’installer le paquet nvidia-driver en version 411 ainsi que 450 en redémarrant à chaque fois. La première fois il m’a dit qu’il y avait in conflit avec le driver « nouveau » puis il ne me l’a plus dit par la suite malgré les réinstallations.
Donc moralement il me semble que ma carte graphique fonctionne mal et que c’est plutôt la carte intel qui fait tout, sauf que la carte intel n’est pas reliée à la sortie HDMI. Est-ce quelqu’un a une idée pour faire fonctionner ma sortie HDMI s’il vous plait ? Je vous remercie d’avance et vous souhaite une bonne soirée.
