Sortie TV avec câble SVIDEO et driver proprieo nvidia
J’ai installé les pilotes propriétaires nvidia sans trop de problèmes, j’ai la 3d, UT2004, compiz et compagnie ça marche d’enfer. J’ai installé nvidia-settings puis avec lui j’ai réglé la sortie TV en tinview clone, j’ai sauvegardé dans xorg.conf, j’ai relancé X mais je me retrouve avec le clone sur la télé en noir et blanc, pourquoi ? ? ?
voici mon xorg.conf
[code]# nvidia-settings: X configuration file generated by nvidia-settings
nvidia-settings: version 1.0 (buildmeister@builder3) Wed Jun 13 18:40:26 PDT 2007
nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 1.0 (buildmeister@builder3) Wed Jun 13 18:39:30 PDT 2007
xorg.conf (xorg X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the xorg.conf manual page.
(Type “man xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "ServerLayout"
Identifier "Default Layout"
Screen 0 “Screen0” 0 0
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
InputDevice "Synaptics Touchpad"
EndSection
Section "Files"
EndSection
Section "Module"
Load "glx"
Load "nvidia"
EndSection
Section "ServerFlags"
Option “Xinerama” "0"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
EndSection
Identifier "Synaptics Touchpad"
Driver "synaptics"
Option “SendCoreEvents” "true"
Option “Device” "/dev/psaux"
Option “Protocol” "auto-dev"
Option “HorizScrollDelta” "0"
EndSection
Section "Monitor"
Identifier "Écran generique"
HorizSync 30.0 - 65.0
VertRefresh 50.0 - 75.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "TV-0"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
EndSection
Section "Monitor"
Identifier "Monitor1"
ModelName "AUO"
HorizSync 30.0 - 75.0
VertRefresh 60.0
EndSection
Section "Device"
Identifier "nVidia Corporation GeForce 8400M GS"
Driver "nvidia"
Option “TVstandard” "PAL-N"
Option “TVOutFormat” “SVIDEO”
EndSection
Section "Device"
Identifier "Videocard0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce 8400M GS"
EndSection
Section "Device"
Identifier "Videocard1"
Driver "nvidia"
BusID "PCI:1:0:0"
Screen 1
EndSection
Section "Screen"
Identifier "Default Screen"
Device "nVidia Corporation GeForce 8400M GS"
Monitor "Écran generique"
DefaultDepth 24
SubSection "Display"
Depth 24
Modes "1280x1024"
EndSubSection
EndSection
Section “Screen”
Removed Option “TwinView” “1”
Removed Option “metamodes” “TV: nvidia-auto-select +0+0, DFP: nvidia-auto-select +0+0”
Removed Option “TwinView” “0”
Removed Option “metamodes” “TV: nvidia-auto-select +0+0”
Removed Option “metamodes” “DFP: nvidia-auto-select +0+0”
Removed Option “metamodes” “nvidia-auto-select +0+0”
Removed Option “metamodes” “TV: nvidia-auto-select +1280+0, DFP: nvidia-auto-select +0+0”
Identifier     "Screen0"
Device         "Videocard0"
Monitor        "Monitor0"
DefaultDepth    24
Option         "TwinView" "1"
Option         "metamodes" "TV: nvidia-auto-select +0+0, DFP: nvidia-auto-select +0+0"
EndSection
Section "Screen"
Identifier "Screen1"
Device "Videocard0"
Monitor "Monitor1"
DefaultDepth 24
Option “TwinView” "0"
Option “metamodes” "DFP: nvidia-auto-select +0+0"
EndSection
Section "Extensions"
Option “Composite” "enable"
EndSection
Vieille TV uniquement SECAM ?
La télé n’est pas toute jeune, mais en mettant SECAM à la place de pal ça n’avait rien changé
