Bonjour, sur mon serveur je tente d’installer Magento et en effectuant un check post install j’ai ce message d’erreur :
[quote]Warning: shell_exec() has been disabled for security reasons in /home/lolsdxco/domains/lolsdx.com/public_html/magento-check.php on line 28
Your server does not meet the following requirements in order to install Magento.
The following requirements failed, please contact your hosting provider in order to receive assistance with meeting the system requirements for Magento:
* You need MySQL 4.1.20 (or greater)
The following requirements were successfully met:
* You have PHP 5.2.0 (or greater)
* Safe Mode is off
* You have the curl extension
* You have the dom extension
* You have the gd extension
* You have the hash extension
* You have the iconv extension
* You have the mcrypt extension
* You have the pcre extension
* You have the pdo extension
* You have the pdo_mysql extension
* You have the simplexml extension[/quote]
Je ne comprends pas car ma version actuelle de MySql est MySQL 5.0.88
En parlant de ça au passage, des versions sortent que ce soit pour phpmyadmin, mysql ou apache. En faisant un apt-get update et upgrade les version ne sont pas mises à jour comme indéqués sur les sites respectifs concernés.
Faut il que j’ajoute des sources ?
Merci pour tout
