Je suis sur squeeze et je n’arrive pas exécuter le php. Le navigateur me propose de télécharger le fichier php.
dmon@racoon:~$ dpkg -l | grep apache
ii  apache2                              2.2.16-3                             Apache HTTP Server metapackage
ii  apache2-mpm-prefork                  2.2.16-3                             Apache HTTP Server - traditional non-threaded model
ii  apache2-utils                        2.2.16-3                             utility programs for webservers
ii  apache2.2-bin                        2.2.16-3                             Apache HTTP Server common binary files
ii  apache2.2-common                     2.2.16-3                             Apache HTTP Server common files
ii  libapache2-mod-php5                  5.3.2-2                              server-side, HTML-embedded scripting language (Apache 2 module)
ii  libbatik-java                        1.7-6                                xml.apache.org SVG Library
octave@doctave:~$ dpkg -l | grep php
ii  gphpedit                             0.9.97+20100226-1                    development environment for PHP/HTML/CSS
ii  php-benchmark                        1.2.7-5                              Framework to benchmark PHP scripts or function calls
ii  php-pear                             5.3.2-2                              PEAR - PHP Extension and Application Repository
ii  php5                                 5.3.2-2                              server-side, HTML-embedded scripting language (metapackage)
ii  php5-cli                             5.3.2-2                              command-line interpreter for the php5 scripting language
ii  php5-common                          5.3.2-2                              Common files for packages built from the php5 source
ii  php5-gd                              5.3.2-2                              GD module for php5
ii  php5-suhosin                         0.9.32.1-1                           advanced protection module for php5
ii  phpsysinfo                           3.0~rc6-1.1                          PHP based host information
ii  phpunit                              3.4.14-1                             Unit testing suite for PHP5
dmon@racoon:~$ ls /etc/apache2/mods-enabled/
alias.conf       authz_default.load    autoindex.conf  cgi.load      dir.load   negotiation.conf  reqtimeout.conf  status.conf
alias.load       authz_groupfile.load  autoindex.load  deflate.conf  env.load   negotiation.load  reqtimeout.load  status.load
auth_basic.load  authz_host.load       cgid.conf       deflate.load  mime.conf  php5.conf         setenvif.conf    userdir.conf
authn_file.load  authz_user.load       cgid.load       dir.conf      mime.load  php5.load         setenvif.load    userdir.load
dmon@racoon:~$
Je demande ma langue au chat.
Miaou, miaou.
