J’ai voulu alleger un peu la charge de mon serveur et j’ai dons suivi ce tuto à la lettre: technique.arscenic.org/monitorin … s-de-munin
Et bien sur, me voila dans la mouise puisque je n’ai plus de graphs sur mon munin
Pouvez vous m’aider svp??
Voici les infos qui pourront peut etre vous servir:
/etc/munin/munin.conf
# Example configuration file for Munin, generated by 'make build'
# The next three variables specifies where the location of the RRD
# databases, the HTML output, logs and the lock/pid files. They all
# must be writable by the user running munin-cron. They are all
# defaulted to the values you see here.
dbdir /var/lib/munin
htmldir /home/www/munin
logdir /var/log/munin
rundir /var/run/munin
# Where to look for the HTML templates
tmpldir /etc/munin/templates
# (Exactly one) directory to include all files from.
includedir /etc/munin/munin-conf.d
# Make graphs show values per minute instead of per second
graph_period minute
# Graphics files are normaly generated by munin-graph, no matter if
# the graphs are used or not. You can change this to
# on-demand-graphing by following the instructions in
# http://munin.projects.linpro.no/wiki/CgiHowto
graph_strategy cgi
# munin-cgi-graph is invoked by the web server up to very many times at the
# same time. This is not optimal since it results in high CPU and memory
# consumption to the degree that the system can thrash. Again the default is
# 6. Most likely the optimal number for max_cgi_graph_jobs is the same as
# max_graph_jobs.
munin_cgi_graph_jobs 6
# If the automatic CGI url is wrong for your system override it here:
cgiurl_graph /cgi-bin/munin-cgi-graph
# munin-graph runs in parallel, the number of concurrent processes is
# 6. If you want munin-graph to not be parallel set to 0. If set too
# high it will slow down munin-graph. Some experiments are needed to
# determine how many are optimal on your system. On a multi-core
# system with good SCSI disks the number can probably be quite high.
#max_graph_jobs 6
# Drop somejuser@fnord.comm and anotheruser@blibb.comm an email everytime
# something changes (OK -> WARNING, CRITICAL -> OK, etc)
#contact.someuser.command mail -s "Munin notification" somejuser@fnord.comm
#contact.anotheruser.command mail -s "Munin notification" anotheruser@blibb.comm
# For those with Nagios, the following might come in handy. In addition,
# the services must be defined in the Nagios server as well.
#contact.nagios.command /usr/bin/send_nsca nagios.host.comm -c /etc/nsca.conf
# a simple host tree
[minusserveur.minus.local]
address 127.0.0.1
use_node_name yes
#[minus-pc.minus.local]
# address 192.168.1.2
# use_node_name no
# A more complex example of a host tree
## First our "normal" host.
# [fii.foo.com]
# address foo
## Then our other host...
# [fay.foo.com]
# address fay
## Then we want totals...
# [foo.com;Totals] #Force it into the "foo.com"-domain...
# update no # Turn off data-fetching for this "host".
# # The graph "load1". We want to see the loads of both machines...
# # "fii=fii.foo.com:load.load" means "label=machine:graph.field"
# load1.graph_title Loads side by side
# load1.graph_order fii=fii.foo.com:load.load fay=fay.foo.com:load.load
# # The graph "load2". Now we want them stacked on top of each other.
# load2.graph_title Loads on top of each other
# load2.dummy_field.stack fii=fii.foo.com:load.load fay=fay.foo.com:load.load
# load2.dummy_field.draw AREA # We want area instead the default LINE2.
# load2.dummy_field.label dummy # This is needed. Silly, really.
# # The graph "load3". Now we want them summarised into one field
# load3.graph_title Loads summarised
# load3.combined_loads.sum fii.foo.com:load.load fay.foo.com:load.load
# load3.combined_loads.label Combined loads # Must be set, as this is
# # not a dummy field!
## ...and on a side note, I want them listen in another order (default is
## alphabetically)
# # Since [foo.com] would be interpreted as a host in the domain "com", we
# # specify that this is a domain by adding a semicolon.
# [foo.com;]
# node_order Totals fii.foo.com fay.foo.com
/etc/apache2/sites-available# vi default
<VirtualHost *:80>
ServerAdmin webmaster@localhost
DocumentRoot /home/www
<Directory />
Options FollowSymLinks
AllowOverride None
</Directory>
<Directory /home/www/>
Options Indexes FollowSymLinks MultiViews
AllowOverride None
Order allow,deny
allow from None
</Directory>
<Directory /home/www/gallery>
AllowOverride All
Order allow,deny
allow from all
</Directory>
<Directory /home/www/munin>
AllowOverride All
Order allow,deny
allow from all
</Directory>
<Directory /home/www/webmail>
AllowOverride All
Order allow,deny
allow from all
</Directory>
# <Directory /home/www/spark/>
# Options Indexes FollowSymLinks MultiViews
# AllowOverride All
# Order allow,deny
# allow from all
# DirectoryIndex index.html
# </Directory>
<Directory /home/www/jappix/>
AllowOverride All
Order allow,deny
allow from all
DirectoryIndex index.php
</Directory>
<Directory /home/www/Joomla/>
AllowOverride All
Order allow,deny
allow from all
# DirectoryIndex index.php
</Directory>
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "/usr/lib/cgi-bin">
AllowOverride None
Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
Order allow,deny
Allow from all
</Directory>
ErrorLog ${APACHE_LOG_DIR}/error.log
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
CustomLog ${APACHE_LOG_DIR}/access.log combined
Alias /doc/ "/usr/share/doc/"
<Directory "/usr/share/doc/">
Options Indexes MultiViews FollowSymLinks
AllowOverride None
Order deny,allow
Deny from all
Allow from 127.0.0.0/255.0.0.0 ::1/128
</Directory>
</VirtualHost>
/etc/logrotate.d/munin
/var/log/munin/munin-update.log {
daily
missingok
rotate 7
compress
notifempty
create 640 munin adm
/var/log/munin/munin-graph.log {
daily
missingok
rotate 7
compress
notifempty
create 660 munin www-data
/var/log/munin/munin-html.log {
daily
missingok
rotate 7
compress
notifempty
/var/log/munin/munin-limits.log {
daily
missingok
rotate 7
compress
notifempty
Je pense à un soucis de droit, mais j’ai vérifié un par un ceux modifié dans le tuto et ils me semblent tous ok
Un peu d’aide n’est pas de refus
Merci par avance
