SPE Exception exceptions.TypeError: "'NoneType'
Je débute en programmation sous python.
J’utilise actuellement drpython mais je préfère SPE.
Le problème c’est qu’avec SPE mes programmes ne ce lance pas.
Quand je le lance SPE dans un terminal il me dit
[code]damien@damien:~$ spe
SPE v0.8.4.h ©2003-2008 www.stani.be
If spe fails to start:
  • type “python SPE.py --debug > debug.txt 2>&1” at the command prompt
    (or if you use tcsh: “python SPE.py --debug >& debug.txt”)
  • send debug.txt with some info to spe.stani.be[at]gmail.com
Blender support disabled (run SPE inside Blender to enable).
Encrypted debugging enabled.
Launching single instance application (with xml-rpc server) …
18:58:12: Deleted stale lock file ‘/home/damien/SPE 0.8.4.hdamien’.
(python:4181): Gdk-CRITICAL **: gdk_draw_drawable: assertion `src != NULL’ failed
Thank you for using SPE, please donate to support further development.
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xb1633ec> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xb16362c> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xb163f2c> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xa49266c> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xa47f6cc> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xb163cec> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xb16374c> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xb163aac> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xa47f22c> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xa47ff2c> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xa47846c> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xa47fdec> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xa485dcc> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xa47fb2c> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xa4928ac> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xa47f52c> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xa4899ac> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xa49278c> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xa47f82c> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xb163e0c> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xb16398c> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xb163bcc> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xb16386c> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xb16350c> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xa47f3ac> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xa47fc6c> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xa49254c> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xa47f98c> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xa478c4c> ignored
Exception exceptions.TypeError: “‘NoneType’ object is not callable” in <wx.lib.pubsub._NodeCallback instance at 0xa47f10c> ignored
J’ai cherché longtemps une solution mais sans résultat.
personne??
Bon
A force de chercher et de rechercher j’ai fini par trouver une solution.
Dans le fichier /usr/share/spe/_spe/SPE.py
il faut remplacer la ligne la “MIN_WX_VERSION = ‘2.5.4.1’” par “MIN_WX_VERSION = ‘2.8’”
Et voila le tour est joué
